[GRASS-SVN] r45845 - in grass/branches/develbranch_6/gui/wxpython: gui_modules icons support
Mon Apr 4 07:32:36 EDT 2011
Author: martinl
Date: 2011-04-04 04:32:36 -0700 (Mon, 04 Apr 2011)
New Revision: 45845
   grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_base.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gcpmapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_vdigit.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/ogc_services.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdriver.py
   grass/branches/develbranch_6/gui/wxpython/icons/icon.py
   grass/branches/develbranch_6/gui/wxpython/support/update_menudata.py
wxGUI: don't use deprecated 'dict.has_key()'
(merge r45843 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -826,7 +826,7 @@
             if onlyLayer > 0 and layer != onlyLayer:
                 continue
-            if not self.layerPage.has_key(layer):
+            if not layer in self.layerPage:
                 continue
             panel = wx.Panel(parent=self.manageTablePage, id=wx.ID_ANY)
@@ -1887,8 +1887,7 @@
             sqlFile = tempfile.NamedTemporaryFile(mode="wt")
             for sql in self.listOfSQLStatements:
                 enc = UserSettings.Get(group='atm', key='encoding', subkey='value')
-                if not enc and \
-                        os.environ.has_key('GRASS_DB_ENCODING'):
+                if not enc and 'GRASS_DB_ENCODING' in os.environ:
                     enc = os.environ['GRASS_DB_ENCODING']
                 if enc:
                     sqlFile.file.write(sql.encode(enc) + ';')
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_base.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_base.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_base.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -31,7 +31,7 @@
     enc = UserSettings.Get(group = 'atm', key = 'encoding', subkey = 'value')
     if enc:
         value = unicode(value, enc)
-    elif os.environ.has_key('GRASS_DB_ENCODING'):
+    elif 'GRASS_DB_ENCODING' in os.environ:
         value = unicode(value, os.environ['GRASS_DB_ENCODING'])
     else:
         try:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm_dialogs.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -282,8 +282,7 @@
         """!Submit records"""
         for sql in self.GetSQLString(updateValues=True):
-            if not enc and \
             if enc:
                 sql = sql.encode(enc)
@@ -335,17 +334,17 @@
             data = self.mapDBInfo.SelectByPoint(query[0],
                                                 query[1])
             self.cats = {}
-            if data and data.has_key('Layer'):
+            if data and 'Layer' in data:
                 idx = 0
                 for layer in data['Layer']:
                     layer = int(layer)
-                    if data.has_key('Id'):
+                    if 'Id' in data:
                         tfid = int(data['Id'][idx])
                     else:
                         tfid = 0 # Area / Volume
-                    if not self.cats.has_key(tfid):
+                    if not tfid in self.cats:
                         self.cats[tfid] = {}
-                    if not self.cats[tfid].has_key(layer):
+                    if not layer in self.cats[tfid]:
                         self.cats[tfid][layer] = []
                     cat = int(data['Category'][idx])
                     self.cats[tfid][layer].append(cat)
@@ -381,7 +380,7 @@
         for layer in layers: # for each layer
             if not query: # select by layer/cat
-                if self.fid > 0 and self.cats[self.fid].has_key(layer):
+                if self.fid > 0 and layer in self.cats[self.fid]:
                     for cat in self.cats[self.fid][layer]:
                         nselected = self.mapDBInfo.SelectFromTable(layer,
        where="%s=%d" % \
@@ -395,7 +394,7 @@
             if self.action == "add":
                 if nselected <= 0:
-                    if self.cats[self.fid].has_key(layer):
+                    if layer in self.cats[self.fid]:
                         table = self.mapDBInfo.layers[layer]["table"]
                         key = self.mapDBInfo.layers[layer]["key"]
                         columns = self.mapDBInfo.tables[table]
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -361,7 +361,7 @@
         if verbose_orig:
             os.environ["GRASS_VERBOSE"] = verbose_orig
-        elif os.environ.has_key("GRASS_VERBOSE"):
+        elif "GRASS_VERBOSE" in os.environ:
             del os.environ["GRASS_VERBOSE"]
     def __ReadOutput(self, stream):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gcpmapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gcpmapdisp.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gcpmapdisp.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -93,7 +93,7 @@
         self.layerbook  = notebook  # Layer Manager layer tree notebook
         self.parent     = parent
-        if not kwargs.has_key('name'):
+        if 'name' not in kwargs:
             kwargs['name'] = 'GCPMapWindow'
         wx.Frame.__init__(self, parent, id, title, style = style, **kwargs)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/ghelp.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -171,7 +171,7 @@
                 except ValueError:
                     continue # TODO
-                if not modules.has_key(group):
+                if group not in modules:
                     modules[group] = list()
                 modules[group].append(name)
@@ -305,7 +305,7 @@
             return
         data = self.tree.GetPyData(item)
-        if not data or not data.has_key('command'):
+        if not data or 'command' not in data:
             return
         self.tree.itemSelected = item
@@ -319,7 +319,7 @@
             return
             return
         if data['command']:
@@ -388,7 +388,7 @@
                 self._processItem(subItem, element, value, listOfItems)
             data = self.GetPyData(item)
-            if data and data.has_key(element) and \
+            if data and element in data and \
                     value.lower() in data[element].lower():
                 listOfItems.append(item)
@@ -728,7 +728,7 @@
                     errLines.append(line)
                     continue
                 for language in languages.split(' '):
-                    if not translators.has_key(language):
+                    if language not in translators:
                         translators[language] = list()
                     translators[language].append((name, email))
             translatorsFile.close()
@@ -935,7 +935,7 @@
     def OnItemActivated(self, event):
         item = event.GetItem()
-        if data and data.has_key('command'):
+        if data and 'command' in data:
             self._install(data['command'])
     def OnInstall(self, event):
@@ -1001,7 +1001,7 @@
                  'v'  : 'vector',
                  'wx' : 'wxGUI' }
-        if name.has_key(c):
+        if c in name:
             return name[c]
         return c
@@ -1039,7 +1039,7 @@
                 key, value = line.split('=', 1)
                 if key == 'name':
                     prefix, name = value.split('.', 1)
-                    if not mdict.has_key(prefix):
+                    if prefix not in mdict:
                         mdict[prefix] = dict()
                     mdict[prefix][name] = dict()
                 else:
@@ -1054,7 +1054,7 @@
                 if self._expandPrefix(prefix) == prefix:
                     prefix = 'unknown'
                 mdict[prefix][name] = { 'command' : prefix + '.' + name }
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gmodeler.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -496,14 +496,14 @@
             params = action.GetParams()
             for f in params['flags']:
                 if f.get('parameterized', False):
-                    if not result.has_key(name):
+                    if name not in result:
                         result[name] = { 'flags' : list(),
                                          'params': list(),
                                          'idx'   : idx }
                     result[name]['flags'].append(f)
             for p in params['params']:
                 if p.get('parameterized', False):
                                          'params': list(),
                                          'idx'   : idx }
@@ -979,7 +979,7 @@
     def _runAction(self, item, params):
         """!Run given action"""
         name = item.GetName()
-        if params.has_key(name):
+        if name in params:
             paramsOrig = item.GetParams(dcopy = True)
             item.MergeParams(params[name])
@@ -987,7 +987,7 @@
         self.goutput.RunCmd(command = item.GetLog(string = False),
                             onDone = self.OnDone)
             item.SetParams(paramsOrig)
     def OnDone(self, cmd, returncode):
@@ -1810,11 +1810,11 @@
     def MergeParams(self, params):
         """!Merge dictionary of parameters"""
-        if params.has_key('flags'):
+        if 'flags' in params:
                 self.task.set_flag(f['name'],
                                    f.get('value', False))
-        if params.has_key('params'):
+        if 'params' in params:
                 self.task.set_param(p['name'],
                                     p.get('value', ''))
@@ -2842,7 +2842,7 @@
         if self.properties['author']:
             self.fd.write('%s<author>%s</author>\n' % (' ' * self.indent, self.properties['author']))
-        if self.properties.has_key('overwrite') and \
+        if 'overwrite' in self.properties and \
                 self.properties['overwrite']:
             self.fd.write('%s<flag name="overwrite" />\n' % (' ' * self.indent))
         self.indent -= 4
@@ -2858,10 +2858,10 @@
             self.fd.write('%s<variable name="%s" type="%s">\n' % \
                               (' ' * self.indent, name, values['type']))
             self.indent += 4
-            if values.has_key('value'):
+            if 'value' in values:
                 self.fd.write('%s<value>%s</value>\n' % \
                                   (' ' * self.indent, values['value']))
-            if values.has_key('description'):
+            if 'description' in values:
                 self.fd.write('%s<description>%s</description>\n' % \
                                   (' ' * self.indent, values['description']))
             self.indent -= 4
@@ -3399,7 +3399,7 @@
         self.name.SetValue(prop['name'])
         self.desc.SetValue(prop['description'])
         self.author.SetValue(prop['author'])
-        if prop.has_key('overwrite'):
+        if 'overwrite' in prop:
             self.overwrite.SetValue(prop['overwrite'])
 class ModelParamDialog(wx.Dialog):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -87,7 +87,7 @@
         while True:
             requestId, args, kwds = self.requestQ.get()
             for key in ('callable', 'onDone', 'userData'):
-                if kwds.has_key(key):
+                if key in kwds:
                     vars()[key] = kwds[key]
                     del kwds[key]
                 else:
@@ -522,7 +522,7 @@
                 # for all non-display commands.
                 if compReg:
                     tmpreg = os.getenv("GRASS_REGION")
-                    if os.environ.has_key("GRASS_REGION"):
+                    if "GRASS_REGION" in os.environ:
                         del os.environ["GRASS_REGION"]
                 if len(command) == 1:
@@ -1073,7 +1073,7 @@
                 if enc:
                     txt = unicode(txt, enc)
                     txt = unicode(txt, os.environ['GRASS_DB_ENCODING'])
                 else:
                     txt = utils.EncodeString(txt)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -317,21 +317,21 @@
         else:
             filesdict = grass.list_grouped(elementdict[element])
-        first_dir = None
-        for dir in mapsets:
-            dir_node = self.AddItem('Mapset: ' + dir)
-            if not first_dir:
-                first_dir = dir_node
+        first_mapset = None
+        for mapset in mapsets:
+            mapset_node = self.AddItem('Mapset: ' + mapset)
+            if not first_mapset:
+                first_mapset = mapset_node
-            self.seltree.SetItemTextColour(dir_node, wx.Colour(50, 50, 200))
-            if not filesdict.has_key(dir):
+            self.seltree.SetItemTextColour(mapset_node, wx.Colour(50, 50, 200))
+            if mapset not in filesdict:
                 continue
             try:
-                elem_list = filesdict[dir]
+                elem_list = filesdict[mapset]
                 elem_list.sort(key = unicode.lower)
                 for elem in elem_list:
                     if elem != '':
-                        fullqElem = elem + '@' + dir
+                        fullqElem = elem + '@' + mapset
                         if elements:
                             if (exclude and fullqElem in elements) or \
                                     (not exclude and fullqElem not in elements):
@@ -339,26 +339,26 @@
                         if self.filterElements:
                             if self.filterElements(fullqElem):
-                                self.AddItem(elem, parent=dir_node)
+                                self.AddItem(elem, parent=mapset_node)
                         else:
             except StandardError, e:
                 sys.stderr.write(_("GSelect: invalid item: %s") % e)
                 continue
-            if self.seltree.ItemHasChildren(dir_node):
+            if self.seltree.ItemHasChildren(mapset_node):
                 sel = UserSettings.Get(group='general', key='elementListExpand',
                                        subkey='selection')
                 collapse = True
                 if sel == 0: # collapse all except PERMANENT and current
-                    if dir in ('PERMANENT', curr_mapset):
+                    if mapset in ('PERMANENT', curr_mapset):
                         collapse = False
                 elif sel == 1: # collapse all except PERMANENT
-                    if dir == 'PERMANENT':
+                    if mapset == 'PERMANENT':
                         collapse = False
                 elif sel == 2: # collapse all except current
-                    if dir == curr_mapset:
+                    if mapset == curr_mapset:
                         collapse = False
                 elif sel == 3: # collapse all
                     pass
@@ -366,13 +366,13 @@
                     collapse = False
                 if collapse:
-                    self.seltree.Collapse(dir_node)
+                    self.seltree.Collapse(mapset_node)
                 else:
-                    self.seltree.Expand(dir_node)
+                    self.seltree.Expand(mapset_node)
-        if first_dir:
+        if first_mapset:
             # select first mapset (MSW hack)
-            self.seltree.SelectItem(first_dir)
+            self.seltree.SelectItem(first_mapset)
     # helpers
     def FindItem(self, parentItem, text, startLetters = False):
@@ -496,15 +496,15 @@
     def SetData(self, **kargs):
         """!Set object properties"""
-        if kargs.has_key('type'):
+        if 'type' in kargs:
             self.type = kargs['type']
-        if kargs.has_key('mapsets'):
+        if 'mapsets' in kargs:
             self.mapsets = kargs['mapsets']
-        if kargs.has_key('multiple'):
+        if 'multiple' in kargs:
             self.multiple = kargs['multiple']
-        if kargs.has_key('updateOnPopup'):
+        if 'updateOnPopup' in kargs:
             self.updateOnPopup = kargs['updateOnPopup']
-        if kargs.has_key('onPopup'):
+        if 'onPopup' in kargs:
             self.onPopup = kargs['onPopup']
 class VectorDBInfo:
@@ -1226,7 +1226,7 @@
     def OnSettingsLoad(self, event):
         """!Load named settings"""
         name = event.GetString()
-        if not self._settings.has_key(name):
+        if name not in self._settings:
             gcmd.GError(parent = self,
                         message = _("Settings named '%s' not found") % name)
             return
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -874,7 +874,7 @@
     def PropertiesDialog (self, layer, show = True):
         """!Launch the properties dialog"""
-        if self.GetPyData(layer)[0].has_key('propwin') and \
+        if 'propwin' in self.GetPyData(layer)[0] and \
                 self.GetPyData(layer)[0]['propwin'] is not None:
             # recycle GUI dialogs
             win = self.GetPyData(layer)[0]['propwin']
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -709,7 +709,7 @@
         id  = event.GetId()
         val = event.GetString()
-        if not self.pparam.has_key(id):
+        if id not in self.pparam:
             event.Skip()
             return
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -101,7 +101,7 @@
             kwargs['name'] = 'MapWindow'
@@ -1373,9 +1373,9 @@
         if hasattr(self, "tmpreg"):
             if self.tmpreg:
                 os.environ["GRASS_REGION"] = self.tmpreg
-            elif os.environ.has_key('GRASS_REGION'):
+            elif 'GRASS_REGION' in os.environ:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_vdigit.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_vdigit.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -118,7 +118,7 @@
         # translate tmp objects (pointer position)
         if self.toolbar.GetAction() == 'moveLine' and \
                 hasattr(self, "moveInfo"):
-            if self.moveInfo.has_key('beginDiff'):
+            if 'beginDiff' in self.moveInfo:
                 # move line
                 for id in self.moveInfo['id']:
                     self.pdcTmp.TranslateId(id,
@@ -191,8 +191,8 @@
         item = self.tree.FindItemByData('maplayer', mapLayer)
         vdigit = self.tree.GetPyData(item)[0]['vdigit']
         if not vdigit or \
-                not vdigit.has_key('geomAttr') or \
-                not vdigit['geomAttr'].has_key(attrb):
+                'geomAttr' not in vdigit or \
+                attrb not in vdigit['geomAttr']:
             return
         val = -1
@@ -223,7 +223,7 @@
-        if vdigit is None or not vdigit.has_key('geomAttr'):
+        if vdigit is None or 'geomAttr' not in vdigit:
             return
         dbInfo = gselect.VectorDBInfo(vectorName)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -378,7 +378,7 @@
         elif pdctype == 'text': # draw text on top of map
             if not img['active']:
                 return # only draw active text
-            if img.has_key('rotation'):
+            if 'rotation' in img:
                 rotation = float(img['rotation'])
             else:
                 rotation = 0.0
@@ -404,7 +404,7 @@
         @param textinfo text metadata (text, font, color, rotation)
         @param coords reference point
-        if textinfo.has_key('rotation'):
+        if 'rotation' in textinfo:
             rotation = float(textinfo['rotation'])
         else:
             rotation = 0.0
@@ -1236,9 +1236,9 @@
                 self.dragid >= 0):
             # end drag of overlay decoration
-            if self.dragid < 99 and self.overlays.has_key(self.dragid):
+            if self.dragid < 99 and self.dragid in self.overlays:
                 self.overlays[self.dragid]['coords'] = self.pdc.GetIdBounds(self.dragid)
-            elif self.dragid > 100 and self.textdict.has_key(self.dragid):
+            elif self.dragid > 100 and self.dragid in self.textdict:
                 self.textdict[self.dragid]['coords'] = self.pdc.GetIdBounds(self.dragid)
             else:
                 pass
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/menuform.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -193,8 +193,7 @@
                 return
         p = self.task.get_param(self.eventId, element = 'wxId', raiseError = False)
-        if not p or \
-                not p.has_key('wxId-bind'):
+        if not p or 'wxId-bind' not in p:
             return
         # get widget prompt
@@ -224,7 +223,7 @@
             name = win.GetName()
             if name == 'LayerSelect':
-                if cparams.has_key(map) and not cparams[map]['layers']:
+                if map in cparams and not cparams[map]['layers']:
                     win.InsertLayers(vector = map)
                     cparams[map]['layers'] = win.GetItems()
@@ -251,7 +250,7 @@
                     layer = 1
                 if map:
-                    if cparams.has_key(map):
+                    if map in cparams:
                         if not cparams[map]['dbInfo']:
                             cparams[map]['dbInfo'] = gselect.VectorDBInfo(map)
                         self.data[win.InsertColumns] = { 'vector' : map, 'layer' : layer,
@@ -595,7 +594,7 @@
                 required = False
             if not _ignoreBlackList and \
-                    _blackList.has_key(self.task.name) and \
+                    self.task.name in _blackList and \
                     p.get('name') in _blackList[self.task.name]['params']:
                 hidden = True
             else:
@@ -626,7 +625,7 @@
         global _ignoreBlackList
         for p in self.root.findall('flag'):
                     p.get('name') in _blackList[self.task.name]['flags']:
                 hidden = True
             else:
@@ -1067,7 +1066,7 @@
             if task.get('guisection','') ==  '':
                 # Undefined guisections end up into Options
                 task['guisection'] = _('Optional')
-            if not is_section.has_key(task['guisection']):
+            if task['guisection'] not in is_section:
                 # We do it like this to keep the original order, except for Main which goes first
                 is_section[task['guisection']] = 1
                 sections.append(task['guisection'])
@@ -1160,7 +1159,7 @@
                                      label = _("Parameterized in model"))
                 parChk.SetName('ModelParam')
                 parChk.SetValue(f.get('parameterized', False))
-                if f.has_key('wxId'):
+                if 'wxId' in f:
                     f['wxId'].append(parChk.GetId())
                 else:
                     f['wxId'] = [ parChk.GetId() ]
@@ -1174,7 +1173,7 @@
                 if f['name'] ==  vq:
                     chk.SetValue(True)
                     f['value'] = True
-            elif f['name'] ==  'overwrite' and not f.has_key('value'):
+            elif f['name'] ==  'overwrite' and 'value' not in f:
                 chk.SetValue(UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled'))
                 f['value'] = UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled')
@@ -1268,8 +1267,7 @@
                         chkbox = wx.CheckBox(parent = which_panel,
                                              label = text_beautify(label))
                         p[ 'wxId' ].append(chkbox.GetId())
-                        if isEnabled.has_key(val):
+                        if val in isEnabled:
                             chkbox.SetValue(True)
                         hSizer.Add(item = chkbox, proportion = 0,
                                     flag = wx.ADJUST_MINSIZE | wx.ALL, border = 1)
@@ -1533,7 +1531,7 @@
                             win.Bind(wx.EVT_TEXT, self.OnUpdateSelection)
                             p['wxId'] = [ win.GetChildren()[1].GetId() ]
-                    if not p.has_key('wxId'):
+                    if 'wxId' not in p:
                         try:
                             p['wxId'] = [ win.GetId(), ]
                         except AttributeError:
@@ -1620,7 +1618,7 @@
                 parChk.SetValue(p.get('parameterized', False))
-                if p.has_key('wxId'):
+                if 'wxId' in p:
                     p['wxId'].append(parChk.GetId())
                 else:
                     p['wxId'] = [ parChk.GetId() ]
@@ -1643,7 +1641,7 @@
                     title_txt.SetToolTipString(tooltip)
             if p ==  first_param:
-                if p.has_key('wxId') and len(p['wxId']) > 0:
+                if 'wxId' in p and len(p['wxId']) > 0:
                     win = self.FindWindowById(p['wxId'][0])
                     win.SetFocus()
@@ -1876,7 +1874,7 @@
         # Keep the original order, so that some defaults may be recovered
         currentValueList = []
         for v in theParam['values']:
-            if currentValues.has_key(v):
+            if v in currentValues:
                 currentValueList.append(v)
         # Pack it back
@@ -1897,7 +1895,7 @@
         found = False
         for porf in self.task.params + self.task.flags:
-            if not porf.has_key('wxId'):
+            if 'wxId' not in porf:
                 continue
             if myId in porf['wxId']:
                 found = True
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -301,7 +301,7 @@
                               data['persp']['value'],
                               data['twist']['value'])
-        if event and event.zExag and data['z-exag'].has_key('value'):
+        if event and event.zExag and 'value' in data['z-exag']:
             self._display.SetZExag(data['z-exag']['value'])
         if event:
@@ -375,11 +375,11 @@
             return 0
         if layer.type ==  'raster':
-            if not data['surface'].has_key('object'):
+            if 'object' not in data['surface']:
                 return 0
         elif layer.type ==  'vector':
-            if not data['vlines'].has_key('object') and \
-                    not data['points'].has_key('object'):
+            if 'object' not in data['vlines'] and \
+                    'object' not in data['points']:
                 return 0
         return 1
@@ -430,7 +430,7 @@
                 elif type ==  'vector':
                     # data = self.tree.GetPyData(item)[0]['nviz']
                     # vecType = []
-                    # if data and data.has_key('vector'):
+                    # if data and 'vector' in data:
                     #     for v in ('lines', 'points'):
                     #         if data['vector'][v]:
                     #             vecType.append(v)
@@ -471,7 +471,7 @@
                     elif ltype ==  'vector':
                         data = self.tree.GetPyData(layer)[0]['nviz']
                         vecType = []
-                        if data and data.has_key('vector'):
+                        if data and 'vector' in data:
                                     vecType.append(v)
@@ -766,7 +766,7 @@
             vecTypes = ('lines', )
         for vecType in vecTypes:
-            if not data[vecType].has_key('object'):
+            if 'object' not in data[vecType]:
                 continue
             id = data[vecType]['object']['id']
@@ -842,21 +842,21 @@
         """!Generic method to update data layer properties"""
         data = event.data
-        if data.has_key('surface'):
+        if 'surface' in data:
             id = data['surface']['object']['id']
             self.UpdateSurfaceProperties(id, data['surface'])
             # -> initialized
             data['surface']['object']['init'] = True
-        elif data.has_key('volume'):
+        elif 'volume' in data:
             id = data['volume']['object']['id']
             self.UpdateVolumeProperties(id, data['volume'])
             # -> initialized
             data['volume']['object']['init'] = True
-        elif data.has_key('vector'):
+        elif 'vector' in data:
             for type in ('lines', 'points'):
-                if data['vector'][type].has_key('object'):
+                if 'object' in data['vector'][type]:
                     id = data['vector'][type]['object']['id']
                     self.UpdateVectorProperties(id, data['vector'], type)
                     # -> initialized
@@ -867,8 +867,8 @@
         # surface attributes
         for attrb in ('topo', 'color', 'mask',
                      'transp', 'shine', 'emit'):
-            if not data['attribute'].has_key(attrb) or \
-                    not data['attribute'][attrb].has_key('update'):
+            if attrb not in data['attribute'] or \
+                    'update' not in data['attribute'][attrb]:
                 continue
             map = data['attribute'][attrb]['map']
@@ -905,7 +905,7 @@
             data['attribute'][attrb].pop('update')
         # draw res
-        if data['draw']['resolution'].has_key('update'):
+        if 'update' in data['draw']['resolution']:
             coarse = data['draw']['resolution']['coarse']
             fine   = data['draw']['resolution']['fine']
@@ -916,7 +916,7 @@
             data['draw']['resolution'].pop('update')
         # draw style
-        if data['draw']['mode'].has_key('update'):
+        if 'update' in data['draw']['mode']:
             if data['draw']['mode']['value'] < 0: # need to calculate
                 data['draw']['mode']['value'] = \
                     self.nvizDefault.GetDrawMode(mode = data['draw']['mode']['desc']['mode'],
@@ -931,7 +931,7 @@
             data['draw']['mode'].pop('update')
         # wire color
-        if data['draw']['wire-color'].has_key('update'):
+        if 'update' in data['draw']['wire-color']:
             color = data['draw']['wire-color']['value']
             if data['draw']['all']:
                 self._display.SetWireColor(-1, str(color))
@@ -940,7 +940,7 @@
             data['draw']['wire-color'].pop('update')
         # position
-        if data['position'].has_key('update'):
+        if 'update' in data['position']:
             x = data['position']['x']
             y = data['position']['y']
             z = data['position']['z']
@@ -949,11 +949,11 @@
     def UpdateVolumeProperties(self, id, data, isosurfId = None):
         """!Update volume (isosurface/slice) map object properties"""
             self._display.SetIsosurfaceRes(id, data['draw']['resolution']['value'])
-        if data['draw']['shading'].has_key('update'):
+        if 'update' in data['draw']['shading']:
             if data['draw']['shading']['value'] < 0: # need to calculate
                 data['draw']['shading']['value'] = \
                     self.nvizDefault.GetDrawMode(shade = data['draw']['shading'],
@@ -967,8 +967,8 @@
         for isosurf in data['isosurface']:
             for attrb in ('color', 'mask',
-                if not isosurf.has_key(attrb) or \
-                    not isosurf[attrb].has_key('update'):
+                if attrb not in isosurf or \
+                        'update' not in isosurf[attrb]:
                     continue
                 map = isosurf[attrb]['map']
                 value = isosurf[attrb]['value']
@@ -1017,14 +1017,14 @@
     def UpdateVectorLinesProperties(self, id, data):
         """!Update vector line map object properties"""
         # mode
-        if data['color'].has_key('update') or \
-                data['width'].has_key('update') or \
-                data['mode'].has_key('update'):
+        if 'update' in data['color'] or \
+                'update' in data['width'] or \
+                'update' in data['mode']:
             width = data['width']['value']
             color = data['color']['value']
             if data['mode']['type'] ==  'flat':
                 flat = True
                     data.pop('surface')
             else:
                 flat = False
@@ -1032,21 +1032,21 @@
             self._display.SetVectorLineMode(id, color,
                                             width, flat)
-            if data['color'].has_key('update'):
+            if 'update' in data['color']:
                 data['color'].pop('update')
-            if data['width'].has_key('update'):
+            if 'update' in data['width']:
                 data['width'].pop('update')
-            if data['mode'].has_key('update'):
+            if 'update' in data['mode']:
                 data['mode'].pop('update')
         # height
-        if data['height'].has_key('update'):
+        if 'update' in data['height']:
             self._display.SetVectorLineHeight(id,
                                               data['height']['value'])
             data['height'].pop('update')
         # surface
             sid = self.GetLayerId(type = 'raster', name = data['mode']['surface'])
             if sid > -1:
                 self._display.SetVectorLineSurface(id, sid)
@@ -1055,10 +1055,10 @@
     def UpdateVectorPointsProperties(self, id, data):
         """!Update vector point map object properties"""
-        if data['size'].has_key('update') or \
-                data['marker'].has_key('update') or \
-                data['color'].has_key('update'):
+        if 'update' in data['size'] or \
+                'update' in data['marker'] or \
+                'update' in data['color']:
             ret = self._display.SetVectorPointMode(id, data['color']['value'],
                                                    data['width']['value'], float(data['size']['value']),
                                                    data['marker']['value'] + 1)
@@ -1073,17 +1073,17 @@
                 raise gcmd.GException(_("Setting data layer properties failed.\n\n%s") % error)
             for prop in ('size', 'width', 'marker', 'color'):
-                if data[prop].has_key('update'):
+                if 'update' in data[prop]:
                     data[prop].pop('update')
         # height
             self._display.SetVectorPointHeight(id,
         # surface
             if sid > -1:
                 self._display.SetVectorPointSurface(id, sid)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -2532,7 +2532,7 @@
             self.SetMapObjUseMap(nvizType = 'surface',
                                  attrb = attr, map = True) # -> map
-        if data['attribute'].has_key('color'):
+        if 'color' in data['attribute']:
             value = data['attribute']['color']['value']
             if data['attribute']['color']['map']:
                 self.FindWindowById(self.win['surface']['color']['map']).SetValue(value)
@@ -2648,7 +2648,7 @@
         # lines
         showLines = self.FindWindowById(self.win['vector']['lines']['show'])
-        if data['lines'].has_key('object'):
+        if 'object' in data['lines']:
             showLines.SetValue(True)
         else:
             showLines.SetValue(False)
@@ -2693,7 +2693,7 @@
         showPoints = self.FindWindowById(self.win['vector']['points']['show'])
-        if data['points'].has_key('object'):
+        if 'object' in data['points']:
             showPoints.SetValue(True)
         else:
             showPoints.SetValue(False)
@@ -2772,7 +2772,7 @@
                 continue
             # skip empty attributes
-            if not data.has_key(attrb):
+            if attrb not in data:
                 continue
             value = data[attrb]['value']
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/ogc_services.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/ogc_services.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/ogc_services.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -194,7 +194,7 @@
             elif key == 'title':
                 layers[lastLayer][key] = value
             elif key == 'style':
-                if not layers[lastLayer].has_key('style'):
+                if 'style' not in layers[lastLayer]:
                     layers[lastLayer]['style'] = {}
                 layers[lastLayer]['style'][value] = ''
                 lastStyle = value
@@ -260,7 +260,7 @@
             title = data[layer]['title']
             lchild = self.AppendItem(self.root, layer)
             self.SetItemText(lchild, title, 1)
-            if data[layer].has_key('style'):
+            if 'style' in data[layer]:
                 styles = data[layer]['style'].keys()
                 if not styles:
                     continue
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -902,15 +902,15 @@
         @param subkey subkey (value or list)
         @param value value
-        if not dict.has_key(group):
+        if group not in dict:
             dict[group] = {}
-        if not dict[group].has_key(key):
+        if key not in dict[group]:
             dict[group][key] = {}
         if type(subkey) == types.ListType:
             # TODO: len(subkey) > 2
-            if not dict[group][key].has_key(subkey[0]):
+            if subkey[0] not in dict[group][key]:
                 dict[group][key][subkey[0]] = {}
             try:
                 dict[group][key][subkey[0]][subkey[1]] = value
@@ -1922,7 +1922,7 @@
         except ValueError:
             code = -1
         win = self.FindWindowById(self.winId['projection:statusbar:proj4'])
-        if self.epsgCodeDict.has_key(code):
+        if code in self.epsgCodeDict:
             win.SetValue(self.epsgCodeDict[code][1])
         else:
             list.SetSelection(0)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/prompt.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -56,7 +56,7 @@
         self.statusbar = statusbar
-        if kwargs.has_key('style'):
+        if 'style' in kwargs:
             kwargs['style'] = wx.TE_PROCESS_ENTER | kwargs['style']
         else:
@@ -523,7 +523,7 @@
     def GetCommandDesc(self, cmd):
         """!Get description for given command"""
-        if self.moduleDesc.has_key(cmd):
+        if cmd in self.moduleDesc:
             return self.moduleDesc[cmd]['desc']
         return ''
@@ -561,7 +561,7 @@
             except ValueError:
                 continue # TODO
-            if not result.has_key(group):
+            if group not in result:
                 result[group] = list()
             result[group].append(name)
@@ -570,7 +570,7 @@
             for i in range(len(name.split('.'))-1):
                 group = '.'.join([group,name.split('.',1)[0]])
                 name = name.split('.',1)[1]
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -215,7 +215,7 @@
 #            gcmd.RunCommand('d.mon',
 #                            stop = 'cairo')
             del os.environ["GRASS_CAIROFILE"]
-        elif os.environ.has_key("GRASS_PNGFILE"):
+        elif "GRASS_PNGFILE" in os.environ:
             del os.environ["GRASS_PNGFILE"]
         self.force_render = False
@@ -881,7 +881,7 @@
         os.environ["GRASS_HEIGHT"] = str(self.height)
         if UserSettings.Get(group='display', key='driver', subkey='type') == 'cairo':
             os.environ["GRASS_AUTO_WRITE"] = "TRUE"
-            if os.environ.has_key("GRASS_RENDER_IMMEDIATE"):
+            if "GRASS_RENDER_IMMEDIATE" in os.environ:
                 del os.environ["GRASS_RENDER_IMMEDIATE"]
             os.environ["GRASS_RENDER_IMMEDIATE"] = "TRUE"
         else:
@@ -1049,22 +1049,22 @@
         Debug.msg (3, "Map.ChangeLayer(): layer=%s" % layer.name)
             layer.SetType(kargs['type']) # check type
-        if kargs.has_key('command'):
+        if 'command' in kargs:
             layer.SetCmd(kargs['command'])
-        if kargs.has_key('name'):
+        if 'name' in kargs:
             layer.SetName(kargs['name'])
-        if kargs.has_key('active'):
+        if 'active' in kargs:
             layer.SetActive(kargs['active'])
-        if kargs.has_key('hidden'):
+        if 'hidden' in kargs:
             layer.SetHidden(kargs['hidden'])
-        if kargs.has_key('opacity'):
+        if 'opacity' in kargs:
             layer.SetOpacity(kargs['opacity'])
         if render and not layer.Render():
@@ -1200,19 +1200,19 @@
         if  overlay is None:
             overlay = Overlay(id, type = None, cmd = None)
             overlay.SetName(kargs['type']) # type -> overlay
             overlay.SetCmd(kargs['command'])
             overlay.SetActive(kargs['active'])
             overlay.SetHidden(kargs['hidden'])
             overlay.SetOpacity(kargs['opacity'])
         if render and command != [] and not overlay.Render():
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -452,11 +452,11 @@
     scmd = cmd[0]
-    if cmd[1].has_key('flags'):
+    if 'flags' in cmd[1]:
         for flag in cmd[1]['flags']:
             scmd += ' -' + flag
     for flag in ('verbose', 'quiet', 'overwrite'):
-        if cmd[1].has_key(flag) and cmd[1][flag] is True:
+        if flag in cmd[1] and cmd[1][flag] is True:
             scmd += ' --' + flag
     for k, v in cmd[1].iteritems():
@@ -481,7 +481,7 @@
             if flag in ('verbose', 'quiet', 'overwrite'):
                 dcmd[str(flag)] = True
         else: # -> flags
-            if not dcmd.has_key('flags'):
+            if 'flags' not in dcmd:
                 dcmd['flags'] = ''
             dcmd['flags'] += item.replace('-', '')
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -481,8 +481,8 @@
             # default values
             check.SetValue(False)
             if item and tree.GetPyData(item)[0]['vdigit'] and \
-                    tree.GetPyData(item)[0]['vdigit'].has_key('geomAttr') and \
-                    tree.GetPyData(item)[0]['vdigit']['geomAttr'].has_key(attrb):
+                    'geomAttr' in tree.GetPyData(item)[0]['vdigit'] and \
+                    attrb in tree.GetPyData(item)[0]['vdigit']['geomAttr']:
                 check.SetValue(True)
                 column.SetStringSelection(tree.GetPyData(item)[0]['vdigit']['geomAttr'][attrb]['column'])
                 if attrb == 'area':
@@ -765,7 +765,7 @@
        'units' : unitsKey }
             else:
-                        tree.GetPyData(item)[0]['vdigit']['geomAttr'].has_key(key):
+                        key in tree.GetPyData(item)[0]['vdigit']['geomAttr']:
                     del tree.GetPyData(item)[0]['vdigit']['geomAttr'][key]
         # query tool
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/workspace.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -250,7 +250,7 @@
         # init nviz layer properties
         vdigit = dict()
         for node in node_vdigit.findall('geometryAttribute'):
-            if not vdigit.has_key('geomAttr'):
+            if 'geomAttr' not in vdigit:
                 vdigit['geomAttr'] = dict()
             type = node.get('type')
             vdigit['geomAttr'][type] = dict()
@@ -277,7 +277,7 @@
             for sec in ('lines', 'points'):
                 nviz['vector'][sec] = {}
-        if nviz.has_key('surface'):
+        if 'surface' in nviz:
             node_surface = node_nviz.find('surface')
             # attributes
             for attrb in node_surface.findall('attribute'):
@@ -315,7 +315,7 @@
                 # resolution
                 for node_res in node_draw.findall('resolution'):
                     resType = str(node_res.get('type', ''))
-                    if not nviz['surface']['draw'].has_key('resolution'):
+                    if 'resolution' not in nviz['surface']['draw']:
                         nviz['surface']['draw']['resolution'] = {}
                     value = int(self.__getNodeText(node_res, 'value'))
                     nviz['surface']['draw']['resolution'][resType] = value
@@ -338,7 +338,7 @@
                     value = int(self.__getNodeText(node, 'value'))
                     dc[coor] = value
-        elif nviz.has_key('vector'):
+        elif 'vector' in nviz:
             # vpoints
             node_vpoints = node_nviz.find('vpoints')
             if node_vpoints is not None:
@@ -444,9 +444,9 @@
         data['draw']['all'] = False # apply only for current surface
         for control, value in UserSettings.Get(group='nviz', key='surface', subkey='draw').iteritems():
             if control[:3] == 'res':
-                if not data['draw'].has_key('resolution'):
+                if 'resolution' not in data['draw']:
                     data['draw']['resolution'] = {}
-                if not data['draw']['resolution'].has_key('update'):
+                if 'update' not in data['draw']['resolution']:
                     data['draw']['resolution']['update'] = None
                 data['draw']['resolution'][control[4:]] = value
                 continue
@@ -454,7 +454,7 @@
             if control == 'wire-color':
                 value = str(value[0]) + ':' + str(value[1]) + ':' + str(value[2])
             elif control in ('mode', 'style', 'shading'):
-                if not data['draw'].has_key('mode'):
+                if 'mode' not in data['draw']:
                     data['draw']['mode'] = {}
                 continue
@@ -502,7 +502,7 @@
             else:
                 data['draw'][control] = { 'value' : value }
-            if not data['draw'][control].has_key('update'):
+            if 'update' not in data['draw'][control]:
                 data['draw'][control]['update'] = None
@@ -558,7 +558,7 @@
         data['height'] = { 'value' : UserSettings.Get(group='nviz', key='vector',
                                                       subkey=['lines', 'height']) }
-        if data.has_key('object'):
+        if 'object' in data:
             for attrb in ('color', 'width', 'mode', 'height'):
                 data[attrb]['update'] = None
@@ -590,7 +590,7 @@
                                                       subkey=['points', 'height']) }
             for attrb in ('size', 'width', 'marker',
                           'color', 'surface', 'height'):
@@ -809,7 +809,7 @@
                 vdigit = mapTree.GetPyData(item)[0]['vdigit']
                 if vdigit:
                     self.file.write('%s<vdigit>\n' % (' ' * self.indent))
-                    if vdigit.has_key('geomAttr'):
+                    if 'geomAttr' in vdigit:
                         self.indent += 4
                         for type, val in vdigit['geomAttr'].iteritems():
                             units = ''
@@ -838,7 +838,7 @@
         @param data Nviz layer properties
-        if not data.has_key('object'): # skip disabled
+        if 'object' not in data: # skip disabled
             return
         self.indent += 4
@@ -864,12 +864,12 @@
             # draw mode
             if attrb == 'draw':
                 self.file.write('%s<%s' %(' ' * self.indent, attrb))
-                if data[attrb].has_key('mode'):
+                if 'mode' in data[attrb]:
                     for tag, value in data[attrb]['mode']['desc'].iteritems():
                         self.file.write(' %s="%s"' % (tag, value))
                 self.file.write('>\n') # <draw ...>
-                if data[attrb].has_key('resolution'):
+                if 'resolution' in data[attrb]:
                     self.indent += 4
                     for type in ('coarse', 'fine'):
                         self.file.write('%s<resolution type="%s">\n' % (' ' * self.indent, type))
@@ -879,7 +879,7 @@
                         self.indent -= 4
                         self.file.write('%s</resolution>\n' % (' ' * self.indent))
-                if data[attrb].has_key('wire-color'):
+                if 'wire-color' in data[attrb]:
                     self.file.write('%s<wire_color>\n' % (' ' * self.indent))
                     self.indent += 4
                     self.file.write('%s<value>%s</value>\n' % (' ' * self.indent,
@@ -917,7 +917,7 @@
             if len(data[attrb]) < 1: # skip empty attributes
                 continue
-            if not data[attrb].has_key('object'): # skip disabled
+            if 'object' not in data[attrb]: # skip disabled
                 continue
             if attrb == 'lines':
                 self.file.write('%s<v%s>\n' % (' ' * self.indent, attrb))
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdigit.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -394,7 +394,7 @@
         offset = Vect_get_line_offset(self.poMapInfo, line)
-        if not self.changesets.has_key(changeset):
+        if changeset not in self.changesets:
             self.changesets[changeset] = list()
             self.changesetCurrent = changeset
@@ -1277,7 +1277,7 @@
                 id = c_int()
                 Vect_cidx_get_cat_by_index(self.poMapInfo, i, j,
                                            byref(cat), byref(type), byref(id))
-                if self.cats.has_key(field):
+                if field in self.cats:
                     if cat > self.cats[field]:
                         self.cats[field] = cat.value
                 else:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdriver.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdriver.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxvdriver.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -951,7 +951,7 @@
                 Vect_read_line(self.poMapInfo, BPoints, None, line2)
                 if Vect_line_check_duplicate(APoints, BPoints, WITHOUT_Z):
-                    if not ids.has_key(i):
+                    if i not in ids:
                         ids[i] = list()
                         ids[i].append((line1, self._getCatString(line1)))
                         self.selected['idsDupl'].append(line1)
@@ -971,7 +971,7 @@
         catsDict = dict()
         for i in range(cats.n_cats):
             layer = cats.field[i]
-            if not catsDict.has_key(layer):
+            if layer not in catsDict:
                 catsDict[layer] = list()
             catsDict[layer].append(cats.cat[i])
Modified: grass/branches/develbranch_6/gui/wxpython/icons/icon.py
--- grass/branches/develbranch_6/gui/wxpython/icons/icon.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/icons/icon.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -57,7 +57,7 @@
     if iconTheme != 'grass':
         # use default icons if no icon is available
         for key, img in iconSet.iteritems():
-            if not iconSet.has_key(key) or \
+            if key not in iconSet or \
                     iconSet[key] is None: # add key
                 iconSet[key] = img
Modified: grass/branches/develbranch_6/gui/wxpython/support/update_menudata.py
--- grass/branches/develbranch_6/gui/wxpython/support/update_menudata.py	2011-04-04 11:31:19 UTC (rev 45844)
+++ grass/branches/develbranch_6/gui/wxpython/support/update_menudata.py	2011-04-04 11:32:36 UTC (rev 45845)
@@ -77,14 +77,14 @@
         for child in node.getchildren():
             item[child.tag] = child.text
-        if not item.has_key('command'):
+        if 'command' not in item:
             continue
         if item['command'] in ignore:
             continue
         module = item['command'].split(' ')[0]
-        if not modules.has_key(module):
+        if module not in modules:
             grass.warning("'%s' not found in modules" % item['command'])
             continue
@@ -95,7 +95,7 @@
         if node.find('handler').text == 'OnMenuCmd':
             node.find('help').text = desc
-        if not modules[module].has_key('keywords'):
+        if 'keywords' not in modules[module]:
             grass.warning('%s: keywords missing' % module)
         else:
             if node.find('keywords') is None:
