[GRASS-SVN] r46078 - grass/branches/releasebranch_6_4/lib/vector/Vlib
Fri Apr 22 02:58:47 EDT 2011
Author: mmetz
Date: 2011-04-21 23:58:47 -0700 (Thu, 21 Apr 2011)
New Revision: 46078
   grass/branches/releasebranch_6_4/lib/vector/Vlib/buffer2.c
backport r45856
Modified: grass/branches/releasebranch_6_4/lib/vector/Vlib/buffer2.c
--- grass/branches/releasebranch_6_4/lib/vector/Vlib/buffer2.c	2011-04-22 06:57:59 UTC (rev 46077)
+++ grass/branches/releasebranch_6_4/lib/vector/Vlib/buffer2.c	2011-04-22 06:58:47 UTC (rev 46078)
@@ -485,7 +485,7 @@
     /* close the output line */
     Vect_append_point(nPoints, nPoints->x[0], nPoints->y[0], nPoints->z[0]);
-    /*    Vect_line_prune ( nPoints ); */
+    Vect_line_prune ( nPoints );
@@ -533,7 +533,11 @@
     eangle = atan2(vert->y - vert0->y, vert->x - vert0->x);
     while (1) {
-	Vect_append_point(nPoints, vert0->x, vert0->y, 0);
+	if (nPoints->n_points > 0 && (nPoints->x[nPoints->n_points - 1] != vert0->x ||
+	    nPoints->y[nPoints->n_points - 1] != vert0->y))
+	    Vect_append_point(nPoints, vert0->x, vert0->y, 0);
+	else
 	G_debug(4, "ec: v0=%d, v=%d, eside=%d, edge->v1=%d, edge->v2=%d", v0,
 		v, eside, edge->v1, edge->v2);
 	G_debug(4, "ec: append point x=%.18f y=%.18f", vert0->x, vert0->y);
@@ -621,6 +625,7 @@
 	eangle = vert0->angles[opt_j];
     Vect_append_point(nPoints, vert->x, vert->y, 0);
+    Vect_line_prune(nPoints);
     G_debug(4, "ec: append point x=%.18f y=%.18f", vert->x, vert->y);
     return;
@@ -886,14 +891,32 @@
     res = extract_inner_contour(pg2, &winding, cPoints);
     while (res != 0) {
 	if (winding == 0) {
-	    if (!Vect_point_in_poly(cPoints->x[0], cPoints->y[0], area_outer)) {
-		if (Vect_get_point_in_poly(cPoints, &px, &py) != 0)
-		    G_fatal_error(_("Vect_get_point_in_poly() failed"));
-		if (!point_in_buf(area_outer, px, py, da, db, dalpha)) {
-		    add_line_to_array(cPoints, &arrPoints, &count, &allocated,
-				      more);
-		    cPoints = Vect_new_line_struct();
+	    int check_poly = 1;
+	    double area_size;
+	    dig_find_area_poly(cPoints, &area_size);
+	    if (area_size == 0) {
+		G_warning(_("zero area size"));
+		check_poly = 0;
+	    if (cPoints->x[0] != cPoints->x[cPoints->n_points - 1] ||
+		cPoints->y[0] != cPoints->y[cPoints->n_points - 1]) {
+		G_warning(_("Line was not closed"));
+		check_poly = 0;
+	    if (check_poly && !Vect_point_in_poly(cPoints->x[0], cPoints->y[0], area_outer)) {
+		if (Vect_get_point_in_poly(cPoints, &px, &py) == 0) {
+		    if (!point_in_buf(area_outer, px, py, da, db, dalpha)) {
+			add_line_to_array(cPoints, &arrPoints, &count, &allocated,
+					  more);
+			cPoints = Vect_new_line_struct();
+		else {
+		    G_warning(_("Vect_get_point_in_poly() failed"));
@@ -915,18 +938,36 @@
 	while (res != 0) {
 	    if (winding == -1) {
+		double area_size;
+		    check_poly = 0;
+		    check_poly = 0;
 		/* we need to check if the area is in the buffer.
 		   I've simplfied convolution_line(), so that it runs faster,
 		   however that leads to ocasional problems */
-		if (Vect_point_in_poly
+		if (check_poly && Vect_point_in_poly
 		    (cPoints->x[0], cPoints->y[0], area_isles[i])) {
-		    if (!point_in_buf(area_isles[i], px, py, da, db, dalpha)) {
-					  &allocated, more);
+			if (!point_in_buf(area_isles[i], px, py, da, db, dalpha)) {
+					      &allocated, more);
+		    else {
