[GRASS-SVN] r46141 - in grass/trunk/locale: . po
Sat Apr 30 06:45:43 EDT 2011
Author: neteler
Date: 2011-04-30 03:45:43 -0700 (Sat, 30 Apr 2011)
New Revision: 46141
   grass/trunk/locale/Makefile
   grass/trunk/locale/po/grasslibs_pl.po
   grass/trunk/locale/po/grasslibs_pt_br.po
   grass/trunk/locale/po/grasslibs_vi.po
   grass/trunk/locale/po/grasslibs_zh.po
   grass/trunk/locale/po/grassmods_el.po
   grass/trunk/locale/po/grassmods_it.po
   grass/trunk/locale/po/grassmods_ko.po
   grass/trunk/locale/po/grassmods_pl.po
   grass/trunk/locale/po/grassmods_vi.po
   grass/trunk/locale/po/grassmods_zh.po
   grass/trunk/locale/po/grasswxpy_id.po
   grass/trunk/locale/po/grasswxpy_pl.po
msg format fixes
Modified: grass/trunk/locale/Makefile
--- grass/trunk/locale/Makefile	2011-04-30 10:12:43 UTC (rev 46140)
+++ grass/trunk/locale/Makefile	2011-04-30 10:45:43 UTC (rev 46141)
@@ -71,8 +71,8 @@
 verify:
 	@cd ./po/ ; for po in `ls *_*.po 2>/dev/null` ; do \
+		echo "----- $$po:" ; \
 		msgfmt -c $$po; \
-		echo ""; \
 	done
 define dom_rule
Modified: grass/trunk/locale/po/grasslibs_pl.po
--- grass/trunk/locale/po/grasslibs_pl.po	2011-04-30 10:12:43 UTC (rev 46140)
+++ grass/trunk/locale/po/grasslibs_pl.po	2011-04-30 10:45:43 UTC (rev 46141)
@@ -4626,7 +4626,7 @@
 #: ../lib/rst/interp_float/output2d.c:113
 #, c-format
 msgid "First change your cols number to nsizc %d %d"
-msgstr "Najpierw ustaw liczbÄ™ kolumn zgodnie z 'nsizc'"
+msgstr "Najpierw ustaw liczbÄ™ kolumn zgodnie z 'nsizc' %d %d"
 #: ../lib/rst/interp_float/segmen2d.c:111
 msgid "Taking too long to find points for interpolation - please change the region to area where your points are. Continuing calculations..."
Modified: grass/trunk/locale/po/grasslibs_pt_br.po
--- grass/trunk/locale/po/grasslibs_pt_br.po	2011-04-30 10:12:43 UTC (rev 46140)
+++ grass/trunk/locale/po/grasslibs_pt_br.po	2011-04-30 10:45:43 UTC (rev 46141)
@@ -2295,7 +2295,7 @@
 #: ../lib/gis/done_msg.c:38
 #, c-format
 msgid "%s complete. %s"
-msgstr "%s completo. %"
+msgstr "%s completo. %s"
 #: ../lib/gis/gisinit.c:56 ../lib/gis/gisinit.c:91
 msgid "Incompatible library version for module. You need to rebuild GRASS or untangle multiple installations."
Modified: grass/trunk/locale/po/grasslibs_vi.po
--- grass/trunk/locale/po/grasslibs_vi.po	2011-04-30 10:12:43 UTC (rev 46140)
+++ grass/trunk/locale/po/grasslibs_vi.po	2011-04-30 10:45:43 UTC (rev 46141)
@@ -690,7 +690,7 @@
 #: ../lib/raster/color_rules.c:154
 #, c-format
 msgid "bad rule (%s): [%s]"
-msgstr "quy tắc tồi (%s): [%d]"
+msgstr "quy tắc tồi (%s): [%s]"
 #: ../lib/raster/color_rules.c:268
 #, c-format
@@ -4759,7 +4759,7 @@
 #: ../lib/rst/interp_float/vinput2d.c:335
 #, c-format
 msgid "%d points given for interpolation (after thinning) is less than given NPMIN=%d"
-msgstr "%d điểm được cung cấp để nội suy (sau khi làm mảnh) ít hơn NPMIN=% được cung cấp"
+msgstr "%d điểm được cung cấp để nội suy (sau khi làm mảnh) ít hơn NPMIN=%d được cung cấp"
 #: ../lib/rst/interp_float/vinput2d.c:340
 msgid "Zero points in the given region"
Modified: grass/trunk/locale/po/grasslibs_zh.po
--- grass/trunk/locale/po/grasslibs_zh.po	2011-04-30 10:12:43 UTC (rev 46140)
+++ grass/trunk/locale/po/grasslibs_zh.po	2011-04-30 10:45:43 UTC (rev 46141)
@@ -5839,7 +5839,7 @@
 #: ../lib/gmath/solvers_krylov.c:262
 #, c-format
 msgid "Sparse PCG -- iteration %i error  %g\n"
-msgstr "grass不能识别基准系<%s>或找不到参数\n"
+msgstr ""
 #: ../lib/gmath/solvers_krylov.c:264
 #, c-format
Modified: grass/trunk/locale/po/grassmods_el.po
--- grass/trunk/locale/po/grassmods_el.po	2011-04-30 10:12:43 UTC (rev 46140)
+++ grass/trunk/locale/po/grassmods_el.po	2011-04-30 10:45:43 UTC (rev 46141)
@@ -7309,7 +7309,7 @@
 #: ../raster/r.proj/main.c:446 ../raster/r.proj/main.c:457
 #, c-format
 msgid "Cols: %d (%d)"
-msgstr "ù"
+msgstr ""
 #: ../raster/r.proj/main.c:447 ../raster/r.proj/main.c:458
 #, c-format
Modified: grass/trunk/locale/po/grassmods_it.po
--- grass/trunk/locale/po/grassmods_it.po	2011-04-30 10:12:43 UTC (rev 46140)
+++ grass/trunk/locale/po/grassmods_it.po	2011-04-30 10:45:43 UTC (rev 46141)
@@ -20315,7 +20315,7 @@
 #: ../vector/v.proj/main.c:190
 #, c-format
 msgid "Vector map <%s> in location <%s> mapset <%s> not found"
-msgstr "Mappa vettoriale <%s>"
+msgstr "Mappa vettoriale <%s> nella location <%s> mapset <%s> non trovata"
 #: ../vector/v.proj/main.c:214
 #, c-format
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po	2011-04-30 10:12:43 UTC (rev 46140)
+++ grass/trunk/locale/po/grassmods_ko.po	2011-04-30 10:45:43 UTC (rev 46141)
@@ -3,7 +3,6 @@
 # Copyright (C) 2005, GRASS Development Team
 # Huidae Cho <grass4u at gmail.com>, 2005
-#, fuzzy
 msgid ""
 msgstr ""
 "Project-Id-Version: grassmods_ko\n"
Modified: grass/trunk/locale/po/grassmods_pl.po
--- grass/trunk/locale/po/grassmods_pl.po	2011-04-30 10:12:43 UTC (rev 46140)
+++ grass/trunk/locale/po/grassmods_pl.po	2011-04-30 10:45:43 UTC (rev 46141)
@@ -12503,7 +12503,7 @@
 #: ../general/g.proj/main.c:193
 #, c-format
 msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
-msgstr "Tylko jedna z opcji '%s', '%s' lub '%s' może być określona"
+msgstr "Tylko jedna z opcji '%s', '%s', '%s' lub '%s' może być określona"
 #: ../general/g.proj/main.c:222
 msgid "Projection files missing"
@@ -21723,7 +21723,7 @@
 #: ../vector/v.overlay/area_area.c:78
 #, c-format
 msgid "Querying vector map <%s>..."
-msgstr "Odpytywanie mapy wektorowej ..."
+msgstr "Odpytywanie mapy wektorowej <%s>..."
 #: ../vector/v.overlay/area_area.c:114
 msgid "Writing centroids..."
Modified: grass/trunk/locale/po/grassmods_vi.po
--- grass/trunk/locale/po/grassmods_vi.po	2011-04-30 10:12:43 UTC (rev 46140)
+++ grass/trunk/locale/po/grassmods_vi.po	2011-04-30 10:45:43 UTC (rev 46141)
@@ -20181,7 +20181,7 @@
 #: ../vector/v.hull/main.c:93
 #, c-format
 msgid "%d points read from vector map <%s>"
-msgstr "Đọc %d điểm từ bản đồ vec-tơ <%>"
+msgstr "Đọc %d điểm từ bản đồ vec-tơ <%s>"
 #: ../vector/v.hull/hull.c:107
 msgid "Simple planar hulls not implemented yet"
Modified: grass/trunk/locale/po/grassmods_zh.po
--- grass/trunk/locale/po/grassmods_zh.po	2011-04-30 10:12:43 UTC (rev 46140)
+++ grass/trunk/locale/po/grassmods_zh.po	2011-04-30 10:45:43 UTC (rev 46141)
@@ -26177,7 +26177,7 @@
 #: ../ps/ps.map/ps_vareas.c:108
 #, c-format
 msgid "Invalid RGB color definition in column <%s> for category [%d]"
-msgstr "类别[%d]的行[%s]无效的RGB颜色定义"
+msgstr "类别[%d]的行<%s>无效的RGB颜色定义"
 #: ../ps/ps.map/main.c:93
 #, fuzzy
Modified: grass/trunk/locale/po/grasswxpy_id.po
--- grass/trunk/locale/po/grasswxpy_id.po	2011-04-30 10:12:43 UTC (rev 46140)
+++ grass/trunk/locale/po/grasswxpy_id.po	2011-04-30 10:45:43 UTC (rev 46141)
@@ -7078,7 +7078,7 @@
 #: ../gui/wxpython/gui_modules/location_wizard.py:1837
 #, python-format
 msgid "Location <%s> created"
-msgstr "Location <%> telah dibuat"
+msgstr "Location <%s> telah dibuat"
 #: ../gui/wxpython/gui_modules/location_wizard.py:1850
 #, fuzzy, python-format
@@ -8224,7 +8224,7 @@
 #: ../gui/wxpython/gui_modules/vdigit.py:651
 #, python-format
 msgid "Snapping threshold is %(value).1f %(units)s"
-msgstr "Batasan snapping adalah %(value).1f%(units)"
+msgstr "Batasan snapping adalah %(value).1f %(units)s"
 #: ../gui/wxpython/gui_modules/vdigit.py:220
 msgid "Select vector features"
@@ -8471,7 +8471,7 @@
 "Layer and category number must be integer.\n"
 "Layer number must be greater then zero."
 msgstr ""
-"Tidak mampu menambahkan layer/kategori baru <%(layer)/%(category)>.\n"
+"Tidak mampu menambahkan layer/kategori baru <%(layer)s/%(category)s>.\n"
 "Layer dan kategori harus integer.\n"
 "Nomor layer harus lebih besar dari nol."
@@ -9865,8 +9865,8 @@
 "Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
 "exists in the table <%(table)s>."
 msgstr ""
-"Tidak mampu merubah nama kolom <%(column)> ke <%(columnTo). Kolom sudah ada "
-"dalam tabel <%(table)>."
+"Tidak mampu merubah nama kolom <%(column)s> ke <%(columnTo)s>. Kolom sudah ada "
+"dalam tabel <%(table)s>."
 #: ../gui/wxpython/gui_modules/dbm.py:1626
 #, python-format
@@ -9874,8 +9874,8 @@
 "Unable to rename column. Column <%(column)s> doesn't exist in the table <%"
 "(table)s>."
 msgstr ""
-"Tidak mampu merubah nama kolom. Kolom <%(column)> tidak ada di dalam tabel <%"
-"(table)>."
+"Tidak mampu merubah nama kolom. Kolom <%(column)s> tidak ada di dalam tabel <%"
+"(table)s>."
 #: ../gui/wxpython/gui_modules/dbm.py:1654
 msgid "Drop selected column"
@@ -9919,7 +9919,7 @@
 #: ../gui/wxpython/gui_modules/dbm.py:1769
 #, python-format
 msgid "Column <%(column)s> already exists in table <%(table)s>."
-msgstr "Kolom <%(column)> sudah ada di dalam tabel <%(table)>."
+msgstr "Kolom <%(column)s> sudah ada di dalam tabel <%(table)s>."
 #: ../gui/wxpython/gui_modules/dbm.py:1928
 #: ../gui/wxpython/gui_modules/dbm.py:1952
Modified: grass/trunk/locale/po/grasswxpy_pl.po
--- grass/trunk/locale/po/grasswxpy_pl.po	2011-04-30 10:12:43 UTC (rev 46140)
+++ grass/trunk/locale/po/grasswxpy_pl.po	2011-04-30 10:45:43 UTC (rev 46141)
@@ -118,7 +118,7 @@
 #: ../gui/wxpython/wxgui.py:520
 #, python-format
 msgid "Unable to switch to location <%(loc)s> mapset <%(mapset)s>."
-msgstr "Nie można przełączyć do  lokacji <%(loc)s> mapsetu <%<mapset)y>."
+msgstr "Nie można przełączyć do lokacji <%(loc)s> mapsetu <%(mapset)s>."
 #: ../gui/wxpython/wxgui.py:522 ../gui/wxpython/wxgui.py:543
 #: ../gui/wxpython/scripts/r.li.setup.py:337
@@ -6316,7 +6316,7 @@
 "\n"
 "Details: %(err)s"
 msgstr ""
-"Nie można utworzyć nowej lokacji. Lokacja <%loc)s> nie została utworzona.\n"
+"Nie można utworzyć nowej lokacji. Lokacja <%(loc)s> nie została utworzona.\n"
 "\n"
 "Szczegóły: %(err)s"
@@ -8242,7 +8242,7 @@
 #: ../gui/wxpython/gui_modules/sqlbuilder.py:74
 #, python-format
 msgid "GRASS SQL Builder (%(type)s): vector map <%(map)s>"
-msgstr "GRASS SQL Builder (%(typ)ów): map wektorowych <%(map)>"
+msgstr "GRASS SQL Builder (%(typ)ów): map wektorowych <%(map)s>"
 #: ../gui/wxpython/gui_modules/sqlbuilder.py:81
 msgid "SQL statement not verified"
