[GRASS-SVN] r43705 - grass-addons/imagery/i.landsat.acca
Mon Sep 27 11:02:13 EDT 2010
Author: ejtizado
Date: 2010-09-27 15:02:13 +0000 (Mon, 27 Sep 2010)
New Revision: 43705
   grass-addons/imagery/i.landsat.acca/tools.c
Modified: grass-addons/imagery/i.landsat.acca/tools.c
--- grass-addons/imagery/i.landsat.acca/tools.c	2010-09-27 15:01:57 UTC (rev 43704)
+++ grass-addons/imagery/i.landsat.acca/tools.c	2010-09-27 15:02:13 UTC (rev 43705)
@@ -20,326 +20,105 @@
 /* Global variable
-   allow use as parameters of command line */
-int hist_n = 100;		/* interval 100/hist_n */
+   allow use as parameter in the command line */
+int hist_n   = 100;  /* interval of real data 100/hist_n */
 void hist_put(double t, int hist[])
-    int i;
+	int i;
-    /* scale factor */
-    i = (int)(t * ((double)hist_n / 100.));
+	/* scale factor */
+	i = (int)(t * ((double)hist_n/100.));
-    if (i < 1)
-	i = 1;
-    if (i > hist_n)
-	i = hist_n;
+	if (i < 1) i = 1;
+	if (i > hist_n) i = hist_n;
-    hist[i - 1] += 1;
+	hist[i-1] += 1;
-/* Media real no del histograma */
-double mean(int hist[])
+/* histogram moment */
+double moment(int n, int hist[], int k)
-    int i, total;
-    double mean;
+    int i, j, total;
+    double value, hmean, cte;
+    k = 0;
     total = 0;
-    mean = 0.;
-    for (i = 0; i < hist_n; i++) {
-	total += hist[i];
-	mean += (double)(i * hist[i]);
+    hmean  = 0.;
+    for( i = 0; i < hist_n; i++ )
+        total += hist[i];
+        hmean += (double)(i * hist[i]);
-    mean /= (double)total;
+    hmean /= (double)total; /* histogram mean */
-    /* remove scale factor */
-    return (mean / ((double)hist_n / 100.));
+    value = 0.;
+        cte = 1.;
+        for( j = 0; j < n; j++ ) cte *= (i - hmean);
+        value += cte * (double)hist[i]/(double)total;
+    /* remove scale factor *
+    for( j = 0; j < n; j++ ) value /= ((double)hist_n/100.);
+    value = 0.;
+    cte = 100. / ((double)hist_n * (double)(total - k));
+        value += (pow((i - hmean), n) * (double)hist[i] * cte);
+    return value;
-double moment(int n, int hist[])
+/* Real data mean */
+double mean(int hist[])
-    int i, j, total;
-    double value, hmean, temp;
+    int i, total;
+    double value, mean;
     total = 0;
-    hmean = 0.;
-	total += hist[i];
-	hmean += (double)(i * hist[i]);
+    mean  = 0.;
+        total += hist[i];
+        mean += (double)(i * hist[i]);
-    hmean /= (double)total;
+    mean /= (double)total;
-    value = 0.;
-	temp = 1.;
-	for (j = 0; j < n; j++)
-	    temp *= (i - hmean);
-	value += temp * (double)hist[i] / (double)total;
-	value /= ((double)hist_n / 100.);
-    return value;
+    return (mean / ((double)hist_n/100.));
+/* Real data quantile */
 double quantile(double q, int hist[])
     int i, total;
     double value, qmax, qmin;
     total = 0;
-	total += hist[i];
+        total += hist[i];
     qmax = 1.;
-    for (i = hist_n - 1; i >= 0; i--) {
-	qmin = qmax - (double)hist[i] / (double)total;
-	if (q >= qmin) {
-	    value = (q - qmin) / (qmax - qmin) + (i - 1);
-	    break;
-	qmax = qmin;
+    for( i = hist_n - 1; i >= 0; i-- )
+        qmin = qmax - (double)hist[i]/(double)total;
+        if( q >= qmin )
+            value = (q - qmin) / (qmax - qmin) + (i - 1);
+            break;
+        qmax = qmin;
-    return (value / ((double)hist_n / 100.));
+    return (value / ((double)hist_n/100.));
-    FILTER HOLES OF CLOUDS
-    This a >=50% filter of 3x3
-    if >= 50% vecinos cloud then pixel set to cloud
-#define UNDEFINED   -1
-int pval(void *rast, int i)
-    void *ptr = (void *)((CELL *) rast + i);
-    if (G_is_c_null_value(ptr))
-	return 0;
-    else
-	return (int)((CELL *) rast)[i];
-void filter_holes(int verbose, Gfile * out)
-    int row, col, nrows, ncols;
-    char *mapset;
-    void *arast, *brast, *crast;
-    int i, pixel[9], cold, warm, shadow, nulo, lim;
-    Gfile tmp;
-    nrows = G_window_rows();
-    ncols = G_window_cols();
-    if (nrows < 3 || ncols < 3)
-	return;
-    /* Open to read */
-    mapset = G_find_cell2(out->name, "");
-    if (mapset == NULL)
-	G_fatal_error(_("Raster map <%s> not found"), out->name);
-    arast = G_allocate_raster_buf(CELL_TYPE);
-    brast = G_allocate_raster_buf(CELL_TYPE);
-    crast = G_allocate_raster_buf(CELL_TYPE);
-    if ((out->fd = G_open_cell_old(out->name, mapset)) < 0)
-	G_fatal_error(_("Unable to open raster map <%s>"), out->name);
-    /* Open to write */
-    sprintf(tmp.name, "_%d.BBB", getpid());
-    tmp.rast = G_allocate_raster_buf(CELL_TYPE);
-    if ((tmp.fd = G_open_raster_new(tmp.name, CELL_TYPE)) < 0)
-	G_fatal_error(_("Unable to create raster map <%s>"), tmp.name);
-    G_message(_("Filling small holes in clouds ..."));
-    for (row = 0; row < nrows; row++) {
-	/* Read row values */
-	if (row != 0) {
-	    if (G_get_c_raster_row(out->fd, arast, row - 1) < 0)
-		G_fatal_error(_("Unable to read raster map <%s> row %d"), out->name, row - 1);
-	if (G_get_c_raster_row(out->fd, brast, row) < 0) {
-	    G_fatal_error(_("Unable to read raster map <%s> row %d"), out->name, row);
-	if (row != (nrows - 1)) {
-	    if (G_get_c_raster_row(out->fd, crast, row + 1) < 0)
-		G_fatal_error(_("Unable to read raster map <%s> row %d"), out->name, row + 1);
-	/* Analysis of all pixels */
-	for (col = 0; col < ncols; col++) {
-	    pixel[0] = pval(brast, col);
-	    if (pixel[0] == 0) {
-		if (row == 0) {
-		    pixel[1] = -1;
-		    pixel[2] = -1;
-		    pixel[3] = -1;
-		    if (col == 0) {
-			pixel[4] = -1;
-			pixel[5] = pval(brast, col + 1);
-			pixel[6] = -1;
-			pixel[7] = pval(crast, col);
-			pixel[8] = pval(crast, col + 1);
-		    else if (col != (ncols - 1)) {
-			pixel[4] = pval(brast, col - 1);
-			pixel[6] = pval(crast, col - 1);
-		    else {
-			pixel[5] = -1;
-			pixel[8] = -1;
-		else if (row != (nrows - 1)) {
-		    if (col == 0) {
-			pixel[1] = -1;
-			pixel[2] = pval(arast, col);
-			pixel[3] = pval(arast, col + 1);
-			pixel[4] = -1;
-			pixel[6] = -1;
-			pixel[1] = pval(arast, col - 1);
-		    else {
-			pixel[3] = -1;
-			pixel[5] = -1;
-			pixel[8] = -1;
-		else {
-		    pixel[6] = -1;
-		    pixel[7] = -1;
-		    pixel[8] = -1;
-		    if (col == 0) {
-			pixel[1] = -1;
-			pixel[4] = -1;
-		    else {
-			pixel[3] = -1;
-			pixel[5] = -1;
-		pixel[1] = (row == 0 || col == 0)                 ? -1 : pval(arast, col - 1);
-		pixel[2] = (row == 0)                             ? -1 : pval(arast, col);
-		pixel[3] = (row == 0 || col == (ncols-1))	  ? -1 : pval(arast, col + 1);
-		pixel[4] = (col == 0)				  ? -1 : pval(brast, col - 1);
-		pixel[5] = (col == (ncols-1))			  ? -1 : pval(brast, col + 1);
-		pixel[6] = (row == (nrows-1) || col == 0)	  ? -1 : pval(crast, col - 1);
-		pixel[7] = (row == (nrows-1))			  ? -1 : pval(crast, col);
-		pixel[8] = (row == (nrows-1) || col == (ncols-1)) ? -1 : pval(crast, col + 1);
-		cold = warm = shadow = nulo = 0;
-		for (i = 1; i < 9; i++) {
-		    switch (pixel[i]) {
-		    case IS_COLD_CLOUD:
-			cold++;
-			break;
-		    case IS_WARM_CLOUD:
-			warm++;
-			break;
-		    case IS_SHADOW:
-			shadow++;
-			break;
-		    default:
-			nulo++;
-			break;
-		lim = (int)(cold + warm + shadow + nulo) / 2;
-		/* Entra pixel[0] = 0 */
-		if (nulo < lim) {
-		    if (shadow >= (cold + warm))
-			pixel[0] = IS_SHADOW;
-		    else
-			pixel[0] =
-			    (warm > cold) ? IS_WARM_CLOUD : IS_COLD_CLOUD;
-	    if (pixel[0] != 0) {
-		((CELL *) tmp.rast)[col] = pixel[0];
-	    else {
-		G_set_c_null_value((CELL *) tmp.rast + col, 1);
-	if (G_put_raster_row(tmp.fd, tmp.rast, CELL_TYPE) < 0)
-	    G_fatal_error(_("Failed writing raster map <%s> row %d"), tmp.name, row);
-	G_percent(row, nrows, 2);
-    G_free(arast);
-    G_free(brast);
-    G_free(crast);
-    G_close_cell(out->fd);
-    G_free(tmp.rast);
-    G_close_cell(tmp.fd);
-    G_remove("cats", out->name);
-    G_remove("cell", out->name);
-    G_remove("cellhd", out->name);
-    G_remove("cell_misc", out->name);
-    G_remove("hist", out->name);
-    G_rename("cats", tmp.name, out->name);
-    G_rename("cell", tmp.name, out->name);
-    G_rename("cellhd", tmp.name, out->name);
-    G_rename("cell_misc", tmp.name, out->name);
-    G_rename("hist", tmp.name, out->name);
-    return;
