[GRASS-SVN] r47417 - grass-addons/grass7/gui/wxpython/wx.wms
Thu Aug 4 04:35:01 EDT 2011
Author: sudeepsingh
Date: 2011-08-04 01:35:01 -0700 (Thu, 04 Aug 2011)
New Revision: 47417
Added:
   grass-addons/grass7/gui/wxpython/wx.wms/LoadConfig.py
   grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py
   grass-addons/grass7/gui/wxpython/wx.wms/addserver.py
   grass-addons/grass7/gui/wxpython/wx.wms/config
   grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
Function to load config file moved into this file
Added: grass-addons/grass7/gui/wxpython/wx.wms/LoadConfig.py
--- grass-addons/grass7/gui/wxpython/wx.wms/LoadConfig.py	                        (rev 0)
+++ grass-addons/grass7/gui/wxpython/wx.wms/LoadConfig.py	2011-08-04 08:35:01 UTC (rev 47417)
@@ -0,0 +1,11 @@
+def loadConfigFile(self):
+    try:
+        f=open('config','r')
+        lines = f.readlines()
+        f.close()
+        self.name_url_delimiter = lines[0].split()[1]
+        print "config file loaded successfully"
+        print self.name_url_delimiter
+        return True
+    except:
+        return False
Modified: grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py
--- grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py	2011-08-04 08:28:07 UTC (rev 47416)
+++ grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py	2011-08-04 08:35:01 UTC (rev 47417)
@@ -27,6 +27,7 @@
 def addServerInfo(soup, serverinfo, snamevalue, urlvalue, unamevalue, passwordvalue):
+    snamevalue = unicode(snamevalue)
     elements = soup.findAll(id = snamevalue)
     if(len(elements)!=0):
         return False
@@ -47,6 +48,7 @@
         server.insert(3, password)
         #Adding attribute to server tag
         server['id'] = snamevalue
         #Adding text values to the server info fields
@@ -57,6 +59,7 @@
         return True
 def removeServerInfo(soup, serverID):
+    serverID = unicode(serverID)
     elements = soup.findAll(id = serverID)
     if(len(elements)==0):
         return False
@@ -66,6 +69,7 @@
         return True
 def updateServerInfo(soup, serverinfo, snamevalue, urlvalue, unamevalue, passwordvalue):
     if(removeServerInfo(soup, snamevalue)):
         if(addServerInfo(soup, serverinfo, snamevalue, urlvalue, unamevalue, passwordvalue)):
             return True
@@ -83,7 +87,7 @@
         username = element.findAll('username')[0]
         password = element.findAll('password')[0]
         serverdata = ServerData()
-        serverdata.servername = servername.contents[0].strip()
+        serverdata.servername = unicode(servername.contents[0].strip())
         serverdata.url = serverurl.contents[0].strip()
         serverdata.username = username.contents[0].strip()
         serverdata.password = password.contents[0].strip()
Modified: grass-addons/grass7/gui/wxpython/wx.wms/addserver.py
--- grass-addons/grass7/gui/wxpython/wx.wms/addserver.py	2011-08-04 08:28:07 UTC (rev 47416)
+++ grass-addons/grass7/gui/wxpython/wx.wms/addserver.py	2011-08-04 08:35:01 UTC (rev 47417)
@@ -5,7 +5,9 @@
 import wx
 from BeautifulSoup import BeautifulSoup, Tag, NavigableString, BeautifulStoneSoup
 from ServerInfoAPIs import addServerInfo, removeServerInfo, updateServerInfo, initServerInfoBase, getAllRows
+from LoadConfig import loadConfigFile
 # begin wxGlade: extracode
 # end wxGlade
@@ -49,6 +51,10 @@
         #sudeep code starts
+        if( not loadConfigFile(self)):
+            print 'Config File Error, Unable to start application...'
+            self.Close()
         self.soup = initServerInfoBase('ServersList.xml')
         self.Bind(wx.EVT_CLOSE, self.OnQuit)
         self.__populate_URL_List(self.ServerList)
@@ -115,7 +121,8 @@
     def __populate_URL_List(self, ComboBox):
         self.servers = getAllRows(self.soup)
         for key, value in self.servers.items():
-            ComboBox.Append(value.servername+" "+value.url)
+            ComboBox.Append(value.servername+self.name_url_delimiter+value.url)
+            #ComboBox.Append(value.servername+" "+value.url)
         print self.servers
         return
     	''''f = open('serverList.txt','r')
@@ -144,13 +151,16 @@
     def __update_URL_List(self):
         self.ServerList.Clear()
-        for k,v in self.servers.iteritems():
-            name = v.servername+" "+v.url
-            self.ServerList.Append(name)
+        for key,value in self.servers.iteritems():
+            #name = v.servername+" "+v.url
+            self.ServerList.Append(value.servername+self.name_url_delimiter+value.url)
+            #self.ServerList.Append(name)
     def OnSave(self, event): # wxGlade: ServerAdd.<event_handler>
         #print "Event handler `OnSave' not implemented"
-        newServerName = self.ServerNameText.GetValue()
+        newServerName = unicode(self.ServerNameText.GetValue())
+        print newServerName
+        print 'check12'
         if(self.servers.has_key(newServerName)):
             update = True
             #print 'Server Name already exists'
@@ -193,11 +203,11 @@
             self.__update_URL_List()
   	    #Update_Url_List(newServerName+" "+newUrl)
         else:
-            print "Please Fill all the fields"
+            print "Please Fill servername and url fields"
         event.Skip()
     def OnRemove(self, event): # wxGlade: ServerAdd.<event_handler>
-        serverName = self.ServerNameText.GetValue()
+        serverName = unicode(self.ServerNameText.GetValue())
         if(len(serverName) > 0):
             if(removeServerInfo(self.soup, serverName)):
                 print 'remove successful'
@@ -231,10 +241,10 @@
         f = open('ServersList.xml','w')
         f.write(xml)
         f.close()
-        out = open('serverList.txt','w')
+        '''out = open('serverList.txt','w')
             out.write(v.servername+" "+v.url+" "+v.username+" "+v.password+"\n")
-        exit()
+        exit()'''
         #ServerAdd.Close()
         #print "Event handler `OnQuit' not implemented"
         event.Skip()
@@ -244,11 +254,11 @@
         url = self.ServerList.GetValue()
         print 'here'
         print url
-        urlarr = url.split()
+        urlarr = url.split(self.name_url_delimiter)
         print urlarr
         print self.servers
         if(len(urlarr)==2):
-            self.selectedServer = self.servers[urlarr[0]]
+            self.selectedServer = self.servers[unicode(urlarr[0])]
             print self.selectedServer
             self.ServerNameText.SetValue(self.selectedServer.servername)
             self.URLText.SetValue(self.selectedServer.url)
Modified: grass-addons/grass7/gui/wxpython/wx.wms/config
--- grass-addons/grass7/gui/wxpython/wx.wms/config	2011-08-04 08:28:07 UTC (rev 47416)
+++ grass-addons/grass7/gui/wxpython/wx.wms/config	2011-08-04 08:35:01 UTC (rev 47417)
@@ -0,0 +1 @@
+delimeter_servername_url :
Modified: grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
--- grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py	2011-08-04 08:28:07 UTC (rev 47416)
+++ grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py	2011-08-04 08:35:01 UTC (rev 47417)
@@ -9,8 +9,8 @@
 from WMSMapDisplay import NewImageFrame
 from addserver import AddServerFrame
 # end wxGlade
@@ -46,12 +46,18 @@
         #Sudeep's Code Starts
         #self.urlInput.SetValue('http://www.gisnet.lv/cgi-bin/topo')
+        self.usernameInput.Disable()
+        self.passwordInput.Disable()
+            self.Close()
         self.__populate_Url_List(self.ServerList)
         self.selectedURL="No server selected"
         self.layerTreeRoot = self.LayerTree.AddRoot("Layers")
-        self.usernameInput.Disable()
-        self.passwordInput.Disable()
         #items = ["a", "b", "c"]
         #itemId = self.LayerTree.AppendItem(self.layerTreeRoot, "item")
         #self.LayerTree.AppendItem(itemId, "inside")
@@ -93,10 +99,14 @@
         ComboBox = self.ServerList
         ComboBox.Append(name)
     def __populate_Url_List(self, ComboBox):
+            #ComboBox.Append(value.servername+" "+self.name_url_delimiter+" "+value.url)
         print self.servers
         return
@@ -114,6 +124,10 @@
         f.close()'''
     def OnGetCapabilities(self, event): # wxGlade: wmsFrame.<event_handler>
+        if(self.selectedURL == "No server selected"):
+            print 'no url selected\n returning...\n'
+            return
         self.usernameInput.Enable()
         self.passwordInput.Enable()
@@ -196,6 +210,8 @@
     def OnServerListEnter(self, event): # wxGlade: wmsFrame.<event_handler>
+        return
         print "Event handler `OnServerListEnter' not implemented"
         print self.ServerList.CurrentSelection
@@ -216,15 +232,25 @@
             print "Format not recognized, Format: Severname URL"
         #Sudeep's Code Ends
         event.Skip()
+    def printDict(self,dict):
+        for key in dict.keys():
+            print "the key name is" + key + "and its value is"
     def OnServerList(self, event): # wxGlade: wmsFrame.<event_handler>
         print "Event handler `OnServerList' not implemented"
+        print "OnServerList:printing urlarr"
+        print urlarr
+        print urlarr[0]
+        print urlarr[0].encode()
+        self.printDict(self.servers)
+        print "OnServerList: done"
         if(len(urlarr)==2):
-            self.selectedURL = self.servers[urlarr[0]].url
+            self.selectedURL = self.servers[urlarr[0].encode()].url
             print self.selectedURL
         else:
             print "Wrong format of URL selected"
