[GRASS-SVN] r45851 - in grass/trunk/imagery: i.biomass i.latlong
i.modis.qc
svn_grass at osgeo.org
Mon Apr 4 15:37:06 EDT 2011
Author: neteler
Date: 2011-04-04 12:37:06 -0700 (Mon, 04 Apr 2011)
New Revision: 45851
grass/trunk/imagery/i.biomass/main.c
grass/trunk/imagery/i.latlong/i.latlong.html
grass/trunk/imagery/i.latlong/main.c
grass/trunk/imagery/i.modis.qc/main.c
msg cosmetics
Modified: grass/trunk/imagery/i.biomass/main.c
--- grass/trunk/imagery/i.biomass/main.c 2011-04-04 19:32:59 UTC (rev 45850)
+++ grass/trunk/imagery/i.biomass/main.c 2011-04-04 19:37:06 UTC (rev 45851)
@@ -52,7 +52,7 @@
G_add_keyword(_("fpar"));
G_add_keyword(_("yield"));
module->description =
- _("Computes biomass growth, precursor of crop yield calculation");
+ _("Computes biomass growth, precursor of crop yield calculation.");
/* Define the different options */
input1 = G_define_standard_option(G_OPT_R_INPUT);
Modified: grass/trunk/imagery/i.latlong/i.latlong.html
--- grass/trunk/imagery/i.latlong/i.latlong.html 2011-04-04 19:32:59 UTC (rev 45850)
+++ grass/trunk/imagery/i.latlong/i.latlong.html 2011-04-04 19:37:06 UTC (rev 45851)
@@ -1,10 +1,12 @@
<H2>DESCRIPTION</H2>
-<EM>i.latlong</EM> creates a latitude (degree decimal) map, or longitude if the -l flag is used, from any map in any projection using PROJ.4 library.
-This is an input to r.sun and i.evapo.potrad.
+<EM>i.latlong</EM> creates a latitude (degree decimal) map, or longitude
+if the -l flag is used, from any map in any projection using PROJ.4 library.
+This is an input to <em>r.sun</em> and <em>i.evapo.potrad</em>.
<H2>NOTES</H2>
-The proj <A HREF="http://www.remotesensing.org/proj/">website</A>.
+The PROJ.4 <A HREF="http://trac.osgeo.org/proj/">website</A>.
<H2>TODO</H2>
Datum transform is not implemented, the same datum is taken as output.
Modified: grass/trunk/imagery/i.latlong/main.c
--- grass/trunk/imagery/i.latlong/main.c 2011-04-04 19:32:59 UTC (rev 45850)
+++ grass/trunk/imagery/i.latlong/main.c 2011-04-04 19:37:06 UTC (rev 45851)
@@ -57,7 +57,7 @@
G_add_keyword(_("latitude"));
G_add_keyword(_("longitude"));
G_add_keyword(_("projection"));
- module->description = _("creates a latitude/longitude map");
+ module->description = _("Creates a latitude/longitude map.");
Modified: grass/trunk/imagery/i.modis.qc/main.c
--- grass/trunk/imagery/i.modis.qc/main.c 2011-04-04 19:32:59 UTC (rev 45850)
+++ grass/trunk/imagery/i.modis.qc/main.c 2011-04-04 19:37:06 UTC (rev 45851)
@@ -121,7 +121,7 @@
G_add_keyword(_("Vegetation"));
G_add_keyword(_("Modis"));
- _("Extract quality control parameters from Modis QC layers");
+ _("Extract quality control parameters from Modis QC layers.");
input = G_define_option();
