[GRASS-SVN] r45943 -
grass/branches/releasebranch_6_4/vector/v.out.ogr
svn_grass at osgeo.org
Wed Apr 13 09:12:21 EDT 2011
Author: martinl
Date: 2011-04-13 06:12:21 -0700 (Wed, 13 Apr 2011)
New Revision: 45943
grass/branches/releasebranch_6_4/vector/v.out.ogr/description.html
grass/branches/releasebranch_6_4/vector/v.out.ogr/main.c
v.out.ogr: sync code with devbr6
Modified: grass/branches/releasebranch_6_4/vector/v.out.ogr/description.html
--- grass/branches/releasebranch_6_4/vector/v.out.ogr/description.html 2011-04-13 13:10:38 UTC (rev 45942)
+++ grass/branches/releasebranch_6_4/vector/v.out.ogr/description.html 2011-04-13 13:12:21 UTC (rev 45943)
@@ -25,8 +25,10 @@
To export areas with holes into, e.g., a Shapefile, while keeping the
holes as holes, the flag <em>-c</em> has to be used.
+<p>
+The "-z" flag can be used to automatically export a 3D map to a 3D Shapefile, instead
+of setting the correct <em>lco=</em> option manually.
<h2>EXAMPLES</h2>
<h3>Export to Shapefile</h3>
@@ -55,6 +57,11 @@
<div class="code"><pre>
v.out.ogr input=objects_3d type=face dsn=faces_3d.shp lco="SHPT=POLYGONZ"
</pre></div>
+<p>
+Export 3D faces from GRASS vector map to Shapefile format, automatic 3D setting:
+<div class="code"><pre>
+v.out.ogr input=objects_3d type=face dsn=faces_3d.shp -z"
+</pre></div>
<h3>Export to GML</h3>
Modified: grass/branches/releasebranch_6_4/vector/v.out.ogr/main.c
--- grass/branches/releasebranch_6_4/vector/v.out.ogr/main.c 2011-04-13 13:10:38 UTC (rev 45942)
+++ grass/branches/releasebranch_6_4/vector/v.out.ogr/main.c 2011-04-13 13:12:21 UTC (rev 45943)
@@ -27,14 +27,21 @@
#include "ogr_api.h"
#include "cpl_string.h"
+/* some hard limits */
+#define SQL_BUFFER_SIZE 2000
+#define MAX_OGR_DRIVERS 2000
int fout, fskip; /* features written/ skip */
int nocat, noatt, nocatskip; /* number of features without cats/atts written/skip */
int mk_att(int cat, struct field_info *Fi, dbDriver * Driver,
- int ncol, int doatt, int nocat, OGRFeatureH Ogr_feature);
+ int ncol, int doatt, int nocat, OGRFeatureH Ogr_feature,
+ dbCursor cursor);
char *OGR_list_write_drivers();
-char OGRdrivers[2000];
+char OGRdrivers[MAX_OGR_DRIVERS];
int main(int argc, char *argv[])
@@ -42,12 +49,14 @@
int num_to_export;
char *mapset;
int field;
+ int overwrite, found;
struct GModule *module;
struct Option *in_opt, *dsn_opt, *layer_opt, *type_opt, *frmt_opt,
*field_opt, *dsco, *lco;
- struct Flag *cat_flag, *esristyle, *poly_flag, *update_flag, *nocat_flag;
- char buf[2000];
- char key1[200], key2[200];
+ struct Flag *cat_flag, *esristyle, *poly_flag, *update_flag, *nocat_flag,
+ *shapez_flag;
+ char buf[SQL_BUFFER_SIZE];
+ char key1[SQL_BUFFER_SIZE], key2[SQL_BUFFER_SIZE];
struct Key_Value *projinfo, *projunits;
struct Cell_head cellhd;
char **tokens;
@@ -66,6 +75,7 @@
dbTable *Table;
dbString dbstring;
dbColumn *Column;
+ dbCursor cursor;
/* OGR */
int drn, ogr_ftype = OFTInteger;
@@ -87,7 +97,7 @@
module = G_define_module();
module->keywords = _("vector, export");
module->description =
- _("Converts to one of the supported OGR vector formats.");
+ _("Converts GRASS vector map to one of the supported OGR vector formats.");
in_opt = G_define_standard_option(G_OPT_V_INPUT);
@@ -95,8 +105,8 @@
type_opt->options = "point,line,boundary,centroid,area,face,kernel,auto";
type_opt->answer = "line,boundary";
type_opt->description =
- _("Feature type. Combination of types is not supported "
- "by all formats.");
+ _("Feature type(s). Combinations not supported "
+ "by all output formats. Default: first type found in input.");
type_opt->guisection = _("Input");
dsn_opt = G_define_option();
@@ -168,6 +178,11 @@
esristyle->description = _("Use ESRI-style .prj file format "
"(applies to Shapefile output only)");
+ shapez_flag = G_define_flag();
+ shapez_flag->key = 'z';
+ shapez_flag->description = _("Create 3D output if input is 3D "
+ "(applies to Shapefile output only)");
poly_flag = G_define_flag();
poly_flag->key = 'p';
poly_flag->description = _("Export lines as polygons");
@@ -231,6 +246,24 @@
G_debug(3, "Adding faces to export list.");
num_types++;
+ /* this check HAS TO FOLLOW RIGHT AFTER check for GV_FACE! */
+ if (Vect_get_num_volumes(&In) > 0) {
+ G_warning(_("Volumes will be exported as sets of faces."));
+ if (num_types == 0) {
+ /* no other types yet? */
+ type_opt->answers[num_types] = strdup("volume");
+ G_debug(3, "Adding volumes to export list.");
+ num_types++;
+ else {
+ if (strcmp(type_opt->answers[num_types - 1], "face")) {
+ /* only put faces on export list if that's not the case already */
+ num_types++;
if (num_types == 0)
G_fatal_error(_("Could not determine input map's feature type(s)."));
@@ -276,6 +309,7 @@
((GV_KERNEL & otype) && (GV_AREA & otype)) ||
((GV_KERNEL & otype) && (GV_FACE & otype)) ||
((GV_KERNEL & otype) && (GV_VOLUME & otype))
G_warning(_("The combination of types is not supported"
" by all formats."));
@@ -293,6 +327,133 @@
if (Vect_get_num_islands(&In) > 0 && !cat_flag->answer)
G_warning(_("The map contains islands. To preserve them in the output map, use the -c flag"));
+ /* check what users wants to export and what's present in the map */
+ if (Vect_get_num_primitives(&In, GV_POINT) > 0 && !(otype & GV_POINTS))
+ G_warning(_("%d point(s) found, but not requested to be exported. "
+ "Verify 'type' parameter."), Vect_get_num_primitives(&In,
+ GV_POINT));
+ if (Vect_get_num_primitives(&In, GV_LINE) > 0 && !(otype & GV_LINES))
+ G_warning(_("%d line(s) found, but not requested to be exported. "
+ GV_LINE));
+ if (Vect_get_num_primitives(&In, GV_BOUNDARY) > 0 &&
+ !(otype & GV_BOUNDARY) && !(otype & GV_AREA))
+ G_warning(_("%d boundary(ies) found, but not requested to be exported. "
+ GV_BOUNDARY));
+ if (Vect_get_num_primitives(&In, GV_CENTROID) > 0 &&
+ !(otype & GV_CENTROID) && !(otype & GV_AREA))
+ G_warning(_("%d centroid(s) found, but not requested to be exported. "
+ GV_CENTROID));
+ if (Vect_get_num_areas(&In) > 0 && !(otype & GV_AREA))
+ G_warning(_("%d areas found, but not requested to be exported. "
+ "Verify 'type' parameter."), Vect_get_num_areas(&In));
+ if (Vect_get_num_primitives(&In, GV_FACE) > 0 && !(otype & GV_FACE))
+ G_warning(_("%d face(s) found, but not requested to be exported. "
+ GV_FACE));
+ if (Vect_get_num_primitives(&In, GV_KERNEL) > 0 &&
+ !(otype & GV_KERNEL) && !(otype & GV_VOLUME))
+ G_warning(_("%d kernel(s) found, but not requested to be exported. "
+ GV_KERNEL));
+ if (Vect_get_num_volumes(&In) > 0 && !(otype & GV_VOLUME))
+ G_warning(_("%d volume(s) found, but not requested to be exported. "
+ "Verify 'type' parameter."), Vect_get_num_volumes(&In));
+ /* warn and eventually abort if there is nothing to be exported */
+ num_to_export = 0;
+ if (Vect_get_num_primitives(&In, GV_POINT) < 1 && (otype & GV_POINTS)) {
+ G_warning(_("No points found, but requested to be exported. "
+ "Will skip this geometry type."));
+ else {
+ if (otype & GV_POINT)
+ num_to_export += Vect_get_num_primitives(&In, GV_POINT);
+ if (Vect_get_num_primitives(&In, GV_LINE) < 1 && (otype & GV_LINE)) {
+ G_warning(_("No lines found, but requested to be exported. "
+ else {
+ if (otype & GV_LINE)
+ num_to_export += Vect_get_num_primitives(&In, GV_LINE);
+ if (Vect_get_num_primitives(&In, GV_BOUNDARY) < 1 &&
+ (otype & GV_BOUNDARY)) {
+ G_warning(_("No boundaries found, but requested to be exported. "
+ else {
+ if (otype & GV_BOUNDARY)
+ num_to_export += Vect_get_num_primitives(&In, GV_BOUNDARY);
+ if (Vect_get_num_areas(&In) < 1 && (otype & GV_AREA)) {
+ G_warning(_("No areas found, but requested to be exported. "
+ else {
+ if (otype & GV_AREA)
+ num_to_export += Vect_get_num_areas(&In);
+ if (Vect_get_num_primitives(&In, GV_CENTROID) < 1 &&
+ (otype & GV_CENTROID)) {
+ G_warning(_("No centroids found, but requested to be exported. "
+ else {
+ if (otype & GV_CENTROID)
+ num_to_export += Vect_get_num_primitives(&In, GV_CENTROID);
+ if (Vect_get_num_primitives(&In, GV_FACE) < 1 && (otype & GV_FACE)) {
+ G_warning(_("No faces found, but requested to be exported. "
+ else {
+ if (otype & GV_FACE)
+ num_to_export += Vect_get_num_primitives(&In, GV_FACE);
+ if (Vect_get_num_primitives(&In, GV_KERNEL) < 1 && (otype & GV_KERNEL)) {
+ G_warning(_("No kernels found, but requested to be exported. "
+ else {
+ if (otype & GV_KERNEL)
+ num_to_export += Vect_get_num_primitives(&In, GV_KERNEL);
+ if (Vect_get_num_volumes(&In) < 1 && (otype & GV_VOLUME)) {
+ G_warning(_("No volumes found, but requested to be exported. "
+ else {
+ if (otype & GV_VOLUME)
+ num_to_export += Vect_get_num_volumes(&In);
+ G_debug(1, "Requested to export %d geometries", num_to_export);
+ if (num_to_export < 1) {
+ G_warning(_("Nothing to export"));
+ exit(EXIT_SUCCESS);
/* fetch PROJ info */
G_get_default_window(&cellhd);
if (cellhd.proj == PROJECTION_XY)
@@ -349,6 +510,28 @@
G_fatal_error(_("Unable to open OGR data source '%s'"),
dsn_opt->answer);
+ /* check if OGR layer exists */
+ overwrite = G_check_overwrite(argc, argv);
+ found = FALSE;
+ for (i = 0; i < OGR_DS_GetLayerCount(Ogr_ds); i++) {
+ Ogr_layer = OGR_DS_GetLayer(Ogr_ds, i);
+ Ogr_field = OGR_L_GetLayerDefn(Ogr_layer);
+ if (strcmp(OGR_FD_GetName(Ogr_field), layer_opt->answer))
+ continue;
+ found = TRUE;
+ if (!overwrite) {
+ G_fatal_error(_("Layer <%s> already exists in OGR data source '%s'"),
+ layer_opt->answer, dsn_opt->answer);
+ else if (overwrite) {
+ G_warning(_("OGR layer <%s> already exists and will be overwritten"),
+ layer_opt->answer);
+ OGR_DS_DeleteLayer(Ogr_ds, i);
+ break;
/* parse layer creation options */
i = 0;
while (lco->answers[i]) {
@@ -359,6 +542,38 @@
i++;
+ /* Automatically append driver options for 3D output to
+ layer creation options if 'z' is given. */
+ if ((shapez_flag->answer) && (Vect_is_3d(&In)) &&
+ (strcmp(frmt_opt->answer, "ESRI_Shapefile") == 0)) {
+ /* find right option */
+ char shape_geom[20];
+ if ((otype & GV_POINTS) || (otype & GV_KERNEL))
+ sprintf(shape_geom, "POINTZ");
+ if ((otype & GV_LINES))
+ sprintf(shape_geom, "ARCZ");
+ if ((otype & GV_AREA) || (otype & GV_FACE) || (otype & GV_VOLUME))
+ sprintf(shape_geom, "POLYGONZ");
+ /* check if the right LCO is already present */
+ const char *shpt;
+ shpt = CSLFetchNameValue(papszLCO, "SHPT");
+ if ((!shpt)) {
+ /* Not set at all? Good! */
+ papszLCO = CSLSetNameValue(papszLCO, "SHPT", shape_geom);
+ else {
+ if (strcmp(shpt, shape_geom) != 0) {
+ /* Set but to a different value? Override! */
+ G_warning(_("Overriding existing user-defined 'SHPT=' LCO."));
+ /* Set correct LCO for this geometry type */
/* check if the map is 3d */
if (Vect_is_3d(&In)) {
/* specific check for shp */
@@ -369,7 +584,7 @@
if (!shpt || shpt[strlen(shpt) - 1] != 'Z') {
G_warning(_("Vector map <%s> is 3D. "
"Use format specific layer creation options (parameter 'lco') "
- "to export in 3D rather than 2D (default)"),
+ "or '-z' flag to export in 3D rather than 2D (default)"),
in_opt->answer);
@@ -486,127 +701,23 @@
fout = fskip = nocat = noatt = nocatskip = 0;
- /* check what users wants to export and what's present in the map */
- if (Vect_get_num_primitives(&In, GV_POINT) > 0 && !(otype & GV_POINTS))
- G_warning(_("%d point(s) found, but not requested to be exported. "
- "Verify 'type' parameter."), Vect_get_num_primitives(&In,
- GV_POINT));
- if (Vect_get_num_primitives(&In, GV_LINE) > 0 && !(otype & GV_LINES))
- G_warning(_("%d line(s) found, but not requested to be exported. "
- GV_LINE));
- if (Vect_get_num_primitives(&In, GV_BOUNDARY) > 0 &&
- !(otype & GV_BOUNDARY) && !(otype & GV_AREA))
- G_warning(_("%d boundary(ies) found, but not requested to be exported. "
- GV_BOUNDARY));
- if (Vect_get_num_primitives(&In, GV_CENTROID) > 0 &&
- !(otype & GV_CENTROID) && !(otype & GV_AREA))
- G_warning(_("%d centroid(s) found, but not requested to be exported. "
- GV_CENTROID));
- if (Vect_get_num_areas(&In) > 0 && !(otype & GV_AREA))
- G_warning(_("%d areas found, but not requested to be exported. "
- "Verify 'type' parameter."), Vect_get_num_areas(&In));
- if (Vect_get_num_primitives(&In, GV_FACE) > 0 && !(otype & GV_FACE))
- G_warning(_("%d faces found, but not requested to be exported. "
- GV_FACE));
- if (Vect_get_num_primitives(&In, GV_KERNEL) > 0 &&
- !(otype & GV_KERNEL) && !(otype & GV_VOLUME))
- G_warning(_("%d kernel(s) found, but not requested to be exported. "
- GV_KERNEL));
- /* warn and eventually abort if there is nothing to be exported */
- num_to_export = 0;
- if (Vect_get_num_primitives(&In, GV_POINT) < 1 && (otype & GV_POINTS)) {
- G_warning(_("No points found, but requested to be exported. "
- "Will skip this geometry type."));
+ /* Fetch all attribute records */
+ if (doatt) {
+ sprintf(buf, "SELECT * FROM %s", Fi->table);
+ G_debug(2, "SQL: %s", buf);
+ db_set_string(&dbstring, buf);
+ if (db_open_select_cursor
+ (Driver, &dbstring, &cursor, DB_SEQUENTIAL) != DB_OK) {
+ G_fatal_error(_("Cannot select attributes for cat = %d"), cat);
- else {
- if (otype & GV_POINT)
- num_to_export =
- num_to_export + Vect_get_num_primitives(&In, GV_POINT);
- if (Vect_get_num_primitives(&In, GV_LINE) < 1 && (otype & GV_LINE)) {
- G_warning(_("No lines found, but requested to be exported. "
- else {
- if (otype & GV_LINE)
- num_to_export =
- num_to_export + Vect_get_num_primitives(&In, GV_LINE);
+ if (OGR_L_TestCapability(Ogr_layer, OLCTransactions))
+ OGR_L_StartTransaction(Ogr_layer);
- if (Vect_get_num_primitives(&In, GV_BOUNDARY) < 1 &&
- (otype & GV_BOUNDARY)) {
- G_warning(_("No boundaries found, but requested to be exported. "
- else {
- if (otype & GV_BOUNDARY)
- num_to_export =
- num_to_export + Vect_get_num_primitives(&In, GV_BOUNDARY);
- if (Vect_get_num_areas(&In) < 1 && (otype & GV_AREA)) {
- G_warning(_("No areas found, but requested to be exported. "
- else {
- if (otype & GV_AREA)
- num_to_export = num_to_export + Vect_get_num_areas(&In);
- if (Vect_get_num_primitives(&In, GV_CENTROID) < 1 &&
- (otype & GV_CENTROID)) {
- G_warning(_("No centroids found, but requested to be exported. "
- else {
- if (otype & GV_CENTROID)
- num_to_export =
- num_to_export + Vect_get_num_primitives(&In, GV_CENTROID);
- if (Vect_get_num_primitives(&In, GV_FACE) < 1 && (otype & GV_FACE)) {
- G_warning(_("No faces found, but requested to be exported. "
- else {
- if (otype & GV_FACE)
- num_to_export =
- num_to_export + Vect_get_num_primitives(&In, GV_FACE);
- if (Vect_get_num_primitives(&In, GV_KERNEL) < 1 && (otype & GV_KERNEL)) {
- G_warning(_("No kernels found, but requested to be exported. "
- else {
- if (otype & GV_KERNEL)
- num_to_export =
- num_to_export + Vect_get_num_primitives(&In, GV_KERNEL);
- G_debug(1, "Requested to export %d geometries", num_to_export);
- if (num_to_export < 1) {
- G_warning(_("Nothing to export"));
- exit(EXIT_SUCCESS);
/* Lines (run always to count features of different type) */
if ((otype & GV_POINTS) || (otype & GV_LINES)) {
- G_message(_("Exporting %i points/lines..."), Vect_get_num_lines(&In));
+ G_message(_("Exporting %i geometries..."), Vect_get_num_lines(&In));
for (i = 1; i <= Vect_get_num_lines(&In); i++) {
G_percent(i, Vect_get_num_lines(&In), 1);
@@ -678,7 +789,7 @@
mk_att(cat, Fi, Driver, ncol, doatt, nocat_flag->answer,
- Ogr_feature);
+ Ogr_feature, cursor);
OGR_L_CreateFeature(Ogr_layer, Ogr_feature);
OGR_G_DestroyGeometry(Ogr_geometry);
@@ -753,7 +864,7 @@
- Ogr_feature);
@@ -814,7 +925,7 @@
- Ogr_feature);
@@ -826,8 +937,7 @@
/* Kernels */
if (otype & GV_KERNEL) {
- G_message(_("Exporting %i kernels..."),
- Vect_get_num_primitives(&In, GV_KERNEL));
+ G_message(_("Exporting %i kernels..."), Vect_get_num_kernels(&In));
@@ -870,7 +980,7 @@
- Ogr_feature);
@@ -885,18 +995,25 @@
NOTE: We can probably just merge this with faces export function.
Except for GRASS, which output format would know the difference?
+ if ((otype & GV_VOLUME)) {
+ G_message(_("Exporting %i volumes..."), Vect_get_num_volumes(&In));
+ G_warning(_("Export of volumes not implemented yet. Skipping."));
+ OGR_L_CommitTransaction(Ogr_layer);
OGR_DS_Destroy(Ogr_ds);
Vect_close(&In);
if (doatt) {
+ db_close_cursor(&cursor);
db_close_database(Driver);
db_shutdown_driver(Driver);
/* Summary */
- G_message(_("%d features written"), fout);
if (nocat > 0)
G_warning(_("%d features without category were written"), nocat);
if (noatt > 0)
@@ -913,20 +1030,21 @@
G_warning ("%d features of different type skip", fskip);
+ G_done_msg(_("%d features written to <%s> (%s)."), fout,
+ layer_opt->answer, frmt_opt->answer);
exit(EXIT_SUCCESS);
int mk_att(int cat, struct field_info *Fi, dbDriver * Driver, int ncol,
- int doatt, int nocat, OGRFeatureH Ogr_feature)
+ int doatt, int nocat, OGRFeatureH Ogr_feature, dbCursor cursor)
int j, ogrfieldnum;
- char buf[2000];
int colsqltype, colctype, more;
dbTable *Table;
dbString dbstring;
dbColumn *Column;
- dbCursor cursor;
dbValue *Value;
G_debug(2, "mk_att() cat = %d, doatt = %d", cat, doatt);
@@ -944,66 +1062,59 @@
/* Read & set attributes */
if (cat >= 0) { /* Line with category */
if (doatt) {
- sprintf(buf, "SELECT * FROM %s WHERE %s = %d", Fi->table, Fi->key,
- cat);
- G_debug(2, "SQL: %s", buf);
- db_set_string(&dbstring, buf);
- if (db_open_select_cursor
- (Driver, &dbstring, &cursor, DB_SEQUENTIAL) != DB_OK) {
- G_fatal_error(_("Cannot select attributes for cat = %d"),
- cat);
- else {
+ if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
+ G_fatal_error(_("Unable to fetch data from table"));
+ if (!more) {
+ /* start from the beginning in case multiple grass vector features
+ * share the same category */
- if (!more) {
- /* start from the beginning in case multiple grass vector features
- * share the same category */
- if (db_fetch(&cursor, DB_NEXT, &more) != DB_OK)
- G_fatal_error(_("Unable to fetch data from table"));
- if (!more) {
- /* G_warning ("No database record for cat = %d", cat); */
- /* Set at least key column to category */
- if (!nocat) {
- ogrfieldnum =
- OGR_F_GetFieldIndex(Ogr_feature, Fi->key);
- OGR_F_SetFieldInteger(Ogr_feature, ogrfieldnum, cat);
- noatt++;
- else {
- G_fatal_error(_("No database record for cat = %d and export of 'cat' disabled"),
- cat);
+ if (!more) {
+ /* G_warning ("No database record for cat = %d", cat); */
+ /* Set at least key column to category */
+ if (!nocat) {
+ ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature, Fi->key);
+ OGR_F_SetFieldInteger(Ogr_feature, ogrfieldnum, cat);
+ noatt++;
else {
- Table = db_get_cursor_table(&cursor);
- for (j = 0; j < ncol; j++) {
- Column = db_get_table_column(Table, j);
- Value = db_get_column_value(Column);
- db_convert_column_value_to_string(Column, &dbstring); /* for debug only */
- G_debug(2, "col %d : val = %s", j,
- db_get_string(&dbstring));
+ G_fatal_error(_("No database record for cat = %d and export of 'cat' disabled"),
+ cat);
+ else {
+ Table = db_get_cursor_table(&cursor);
+ for (j = 0; j < ncol; j++) {
+ Column = db_get_table_column(Table, j);
+ Value = db_get_column_value(Column);
+ db_convert_column_value_to_string(Column, &dbstring); /* for debug only */
+ G_debug(2, "col %d : val = %s", j,
+ db_get_string(&dbstring));
- colsqltype = db_get_column_sqltype(Column);
- colctype = db_sqltype_to_Ctype(colsqltype);
- G_debug(2, " colctype = %d", colctype);
+ colsqltype = db_get_column_sqltype(Column);
+ colctype = db_sqltype_to_Ctype(colsqltype);
+ G_debug(2, " colctype = %d", colctype);
- ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature,
- db_get_column_name
- (Column));
+ db_get_column_name
+ (Column));
- /* Reset */
- if ( ( ( nocat ) && (strcmp(Fi->key, db_get_column_name(Column)) == 0) ) == 0 ) {
- /* if this is 'cat', then execute the following only if the '-s' flag was NOT given*/
- OGR_F_UnsetField(Ogr_feature, ogrfieldnum);
+ /* Reset */
+ if (((nocat) &&
+ (strcmp(Fi->key, db_get_column_name(Column)) ==
+ 0)) == 0) {
+ /* if this is 'cat', then execute the following only if the '-s' flag was NOT given */
+ OGR_F_UnsetField(Ogr_feature, ogrfieldnum);
- /* prevent writing NULL values */
- if (!db_test_value_isnull(Value)) {
- if ( ( (nocat) && (strcmp(Fi->key, db_get_column_name(Column)) == 0) ) == 0 ) {
+ /* prevent writing NULL values */
+ if (!db_test_value_isnull(Value)) {
+ if (((nocat) &&
+ 0)) == 0) {
switch (colctype) {
case DB_C_TYPE_INT:
@@ -1030,10 +1141,8 @@
break;
- db_close_cursor(&cursor);
else { /* Use cat only */
@@ -1042,7 +1151,7 @@
else {
- /* G_warning ( "Line without cat of layer %d", field); */
+ /* G_warning ("Line without cat of layer %d", field); */
nocat++;
fout++;
