[GRASS-SVN] r45877 - grass/trunk/scripts/v.in.mapgen
Fri Apr 8 23:48:14 EDT 2011
Author: hamish
Date: 2011-04-08 20:48:14 -0700 (Fri, 08 Apr 2011)
New Revision: 45877
   grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
use %.15g instead of %.8f (#335)
Modified: grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
--- grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py	2011-04-09 03:28:08 UTC (rev 45876)
+++ grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py	2011-04-09 03:48:14 UTC (rev 45877)
@@ -116,7 +116,7 @@
 		if points != []:
 		    outf.write("L %d\n" % len(points))
 		    for point in points:
-			outf.write(" %.8f %.8f %.8f\n" % tuple(map(float,point)))
+			outf.write(" %.15g %.15g %.15g\n" % tuple(map(float,point)))
 		points = []
 	    else:
 		if len(f) == 2:
@@ -127,7 +127,7 @@
                 try:
-                    outf.write(" %.8f %.8f %.8f\n" % tuple(map(float, point)))
+                    outf.write(" %.15g %.15g %.15g\n" % tuple(map(float, point)))
                 except ValueError:
                     grass.fatal(_("An error occured on line '%s', exiting.") % line.strip())
     else:
@@ -138,7 +138,7 @@
 		if points != []:
-			outf.write(" %.8f %.8f\n" % tuple(map(float,point)))
+			outf.write(" %.15g %.15g\n" % tuple(map(float,point)))
 		points = []
 	    else:
 		points.append(line.rstrip('\r\n').split('\t'))
@@ -146,7 +146,7 @@
 	if points != []:
     outf.close()
     inf.close()
