[GRASS-SVN] r43647 - grass-addons/gui/wxpython/wx.path
    svn_grass at osgeo.org
    Thu Sep 23 07:05:45 EDT 2010
Author: rashadkm
Date: 2010-09-23 11:05:45 +0000 (Thu, 23 Sep 2010)
New Revision: 43647
   grass-addons/gui/wxpython/wx.path/wx.path.py
fixed for grass6.4.0RC6 and grass6.5 (need some cleanup)
Modified: grass-addons/gui/wxpython/wx.path/wx.path.py
--- grass-addons/gui/wxpython/wx.path/wx.path.py	2010-09-23 10:09:03 UTC (rev 43646)
+++ grass-addons/gui/wxpython/wx.path/wx.path.py	2010-09-23 11:05:45 UTC (rev 43647)
@@ -24,6 +24,7 @@
 import math
 import tempfile
 import copy
+import time
 gbase = os.getenv("GISBASE")
 pypath = os.path.join(gbase,'etc','wxpython','gui_modules')
@@ -57,7 +58,16 @@
 from preferences import globalSettings as UserSettings
 from icon  import Icons
 from mapdisp import Command
-from mapdisp import BufferedWindow
+grassversion = os.getenv("GRASS_VERSION")
+if grassversion.rfind("6.4") != 0:
+    from mapdisp_window import BufferedWindow
+    from mapdisp_window import MapWindow as MapWindow
+else:
+    from mapdisp import BufferedWindow
+    from mapdisp import MapWindow as MapWindow
 from mapdisp import MapFrame
 from debug import Debug
 import images
@@ -79,6 +89,7 @@
                  Map=None, auimgr=None):
+        self._layerManager = gismgr
         self.Map        = Map
         self.gismanager = gismgr    # GIS Manager object
         self.Map        = Map       # instance of render.Map
@@ -135,67 +146,106 @@
         self.statusbar = self.CreateStatusBar(number=4, style=0)
         self.statusbar.SetStatusWidths([-5, -2, -1, -1])
-        self.toggleStatus = wx.Choice(self.statusbar, wx.ID_ANY,
-                                      choices = globalvar.MAP_DISPLAY_STATUSBAR_MODE)
-        self.toggleStatus.SetSelection(UserSettings.Get(group='display', key='statusbarMode', subkey='selection'))
-        self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.toggleStatus)
+        self.statusbarWin = dict()
+        self.statusbarWin['toggle'] = wx.Choice(self.statusbar, wx.ID_ANY,
+                                                choices = globalvar.MAP_DISPLAY_STATUSBAR_MODE)
+        self.statusbarWin['toggle'].SetSelection(UserSettings.Get(group='display',
+        key='statusbarMode',
+        subkey='selection'))
+        self.statusbar.Bind(wx.EVT_CHOICE, self.OnToggleStatus, self.statusbarWin['toggle'])
         # auto-rendering checkbox
-        self.autoRender = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
-                                      label=_("Render"))
-        self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleRender, self.autoRender)
-        self.autoRender.SetValue(UserSettings.Get(group='display', key='autoRendering', subkey='enabled'))
-        self.autoRender.SetToolTip(wx.ToolTip (_("Enable/disable auto-rendering")))
+        self.statusbarWin['render'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                                  label=_("Render"))
+        self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleRender, self.statusbarWin['render'])
+        self.statusbarWin['render'].SetValue(UserSettings.Get(group='display',
+                                                              key='autoRendering',
+                                                              subkey='enabled'))
+        self.statusbarWin['render'].SetToolTip(wx.ToolTip (_("Enable/disable auto-rendering")))
         # show region
-        self.showRegion = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
-                                      label=_("Show computational extent"))
-        self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleShowRegion, self.showRegion)
+        self.statusbarWin['region'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                                  label=_("Show computational extent"))
+        self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleShowRegion, self.statusbarWin['region'])
-        self.showRegion.SetValue(False)
-        self.showRegion.Hide()
-        self.showRegion.SetToolTip(wx.ToolTip (_("Show/hide computational "
-                                                 "region extent (set with g.region). "
-                                                 "Display region drawn as a blue box inside the "
-                                                 "computational region, "
-                                                 "computational region inside a display region "
-                                                 "as a red box).")))
+        self.statusbarWin['region'].SetValue(False)
+        self.statusbarWin['region'].Hide()
+        self.statusbarWin['region'].SetToolTip(wx.ToolTip (_("Show/hide computational "
+                                                             "region extent (set with g.region). "
+                                                             "Display region drawn as a blue box inside the "
+                                                             "computational region, "
+                                                             "computational region inside a display region "
+                                                             "as a red box).")))
         # set resolution
-        self.compResolution = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
-                                         label=_("Constrain display resolution to computational settings"))
-        self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleResolution, self.compResolution)
-        self.compResolution.SetValue(UserSettings.Get(group='display', key='compResolution', subkey='enabled'))
-        self.compResolution.Hide()
-        self.compResolution.SetToolTip(wx.ToolTip (_("Constrain display resolution "
-                                                     "to computational region settings. "
-                                                     "Default value for new map displays can "
-                                                     "be set up in 'User GUI settings' dialog.")))
+        self.statusbarWin['resolution'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                                      label=_("Constrain display resolution to computational settings"))
+        self.statusbar.Bind(wx.EVT_CHECKBOX, self.OnToggleResolution, self.statusbarWin['resolution'])
+        self.statusbarWin['resolution'].SetValue(UserSettings.Get(group='display', key='compResolution', subkey='enabled'))
+        self.statusbarWin['resolution'].Hide()
+        self.statusbarWin['resolution'].SetToolTip(wx.ToolTip (_("Constrain display resolution "
+        "to computational region settings. "
+        "Default value for new map displays can "
+        "be set up in 'User GUI settings' dialog.")))
         # map scale
-        self.mapScale = wx.TextCtrl(parent=self.statusbar, id=wx.ID_ANY,
-                                    value="", style=wx.TE_PROCESS_ENTER,
-                                    size=(150, -1))
-        self.mapScale.Hide()
-        self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnChangeMapScale, self.mapScale)
+        self.statusbarWin['mapscale'] = wx.ComboBox(parent = self.statusbar, id = wx.ID_ANY,
+                                                    style = wx.TE_PROCESS_ENTER,
+                                                    size=(150, -1))
+        self.statusbarWin['mapscale'].SetItems(['1:1000',
+                                                '1:5000',
+                                                '1:10000',
+                                                '1:25000',
+                                                '1:50000',
+                                                '1:100000',
+                                                '1:1000000'])
+        self.statusbarWin['mapscale'].Hide()
+        self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnChangeMapScale, self.statusbarWin['mapscale'])
+        self.statusbar.Bind(wx.EVT_COMBOBOX, self.OnChangeMapScale, self.statusbarWin['mapscale'])
+        # go to
+        self.statusbarWin['goto'] = wx.TextCtrl(parent=self.statusbar, id=wx.ID_ANY,
+                                                value="", style=wx.TE_PROCESS_ENTER,
+                                                size=(300, -1))
+        self.statusbarWin['goto'].Hide()
+#        self.statusbar.Bind(wx.EVT_TEXT_ENTER, self.OnGoTo, self.statusbarWin['goto'])
+        # projection
+        self.statusbarWin['projection'] = wx.CheckBox(parent=self.statusbar, id=wx.ID_ANY,
+                                                      label=_("Use defined projection"))
+        self.statusbarWin['projection'].SetValue(False)
+        size = self.statusbarWin['projection'].GetSize()
+        self.statusbarWin['projection'].SetMinSize((size[0] + 150, size[1]))
+        self.statusbarWin['projection'].SetToolTip(wx.ToolTip (_("Reproject coordinates displayed "
+        "in the statusbar. Projection can be "
+        "defined in GUI preferences dialog "
+        "(tab 'Display')")))
+        self.statusbarWin['projection'].Hide()
         # mask
-        self.maskInfo = wx.StaticText(parent = self.statusbar, id = wx.ID_ANY,
+        self.statusbarWin['mask'] = wx.StaticText(parent = self.statusbar, id = wx.ID_ANY,
                                                   label = '')
-        self.maskInfo.SetForegroundColour(wx.Colour(255, 0, 0))
+        self.statusbarWin['mask'].SetForegroundColour(wx.Colour(255, 0, 0))
         # on-render gauge
-        self.onRenderGauge = wx.Gauge(parent=self.statusbar, id=wx.ID_ANY,
+        self.statusbarWin['progress'] = wx.Gauge(parent=self.statusbar, id=wx.ID_ANY,
                                       range=0, style=wx.GA_HORIZONTAL)
-        self.onRenderGauge.Hide()
+        self.statusbarWin['progress'].Hide()
         self.StatusbarReposition() # reposition statusbar
         # Init map display (buffered DC & set default cursor)
-        self.MapWindow2D = BufferedWindow(self, id=wx.ID_ANY,
-                                          Map=self.Map, tree=self.tree, gismgr=self.gismanager)
+        self.MapWindow2D = BufferedWindow2(self, id=wx.ID_ANY,
+                                          Map=self.Map, tree=self.tree, lmgr=self.gismanager)
         # default is 2D display mode
         self.MapWindow = self.MapWindow2D
-        self.MapWindow.Bind(wx.EVT_MOTION, self.OnMotion)
+        if grassversion.rfind("6.4") != 0:
+            self.Bind(wx.EVT_MOTION,       self.MapWindow.OnMotion)
+       # else:
+#            self.Bind(wx.EVT_MOTION,       self.MapWindow.OnMotion2)
+       # self.MapWindow.Bind(wx.EVT_MOTION, self.MapWindow.OnMotion)
         self.MapWindow.SetCursor(self.cursors["default"])
         # used by Nviz (3D display mode)
         self.MapWindow3D = None
@@ -205,14 +255,16 @@
         # initialize region values
-        self.__InitDisplay()
+        self.width, self.height = self.GetClientSize()
+        self.Map.ChangeMapSize(self.GetClientSize())
+        self.Map.region = self.Map.GetRegion()
         # Bind various events
         #self.Bind(wx.EVT_ACTIVATE, self.OnFocus)
         self.Bind(wx.EVT_CLOSE,    self.OnCloseWindow)
-        self.Bind(render.EVT_UPDATE_PRGBAR, self.OnUpdateProgress)
+       # self.Bind(render.EVT_UPDATE_PRGBAR, self.OnUpdateProgress)
         # Update fancy gui style
@@ -274,10 +326,47 @@
 	self.coords = []
 	self.points = []
+    def OnMotion2(self, event):
+        Mouse moved
+        Track mouse motion and update status bar
+        # update statusbar if required
+        if self.toggleStatus.GetSelection() == 0: # Coordinates
+            e, n = self.MapWindow.Pixel2Cell(event.GetPositionTuple())
+            if self.toolbars['vdigit'] and \
+                    self.toolbars['vdigit'].GetAction() == 'addLine' and \
+                    self.toolbars['vdigit'].GetAction('type') in ('line', 'boundary') and \
+                    len(self.MapWindow.polycoords) > 0:
+                # for linear feature show segment and total length
+                distance_seg = self.MapWindow.Distance(self.MapWindow.polycoords[-1],
+                                                       (e, n), screen=False)[0]
+                distance_tot = distance_seg
+                for idx in range(1, len(self.MapWindow.polycoords)):
+                    distance_tot += self.MapWindow.Distance(self.MapWindow.polycoords[idx-1],
+                                                            self.MapWindow.polycoords[idx],
+                                                            screen=False )[0]
+                self.statusbar.SetStatusText("%.2f, %.2f (seg: %.2f; tot: %.2f)" % \
+                                                 (e, n, distance_seg, distance_tot), 0)
+            else:
+                if self.Map.projinfo['proj'] == 'll':
+                    self.statusbar.SetStatusText("%s" % utils.Deg2DMS(e, n), 0)
+                else:
+                    self.statusbar.SetStatusText("%.2f, %.2f" % (e, n), 0)
+            event.Skip()
+    def StatusbarReposition(self):
+        """Reposition checkbox in statusbar"""
+        # reposition checkbox
+        widgets = 0
+    def StatusbarUpdate(self):
+        """Update statusbar content"""
+        widgets = 0
     def OnButtonDClick(self,event):
         try:
@@ -302,7 +391,7 @@
 	    command=["v.net.path", 'input=roads', 'output=path','file=tmp','--overwrite']
-    	    gcmd.CommandThread(command,stout=None,stderr=None).run()
+    	    gcmd.CommandThread(command,stdout=None,stderr=None).run()
             self.mapname = 'path@'+ grass.gisenv()['MAPSET']
@@ -315,34 +404,442 @@
-    def __InitDisplay(self):
+class BufferedWindow2(BufferedWindow):
+    """!A Buffered window class.
+    When the drawing needs to change, you app needs to call the
+    UpdateMap() method. Since the drawing is stored in a bitmap, you
+    can also save the drawing to file by calling the
+    SaveToFile(self,file_name,file_type) method.
+    def __init__(self, parent, id = wx.ID_ANY,
+                 Map = None, tree = None, lmgr = None,
+                 style = wx.NO_FULL_REPAINT_ON_RESIZE, **kwargs):
+        MapWindow.__init__(self, parent, id, Map, tree, lmgr, **kwargs)
+        wx.Window.__init__(self, parent, id, style = style, **kwargs)
+        # flags
+        self.resize = False # indicates whether or not a resize event has taken place
+        self.dragimg = None # initialize variable for map panning
+        self.tree = tree
+        self.Map = Map
+        # variables for drawing on DC
+        self.pen = None      # pen for drawing zoom boxes, etc.
+        self.polypen = None  # pen for drawing polylines (measurements, profiles, etc)
+        # List of wx.Point tuples defining a polyline (geographical coordinates)
+        self.polycoords = []
+        # ID of rubber band line
+        self.lineid = None
+        # ID of poly line resulting from cumulative rubber band lines (e.g. measurement)
+        self.plineid = None
+        # event bindings
+        self.Bind(wx.EVT_PAINT,        self.OnPaint)
+        self.Bind(wx.EVT_SIZE,         self.OnSize)
+        self.Bind(wx.EVT_IDLE,         self.OnIdle)
+        ### self.Bind(wx.EVT_MOTION,       self.MouseActions)
+        self.Bind(wx.EVT_MOUSE_EVENTS, self.MouseActions)
+            self.Bind(wx.EVT_MOTION,       self.OnMotion)
+        #else:
+            #self.Bind(wx.EVT_MOTION,       self.MapWindow.OnMotion2)
+        self.processMouse = True
+        # render output objects
+        self.mapfile = None   # image file to be rendered
+        self.img     = None   # wx.Image object (self.mapfile)
+        # used in digitization tool (do not redraw vector map)
+        self.imgVectorMap = None
+        # decoration overlays
+        self.overlays = {}
+        # images and their PseudoDC ID's for painting and dragging
+        self.imagedict = {}
+        self.select = {}      # selecting/unselecting decorations for dragging
+        self.textdict = {}    # text, font, and color indexed by id
+        self.currtxtid = None # PseudoDC id for currently selected text
+        # zoom objects
+        self.zoomhistory  = [] # list of past zoom extents
+        self.currzoom     = 0 # current set of extents in zoom history being used
+        self.zoomtype     = 1   # 1 zoom in, 0 no zoom, -1 zoom out
+        self.hitradius    = 10 # distance for selecting map decorations
+        self.dialogOffset = 5 # offset for dialog (e.g. DisplayAttributesDialog)
+        # OnSize called to make sure the buffer is initialized.
+        # This might result in OnSize getting called twice on some
+        # platforms at initialization, but little harm done.
+        ### self.OnSize(None)
+            self.DefinePseudoDC()
+        else:
+            self.pdc = wx.PseudoDC()
+            # used for digitization tool
+            self.pdcVector = None
+            # decorations (region box, etc.)
+            self.pdcDec = wx.PseudoDC()
+            # pseudoDC for temporal objects (select box, measurement tool, etc.)
+            self.pdcTmp = wx.PseudoDC()
+        # redraw all pdc's, pdcTmp layer is redrawn always (speed issue)
+        self.redrawAll = True
+        # will store an off screen empty bitmap for saving to file
+        self._buffer = ''
+        self.Bind(wx.EVT_ERASE_BACKGROUND, lambda x:None)
+#        self.Bind(wx.EVT_KEY_DOWN , Bufferedwindow.OnKeyDown)
+        # vars for handling mouse clicks
+        self.dragid   = -1
+        self.lastpos  = (0, 0)
+    def OnPaint(self, event):
+        Draw PseudoDC's to buffered paint DC
+        self.pdc for background and decorations
+        self.pdcVector for vector map which is edited
+        self.pdcTmp for temporaly drawn objects (self.polycoords)
+        If self.redrawAll is False on self.pdcTmp content is re-drawn
-        Initialize map display, set dimensions and map region
+        Debug.msg(4, "BufferedWindow.OnPaint(): redrawAll=%s" % self.redrawAll)
+        dc = wx.BufferedPaintDC(self, self.buffer)
+        ### dc.SetBackground(wx.Brush("White"))
+        dc.Clear()
+        # use PrepareDC to set position correctly
+        self.PrepareDC(dc)
+        # create a clipping rect from our position and size
+        # and update region
+        rgn = self.GetUpdateRegion().GetBox()
+        dc.SetClippingRect(rgn)
+        switchDraw = False
+        if self.redrawAll is None:
+            switchDraw = True
+        if self.redrawAll: # redraw pdc and pdcVector
+            # draw to the dc using the calculated clipping rect
+            self.pdc.DrawToDCClipped(dc, rgn)
+            # draw vector map layer
+            if self.pdcVector:
+                # decorate with GDDC (transparency)
+                try:
+                    gcdc = wx.GCDC(dc)
+                    self.pdcVector.DrawToDCClipped(gcdc, rgn)
+                except NotImplementedError, e:
+                    print >> sys.stderr, e
+                    self.pdcVector.DrawToDCClipped(dc, rgn)
+            self.bufferLast = None
+        else: # do not redraw pdc and pdcVector
+            if self.bufferLast is None:
+                # draw to the dc
+                self.pdc.DrawToDC(dc)
+                    try:
+                        self.pdcVector.DrawToDC(gcdc)
+                        self.pdcVector.DrawToDC(dc)
+                # store buffered image
+                # self.bufferLast = wx.BitmapFromImage(self.buffer.ConvertToImage())
+                self.bufferLast = dc.GetAsBitmap(wx.Rect(0, 0, self.Map.width, self.Map.height))
+            pdcLast = self.PseudoDC(vdigit = False)
+            pdcLast.DrawBitmap(self.bufferLast, 0, 0, False)
+            pdcLast.DrawToDC(dc)
+        # draw decorations (e.g. region box)
+        try:
+            self.pdcDec.DrawToDC(gcdc)
+            self.pdcDec.DrawToDC(dc)
+        # draw temporary object on the foreground
+        ### self.pdcTmp.DrawToDCClipped(dc, rgn)
+        self.pdcTmp.DrawToDC(dc)
+        if switchDraw:
+            self.redrawAll = False
+        self.polypen = wx.Pen(colour="RED", width=1, style=wx.SOLID)
+        self.pdc.BeginDrawing()
+        self.pdc.SetBrush(wx.Brush(wx.CYAN, wx.TRANSPARENT))
+        self.pdc.SetPen(self.polypen)
+        if (len(self.parent.coords) < 2):
+            return
+        i = 1
+        while i < len(self.parent.coords):
+            self.pdc.DrawLinePoint(wx.Point(self.parent.coords[i-1][0], self.parent.coords[i-1][1]),
+                              wx.Point(self.parent.coords[i][0], self.parent.coords[i][1]))
+            i += 1
+        self.pdc.EndDrawing()
+        self.polypen = wx.Pen(colour="GREEN", width=1, style=wx.SOLID)
+        if (len(self.parent.coor) < 2):
+            return
+        i = 1
+        while i < len(self.parent.coor):
+            self.pdc.DrawLinePoint(wx.Point(self.parent.coor[i-1][0], self.parent.coor[i-1][1]),
+                              wx.Point(self.parent.coor[i][0], self.parent.coor[i][1]))
+            i += 1
+        self.Refresh()
+    def UpdateMap(self, render=True, renderVector=True):
+        Updates the canvas anytime there is a change to the
+        underlaying images or to the geometry of the canvas.
+        @param render re-render map composition
+        @param renderVector re-render vector map layer enabled for editing (used for digitizer)
-        self.width, self.height = self.GetClientSize()
+        start = time.clock()
+        # if len(self.Map.GetListOfLayers()) == 0:
+        #    return False
+        if self.img is None:
+            render = True
+        # initialize process bar (only on 'render')
+        if render is True or renderVector is True:
+            self.parent.statusbarWin['progress'].Show()
+            if self.parent.statusbarWin['progress'].GetRange() > 0:
+                self.parent.statusbarWin['progress'].SetValue(1)
+        # render background image if needed
+        # update layer dictionary if there has been a change in layers
+        if self.tree and self.tree.reorder == True:
+            self.tree.ReorderLayers()
+        # reset flag for auto-rendering
+        if self.tree:
+            self.tree.rerender = False
+        if render:
+            # update display size
+            if self.parent.statusbarWin['resolution'].IsChecked():
+                # use computation region resolution for rendering
+                windres = True
+            else:
+                windres = False
+            self.mapfile = self.Map.Render(force=True, mapWindow=self.parent,
+                                           windres=windres)
+        else:
+            self.mapfile = self.Map.Render(force=False, mapWindow=self.parent)
+        self.img = self.GetImage() # id=99
+        # clear pseudoDcs
+        for pdc in (self.pdc,
+                    self.pdcDec,
+                    self.pdcTmp):
+            pdc.Clear()
+            pdc.RemoveAll()
+        # draw background map image to PseudoDC
+        if not self.img:
+            self.Draw(self.pdc, pdctype='clear')
+        else:
+            try:
+                id = self.imagedict[self.img]['id']
+            except:
+                return False
-        Debug.msg(2, "MapFrame.__InitDisplay():")
-        self.Map.ChangeMapSize(self.GetClientSize())
-        self.Map.region = self.Map.GetRegion() # g.region -upgc
-        # self.Map.SetRegion() # adjust region to match display window
-    def GetLayerManager(self):
-        return self
+            self.Draw(self.pdc, self.img, drawid=id)
+        # render vector map layer
-    def AddToolbar(self, name):
-        """!Add defined toolbar to the window
+        # render overlays
+        for img in self.GetOverlay():
+            # draw any active and defined overlays
+            if self.imagedict[img]['layer'].IsActive():
+                id = self.imagedict[img]['id']
+                self.Draw(self.pdc, img=img, drawid=id,
+                          pdctype=self.overlays[id]['pdcType'], coords=self.overlays[id]['coords'])
+        for id in self.textdict.keys():
+            self.Draw(self.pdc, img=self.textdict[id], drawid=id,
+                      pdctype='text', coords=[10, 10, 10, 10])
+        # optionally draw computational extent box
+        self.DrawCompRegionExtent()
+        # redraw pdcTmp if needed
+        if len(self.polycoords) > 0:
+            self.DrawLines(self.pdcTmp)
+        # clear measurement
+        stop = time.clock()
+        # hide process bar
+        self.parent.statusbarWin['progress'].Hide()
+        ### self.Map.SetRegion()
+        self.parent.StatusbarUpdate()
+        if grass.find_file(name = 'MASK', element = 'cell')['name']:
+            # mask found
+            self.parent.statusbarWin['mask'].SetLabel(_('MASK'))
+        else:
+            self.parent.statusbarWin['mask'].SetLabel('')
+        Debug.msg (2, "BufferedWindow.UpdateMap(): render=%s, renderVector=%s -> time=%g" % \
+                   (render, renderVector, (stop-start)))
+        return True
+    def OnMotion(self, event):
+        """!Mouse moved
-        # default toolbar
-        self.toolbars['map'] = toolbars.MapToolbar(self, self.Map)
+        if self.parent.statusbarWin['toggle'].GetSelection() == 0: # Coordinates
+            precision = int(UserSettings.Get(group = 'projection', key = 'format',
+                                             subkey = 'precision'))
+            format = UserSettings.Get(group = 'projection', key = 'format',
+                                      subkey = 'll')
+            try:
+                e, n = self.Pixel2Cell(event.GetPositionTuple())
+            except (TypeError, ValueError):
+                self.parent.statusbar.SetStatusText("", 0)
+                return
+            if self.parent.toolbars['vdigit'] and \
+                    self.parent.toolbars['vdigit'].GetAction() == 'addLine' and \
+                    self.parent.toolbars['vdigit'].GetAction('type') in ('line', 'boundary') and \
+                    len(self.polycoords) > 0:
+                distance_seg = self.Distance(self.polycoords[-1],
+                for idx in range(1, len(self.polycoords)):
+                    distance_tot += self.Distance(self.polycoords[idx-1],
+                                                  self.polycoords[idx],
+                                                  screen=False )[0]
+                self.parent.statusbar.SetStatusText("%.*f, %.*f (seg: %.*f; tot: %.*f)" % \
+                                                 (precision, e, precision, n,
+                                                  precision, distance_seg,
+                                                  precision, distance_tot), 0)
+            else:
+                if self.parent.statusbarWin['projection'].IsChecked():
+                    if not UserSettings.Get(group='projection', key='statusbar', subkey='proj4'):
+                        self.parent.statusbar.SetStatusText(_("Projection not defined (check the settings)"), 0)
+                    else:
+                        proj, coord  = utils.ReprojectCoordinates(coord = (e, n),
+        projOut = UserSettings.Get(group='projection',
+        key='statusbar',
+        subkey='proj4'),
+        flags = 'd')
+                        if coord:
+                            e, n = coord
+                            if proj in ('ll', 'latlong', 'longlat') and format == 'DMS':
+                                self.parent.statusbar.SetStatusText(utils.Deg2DMS(e, n, precision = precision),
+        0)
+                            else:
+                                self.parent.statusbar.SetStatusText("%.*f; %.*f" % \
+        (precision, e, precision, n), 0)
+                        else:
+                            self.parent.statusbar.SetStatusText(_("Error in projection (check the settings)"), 0)
+                else:
+                    if self.parent.Map.projinfo['proj'] == 'll' and format == 'DMS':
+                                                            0)
+                    else:
+        event.Skip()
-        self._mgr.AddPane(self.toolbars['map'].toolbar,
-                              wx.aui.AuiPaneInfo().
-                              Name("maptoolbar").Caption(_("Map Toolbar")).
-                              ToolbarPane().Top().
-                              LeftDockable(False).RightDockable(False).
-                              BottomDockable(False).TopDockable(True).
-                              CloseButton(False).Layer(2).
-                              BestSize((self.toolbars['map'].GetToolbar().GetSize())))
+    def OnLeftUp(self, event):
+        """!Left mouse button released
+        Debug.msg (5, "BufferedWindow.OnLeftUp(): use=%s" % \
+                       self.mouse["use"])
+        self.mouse['end'] = event.GetPositionTuple()[:]
+        if self.mouse['use'] in ["zoom", "pan"]:
+            # set region in zoom or pan
+            begin = self.mouse['begin']
+            end = self.mouse['end']
+            if self.mouse['use'] == 'zoom':
+                # set region for click (zero-width box)
+                if begin[0] - end[0] == 0 or \
+                        begin[1] - end[1] == 0:
+                    # zoom 1/2 of the screen (TODO: settings)
+                    begin = (end[0] - self.Map.width / 4,
+                             end[1] - self.Map.height / 4)
+                    end   = (end[0] + self.Map.width / 4,
+                             end[1] + self.Map.height / 4)
+            self.Zoom(begin, end, self.zoomtype)
+            # redraw map
+            self.UpdateMap(render=True)
 class PathApp(wx.App):
