[GRASS-SVN] r46118 - grass-addons/gui/wxpython/wx.psmap/gui_modules
Wed Apr 27 11:51:08 EDT 2011
Author: annakrat
Date: 2011-04-27 08:51:08 -0700 (Wed, 27 Apr 2011)
New Revision: 46118
   grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py
   grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap_dialogs.py
wx.psmap: remove 'True if condition else False' construction (not available for Python 2.4)
Modified: grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py
--- grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py	2011-04-27 09:17:12 UTC (rev 46117)
+++ grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap.py	2011-04-27 15:51:08 UTC (rev 46118)
@@ -479,8 +479,12 @@
                 s = '.' + s
             suffix.append(s)
         raster = self.instruction.FindInstructionByType('raster')
-        rasterId = raster.id if raster else None
+        if raster:
+            rasterId = raster.id
+        else:
+            rasterId = None
         if rasterId and self.instruction[rasterId]['raster']:
             mapName = self.instruction[rasterId]['raster'].split('@')[0] + suffix[0]
         else:
@@ -575,11 +579,20 @@
     def OnZoomAll(self, event):
         self.mouseOld = self.mouse['use']
-        self.cursorOld = self.canvas.GetCursor() if self.currentPage == 0 else self.previewCanvas.GetCursor()
+        if self.currentPage == 0:
+            self.cursorOld = self.canvas.GetCursor()
+        else:
+            self.previewCanvas.GetCursor()
         self.mouse["use"] = "zoomin"
-        self.canvas.ZoomAll() if self.currentPage == 0 else self.previewCanvas.ZoomAll()
+            self.canvas.ZoomAll()
+        else:
+            self.previewCanvas.ZoomAll()
         self.mouse["use"] = self.mouseOld
-        self.canvas.SetCursor(self.cursorOld)  if self.currentPage == 0 else self.previewCanvas.SetCursor(self.cursorOld)
+            self.canvas.SetCursor(self.cursorOld)
+        else:
+            self.previewCanvas.SetCursor(self.cursorOld)
     def OnAddMap(self, event, notebook = False):
@@ -821,7 +834,11 @@
         scale = mapInitRect.Get()[2]/realWidth
         initMap = self.instruction.FindInstructionByType('initMap')
-        id = initMap.id if initMap else None
+        if initMap:
+            id = initMap.id
+        else:
+            id = None
         if not id:
             id = wx.NewId()
@@ -874,7 +891,11 @@
             if itype == 'text':
-                rot = float(self.instruction[id]['rotate']) if self.instruction[id]['rotate'] else 0
+                if self.instruction[id]['rotate']:
+                    rot = float(self.instruction[id]['rotate'])
+                else:
+                    rot = 0
                 extent = self.getTextExtent(textDict = self.instruction[id].GetInstruction())
                 rect = wx.Rect2D(self.instruction[id]['where'][0], self.instruction[id]['where'][1], 0, 0)
@@ -1440,7 +1461,11 @@
                 x, y = self.instruction[id]['coords'][0] - self.instruction[id]['xoffset'],\
                         self.instruction[id]['coords'][1] + self.instruction[id]['yoffset']
                 extent = self.parent.getTextExtent(textDict = self.instruction[id])
-                rot = float(self.instruction[id]['rotate'])/180*pi if self.instruction[id]['rotate'] is not None else 0
+                if self.instruction[id]['rotate'] is not None:
+                    rot = float(self.instruction[id]['rotate'])/180*pi
+                else:
+                    rot = 0
                 if self.instruction[id]['ref'].split()[0] == 'lower':
                     y += extent[1]
                 elif self.instruction[id]['ref'].split()[0] == 'center':
@@ -1473,8 +1498,12 @@
             rW, rH = float(rect.GetWidth()), float(rect.GetHeight())
             zoomFactor = 1/max(rW/cW, rH/cH)
             # when zooming to full extent, in some cases, there was zoom 1.01..., which causes problem
-            zoomFactor = zoomFactor if abs(zoomFactor - 1) > 0.01 else 1.
+            if abs(zoomFactor - 1) > 0.01:
+                zoomFactor = zoomFactor
+            else:
+                zoomFactor = 1.
             if self.mouse['use'] == 'zoomout':
                 zoomFactor = min(rW/cW, rH/cH)
             if rW/rH > cW/cH:
@@ -1522,7 +1551,11 @@
                     self.DrawRotText(pdc = self.pdcObj, drawId = id, textDict = self.instruction[id],
                      coords = coords, bounds = oRect )
+                    else:
+                        rot = 0
                     self.instruction[id]['rect'] = bounds = self.parent.getModifiedTextBounds(coords[0], coords[1], extent, rot)
                     self.pdcObj.SetIdBounds(id, bounds)
                 else:
@@ -1594,9 +1627,17 @@
         return drawid
     def DrawRotText(self, pdc, drawId, textDict, coords, bounds):
-        rot = float(textDict['rotate']) if textDict['rotate'] else 0
+        if textDict['rotate']:
+            rot = float(textDict['rotate'])
+        else:
+            rot = 0
         fontsize = str(textDict['fontsize'] * self.currScale)
-        background = textDict['background'] if textDict['background'] != 'none' else None
+        if textDict['background'] != 'none':
+            background = textDict['background']
+        else:
+            background = None
         pdc.RemoveId(drawId)
         pdc.SetId(drawId)
@@ -1693,9 +1734,17 @@
         """!Updates map frame label"""
         vector = self.instruction.FindInstructionByType('vector')
-        vectorId = vector.id if vector else None
+        if vector:
+            vectorId = vector.id
+        else:
+            vectorId = None
+        if raster:
+        else:
+            rasterId = None
         rasterName = 'None'
         if rasterId:
             rasterName = self.instruction[rasterId]['raster'].split('@')[0]
Modified: grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap_dialogs.py
--- grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap_dialogs.py	2011-04-27 09:17:12 UTC (rev 46117)
+++ grass-addons/gui/wxpython/wx.psmap/gui_modules/psmap_dialogs.py	2011-04-27 15:51:08 UTC (rev 46118)
@@ -731,7 +731,11 @@
             try:
                 scaleText = text.strip('scale ').split(':')[1]
                 # when scale instruction given and region comment also, then scaletype is fixed scale
-                instr['scaleType'] = 2 if not isRegionComment else 3
+                if not isRegionComment:
+                    instr['scaleType'] = 2
+                else:
+                    instr['scaleType'] = 3
                 scale = 1/float(scaleText)
                 if abs(scale - self.instruction['scale']) > (0.01 * scale):
                     GWarning(_("Scale has changed, old value: %s\nnew value: %s") % (scale, self.instruction['scale']))
@@ -1166,7 +1170,11 @@
                                                     fromUnit = 'point', toUnit = 'inch')
         if discrete == 'y':
-            cols = cols if cols else 1
+            if cols:
+                cols = cols
+            else:
+                cols = 1
             rinfo = grass.raster_info(raster)
             if rinfo['datatype'] in ('DCELL', 'FCELL'):
                 minim, maxim = rinfo['min'], rinfo['max']
@@ -1198,7 +1206,11 @@
             width += textPart
         elif discrete == 'y':
+            if cols:
+                cols = cols
+            else:
+                cols = 1
             if width:
                 width = width
             else:
@@ -1262,8 +1274,16 @@
     def EstimateSize(self, vectorInstr, fontsize, width = None, cols = None):
         """!Estimate size to draw vector legend"""
-        width = width if width else fontsize/24.0
+        if width:
+            width = width
+        else:
+            width = fontsize/24.0
+        if cols:
+            cols = cols
+        else:
+            cols = 1
         vectors = vectorInstr['list']
         labels = [vector[4] for vector in vectors if vector[3] != 0]
         extent = (len(max(labels, key = len)) * fontsize / 2, fontsize)
@@ -1846,7 +1866,11 @@
         PsmapDialog.__init__(self, parent = parent, id = id, title = "", settings = settings)
         self.isNotebook = notebook
-        self.objectType = ('mapNotebook',) if self.isNotebook else ('map',)
+        if self.isNotebook:
+            self.objectType = ('mapNotebook',)
+        else:
+            self.objectType = ('map',)
         #notebook
         if self.isNotebook:
@@ -2072,7 +2096,10 @@
         gridBagSizer = wx.GridBagSizer(hgap = 5, vgap = 5)
         self.borderCheck = wx.CheckBox(self, id = wx.ID_ANY, label = (_("draw border around map frame")))
-        self.borderCheck.SetValue(True if self.mapFrameDict['border'] == 'y' else False)
+        if self.mapFrameDict['border'] == 'y':
+            self.borderCheck.SetValue(True)
+        else:
+            self.borderCheck.SetValue(False)
         self.borderColorText = wx.StaticText(self, id = wx.ID_ANY, label = _("border color:"))
         self.borderWidthText = wx.StaticText(self, id = wx.ID_ANY, label = _("border width (pts):"))
@@ -2116,10 +2143,18 @@
     def OnMap(self, event):
         """!Selected map or region changing"""
-        self.selected = self.select.GetValue() if self.select.GetValue() else None
+        if self.select.GetValue():
+            self.selected = self.select.GetValue()
+        else:
+            self.selected = None
         if self.scaleChoice.GetSelection() == 0:
             self.selectedMap = self.selected
-            mapType = 'raster' if self.rasterTypeRadio.GetValue() else 'vector'
+            if self.rasterTypeRadio.GetValue():
+                mapType = 'raster'
+            else:
+                mapType = 'vector'
             self.scale[0], self.center[0], foo = AutoAdjust(self, scaleType = 0, map = self.selected,
                                                 mapType = mapType, rect = self.mapFrameDict['rect'])
             #self.center[0] = self.RegionCenter(self.RegionDict(scaleType = 0))
@@ -2154,7 +2189,11 @@
                 self.vectorTypeRadio.Show()
                 self.drawMap.Show()
                 self.staticBox.SetLabel(" %s " % _("Map selection"))
-                stype = 'raster' if self.rasterTypeRadio.GetValue() else 'vector'
+                    stype = 'raster'
+                else:
+                    stype = 'vector'
                 self.select.SetElementList(type = stype)
                 self.mapText.SetLabel(self.mapOrRegionText[0])
                 self.select.SetToolTipString(_("Region is set to match this map,\nraster or vector map must be added later"))
@@ -2296,7 +2335,11 @@
                 self.scale[0], self.center[0], self.rectAdjusted = AutoAdjust(self, scaleType = 0, map = mapFrameDict['map'],
        mapType = self.mapType, rect = self.mapFrameDict['rect'])
-                mapFrameDict['rect'] = self.rectAdjusted if self.rectAdjusted else self.mapFrameDict['rect']
+                if self.rectAdjusted:
+                    mapFrameDict['rect'] = self.rectAdjusted
+                else:
+                    mapFrameDict['rect'] = self.mapFrameDict['rect']
                 mapFrameDict['scale'] = self.scale[0]
                 mapFrameDict['center'] = self.center[0]
@@ -2305,7 +2348,11 @@
                     RunCommand('g.region', rast = mapFrameDict['map'])
                 if self.mapType == 'vector':
+                    if raster:
+                    else:
+                        rasterId = None
                     if rasterId:
                         RunCommand('g.region', vect = mapFrameDict['map'], rast = self.instruction[rasterId]['raster'])
@@ -2327,7 +2374,11 @@
                 mapFrameDict['region'] = self.select.GetValue()
                 self.scale[1], self.center[1], self.rectAdjusted = AutoAdjust(self, scaleType = 1, region = mapFrameDict['region'],
+                else:
                 mapFrameDict['scale'] = self.scale[1]
                 mapFrameDict['center'] = self.center[1]
                 # set region
@@ -2343,7 +2394,11 @@
             mapFrameDict['mapType'] = None
             mapFrameDict['region'] = None
             self.scale[2], self.center[2], self.rectAdjusted = AutoAdjust(self, scaleType = 2, rect = self.mapFrameDict['rect'])
+            else:
             mapFrameDict['scale'] = self.scale[2]
             mapFrameDict['center'] = self.center[2]
@@ -2356,7 +2411,11 @@
                 region = grass.region()
+            if raster:
+            else:
+                rasterId = None
             if rasterId: # because of resolution
                 RunCommand('g.region', n = region['north'], s = region['south'],
                             e = region['east'], w = region['west'], rast = self.instruction[rasterId]['raster'])
@@ -2387,7 +2446,11 @@
         SetResolution(dpi = mapFrameDict['resolution'], width = mapFrameDict['rect'].width,
                                                         height = mapFrameDict['rect'].height)
         # border
-        mapFrameDict['border'] = 'y' if self.borderCheck.GetValue() else 'n'
+        if self.borderCheck.GetValue():
+            mapFrameDict['border'] = 'y'
+        else:
+            mapFrameDict['border'] = 'n'
         if mapFrameDict['border'] == 'y':
             mapFrameDict['width'] = self.borderWidthCtrl.GetValue()
             mapFrameDict['color'] = convertRGB(self.borderColourPicker.GetColour())
@@ -2520,7 +2583,11 @@
             self.vectorList = []
         vLegend = self.instruction.FindInstructionByType('vectorLegend')
-        self.vLegendId = vLegend.id if vLegend else None
+        if vLegend:
+            self.vLegendId = vLegend.id
+        else:
+            self.vLegendId = None
         self._layout()
@@ -2655,7 +2722,12 @@
             for i in range(pos, len(self.vectorList)):
                 if self.vectorList[i][3]:# can be 0
                     self.vectorList[i][3] -= 1
-            self.updateListBox(selected = pos if pos < len(self.vectorList) -1 else len(self.vectorList) -1)
+            if pos < len(self.vectorList) -1:
+                selected = pos
+            else:
+                selected = len(self.vectorList) -1
+            self.updateListBox(selected = selected)
             if self.listbox.IsEmpty():
                 self.enableButtons(False)
@@ -2668,7 +2740,12 @@
                 self.vectorList.insert(pos - 1, self.vectorList.pop(pos))
             if not self.vLegendId:
                 self.reposition()
-            self.updateListBox(selected = (pos - 1) if pos > 0 else 0)
+            if pos > 0:
+                self.updateListBox(selected = (pos - 1))
+            else:
+                self.updateListBox(selected = 0)
     def OnDown(self, event):
         """!Moves selected map to bottom"""
@@ -2678,7 +2755,11 @@
                 self.vectorList.insert(pos + 1, self.vectorList.pop(pos))
                     self.reposition()
-            self.updateListBox(selected = (pos + 1) if pos < len(self.vectorList) -1 else len(self.vectorList) -1)
+                self.updateListBox(selected = (pos + 1))
+            else:
+                self.updateListBox(selected = len(self.vectorList) -1)
     def OnProperties(self, event):
         """!Opens vector map properties dialog"""
@@ -2887,9 +2968,14 @@
             box   = wx.StaticBox (parent = panel, id = wx.ID_ANY, label = " %s " % _("Feature type"))
             sizer = wx.StaticBoxSizer(box, wx.HORIZONTAL)
-            label = (_("points"), _("centroids")) if self.type == 'points' else (_("lines"), _("boundaries"))
-            name = ("point", "centroid") if self.type == 'points' else ("line", "boundary")
+            if self.type == 'points':
+                label = (_("points"), _("centroids"))
+            else:
+                label = (_("lines"), _("boundaries"))
+                name = ("point", "centroid")
+            else:
+                name = ("line", "boundary")
             self.checkType1 = wx.CheckBox(panel, id = wx.ID_ANY, label = label[0], name = name[0])
             self.checkType2 = wx.CheckBox(panel, id = wx.ID_ANY, label = label[1], name = name[1])
             self.checkType1.SetValue(self.vPropertiesDict['type'].find(name[0]) >= 0)
@@ -2914,12 +3000,20 @@
         self.layerChoice.SetStringSelection(self.currLayer)
-        table = self.mapDBInfo.layers[int(self.currLayer)]['table'] if self.connection else ""
+        if self.connection:
+            table = self.mapDBInfo.layers[int(self.currLayer)]['table']
+        else:
+            table = ""
         self.radioWhere = wx.RadioButton(panel, id = wx.ID_ANY, label = "SELECT * FROM %s WHERE" % table, style = wx.RB_GROUP)
         self.textCtrlWhere = wx.TextCtrl(panel, id = wx.ID_ANY, value = "")
-        cols = self.mapDBInfo.GetColumns(self.mapDBInfo.layers[int(self.currLayer)]['table']) if self.connection else []
+            cols = self.mapDBInfo.GetColumns(self.mapDBInfo.layers[int(self.currLayer)]['table'])
+        else:
+            cols = []
         self.choiceColumns = wx.Choice(panel, id = wx.ID_ANY, choices = cols)
         self.radioCats = wx.RadioButton(panel, id = wx.ID_ANY, label = "Choose categories ")
@@ -2955,7 +3049,10 @@
         self.mask = wx.CheckBox(panel, id = wx.ID_ANY, label = _("Use current mask"))
-        self.mask.SetValue(True if self.vPropertiesDict['masked'] == 'y' else False)
+        if self.vPropertiesDict['masked'] == 'y':
+            self.mask.SetValue(True)
+        else:
+            self.mask.SetValue(False)
         sizer.Add(self.mask, proportion = 1, flag = wx.EXPAND|wx.ALL, border = 5)
         border.Add(item = sizer, proportion = 0, flag = wx.ALL | wx.EXPAND, border = 5)
@@ -2990,12 +3087,20 @@
         else:
             self.widthSpin = wx.SpinCtrl(panel, id = wx.ID_ANY, min = 1, max = 25, initial = 1,
                                          size = self.spinCtrlSize)
+        if self.vPropertiesDict['color'] != 'none':
+            self.widthSpin.SetValue(self.vPropertiesDict['width'] )
+        else:
+            self.widthSpin.SetValue(1)
-        self.widthSpin.SetValue(self.vPropertiesDict['width'] if self.vPropertiesDict['color'] != 'none' else 1)
         colorText = wx.StaticText(panel, id = wx.ID_ANY, label = _("Color:"))
         self.colorPicker = wx.ColourPickerCtrl(panel, id = wx.ID_ANY)
-        self.colorPicker.SetColour(convertRGB(self.vPropertiesDict['color']) if self.vPropertiesDict['color'] != 'none' else 'black')
+            self.colorPicker.SetColour(convertRGB(self.vPropertiesDict['color']))
+        else:
+            self.colorPicker.SetColour('black')
         self.gridBagSizerO.Add(self.outlineCheck, pos = (0, 0), span = (1,2), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
@@ -3026,7 +3131,11 @@
         else:
             self.colorPickerRadio.SetValue(False)
         self.fillColorPicker = wx.ColourPickerCtrl(panel, id = wx.ID_ANY)
-        self.fillColorPicker.SetColour(convertRGB(self.vPropertiesDict['fcolor']) if self.vPropertiesDict['fcolor'] != 'none' else 'red')
+        if self.vPropertiesDict['fcolor'] != 'none':
+            self.fillColorPicker.SetColour(convertRGB(self.vPropertiesDict['fcolor']))
+        else:
+            self.fillColorPicker.SetColour('red')
         self.colorColRadio = wx.RadioButton(panel, id = wx.ID_ANY, label = _("color from map table column:"))
@@ -3084,11 +3193,19 @@
             self.outWidthSpin = wx.SpinCtrl(panel, id = wx.ID_ANY, min = 1, max = 30, initial = 1,
-        self.outWidthSpin.SetValue(self.vPropertiesDict['hwidth'] if self.vPropertiesDict['hcolor'] != 'none' else 1)
+        if self.vPropertiesDict['hcolor'] != 'none':
+            self.outWidthSpin.SetValue(self.vPropertiesDict['hwidth'] )
+        else:
+            self.outWidthSpin.SetValue(1)
-        self.colorPicker.SetColour(convertRGB(self.vPropertiesDict['hcolor']) if self.vPropertiesDict['hcolor'] != 'none' else 'black')
+            self.colorPicker.SetColour(convertRGB(self.vPropertiesDict['hcolor']) )
+        else:
@@ -3118,7 +3235,11 @@
         else:
-        self.fillColorPicker.SetColour(convertRGB(self.vPropertiesDict['color']) if self.vPropertiesDict['color'] != 'none' else 'black')
+            self.fillColorPicker.SetColour(convertRGB(self.vPropertiesDict['color']) )
+        else:
+            self.fillColorPicker.SetColour('black')
@@ -3204,7 +3325,9 @@
         self.sizeRadio.SetValue(self.vPropertiesDict['size'] is not None)
         self.sizecolumnRadio.SetValue(bool(self.vPropertiesDict['sizecolumn']))
-        self.sizeSpin.SetValue(self.vPropertiesDict['size'] if self.vPropertiesDict['size'] else 5)
+        if self.vPropertiesDict['size']:
+            self.sizeSpin.SetValue(self.vPropertiesDict['size'])
+        else: self.sizeSpin.SetValue(5)
         if self.vPropertiesDict['sizecolumn']:
             self.scaleSpin.SetValue(self.vPropertiesDict['scale'])
             self.sizeColChoice.SetStringSelection(self.vPropertiesDict['sizecolumn'])
@@ -3244,7 +3367,10 @@
         self.rotateCheck.SetValue(self.vPropertiesDict['rotation'])
         self.rotateRadio.SetValue(self.vPropertiesDict['rotate'] is not None)
         self.rotatecolumnRadio.SetValue(bool(self.vPropertiesDict['rotatecolumn']))
-        self.rotateSpin.SetValue(self.vPropertiesDict['rotate'] if self.vPropertiesDict['rotate'] else 0)
+        if self.vPropertiesDict['rotate']:
+            self.rotateSpin.SetValue(self.vPropertiesDict['rotate'])
+        else:
+            self.rotateSpin.SetValue(0)
         if self.vPropertiesDict['rotatecolumn']:
             self.rotateColChoice.SetStringSelection(self.vPropertiesDict['rotatecolumn'])
         else:
@@ -3387,7 +3513,11 @@
         if self.layerChoice.GetStringSelection() == self.currLayer:
             return
         self.currLayer = self.layerChoice.GetStringSelection()
+        else:
+            cols = []
         self.choiceColumns.SetItems(cols)
         self.choiceColumns.SetSelection(0)
@@ -3447,7 +3577,11 @@
     def getColsChoice(self, parent):
         """!Returns a wx.Choice with table columns"""
+        else:
+            cols = []
         choice = wx.Choice(parent = parent, id = wx.ID_ANY, choices = cols)
         return choice
@@ -3474,7 +3608,11 @@
                 self.vPropertiesDict['where'] = self.choiceColumns.GetStringSelection() + " " \
        + self.textCtrlWhere.GetValue()
         #mask
-        self.vPropertiesDict['masked'] = 'y' if self.mask.GetValue() else 'n'
+        if self.mask.GetValue():
+            self.vPropertiesDict['masked'] = 'y'
+        else:
+            self.vPropertiesDict['masked'] = 'n'
         #colors
         if self.type in ('points', 'areas'):
@@ -3559,7 +3697,11 @@
                 self.vPropertiesDict['width'] = self.widthSpin.GetValue()
                 self.vPropertiesDict['cwidth'] = None
             #line style
-            self.vPropertiesDict['style'] = self.styleCombo.GetValue() if self.styleCombo.GetValue() else 'solid'
+            if self.styleCombo.GetValue():
+                self.vPropertiesDict['style'] = self.styleCombo.GetValue()
+            else:
+                self.vPropertiesDict['style'] = 'solid'
             self.vPropertiesDict['linecap'] = self.linecapChoice.GetStringSelection()
@@ -3573,13 +3715,25 @@
         self.objectType = ('rasterLegend', 'vectorLegend')
         self.instruction = settings
         map = self.instruction.FindInstructionByType('map')
-        self.mapId = map.id if map else None
+        if map:
+            self.mapId = map.id
+        else:
+            self.mapId = None
-        self.vectorId = vector.id if vector else None
+        if vector:
+            self.vectorId = vector.id
+        else:
+            self.vectorId = None
-        self.rasterId = raster.id if raster else None
+        if raster:
+            self.rasterId = raster.id
+        else:
+            self.rasterId = None
         self.pageId = self.instruction.FindInstructionByType('page').id
         currPage = self.instruction[self.pageId].GetInstruction()
         #raster legend
@@ -3604,7 +3758,11 @@
-        self.currRaster = self.instruction[self.rasterId]['raster'] if self.rasterId else None
+        if self.rasterId:
+            self.currRaster = self.instruction[self.rasterId]['raster']
+        else:
+            self.currRaster = None
         #notebook
         self.notebook = wx.Notebook(parent = self, id = wx.ID_ANY, style = wx.BK_DEFAULT)
@@ -3650,7 +3808,10 @@
         self.rasterSelect = Select( panel, id = wx.ID_ANY, size = globalvar.DIALOG_GSELECT_SIZE,
                                     type = 'raster', multiple = False,
                                     updateOnPopup = True, onPopup = None)
-        self.rasterSelect.SetValue(self.rLegendDict['raster'] if not self.rLegendDict['rasterDefault'] else '')
+        if not self.rLegendDict['rasterDefault']:
+            self.rasterSelect.SetValue(self.rLegendDict['raster'])
+        else:
+            self.rasterSelect.SetValue('')
         flexSizer.Add(self.rasterDefault, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
         flexSizer.Add(self.rasterCurrent, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL|wx.LEFT, border = 10)
         flexSizer.Add(self.rasterOther, proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
@@ -3684,10 +3845,16 @@
         gridBagSizer = wx.GridBagSizer (hgap = 5, vgap = 5)
         # no data
         self.nodata = wx.CheckBox(panel, id = wx.ID_ANY, label = _('draw "no data" box'))
-        self.nodata.SetValue(True if self.rLegendDict['nodata'] == 'y' else False)
+        if self.rLegendDict['nodata'] == 'y':
+            self.nodata.SetValue(True)
+        else:
+            self.nodata.SetValue(False)
         #tickbar
         self.ticks = wx.CheckBox(panel, id = wx.ID_ANY, label = _("draw ticks across color table"))
-        self.ticks.SetValue(True if self.rLegendDict['tickbar'] == 'y' else False)
+        if self.rLegendDict['tickbar'] == 'y':
+            self.ticks.SetValue(True)
+        else:
+            self.ticks.SetValue(False)
         # range
         if self.rasterId and self.instruction[self.rasterId]['raster']:
             rinfo = grass.raster_info(self.instruction[self.rasterId]['raster'])
@@ -3818,7 +3985,10 @@
     def sizePositionFont(self, legendType, parent, mainSizer):
         """!Insert widgets for size, position and font control"""
-        legendDict = self.rLegendDict if legendType == 'raster' else self.vLegendDict
+        if legendType == 'raster':
+            legendDict = self.rLegendDict
+        else:
+            legendDict = self.vLegendDict
         panel = parent
         border = mainSizer
@@ -4051,7 +4221,11 @@
                 self.vectorListCtrl.SetItemData(pos, idx1)
                 self.vectorListCtrl.SetItemData(pos - 1, idx2)
                 self.vectorListCtrl.SortItems(cmp)
-                selected = (pos - 1) if pos > 0 else 0
+                if pos > 0:
+                    selected = (pos - 1)
+                else:
+                    selected = 0
                 self.vectorListCtrl.Select(selected)
@@ -4064,7 +4238,11 @@
                 self.vectorListCtrl.SetItemData(pos + 1, idx2)
-                selected = (pos + 1) if pos < self.vectorListCtrl.GetItemCount() -1 else self.vectorListCtrl.GetItemCount() -1
+                if pos < self.vectorListCtrl.GetItemCount() -1:
+                    selected = (pos + 1)
+                else:
+                    selected = self.vectorListCtrl.GetItemCount() -1
     def OnEditLabel(self, event):
@@ -4209,7 +4387,11 @@
         """!Save information from vector legend dialog to dictionary"""
+        if vector:
+        else:
         #is vector legend
         if not self.isVLegend.GetValue():
             self.vLegendDict['vLegend'] = False
@@ -4319,8 +4501,16 @@
             self.panelRaster.position['yCtrl'].SetValue("%5.3f" % y)
         #update name and type of raster
-        currRaster = raster['raster'] if raster else None
+        if raster:
+        else:
+        if raster:
+            currRaster = raster['raster']
+        else:
+            currRaster = None
         rasterType = getRasterType(map = currRaster)
         self.rasterCurrent.SetLabel( _("%s: type %s") % (currRaster, str(rasterType)))
@@ -4436,14 +4626,28 @@
         self.colors['borderColor'] = wx.ColourPickerCtrl(panel, id = wx.ID_ANY)
         self.colors['backgroundColor'] = wx.ColourPickerCtrl(panel, id = wx.ID_ANY)
-        self.colors['borderCtrl'].SetValue(True if self.mapinfoDict['border'] != 'none' else False)
-        self.colors['backgroundCtrl'].SetValue(True if self.mapinfoDict['background'] != 'none' else False)
-        self.colors['borderColor'].SetColour(convertRGB(self.mapinfoDict['border'])
-                                            if self.mapinfoDict['border'] != 'none' else 'black')
+        if self.mapinfoDict['border'] != 'none':
+            self.colors['borderCtrl'].SetValue(True)
+        else:
+            self.colors['borderCtrl'].SetValue(False)
-        self.colors['backgroundColor'].SetColour(convertRGB(self.mapinfoDict['background'])
-                                            if self.mapinfoDict['background'] != 'none' else 'black')
+        if self.mapinfoDict['background'] != 'none':
+            self.colors['backgroundCtrl'].SetValue(True)
+        else:
+            self.colors['backgroundCtrl'].SetValue(False)
+            self.colors['borderColor'].SetColour(convertRGB(self.mapinfoDict['border']))
+        else:
+            self.colors['borderColor'].SetColour('black')
+            self.colors['backgroundColor'].SetColour(convertRGB(self.mapinfoDict['background']))
+        else:
+            self.colors['backgroundColor'].SetColour('black')
         flexSizer.Add(self.colors['borderCtrl'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
         flexSizer.Add(self.colors['borderColor'], proportion = 0, flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
@@ -4480,8 +4684,16 @@
         currUnit = self.panel.units['unitsCtrl'].GetStringSelection()
         self.mapinfoDict['unit'] = currUnit
         # position
-        x = self.panel.position['xCtrl'].GetValue() if self.panel.position['xCtrl'].GetValue() else self.mapinfoDict['where'][0]
-        y = self.panel.position['yCtrl'].GetValue() if self.panel.position['yCtrl'].GetValue() else self.mapinfoDict['where'][1]
+        if self.panel.position['xCtrl'].GetValue():
+            x = self.panel.position['xCtrl'].GetValue()
+        else:
+            x = self.mapinfoDict['where'][0]
+        if self.panel.position['yCtrl'].GetValue():
+            y = self.panel.position['yCtrl'].GetValue()
+        else:
+            y = self.mapinfoDict['where'][1]
         x = self.unitConv.convert(value = float(self.panel.position['xCtrl'].GetValue()), fromUnit = currUnit, toUnit = 'inch')
         y = self.unitConv.convert(value = float(self.panel.position['yCtrl'].GetValue()), fromUnit = currUnit, toUnit = 'inch')
         self.mapinfoDict['where'] = (x, y)
@@ -4695,7 +4907,10 @@
         self.fontsizeCtrl.SetValue(self.scalebarDict['fontsize'])
         self.backgroundCheck = wx.CheckBox(panel, id = wx.ID_ANY, label = _("transparent text background"))
-        self.backgroundCheck.SetValue(False if self.scalebarDict['background'] == 'y' else True)
+        if self.scalebarDict['background'] == 'y':
+            self.backgroundCheck.SetValue(False)
+        else:
+            self.backgroundCheck.SetValue(True)
         gridBagSizer.Add(sbTypeText, pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
@@ -4725,8 +4940,16 @@
         self.scalebarDict['unit'] = currUnit
         # position
-        x = self.panel.position['xCtrl'].GetValue() if self.panel.position['xCtrl'].GetValue() else self.scalebarDict['where'][0]
-        y = self.panel.position['yCtrl'].GetValue() if self.panel.position['yCtrl'].GetValue() else self.scalebarDict['where'][1]
+        else:
+            x = self.scalebarDict['where'][0]
+        else:
+            y = self.scalebarDict['where'][1]
@@ -4736,7 +4959,11 @@
         self.scalebarDict['segment'] = self.sbSegmentsCtrl.GetValue()
         self.scalebarDict['numbers'] = self.sbLabelsCtrl.GetValue()
         self.scalebarDict['fontsize'] = self.fontsizeCtrl.GetValue()
-        self.scalebarDict['background'] = 'n' if self.backgroundCheck.GetValue() else 'y'
+        if self.backgroundCheck.GetValue():
+            self.scalebarDict['background'] = 'n'
+        else:
+            self.scalebarDict['background'] = 'y'
         # size
@@ -4887,16 +5114,37 @@
         self.effect['borderWidth'] = wx.SpinCtrl(panel, id = wx.ID_ANY, size = self.spinCtrlSize, min = 1, max = 25, initial = 1)
         self.effect['borderWidthLabel'] = wx.StaticText(panel, id = wx.ID_ANY, label = _("Width (pts):"))
         #set values
-        self.effect['backgroundCtrl'].SetValue(True if self.textDict['background'] != 'none' else False)
-        self.effect['backgroundColor'].SetColour(convertRGB(self.textDict['background'])
-                                            if self.textDict['background'] != 'none' else 'white')
-        self.effect['highlightCtrl'].SetValue(True if self.textDict['hcolor'] != 'none' else False)
-        self.effect['highlightColor'].SetColour(convertRGB(self.textDict['hcolor'])
-                                            if self.textDict['hcolor'] != 'none' else convertRGB('grey'))
+        if self.textDict['background'] != 'none':
+            self.effect['backgroundCtrl'].SetValue(True)
+        else:
+            self.effect['backgroundCtrl'].SetValue(False)
+            self.effect['backgroundColor'].SetColour(convertRGB(self.textDict['background']))
+        else:
+            self.effect['backgroundColor'].SetColour('white')
+        if self.textDict['hcolor'] != 'none':
+            self.effect['highlightCtrl'].SetValue(True)
+        else:
+            self.effect['highlightCtrl'].SetValue(False)
+            self.effect['highlightColor'].SetColour(convertRGB(self.textDict['hcolor']))
+        else:
+            self.effect['highlightColor'].SetColour(convertRGB('grey'))
         self.effect['highlightWidth'].SetValue(float(self.textDict['hwidth']))
-        self.effect['borderCtrl'].SetValue(True if self.textDict['border'] != 'none' else False)
-        self.effect['borderColor'].SetColour(convertRGB(self.textDict['border'])
-                                            if self.textDict['border'] != 'none' else 'black')
+        if self.textDict['border'] != 'none':
+            self.effect['borderCtrl'].SetValue(True)
+        else:
+            self.effect['borderCtrl'].SetValue(False)
+            self.effect['borderColor'].SetColour(convertRGB(self.textDict['border']))
+        else:
+            self.effect['borderColor'].SetColour('black')
         self.effect['borderWidth'].SetValue(float(self.textDict['width']))
         gridBagSizer.Add(self.effect['backgroundCtrl'], pos = (0,0), flag = wx.ALIGN_CENTER_VERTICAL, border = 0)
@@ -5158,16 +5406,32 @@
             self.textDict['XY'] = True
             currUnit = self.positionPanel.units['unitsCtrl'].GetStringSelection()
             self.textDict['unit'] = currUnit
-            x = self.positionPanel.position['xCtrl'].GetValue() if self.positionPanel.position['xCtrl'].GetValue() else self.textDict['where'][0]
-            y = self.positionPanel.position['yCtrl'].GetValue() if self.positionPanel.position['yCtrl'].GetValue() else self.textDict['where'][1]
+            if self.positionPanel.position['xCtrl'].GetValue():
+                x = self.positionPanel.position['xCtrl'].GetValue()
+            else:
+                x = self.textDict['where'][0]
+            if self.positionPanel.position['yCtrl'].GetValue():
+                y = self.positionPanel.position['yCtrl'].GetValue()
+            else:
+                y = self.textDict['where'][1]
             x = self.unitConv.convert(value = float(x), fromUnit = currUnit, toUnit = 'inch')
             y = self.unitConv.convert(value = float(y), fromUnit = currUnit, toUnit = 'inch')
             self.textDict['where'] = x, y
             self.textDict['east'], self.textDict['north'] = PaperMapCoordinates( self.instruction[self.mapId], x, y, paperToMap = True)
         else:
             self.textDict['XY'] = False
-            self.textDict['east'] = self.eastingCtrl.GetValue() if self.eastingCtrl.GetValue() else self.textDict['east']
-            self.textDict['north'] = self.northingCtrl.GetValue() if self.northingCtrl.GetValue() else self.textDict['north']
+            if self.eastingCtrl.GetValue():
+                self.textDict['east'] = self.eastingCtrl.GetValue()
+            else:
+                self.textDict['east'] = self.textDict['east']
+            if self.northingCtrl.GetValue():
+                self.textDict['north'] = self.northingCtrl.GetValue()
+            else:
+                self.textDict['north'] = self.textDict['north']
             self.textDict['where'] = PaperMapCoordinates(map = self.instruction[self.mapId], x = float(self.textDict['east']),
                                                             y = float(self.textDict['north']), paperToMap = False)
         #rotation
@@ -5238,8 +5502,9 @@
         else:
             color = map(lambda x: int(x * 255), psmapColors[rgb])
             color = wx.Color(*color)
-            return color if color.IsOk() else None
+            if color.IsOk():
+                return color
+            return None
 def PaperMapCoordinates(map, x, y, paperToMap = True):
@@ -5259,15 +5524,30 @@
     if not paperToMap:
         textEasting, textNorthing = x, y
         eastingDiff = textEasting - cornerEasting
-        eastingDiff = - eastingDiff if currRegionDict['w'] > currRegionDict['e'] else eastingDiff
+        if currRegionDict['w'] > currRegionDict['e']:
+            eastingDiff = - eastingDiff
+        else:
+            eastingDiff = eastingDiff
         northingDiff = textNorthing - cornerNorthing
-        northingDiff = - northingDiff if currRegionDict['n'] > currRegionDict['s'] else northingDiff
+        if currRegionDict['n'] > currRegionDict['s']:
+            northingDiff = - northingDiff
+        else:
+            northingDiff = northingDiff
         xPaper = xMap + unitConv.convert(value = eastingDiff, fromUnit = 'meter', toUnit = 'inch') * currScale
         yPaper = yMap + unitConv.convert(value = northingDiff, fromUnit = 'meter', toUnit = 'inch') * currScale
         return xPaper, yPaper
     else:
-        eastingDiff = (x - xMap) if currRegionDict['w'] < currRegionDict['e'] else (xMap - x)
-        northingDiff = (y - yMap) if currRegionDict['n'] < currRegionDict['s'] else (yMap - y)
+        if currRegionDict['w'] < currRegionDict['e']:
+            eastingDiff = (x - xMap)
+        else:
+            eastingDiff = (xMap - x)
+        if currRegionDict['n'] < currRegionDict['s']:
+            northingDiff = (y - yMap)
+        else:
+            northingDiff = (yMap - y)
         textEasting = cornerEasting + unitConv.convert(value = eastingDiff, fromUnit = 'inch', toUnit = 'meter') / currScale
         textNorthing = cornerNorthing + unitConv.convert(value = northingDiff, fromUnit = 'inch', toUnit = 'meter') / currScale
         return int(textEasting), int(textNorthing)
@@ -5371,8 +5651,12 @@
         centerN = mapDict['center'][1]
+        if raster:
+        else:
+            rasterId = None
         if rasterId:
             RunCommand('g.region', n = ceil(centerN + rectHalfMeter[1]),
                            s = floor(centerN - rectHalfMeter[1]),
