[GRASS-SVN] r45883 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Sat Apr 9 15:24:09 EDT 2011
Author: martinl
Date: 2011-04-09 12:24:09 -0700 (Sat, 09 Apr 2011)
New Revision: 45883
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
attempt to fix #1300 (WxGUI measure tool gives wrong results)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2011-04-09 18:59:47 UTC (rev 45882)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2011-04-09 19:24:09 UTC (rev 45883)
@@ -1647,32 +1647,33 @@
         if self._layerManager.notebook.GetSelection() != 1:
             self._layerManager.notebook.SetSelection(1)
         dist, (north, east) = self.MapWindow.Distance(beginpt, endpt)
         dist = round(dist, 3)
         d, dunits = self.FormatDist(dist)
         self.totaldist += dist
         td, tdunits = self.FormatDist(self.totaldist)
         strdist = str(d)
         strtotdist = str(td)
         if self.Map.projinfo['proj'] == 'xy' or 'degree' not in self.Map.projinfo['unit']:
             angle = int(math.degrees(math.atan2(north,east)) + 0.5)
             angle = 180 - angle
             if angle < 0:
                 angle = 360+angle
-            mstring = 'segment = %s %s\ttotal distance = %s %s\tbearing = %d deg' \
-                % (strdist,dunits,strtotdist,tdunits,angle)
+            mstring = '%s = %s %s\t%s = %s %s\tbearing = %d %s' \
+                % (_('segment'), strdist, dunits, _('total distance'), strtotdist, tdunits,
+                   angle, _('deg'))
         else:
-            mstring = 'segment = %s %s\ttotal distance = %s %s' \
-                % (strdist,dunits,strtotdist,tdunits)
+            mstring = '%s = %s %s\t%s = %s %s' \
+                % (_('segment'), strdist, dunits, _('total distance'), strtotdist, tdunits)
         self._layerManager.goutput.WriteLog(mstring)
         return dist
     def Profile(self, event):
@@ -1695,13 +1696,13 @@
         """!Format length numbers and units in a nice way,
         as a function of length. From code by Hamish Bowman
         Grass Development Team 2006"""
         mapunits = self.Map.projinfo['units']
         if mapunits == 'metres': mapunits = 'meters'
         outunits = mapunits
         dist = float(dist)
         divisor = 1.0
         # figure out which units to use
         if mapunits == 'meters':
             if dist > 2500.0:
@@ -1724,7 +1725,7 @@
                 divisor = (1/60.0)
             else:
                 outunits = 'deg'
         # format numbers in a nice way
         if (dist/divisor) >= 2500.0:
             outdist = round(dist/divisor)
@@ -1734,10 +1735,9 @@
             outdist = round(dist/divisor,int(math.ceil(3-math.log10(dist/divisor))))
         else:
             outdist = float(dist/divisor)
         return (outdist, outunits)
     def Histogram(self, event):
         """!Init histogram display canvas and tools
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2011-04-09 18:59:47 UTC (rev 45882)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2011-04-09 19:24:09 UTC (rev 45883)
@@ -1743,7 +1743,7 @@
         if tmpreg:
             os.environ["GRASS_REGION"] = tmpreg
-    def Distance(self, beginpt, endpt, screen=True):
+    def Distance(self, beginpt, endpt, screen = True):
         """!Calculete distance
         LL-locations not supported
@@ -1754,13 +1754,14 @@
         @param endpt second point
         @param screen True for screen coordinates otherwise EN
-        x1, y1 = beginpt
-        x2, y2 = endpt
         if screen:
-            dEast  = (x2 - x1) * self.Map.region["ewres"]
-            dNorth = (y2 - y1) * self.Map.region["nsres"]
+            e1, n1 = self.Pixel2Cell(beginpt)
+            e2, n2 = self.Pixel2Cell(endpt)
         else:
-            dEast  = (x2 - x1)
+            e1, n1 = beginpt
+            e2, n2 = endpt
+        dEast  = (e2 - e1)
+        dNorth = (n2 - n1)
-        return (math.sqrt(math.pow((dEast),2) + math.pow((dNorth),2)), (dEast, dNorth))
+        return (math.sqrt(math.pow((dEast), 2) + math.pow((dNorth), 2)), (dEast, dNorth))
