[GRASS-SVN] r45956 - in grass/branches/releasebranch_6_4: include lib/vector/Vlib
Wed Apr 13 15:04:37 EDT 2011
Author: martinl
Date: 2011-04-13 12:04:37 -0700 (Wed, 13 Apr 2011)
New Revision: 45956
   grass/branches/releasebranch_6_4/include/Vect.h
   grass/branches/releasebranch_6_4/lib/vector/Vlib/net.c
add Vect_net_shortest_path_coor2 for v.kernel
    (merge r45408, r45409 from devbr6)
Modified: grass/branches/releasebranch_6_4/include/Vect.h
--- grass/branches/releasebranch_6_4/include/Vect.h	2011-04-13 19:02:30 UTC (rev 45955)
+++ grass/branches/releasebranch_6_4/include/Vect.h	2011-04-13 19:04:37 UTC (rev 45956)
@@ -372,6 +372,11 @@
 				double *, struct line_pnts *, struct ilist *,
 				struct line_pnts *, struct line_pnts *,
 				double *, double *);
+int Vect_net_shortest_path_coor2(struct Map_info *, double, double, double,
+				double, double, double, double, double,
+				double *, struct line_pnts *, struct ilist *, struct ilist *,
+				struct line_pnts *, struct line_pnts *,
+				double *, double *);
 /* Miscellaneous */
 int Vect_topo_dump(struct Map_info *, FILE *);
Modified: grass/branches/releasebranch_6_4/lib/vector/Vlib/net.c
--- grass/branches/releasebranch_6_4/lib/vector/Vlib/net.c	2011-04-13 19:02:30 UTC (rev 45955)
+++ grass/branches/releasebranch_6_4/lib/vector/Vlib/net.c	2011-04-13 19:04:37 UTC (rev 45956)
@@ -17,13 +17,13 @@
  * \date 2001-2008
-#include<stdlib.h>
-#include<string.h>
-#include<fcntl.h>
-#include<grass/gis.h>
-#include<grass/dbmi.h>
-#include<grass/Vect.h>
-#include<grass/glocale.h>
+#include <stdlib.h>
+#include <string.h>
+#include <fcntl.h>
+#include <grass/gis.h>
+#include <grass/dbmi.h>
+#include <grass/Vect.h>
+#include <grass/glocale.h>
 static int From_node;		/* from node set in SP and used by clipper for first arc */
@@ -863,6 +863,39 @@
 			    struct line_pnts *TPoints, double *fdist,
 			    double *tdist)
+  return Vect_net_shortest_path_coor2 ( Map, fx, fy, fz, tx, ty, tz, fmax, tmax,
+            costs, Points, List, NULL, FPoints, TPoints, fdist, tdist );
+   \brief Find shortest path on network between 2 points given by coordinates.
+   \param Map vector map
+   \param fx,fy,fz from point x coordinate (z ignored)
+   \param tx,ty,tz to point x coordinate (z ignored)
+   \param fmax maximum distance to the network from 'from'
+   \param tmax maximum distance to the network from 'to'
+   \param costs pointer where to store costs on the network (or NULL)
+   \param Points pointer to the structure where to store vertices of shortest path (or NULL)
+   \param List pointer to the structure where list of lines on the network is stored (or NULL)
+   \param List pointer to the structure where list of nodes on the network is stored (or NULL)
+   \param FPoints pointer to the structure where to store line from 'from' to first network node (or NULL)
+   \param TPoints pointer to the structure where to store line from last network node to 'to' (or NULL)
+   \param fdist distance from 'from' to the net (or NULL)
+   \param tdist distance from 'to' to the net (or NULL)
+   \return 1 OK, 0 not reachable
+int
+Vect_net_shortest_path_coor2(struct Map_info *Map,
+			    double fx, double fy, double fz, double tx,
+			    double ty, double tz, double fmax, double tmax,
+			    double *costs, struct line_pnts *Points,
+			    struct ilist *List, struct ilist *NodesList,
+                            struct line_pnts *FPoints,
+			    struct line_pnts *TPoints, double *fdist,
+			    double *tdist)
     int fnode[2], tnode[2];	/* nearest nodes, *node[1] is 0 if only one was found */
     double fcosts[2], tcosts[2], cur_cst;	/* costs to nearest nodes on the network */
     int nfnodes, ntnodes, fline, tline;
@@ -872,6 +905,11 @@
     int reachable, shortcut;
     int i, j, fn = 0, tn = 0;
+    /* from/to_point_node is set if from/to point projected to line
+     *falls exactly on node (shortcut -> fline == tline) */
+    int from_point_node = 0;
+    int to_point_node = 0;
     G_debug(3, "Vect_net_shortest_path_coor()");
     if (first) {
@@ -900,6 +938,8 @@
 	Vect_reset_line(FPoints);
     if (TPoints)
 	Vect_reset_line(TPoints);
+    if (NodesList != NULL)
+	Vect_reset_list(NodesList);
     /* Find nearest nodes */
     fnode[0] = fnode[1] = tnode[0] = tnode[1] = 0;
@@ -911,6 +951,10 @@
     if (nfnodes == 0)
 	return 0;
+    if ( nfnodes == 1 && fPoints[0]->n_points < 3 ) {
+        from_point_node = fnode[0];
     ntnodes =
 	Vect_net_nearest_nodes(Map, tx, ty, tz, GV_BACKWARD, tmax,
 			       &(tnode[0]), &(tnode[1]), &tline, &(tcosts[0]),
@@ -918,12 +962,21 @@
     if (ntnodes == 0)
 	return 0;
+    if ( ntnodes == 1 && tPoints[0]->n_points < 3 ) {
+        to_point_node = tnode[0];
     G_debug(3, "fline = %d tline = %d", fline, tline);
     reachable = shortcut = 0;
     cur_cst = PORT_DOUBLE_MAX;
     /* It may happen, that 2 points are at the same line. */
+    /* TODO?: it could also happen that fline != tline but both points are on the same
+     * line if they fall on node but a different line was found. This case is correctly
+     * handled as normal non shortcut, but it could be added here. In that case
+     * NodesList collection must be changed */
     if (fline == tline && (nfnodes > 1 || ntnodes > 1)) {
 	double len, flen, tlen, c, fseg, tseg;
 	double fcx, fcy, fcz, tcx, tcy, tcz;
@@ -1013,8 +1066,28 @@
 	if (shortcut) {
 	    if (Points)
 		Vect_append_points(Points, SPoints, GV_FORWARD);
+            if (NodesList) {
+                /* Check if from/to point projected to line falls on node and
+                 *add it to the list */
+                if (from_point_node > 0)
+		    Vect_list_append(NodesList, from_point_node);
+                if (to_point_node > 0)
+		    Vect_list_append(NodesList, to_point_node);
 	else {
+            if (NodesList) {
+                /* it can happen that starting point falls on node but SP starts
+                 * form the other node, add it in that case,
+                 * similarly for to point below */
+                if (from_point_node > 0 && from_point_node != fnode[fn]) {
+                /* add starting net SP search node */
+                Vect_list_append(NodesList, fnode[fn]);
 	    ret =
 		Vect_net_shortest_path(Map, fnode[fn], tnode[tn], LList,
 				       NULL);
@@ -1040,7 +1113,18 @@
 		    else
 			Vect_append_points(Points, APoints, GV_BACKWARD);
+                if (NodesList) {
+                    int node, node1, node2;
+                    Vect_get_line_nodes(Map, abs(line), &node1, &node2);
+                    /* add the second node, the first of first segmet was alread added */
+                    if (line > 0)
+			node = node2;
+                    else
+			node = node1;
+                    Vect_list_append(NodesList, node);
 		if (List)
 		    Vect_list_append(List, line);
@@ -1050,6 +1134,12 @@
 	    if (TPoints)
 		Vect_append_points(TPoints, tPoints[tn], GV_FORWARD);
+            if (NodesList) {
+                if (to_point_node > 0 && to_point_node != tnode[tn]) {
 	if (costs)
