[GRASS-SVN] r45911 - grass/trunk/vector/v.out.ogr
Tue Apr 12 02:53:23 EDT 2011
Author: martinl
Date: 2011-04-11 23:53:23 -0700 (Mon, 11 Apr 2011)
New Revision: 45911
   grass/trunk/vector/v.out.ogr/main.c
v.out.ogr: support transactions (major speed up)
Modified: grass/trunk/vector/v.out.ogr/main.c
--- grass/trunk/vector/v.out.ogr/main.c	2011-04-12 06:29:03 UTC (rev 45910)
+++ grass/trunk/vector/v.out.ogr/main.c	2011-04-12 06:53:23 UTC (rev 45911)
@@ -308,8 +308,7 @@
     else {
 	if (otype & GV_POINT)
-	    num_to_export =
-		num_to_export + Vect_get_num_primitives(&In, GV_POINT);
+	    num_to_export += Vect_get_num_primitives(&In, GV_POINT);
     if (Vect_get_num_primitives(&In, GV_LINE) < 1 && (otype & GV_LINE)) {
@@ -318,8 +317,7 @@
     else {
 	if (otype & GV_LINE)
-	    num_to_export =
-		num_to_export + Vect_get_num_primitives(&In, GV_LINE);
+	    num_to_export += Vect_get_num_primitives(&In, GV_LINE);
     if (Vect_get_num_primitives(&In, GV_BOUNDARY) < 1 &&
@@ -329,8 +327,7 @@
     else {
 	if (otype & GV_BOUNDARY)
-	    num_to_export =
-		num_to_export + Vect_get_num_primitives(&In, GV_BOUNDARY);
+	    num_to_export += Vect_get_num_primitives(&In, GV_BOUNDARY);
     if (Vect_get_num_areas(&In) < 1 && (otype & GV_AREA)) {
@@ -339,7 +336,7 @@
     else {
 	if (otype & GV_AREA)
-	    num_to_export = num_to_export + Vect_get_num_areas(&In);
+	    num_to_export += Vect_get_num_areas(&In);
     if (Vect_get_num_primitives(&In, GV_CENTROID) < 1 &&
@@ -349,8 +346,7 @@
     else {
 	if (otype & GV_CENTROID)
-	    num_to_export =
-		num_to_export + Vect_get_num_primitives(&In, GV_CENTROID);
+	    num_to_export += Vect_get_num_primitives(&In, GV_CENTROID);
     if (Vect_get_num_primitives(&In, GV_FACE) < 1 && (otype & GV_FACE)) {
@@ -359,8 +355,7 @@
     else {
 	if (otype & GV_FACE)
-	    num_to_export =
-		num_to_export + Vect_get_num_primitives(&In, GV_FACE);
+	    num_to_export += Vect_get_num_primitives(&In, GV_FACE);
     if (Vect_get_num_primitives(&In, GV_KERNEL) < 1 && (otype & GV_KERNEL)) {
@@ -369,8 +364,7 @@
     else {
 	if (otype & GV_KERNEL)
-	    num_to_export =
-		num_to_export + Vect_get_num_primitives(&In, GV_KERNEL);
+	    num_to_export += Vect_get_num_primitives(&In, GV_KERNEL);
     if (Vect_get_num_volumes(&In) < 1 && (otype & GV_VOLUME)) {
@@ -379,7 +373,7 @@
     else {
 	if (otype & GV_VOLUME)
-	    num_to_export = num_to_export + Vect_get_num_volumes(&In);
+	    num_to_export += Vect_get_num_volumes(&In);
     G_debug(1, "Requested to export %d features", num_to_export);
@@ -534,7 +528,7 @@
 	else
 	    G_fatal_error(_("Unable to create OGR layer"));
     db_init_string(&dbstring);
     /* Vector attributes -> OGR fields */
@@ -644,7 +638,6 @@
     fout = fskip = nocat = noatt = nocatskip = 0;
     /* Fetch all attribute records */
     if (doatt) {
     	sprintf(buf, "SELECT * FROM %s", Fi->table);
@@ -656,8 +649,10 @@
     	      cat);
+    if (OGR_L_TestCapability(Ogr_layer, OLCTransactions))
+	OGR_L_StartTransaction(Ogr_layer);
     /* Lines (run always to count features of different type) */
     if ((otype & GV_POINTS) || (otype & GV_LINES)) {
 	G_message(_("Exporting %i features..."), Vect_get_num_lines(&In));
@@ -941,6 +936,9 @@
 	G_warning(_("Export of volumes not implemented yet. Skipping."));
+	OGR_L_CommitTransaction(Ogr_layer);
     OGR_DS_Destroy(Ogr_ds);
     Vect_close(&In);
