[GRASS-SVN] r47426 - in grass/trunk/scripts: d.correlate d.polar d.rast.edit d.rast.leg d.shadedmap d.vect.thematic db.dropcolumn db.droptable db.in.ogr db.out.ogr db.test i.fusion.brovey i.image.mosaic i.in.spotvgt i.landsat.rgb i.oif i.spectral i.tasscap m.proj r.blend r.buffer r.colors.stddev r.fillnulls r.grow r.in.aster r.in.srtm r.in.wms r.mask r.out.xyz r.pack r.plane r.reclass.area r.rgb r.shaded.relief r.tileset r.unpack v.centroids v.colors v.convert.all v.db.addcolumn v.db.addtable v.db.dropcolumn v.db.droprow v.db.droptable v.db.join v.db.reconnect.all v.db.renamecolumn v.db.univar v.db.update v.dissolve v.in.e00 v.in.geonames v.in.gns v.in.lines v.in.mapgen v.in.sites.all v.in.wfs v.krige v.out.gps v.rast.stats v.report v.what.vect wxpyimgview
Thu Aug 4 07:38:53 EDT 2011
Author: martinl
Date: 2011-08-04 04:38:53 -0700 (Thu, 04 Aug 2011)
New Revision: 47426
   grass/trunk/scripts/d.correlate/d.correlate.py
   grass/trunk/scripts/d.polar/d.polar.py
   grass/trunk/scripts/d.rast.edit/d.rast.edit.py
   grass/trunk/scripts/d.rast.leg/d.rast.leg.py
   grass/trunk/scripts/d.shadedmap/d.shadedmap.py
   grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
   grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py
   grass/trunk/scripts/db.droptable/db.droptable.py
   grass/trunk/scripts/db.in.ogr/db.in.ogr.py
   grass/trunk/scripts/db.out.ogr/db.out.ogr.py
   grass/trunk/scripts/db.test/db.test.py
   grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py
   grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
   grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
   grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
   grass/trunk/scripts/i.oif/i.oif.py
   grass/trunk/scripts/i.spectral/i.spectral.py
   grass/trunk/scripts/i.tasscap/i.tasscap.py
   grass/trunk/scripts/m.proj/m.proj.py
   grass/trunk/scripts/r.blend/r.blend.py
   grass/trunk/scripts/r.buffer/r.buffer.py
   grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py
   grass/trunk/scripts/r.fillnulls/r.fillnulls.py
   grass/trunk/scripts/r.grow/r.grow.py
   grass/trunk/scripts/r.in.aster/r.in.aster.py
   grass/trunk/scripts/r.in.srtm/r.in.srtm.py
   grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py
   grass/trunk/scripts/r.in.wms/r.in.wms.py
   grass/trunk/scripts/r.mask/r.mask.py
   grass/trunk/scripts/r.out.xyz/r.out.xyz.py
   grass/trunk/scripts/r.pack/r.pack.py
   grass/trunk/scripts/r.plane/r.plane.py
   grass/trunk/scripts/r.reclass.area/r.reclass.area.py
   grass/trunk/scripts/r.rgb/r.rgb.py
   grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py
   grass/trunk/scripts/r.tileset/r.tileset.py
   grass/trunk/scripts/r.unpack/r.unpack.py
   grass/trunk/scripts/v.centroids/v.centroids.py
   grass/trunk/scripts/v.colors/v.colors.py
   grass/trunk/scripts/v.convert.all/v.convert.all.py
   grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py
   grass/trunk/scripts/v.db.addtable/v.db.addtable.py
   grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py
   grass/trunk/scripts/v.db.droprow/v.db.droprow.py
   grass/trunk/scripts/v.db.droptable/v.db.droptable.py
   grass/trunk/scripts/v.db.join/v.db.join.py
   grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
   grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py
   grass/trunk/scripts/v.db.univar/v.db.univar.py
   grass/trunk/scripts/v.db.update/v.db.update.py
   grass/trunk/scripts/v.dissolve/v.dissolve.py
   grass/trunk/scripts/v.in.e00/v.in.e00.py
   grass/trunk/scripts/v.in.geonames/v.in.geonames.py
   grass/trunk/scripts/v.in.gns/v.in.gns.py
   grass/trunk/scripts/v.in.lines/v.in.lines.py
   grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
   grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py
   grass/trunk/scripts/v.in.wfs/v.in.wfs.py
   grass/trunk/scripts/v.krige/v.krige.py
   grass/trunk/scripts/v.out.gps/v.out.gps.py
   grass/trunk/scripts/v.rast.stats/v.rast.stats.py
   grass/trunk/scripts/v.report/v.report.py
   grass/trunk/scripts/v.what.vect/v.what.vect.py
   grass/trunk/scripts/wxpyimgview/wxpyimgview.py
   grass/trunk/scripts/wxpyimgview/wxpyimgview_gui.py
python scripts: use standard option
       		standardize option names
Modified: grass/trunk/scripts/d.correlate/d.correlate.py
--- grass/trunk/scripts/d.correlate/d.correlate.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/d.correlate/d.correlate.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -13,22 +13,17 @@
 #               License (>=v2). Read the file COPYING that comes with GRASS
 #               for details.
-# TODO GRASS 7: rename parameters to map1, map2 or better multiple map=map1[,map2[...]]
-#%Module
-#%  description: Prints a graph of the correlation between data layers (in pairs).
-#%  keywords: display
-#%  keywords: diagram
-#%End
-#%option
-#% key: layers
-#% type: string
-#% gisprompt: old,cell,raster
-#% description: raster input map
-#% required: yes
-#% multiple: yes
+#%module
+#% description: Prints a graph of the correlation between raster maps (in pairs).
+#% keywords: display
+#% keywords: raster
+#% keywords: diagram
+#% keywords: correlation
 #%end
+#%option G_OPT_R_MAPS
+#%end
 import sys
 import os
Modified: grass/trunk/scripts/d.polar/d.polar.py
--- grass/trunk/scripts/d.polar/d.polar.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/d.polar/d.polar.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -23,13 +23,8 @@
 #%End
-#%option
-#% key: map
-#% type: string
-#% key_desc: name
 #% description: Name of raster angle map
-#% required : yes
 #%End
 #%option
 #% key: undef
@@ -37,11 +32,9 @@
 #% description: Pixel value to be interpreted as undefined (different from NULL)
 #% required : no
 #%End
-#%option
+#%option G_OPT_F_OUTPUT
 #% key: eps
-#% type: string
-#% gisprompt: new_file,file,output
-#% description: Name of optional EPS output file
+#% description: Name for optional EPS output file
 #% required : no
 #%end
 #%flag
Modified: grass/trunk/scripts/d.rast.edit/d.rast.edit.py
--- grass/trunk/scripts/d.rast.edit/d.rast.edit.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/d.rast.edit/d.rast.edit.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -18,78 +18,61 @@
-#%Module
-#% description: Interactively edit cell values in a raster map.
+#%module
+#% description: Edits cell values in a raster map.
 #% keywords: raster
-#%End
-#%Option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Name of input raster map
-#%End
-#%Option
-#% key: output
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Name for output raster map
-#% gisprompt: new,cell,raster
-#%End
-#%Option
+#% keywords: edit
+#%end
+#%option G_OPT_R_INPUT
+#%end
+#%option G_OPT_R_OUTPUT
+#%end
 #% key: aspect
-#% type: string
 #% required: no
-#% multiple: no
-#% key_desc: name
-#% description: Name of aspect raster map
-#%End
-#%Option
+#% description: Name of input aspect raster map
+#%end
+#%option
 #% key: width
 #% type: integer
 #% required: no
 #% multiple: no
 #% description: Width of display canvas
 #% answer: 640
-#%End
-#%Option
+#%end
+#%option
 #% key: height
 #% type: integer
 #% required: no
 #% multiple: no
 #% description: Height of display canvas
 #% answer: 480
-#%End
-#%Option
+#%end
+#%option
 #% key: size
 #% type: integer
 #% required: no
 #% multiple: no
 #% description: Minimum size of each cell
 #% answer: 12
-#%End
-#%Option
+#%end
+#%option
 #% key: rows
 #% type: integer
 #% required: no
 #% multiple: no
 #% description: Maximum number of rows to load
 #% answer: 100
-#%End
-#%Option
+#%end
+#%option
 #% key: cols
 #% type: integer
 #% required: no
 #% multiple: no
 #% description: Maximum number of columns to load
 #% answer: 100
-#%End
+#%end
 import sys
 import math
Modified: grass/trunk/scripts/d.rast.leg/d.rast.leg.py
--- grass/trunk/scripts/d.rast.leg/d.rast.leg.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/d.rast.leg/d.rast.leg.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -36,10 +36,10 @@
 # Glynn Clements 10/2008: converted to Python
-#%Module
-#%  description: Displays a raster map and its legend on a graphics window
-#%End
+#%module
+#% description: Displays a raster map and its legend on a graphics window
+#%end
 #%flag
 #%  key: f
 #%  description: Flip legend
@@ -48,25 +48,19 @@
 #%  key: n
 #%  description: Omit entries with missing label
 #%end
-#%option
-#% key: map
-#% type: string
 #% description: Name of raster map to display
-#% required : yes
 #%end
 #%option
 #% key: lines
 #% type: integer
 #% description: Number of lines to appear in the legend
-#% required : no
+#% required: no
 #%end
-#%option
-#% key: rast
-#% type: string
-#% description: Name of raster map to generate legend from
-#% required : no
+#% key: raster
+#% description: Name of input raster map to generate legend from
+#% required: no
 #%end
 import sys
Modified: grass/trunk/scripts/d.shadedmap/d.shadedmap.py
--- grass/trunk/scripts/d.shadedmap/d.shadedmap.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/d.shadedmap/d.shadedmap.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -14,23 +14,17 @@
-#%Module
-#% description: Drapes a color raster over a shaded relief map using d.his
+#%module
+#% description: Drapes a color raster over a shaded relief map.
-#%End
-#%option
+#%end
 #% key: reliefmap
-#% type: string
-#% description: Name of shaded relief or aspect map
-#% required : yes
+#% description: Name of shaded relief or aspect raster map
 #%end
-#%option
 #% key: drapemap
-#% type: string
-#% description: Name of raster to drape over relief map
-#% required : yes
+#% description: Name of raster to drape over relief raster map
 #%end
 #%option
 #% key: brighten
Modified: grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -16,189 +16,159 @@
-#%Module
+#%module
 #% description: Displays thematic vector map
 #% keywords: vector
 #% keywords: thematic
 #% keywords: legend
-#%End
-#%option
-#% guisection: Files
-#% key: map
-#% type: string
-#% gisprompt: old,vector,vector
-#% description: Name of vector map
-#% required : yes
 #%end
-#%option
-#% guisection: Theme
-#% key: type
-#% type: string
-#% description: Feature type
-#% options: area,point,centroid,line,boundary
-#% answer: area
-#% required : yes
+#%option G_OPT_V_MAP
 #%end
-#%option
-#% key: column
-#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
-#% type: string
+#%option G_OPT_V_FIELD
+#%end
+#%option G_OPT_DB_COLUMN
 #% description: Name of attribute column to use for thematic display (must be numeric)
-#% required : yes
+#% required: yes
 #%end
+#%option G_OPT_V_TYPE
+#% answer: area
+#%end
 #%option
 #% key: themetype
 #% type: string
 #% options: graduated_colors,graduated_points,graduated_lines
 #% answer: graduated_colors
 #% description: Type of thematic display
-#% required : yes
+#% required: yes
+#% guisection: Theme
 #%end
 #%option
 #% key: themecalc
 #% type: string
 #% options: interval,std_deviation,quartiles,custom_breaks
 #% answer: interval
 #% description: Thematic divisions of data for display
-#% required : yes
+#% required: yes
 #%end
 #%option
 #% key: breakpoints
 #% type: string
 #% label: Break points for custom breaks option
 #% description: Separate values by spaces (0 10 20 30 ...)
-#% required : no
-#%end
-#%option
+#% required: no
-#% key: layer
-#% type: integer
-#% gisprompt: old_layer,layer,layer
-#% description: Layer number
-#% answer: 1
-#% required : no
 #%end
 #%option
-#% guisection: Points
 #% key: icon
 #% type: string
 #% description: Vector point icon for point data
 #% options: basic/box,basic/circle,basic/cross2,basic/diamond,basic/star,basic/cross1,basic/x
 #% answer: basic/circle
-#% required : no
+#% required: no
+#% guisection: Points
 #%end
 #%option
 #% key: size
 #% type: double
 #% label: Icon size for point data
 #% description: Minimum icon size/line width for graduated points/lines)
 #% answer: 5
-#% required : no
+#% required: no
 #%end
 #%option
 #% key: maxsize
 #% type: double
 #% description: Maximum icon size/line width for graduated points and lines
 #% answer: 20
-#% required : no
+#% required: no
 #%end
 #%option
 #% key: nint
 #% type: integer
 #% description: Number of classes for interval theme (integer)
 #% answer: 4
-#% required : no
+#% required: no
 #%end
 #%option
-#% guisection: Color
 #% key: colorscheme
 #% type: string
 #% label: Color scheme for graduated color mapping
 #% description: Select 'single_color' for graduated point/line display
 #% options: blue-red,red-blue,green-red,red-green,blue-green,green-blue,cyan-yellow,yellow-cyan,custom_gradient,single_color
 #% answer: blue-red
-#% required : yes
+#% required: yes
+#% guisection: Color
 #%end
 #% option
 #% key: pointcolor
 #% type: string
 #% label: Color for graduated points map
 #% description: GRASS named color or R:G:B triplet. Set color scheme to single color
 #% answer: 255:0:0
-#% required : no
+#% required: no
 #%end
 #% option
 #% key: linecolor
 #% type: string
 #% label: Color for graduated lines or point/area outlines
 #% description: GRASS named color or R:G:B triplet. Set color scheme to single color.
 #% answer: 0:0:0
-#% required : no
+#% required: no
 #%end
 #% option
 #% key: startcolor
 #% type: string
 #% label: Beginning color for custom color gradient
 #% description: Must be expressed as R:G:B triplet
 #% answer: 255:0:0
-#% required : no
+#% required: no
 #%end
 #% option
 #% key: endcolor
 #% type: string
 #% label: Ending color for custom color gradient
 #% answer: 0:0:255
-#% required : no
+#% required: no
 #%end
 #% option
-#% guisection: Misc
 #% key: monitor
 #% type: string
-#% description: Select x11 display monitor for legend
-#% options: x0,x1,x2,x3,x4,x5,x6,none
-#% answer: x1
-#% required : no
+#% description: Select WXGUI display monitor for legend
+#% options: wx0,wx1,wx2,wx3,wx4,wx5,wx6,none
+#% answer: wx1
+#% required: no
+#% guisection: Misc
 #%end
 #%flag
-#%key: g
+#% key: g
 #%description: Save thematic map commands to group file for GIS Manager
 #%end
-#%option
+#%option G_OPT_DB_WHERE
-#% key: where
-#% type: string
-#% description: WHERE conditions of SQL statement without 'where' keyword
-#% required : no
 #%end
 #%option
 #% key: psmap
 #% type: string
 #% label: Root for the name of psmap instruction files to be in current directory
 #% description: If not set, no psmap instruction files will be created)
-#% required : no
-#%end
-#%option
+#% required: no
-#% key: group
-#% type: string
-#% gisprompt: new_file,file,group
+#%end
+#%option G_OPT_I_GROUP
 #% description: Name of group file where thematic map commands will be saved
-#% required : no
+#% required: no
+#% guisection: Files
 #%end
 #%flag
Modified: grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py
--- grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/db.dropcolumn/db.dropcolumn.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -28,21 +28,12 @@
 #%  description: Force removal (required for actual deletion of files)
 #%end
-#%option
-#% key: table
-#% type: string
-#% key_desc : name
-#% description: Table from which to drop attribute column
+#%option G_OPT_DB_TABLE
 #% required : yes
-#% gisprompt: old_dbtable,dbtable,dbtable
 #%end
-#%option
-#% key: column
-#% type: string
-#% description: Name of the column
 #% required : yes
-#% gisprompt: old,dbcolumn,dbcolumn
 #%end
 import sys
Modified: grass/trunk/scripts/db.droptable/db.droptable.py
--- grass/trunk/scripts/db.droptable/db.droptable.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/db.droptable/db.droptable.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -15,24 +15,20 @@
-#%Module
-#%  description: Drops an attribute table.
-#%  keywords: database
-#%  keywords: attribute table
-#%End
+#%module
+#% description: Drops an attribute table.
+#% keywords: database
+#% keywords: attribute table
+#%end
 #%flag
-#%  key: f
-#%  description: Force removal (required for actual deletion of files)
+#% key: f
+#% description: Force removal (required for actual deletion of files)
 #%end
-#%option
-#% key: table
-#% type: string
-#% key_desc : name
-#% description: Table to drop
-#% required : yes
+#% description: Table name to drop
+#% required: yes
 #%end
 import sys
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -37,7 +37,7 @@
 #% required : no
 #%end
-#%option
+#%option
 #% key: output
 #% type: string
 #% description: Name for output table
Modified: grass/trunk/scripts/db.out.ogr/db.out.ogr.py
--- grass/trunk/scripts/db.out.ogr/db.out.ogr.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/db.out.ogr/db.out.ogr.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -14,24 +14,21 @@
-#%Module
-#%  description: Exports attribute tables into various formats.
-#%End
+#%module
+#% description: Exports attribute tables into various formats.
+#%end
-#%option
 #% key: input
-#% type: string
-#% key_desc : name
-#% description: GRASS table name
-#% required : yes
+#% required: yes
 #%end
 #%option
 #% key: dsn
 #% type: string
-#% key_desc : name
+#% key_desc: name
 #% gisprompt: new_file,file,input
 #% description: Table file to be exported or DB connection string
 #% required : yes
@@ -41,17 +38,17 @@
 #% key: format
 #% type: string
 #% description: Table format
-#% required : yes
+#% required: yes
 #% options: CSV,DBF,GML,MySQL,PostgreSQL,SQLite
 #% answer: DBF
 #%end
 #%option
-#% key: db_table
+#% key: table
 #% type: string
-#% key_desc : name
-#% description: Name for output table
-#% required : no
+#% key_desc: name
+#% description: Name for output table (defaut: input)
+#% required: no
 #%end
 import sys
Modified: grass/trunk/scripts/db.test/db.test.py
--- grass/trunk/scripts/db.test/db.test.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/db.test/db.test.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -13,18 +13,18 @@
-#% Module
-#%  description: Test database driver, database must exist and set by db.connect.
-#% End
-#% option
-#%  key: test
-#%  type: string
-#%  description: Test name
-#%  required : yes
-#%  options : test1
-#% end
+#%module
+#% description: Test database driver, database must exist and set by db.connect.
+#%end
+#%option
+#% key: test
+#% type: string
+#% description: Test name
+#% required: yes
+#% options: test1
+#%end
 import sys
 import os
Modified: grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py
--- grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/i.fusion.brovey/i.fusion.brovey.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -48,39 +48,26 @@
 #%  description: SPOT sensor
 #%  guisection: Sensor
 #%END
-#%option
 #% key: ms1
-#% type: string
 #% description: Name of input raster map (green: tm2 | qbird_green | spot1)
-#% required : yes
 #%end
-#%option
 #% key: ms2
-#% type: string
 #% description: Name of input raster map (NIR: tm4 | qbird_nir | spot2
-#% required : yes
 #%end
-#%option
 #% key: ms3
-#% type: string
 #% description: Name of input raster map (MIR; tm5 | qbird_red | spot3
-#% required : yes
 #%end
-#%option
 #% key: pan
-#% type: string
 #% description: Name of input raster map (etmpan | qbird_pan | spotpan)
-#% required : yes
 #%end
 #%option
-#% key: outputprefix
+#% key: output_prefix
 #% type: string
-#% description: Name for output raster map prefix (e.g. 'brov')
+#% description: Prefix for output raster maps
 #% required : yes
 #%end
Modified: grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py
--- grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/i.image.mosaic/i.image.mosaic.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -22,27 +22,16 @@
-#% Module
-#%  description: Mosaics several images and extends colormap
-#%  keywords: raster
-#%  keywords: imagery
-#%  keywords: mosaicking
-#% End
-#% option
-#% key: images
-#% type: string
-#% description: maps for mosaic.
-#% required: yes
-#% multiple: yes
-#% end
-#%option
-#% key: output
-#% type: string
-#% description: reclass raster output map
-#% required : no
-#%END
+#%module
+#% description: Mosaics several images and extends colormap.
+#% keywords: imagery
+#% keywords: mosaicking
+#%end
+#%option G_OPT_R_INPUTS
+#%end
+#%end
 import sys
 import os
@@ -73,9 +62,6 @@
     images = options['images'].split(',')
     output = options['output']
-    if not output:
-	output = '.'.join(images) + '.mosaic'
     count = len(images)
     grass.warning(_('Do not forget to set region properly to cover all images.'))
@@ -102,7 +88,7 @@
     p.stdin.close()
     p.wait()
-    grass.message(_("Ready. File %s created.") % output)
+    grass.message(_("Done. Raster map <%s> created.") % output)
     # write cmd history:
     grass.raster_history(output)
Modified: grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py
--- grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/i.in.spotvgt/i.in.spotvgt.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -29,28 +29,19 @@
 #   -> correction of 0001/0001_LOG.TXT coordinates by 0.5 pixel
-#%Module
-#%  description: Imports SPOT VGT NDVI data into a raster map.
-#%  keywords: import
-#%End
+#%module
+#% description: Imports SPOT VGT NDVI data into a raster map.
+#% keywords: import
+#%end
 #%flag
 #% key: a
 #% description: Also import quality map (SM status map layer) and filter NDVI map
 #%end
-#%option
-#% key: file
-#% type: string
-#% description: Existing SPOT VGT NDVI HDF file (0001_NDV.HDF)
-#% gisprompt: old_file,file,input
-#% required : yes
+#%option G_OPT_F_INPUT
+#% description: Name of input SPOT VGT NDVI HDF file
 #%end
-#%option
-#% key: rast
-#% type: string
+#% option G_OPT_R_OUTPUT
 #% required : no
 #%end
Modified: grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py
--- grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/i.landsat.rgb/i.landsat.rgb.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -20,32 +20,23 @@
 # TODO: implement better brightness control
-#%Module
-#%  description: Performs auto-balancing of colors for LANDSAT images.
-#%  keywords: colors
-#%End
-#%option
+#%module
+#% description: Performs auto-balancing of colors for LANDSAT images.
+#% keywords: colors
+#%end
 #% key: red
-#% type: string
-#% description: LANDSAT red channel
-#% required : yes
+#% description: Name of LANDSAT red channel
 #%end
-#%option
 #% key: green
-#% type: string
-#% description: LANDSAT green channel
-#% required : yes
+#% description: Name of LANDSAT green channel
 #%end
-#%option
 #% key: blue
-#% type: string
-#% description: LANDSAT blue channel
-#% required : yes
+#% description: Name of LANDSAT blue channel
 #%end
 #%option
 #% key: strength
@@ -53,7 +44,7 @@
 #% description: Cropping intensity (upper brightness level)
 #% options: 0-100
 #% answer : 98
-#% required : no
+#% required: no
 #%end
 #%flag
 #% key: f
Modified: grass/trunk/scripts/i.oif/i.oif.py
--- grass/trunk/scripts/i.oif/i.oif.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/i.oif/i.oif.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -29,47 +29,29 @@
 #%  keywords: statistics
 #% End
-#% option
+#% option G_OPT_R_INPUT
 #% key: image1
-#% type: string
 #% description: LANDSAT TM band 1.
-#% required : yes
 #% end
-#% option
 #% key: image2
-#% type: string
 #% description: LANDSAT TM band 2.
-#% required : yes
 #% end
-#% option
 #% key: image3
-#% type: string
 #% description: LANDSAT TM band 3.
-#% required : yes
 #% end
-#% option
 #% key: image4
-#% type: string
 #% description: LANDSAT TM band 4.
-#% required : yes
 #% end
-#% option
 #% key: image5
-#% type: string
 #% description: LANDSAT TM band 5.
-#% required : yes
 #% end
-#% option
 #% key: image7
-#% type: string
 #% description: LANDSAT TM band 7.
-#% required : yes
 #% end
 #% Flag
 #% key: g
@@ -109,7 +91,7 @@
 	image[band] = options['image%d' % band]
     # calculate the Stddev for TM bands
-    grass.verbose("Calculating Standard deviations for all bands:")
+    grass.message(_("Calculating Standard deviations for all bands..."))
     stddev = {}
     for band in bands:
 	grass.verbose("band %d" % band)
@@ -117,7 +99,7 @@
 	kv = grass.parse_key_val(s)
 	stddev[band] = float(kv['stddev'])
-    grass.verbose("Calculating Correlation Matrix")
+    grass.message(_("Calculating Correlation Matrix..."))
     correlation = {}
     s = grass.read_command('r.covar', flags = 'r', map = [image[band] for band in bands])
     for i, row in zip(bands, s.splitlines()):
@@ -125,17 +107,16 @@
 	    correlation[i,j] = float(cell)
     # Calculate all combinations
-    grass.verbose("Calculating OIF for the 20 band combinations...")
+    grass.message(_("Calculating OIF for the 20 band combinations..."))
     oif = []
     for p in perms():
 	oif.append((oifcalc(stddev, correlation, *p), p))
     oif.sort(reverse = True)
-    grass.verbose("Ready.")
-    grass.verbose("The Optimum Index Factor analysis result:")
-    grass.verbose("    (Best combination comes first.)")
+    grass.verbose(_("The Optimum Index Factor analysis result "
+                    "(Best combination comes first):"))
     if shell:
 	fmt = "%d%d%d:%f\n"
     else:
Modified: grass/trunk/scripts/i.spectral/i.spectral.py
--- grass/trunk/scripts/i.spectral/i.spectral.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/i.spectral/i.spectral.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -27,35 +27,18 @@
 #%  keywords: raster
 #%  keywords: multispectral
 #%End
-#%option
-#% key: group
-#% type: string
-#% gisprompt: old,group
-#% description: Group input
 #% required : no
 #%end
-#%option
-#% key: raster
-#% type: string
-#% description: Raster input maps
-#% multiple : yes
 #% required : no
 #%end
-#%option
 #% key: output
-#% type: string
-#% gisprompt: new_file,file,PNG
-#% description: Write output to PNG image
-#% multiple : no
+#% description: Name for output PNG image
 #% required : no
 #%end
-#%option
-#% key: coords
-#% type: double
-#% key_desc: east,north
-#% description: Coordinates
-#% multiple : yes
+#%option G_OPT_M_EN
 #% required : yes
 #%end
 #%flag
Modified: grass/trunk/scripts/i.tasscap/i.tasscap.py
--- grass/trunk/scripts/i.tasscap/i.tasscap.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/i.tasscap/i.tasscap.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -33,70 +33,51 @@
 #%Module
-#%  description: Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data
-#%End
+#% description: Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data.
+#% keywords: transformation
+#%end
 #%flag
-#%  key: 4
-#%  description: use transformation rules for LANDSAT-4
-#%END
+#% key: 4
+#% description: Use transformation rules for LANDSAT-4
+#%end
 #%flag
-#%  key: 5
-#%  description: use transformation rules for LANDSAT-5
-#%END
+#% key: 5
+#% description: Use transformation rules for LANDSAT-5
+#%end
 #%flag
-#%  key: 7
-#%  description: use transformation rules for LANDSAT-7
-#%END
-#%option
+#% key: 7
+#% description: Use transformation rules for LANDSAT-7
+#%end
 #% key: band1
-#% type: string
-#% description: raster input map (LANDSAT channel 1)
-#% required : yes
+#% description: Name of input raster map (LANDSAT channel 1)
 #%end
-#%option
 #% key: band2
-#% type: string
-#% description: raster input map (LANDSAT channel 2)
-#% required : yes
+#% description: Name of input raster map (LANDSAT channel 2)
 #%end
-#%option
 #% key: band3
-#% type: string
-#% description: raster input map (LANDSAT channel 3)
-#% required : yes
+#% description: Name of input raster map (LANDSAT channel 3)
 #%end
-#%option
 #% key: band4
-#% type: string
-#% description: raster input map (LANDSAT channel 4)
-#% required : yes
+#% description: Name of input raster map (LANDSAT channel 4)
 #%end
-#%option
 #% key: band5
-#% type: string
-#% description: raster input map (LANDSAT channel 5)
-#% required : yes
+#% description: Name of input raster map (LANDSAT channel 5)
 #%end
-#%option
 #% key: band7
-#% type: string
-#% description: raster input map (LANDSAT channel 7)
-#% required : yes
+#% description: Name of input raster map (LANDSAT channel 7)
 #%end
 #%option
-#% key: outprefix
 #% type: string
-#% description: raster output TC maps prefix
-#% required : yes
+#% required: yes
 #%end
 import sys
Modified: grass/trunk/scripts/m.proj/m.proj.py
--- grass/trunk/scripts/m.proj/m.proj.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/m.proj/m.proj.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -24,37 +24,25 @@
 #    numeric and string columns would survive the trip, and 3rd column would
 #    not be modified as z.
-#%Module
-#%  description: Converts coordinates from one projection to another (cs2cs frontend).
-#%  keywords: miscellaneous
-#%  keywords: projection
-#%End
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old_file,file,file
-#% description: Input coordinate file ('-' to read from stdin)
+#%module
+#% description: Converts coordinates from one projection to another (cs2cs frontend).
+#% keywords: miscellaneous
+#% keywords: projection
+#%end
+#% description: Name of input coordinate file ('-' to read from stdin)
 #% answer: -
-#% key_desc : filename
 #% guisection: Files & format
 #%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new_file,file,file
-#% description: Output coordinate file (omit to send to stdout)
+#% description: Name for output coordinate file (omit to send to stdout)
 #% required : no
 #%end
-#%option
-#% key: fs
-#% type: string
+#%option G_OPT_F_SEP
 #% label: Field separator (format: input[,output])
 #% description: Valid field separators are also "space", "tab", or "comma"
 #% required : no
-#% key_desc : string
-#% answer : |
 #%end
 #%option
Modified: grass/trunk/scripts/r.blend/r.blend.py
--- grass/trunk/scripts/r.blend/r.blend.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.blend/r.blend.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -14,30 +14,22 @@
-#%Module
-#%  description: Blends color components of two raster maps by a given ratio.
-#%End
-#%option
+#%module
+#% description: Blends color components of two raster maps by a given ratio.
+#%end
 #% key: first
-#% type: string
 #% description: Name of first raster map for blending
-#% key_desc : name
-#% required : yes
 #%end
-#%option
 #% key: second
-#% type: string
 #% description: Name of second raster map for blending
-#% key_desc : name
-#% required : yes
 #%end
-#%option
-#% key: output
+#%option
 #% type: string
-#% description: Base name for red, green and blue output maps containing the blend
+#% description: Prefix for red, green and blue output raster maps containing
 #% key_desc : name
 #% required : yes
 #%end
Modified: grass/trunk/scripts/r.buffer/r.buffer.py
--- grass/trunk/scripts/r.buffer/r.buffer.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.buffer/r.buffer.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -14,49 +14,31 @@
-#%Module
+#%module
 #% description: Creates a raster map showing buffer zones surrounding cells that contain non-NULL category values.
 #% keywords: raster
 #% keywords: buffer
-#%End
-#%Flag
+#%end
+#%flag
 #% key: z
 #% description: Ignore zero (0) data cells instead of NULL cells
-#%End
-#%Option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#%End
-#%Option
-#% key: output
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#%End
-#%Option
+#%end
+#%end
+#%end
+#%option
 #% key: distances
 #% type: double
 #% required: yes
 #% multiple: yes
 #% description: Distance zone(s)
-#%End
-#%Option
-#% key: units
-#% type: string
-#% required: no
-#% multiple: no
+#%end
+#%option G_OPT_M_UNITS
 #% options: meters,kilometers,feet,miles,nautmiles
 #% description: Units of distance
 #% answer: meters
-#%End
+#%end
 import sys
 import os
Modified: grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py
--- grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.colors.stddev/r.colors.stddev.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -14,19 +14,13 @@
-#%Module
-#% description: Set color rules based on stddev from a raster map's mean value.
+#%module
+#% description: Sets color rules based on stddev from a raster map's mean value.
 #% keywords: raster
 #% keywords: color table
-#%End
-#% option
-#% key: map
-#% type: string
-#% key_desc: name
-#% required: yes
 #%end
+#% option G_OPT_R_MAP
+#%end
 #%flag
 #% key: b
 #% description: Color using standard deviation bands
Modified: grass/trunk/scripts/r.fillnulls/r.fillnulls.py
--- grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.fillnulls/r.fillnulls.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -20,26 +20,16 @@
-#%Module
-#% description: Fills no-data areas in raster maps using v.surf.rst splines interpolation
+#%module
+#% description: Fills no-data areas in raster maps using splines interpolation.
 #% keywords: raster
 #% keywords: elevation
 #% keywords: interpolation
-#%End
-#%option
-#% key: input
-#% type: string
-#% description: Raster map in which to fill nulls
-#% required : yes
 #%end
-#%option
-#% key: output
-#% type: string
-#% description: Output raster map with nulls filled by interpolation from surrounding values
-#% required : yes
 #%end
+#%end
 #%option
 #% key: tension
 #% type: double
Modified: grass/trunk/scripts/r.grow/r.grow.py
--- grass/trunk/scripts/r.grow/r.grow.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.grow/r.grow.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -17,38 +17,24 @@
 #%Module
 #% description: Generates a raster map layer with contiguous areas grown by one cell.
 #% keywords: raster
-#%End
-#%Flag
+#%end
+#%flag
 #% key: m
-#% description: radius is in map units rather than cells
-#%End
-#%Option
-#% key: input
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#%End
-#%Option
-#% key: output
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#%End
-#%Option
+#% description: Radius is in map units rather than cells
+#%end
+#%end
+#%end
+#%option
 #% key: radius
 #% type: double
 #% required: no
 #% multiple: no
 #% description: Radius of buffer in raster cells
 #% answer: 1.01
-#%End
-#%Option
+#%end
+#%option
 #% key: metric
 #% type: string
 #% required: no
@@ -56,21 +42,21 @@
 #% options: euclidean,maximum,manhattan
 #% description: Metric
 #% answer: euclidean
-#%End
-#%Option
+#%end
+#%option
 #% key: old
 #% type: integer
 #% required: no
 #% multiple: no
 #% description: Value to write for input cells which are non-NULL (-1 => NULL)
-#%End
-#%Option
+#%end
+#%option
 #% key: new
 #% type: integer
 #% required: no
 #% multiple: no
 #% description: Value to write for "grown" cells
-#%End
+#%end
 import sys
 import os
Modified: grass/trunk/scripts/r.in.aster/r.in.aster.py
--- grass/trunk/scripts/r.in.aster/r.in.aster.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.in.aster/r.in.aster.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -26,12 +26,8 @@
 #%  keywords: import
 #%End
-#%option
-#%  key: input
-#%  type: string
-#%  description: Input ASTER image to be georeferenced & rectified
-#%  required: yes
+#%  description: Name of input ASTER image
 #%end
 #%option
 #%  key: proctype
@@ -48,17 +44,9 @@
 #%  answer: all
 #%  required: yes
 #%end
-#%option
-#%  key: output
-#%  type: string
 #%  description: Base name for output raster map (band number will be appended to base name)
-#%  required: yes
 #%end
-#%flag
-#%  key: o
-#%  description: Overwrite existing file
-#%END
 import sys
 import os
@@ -168,7 +156,7 @@
     #import geotiff to GRASS
     grass.message(_("Importing into GRASS ..."))
     outfile = "%s.%s" % (output, band)
-    grass.run_command("r.in.gdal", overwrite = flags['o'], input = tempfile, output = outfile)
+    grass.run_command("r.in.gdal", input = tempfile, output = outfile)
     # write cmd history
     grass.raster_history(outfile)
Modified: grass/trunk/scripts/r.in.srtm/r.in.srtm.py
--- grass/trunk/scripts/r.in.srtm/r.in.srtm.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.in.srtm/r.in.srtm.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -48,18 +48,11 @@
 #%  keywords: raster
 #%  keywords: import
 #%End
-#%option
-#% key: input
-#% type: string
-#% description: SRTM input tile (file without .hgt.zip extension)
-#% required : yes
+#% description: Name of SRTM input tile (file without .hgt.zip extension)
 #%end
-#%option
-#% key: output
-#% type: string
-#% description: Output raster map (default: input tile)
+#% description: Name for output raster map (default: input tile)
 #% required : no
 #%end
 #%flag
Modified: grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py
--- grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.in.wms/r.in.gdalwarp.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -40,18 +40,16 @@
 #% key: k
 #% description: Keep band numbers instead of using band color names
 #%end
-#%option
-#% key: input
-#% type: string
-#% label: Raster file or files to be imported
+#% label: Name of raster file or files to be imported
 #% description: If multiple files are specified they will be patched together.
 #% multiple: yes
-#% required : yes
 #%end
 #%option
 #% key: output
 #% type: string
-#% description: Name for resultant raster map. Each band will be name output.bandname
+#% label: Prefix for resultant raster maps.
+#% description: Each band will be name output.bandname
 #% required : yes
 #%end
 #%option
Modified: grass/trunk/scripts/r.in.wms/r.in.wms.py
--- grass/trunk/scripts/r.in.wms/r.in.wms.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.in.wms/r.in.wms.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -65,11 +65,7 @@
 #% description: Use GDAL WMS driver
 #% guisection: Request
 #%end
-#%option
-#% key: output
-#% type: string
 #% required : no
 #% guisection: Import
 #%end
Modified: grass/trunk/scripts/r.mask/r.mask.py
--- grass/trunk/scripts/r.mask/r.mask.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.mask/r.mask.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -20,13 +20,8 @@
 #% keywords: raster
 #% keywords: mask
 #%end
-#%option
-#% key: input
-#% type: string
-#% description: Raster map to use as mask
-#% required: no
-#% guisection: Create
+#% description: Name of raster map to use as mask
 #%end
 #%option
 #% key: maskcats
@@ -44,6 +39,7 @@
 #% key: r
 #% description: Remove existing mask (overrides other options)
 #% guisection: Remove
+#% suppress_required: yes
 #%end
 import sys
Modified: grass/trunk/scripts/r.out.xyz/r.out.xyz.py
--- grass/trunk/scripts/r.out.xyz/r.out.xyz.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.out.xyz/r.out.xyz.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -16,34 +16,18 @@
-#%Module
-#% description: Export a raster map to a text file as x,y,z values based on cell centers.
+#%module
+#% description: Exports a raster map to a text file as x,y,z values based on cell centers.
 #% keywords: raster
 #% keywords: export
-#%End
-#%option
-#% key: input
-#% type: string
-#% key_desc: name
-#% required: yes
 #%end
-#%option
-#% key: output
-#% type: string
-#% key_desc: name
+#%end
 #% description: Name for output file (if omitted or "-" output to stdout)
 #% required: no
 #%end
-#%option
-#% key: fs
-#% type: string
-#% key_desc: character
-#% description: Field separator
-#% answer: |
-#% required: no
 #%end
 import sys
Modified: grass/trunk/scripts/r.pack/r.pack.py
--- grass/trunk/scripts/r.pack/r.pack.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.pack/r.pack.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -19,20 +19,11 @@
 #% keywords: export
 #% keywords: copying
 #%end
-#%option
-#% key: input
-#% type: string
 #% description: Name of raster map to pack up
-#% key_desc: name
-#% required : yes
 #%end
-#%option
-#% key: output
-#% type: string
 #% description: Name for output file (default is <input>.pack)
-#% key_desc: path
 #% required : no
 #%end
Modified: grass/trunk/scripts/r.plane/r.plane.py
--- grass/trunk/scripts/r.plane/r.plane.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.plane/r.plane.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -16,24 +16,19 @@
-#%Module
-#%  description: Creates raster plane map given dip (inclination), aspect (azimuth) and one point.
-#%  keywords: elevation
-#%End
-#%option
-#% key: name
-#% type: string
-#% description: Name of raster plane to be created
-#% required : yes
+#%module
+#% description: Creates raster plane map given dip (inclination), aspect (azimuth) and one point.
+#% keywords: elevation
 #%end
+#%end
 #%option
 #% key: dip
 #% type: double
 #% gisprompt: -90-90
 #% answer: 0.0
-#% description: Dip of plane. Value must be between -90 and 90 degrees
+#% description: Dip of plane in degrees
 #% required : yes
 #%end
 #%option
@@ -41,7 +36,7 @@
 #% type: double
 #% gisprompt: 0-360
 #% answer: 0.0
-#% description: Azimuth of the plane. Value must be between 0 and 360 degrees
+#% description: Azimuth of the plane in degrees
 #% required : yes
 #%end
 #%option
Modified: grass/trunk/scripts/r.reclass.area/r.reclass.area.py
--- grass/trunk/scripts/r.reclass.area/r.reclass.area.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.reclass.area/r.reclass.area.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -20,39 +20,30 @@
 # 2000: updated to GRASS 5
 # 1998 from NRCS, slightly modified for GRASS 4.2.1
-#%Module
-#%  description: Reclasses a raster map greater or less than user specified area size (in hectares).
-#%  keywords: statistics
-#%  keywords: aggregation
-#%End
+#%module
+#% description: Reclasses a raster map greater or less than user specified area size (in hectares).
+#% keywords: statistics
+#% keywords: aggregation
+#%end
-#%option
-#% key: input
-#% type: string
-#% required : yes
-#%END
+#%end
-#%option
-#% key: output
-#% type: string
-#% required : yes
-#%END
+#%end
 #%option
 #% key: lesser
 #% type: double
 #% description: Lesser value option that sets the <= area size limit [hectares]
-#%END
+#%end
 #%option
 #% key: greater
 #% type: double
 #% description: Greater value option that sets the >= area size limit [hectares]
-#%END
+#%end
 import sys
 import os
Modified: grass/trunk/scripts/r.rgb/r.rgb.py
--- grass/trunk/scripts/r.rgb/r.rgb.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.rgb/r.rgb.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -13,23 +13,19 @@
-#% Module
-#%  description: Split a raster map into red, green and blue maps
-#% End
-#% option
-#%  key: input
-#%  type: string
-#%  description: Input map
-#%  required : yes
-#% end
-#% option
-#%  key: output
-#%  type: string
-#%  description: Base name for output maps
-#%  required : no
-#% end
+#%module
+#% description: Splits a raster map into red, green and blue maps.
+#% keywords: rgb
+#%end
+#%end
+#%option
+#% type: string
+#% description: Prefix for output raster maps (default: input)
+#% required: no
+#%end
 import sys
 import os
@@ -41,7 +37,7 @@
     if not grass.find_file(input)['file']:
-	grass.fatal(_("Map <%s> not found.") % input)
+	grass.fatal(_("Raster map <%s> not found") % input)
     if not output:
 	output = input
Modified: grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py
--- grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.shaded.relief/r.shaded.relief.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -48,64 +48,56 @@
 #   11/99 updated $ewres to ewres() and $nsres to nsres()
 #       updated number to FP in r.mapcalc statement Markus Neteler
-#% Module
-#%  description: Creates shaded relief map from an elevation map (DEM).
-#% End
-#% option
-#%  key: input
-#%  type: string
-#%  description: Name of input elevation map
-#%  required : yes
-#% end
-#% option
-#%  key: output
-#%  type: string
-#%  description: Name for output shaded relief map
-#%  required : yes
-#% end
-#% option
-#%  key: altitude
-#%  type: double
-#%  description: Altitude of the sun in degrees above the horizon
-#%  required : no
-#%  options : 0-90
-#%  answer: 30
-#% end
-#% option
-#%  key: azimuth
-#%  type: double
-#%  description: Azimuth of the sun in degrees to the east of north
-#%  required : no
-#%  options : 0-360
-#%  answer: 270
-#% end
-#% option
-#%  key: zmult
-#%  type: double
-#%  description: Factor for exaggerating relief
-#%  required : no
-#%  answer: 1
-#% end
-#% option
-#%  key: scale
-#%  type: double
-#%  description: Scale factor for converting horizontal units to elevation units
-#%  required : no
-#%  answer: 1
-#%  guisection: Scaling
-#% end
-#% option
-#%  key: units
-#%  type: string
-#%  description: Set scaling factor (applies to lat./long. locations only, none: scale=1)
-#%  required : no
-#%  options: none,meters,feet
-#%  answer: none
-#% end
+#%module
+#% description: Creates shaded relief map from an elevation map (DEM).
+#%end
+#% description: Name of input elevation raster map
+#%end
+#%end
+#%option
+#% key: altitude
+#% type: double
+#% description: Altitude of the sun in degrees above the horizon
+#% required: no
+#% options : 0-90
+#% answer: 30
+#%end
+#%option
+#% key: azimuth
+#% type: double
+#% description: Azimuth of the sun in degrees to the east of north
+#% required: no
+#% options : 0-360
+#% answer: 270
+#%end
+#%option
+#% key: zmult
+#% type: double
+#% description: Factor for exaggerating relief
+#% required: no
+#% answer: 1
+#%end
+#%option
+#% key: scale
+#% type: double
+#% description: Scale factor for converting horizontal units to elevation units
+#% required: no
+#% answer: 1
+#% guisection: Scaling
+#%end
+#%option
+#% key: units
+#% type: string
+#% description: Set scaling factor (applies to lat./long. locations only, none: scale=1)
+#% required: no
+#% options: none,meters,feet
+#% answer: none
+#%end
 import sys
 import os
Modified: grass/trunk/scripts/r.tileset/r.tileset.py
--- grass/trunk/scripts/r.tileset/r.tileset.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.tileset/r.tileset.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -35,11 +35,11 @@
 #    presenting data in a highly inappropriate projection. Do you really
 #    want their data?
-#%Module
+#%module
 #% description: Produces tilings of the source projection for use in the destination region and projection.
 #% keywords: raster
 #% keywords: tiling
-#%End
+#%end
 #%flag
 #% key: g
 #% description: Produces shell script output
@@ -95,18 +95,9 @@
 #% description: Number of cells tiles should overlap in each direction
 #% answer: 0
 #%end
-#%option
-#% key: fs
-#% type: string
 #% description: Output field separator
-#% answer: |
 #%end
-#%option
-#% key: v
-#% type: integer
-#% description: Verbosity level
-#% answer: 0
-#%end
 # Data structures used in this program:
 # A bounding box:
Modified: grass/trunk/scripts/r.unpack/r.unpack.py
--- grass/trunk/scripts/r.unpack/r.unpack.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/r.unpack/r.unpack.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -19,21 +19,12 @@
 #% keywords: import
 #%end
-#%option
-#% key: input
-#% type: string
-#% gisprompt: old,file,input
 #% description: Name of input pack file
-#% key_desc: path
-#% required : yes
 #%end
-#%option
-#% key: output
-#% type: string
 #% description: Name for output raster map (default: taken from input file internals)
-#% key_desc: name
-#% required : no
+#% required: no
 #%end
 #%flag
 #% key: o
Modified: grass/trunk/scripts/v.centroids/v.centroids.py
--- grass/trunk/scripts/v.centroids/v.centroids.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.centroids/v.centroids.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -18,22 +18,10 @@
 #% keywords: area
 #%End
-#%option
-#% key: input
-#% type: string
-#% key_desc: name
-#% description: Name of input vector map
-#%required: yes
+#%option G_OPT_V_INPUT
 #%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new,vector,vector
-#% key_desc: name
-#% description: Name for output vector map
-#% required: yes
+#%option G_OPT_V_OUTPUT
 #%end
 #%option
@@ -45,21 +33,12 @@
 #% required: no
 #%end
-#%option
-#% key: layer
-#% type: integer
-#% gisprompt: new_layer,layer,layer
-#% answer: 1
-#% required: no
 #%end
-#%option
-#% key: cat
-#% type: integer
+#%option G_OPT_V_CAT
 #% description: Category number starting value
 #% answer: 1
-#% required: no
 #%end
 #%option
Modified: grass/trunk/scripts/v.colors/v.colors.py
--- grass/trunk/scripts/v.colors/v.colors.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.colors/v.colors.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -20,35 +20,17 @@
 #% keywords: vector
 #%end
-#% option
-#% key: map
-#% type: string
-#% key_desc: name
-#% required: yes
+#% option G_OPT_V_MAP
 #%end
-#%option
-#% key: layer
-#% type: integer
-#% answer: 1
-#% required: no
 #%end
-#%option
-#% key: column
-#% type: string
-#% description: Name of column containing numeric data
+#% description: Name of attribute column containing numeric data
 #% required : yes
 #%end
-#%option
 #% key: rgb_column
-#% type: string
-#% required: no
 #% description: Name of color column to populate with RGB values
-#% gisprompt: new_dbcolumn,dbcolumn,dbcolumn
 #% answer: GRASSRGB
 #% guisection: Colors
 #%end
@@ -69,21 +51,16 @@
 #% required: no
 #%end
-#%option
 #% key: raster
-#% type: string
-#% key_desc: name
 #% required: no
 #% description: Name of raster map from which to copy color table
 #%end
-#%option
 #% key: rules
-#% type: string
 #% required: no
 #% description: Name of file containing rules
 #%end
 #%flag
Modified: grass/trunk/scripts/v.convert.all/v.convert.all.py
--- grass/trunk/scripts/v.convert.all/v.convert.all.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.convert.all/v.convert.all.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -14,11 +14,11 @@
-#%Module
-#%  description: Converts all older versions of GRASS vector maps in current mapset to current format.
-#%  keywords: vector
-#%  keywords: conversion
+#%module
+#% description: Converts all older versions of GRASS vector maps in current mapset to current format.
+#% keywords: vector
+#% keywords: conversion
 #%end
 import sys
@@ -35,7 +35,7 @@
 	if grass.run_command("v.convert", input = inmap, output = outmap) == 0:
 	    converted += 1
 	else:
-	    grass.warning(_("Error converting map %s to %s") % (inmap, outmap))
+	    grass.warning(_("Error converting map <%s> to <%s>") % (inmap, outmap))
 	    ret = 1
 	if converted < 1:
Modified: grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py
--- grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.db.addcolumn/v.db.addcolumn.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -16,30 +16,18 @@
-#%Module
-#%  description: Adds one or more columns to the attribute table connected to a given vector map.
-#%End
+#%module
+#% description: Adds one or more columns to the attribute table connected to a given vector map.
+#%end
-#%option
-#% key: map
-#% type: string
-#% key_desc : name
-#% description: Name of vector map for which to edit attribute table
-#% required : yes
 #%end
-#%option
-#% key: layer
-#% type: integer
 #% label: Layer number where to add column(s)
-#% description: A single vector map can be connected to multiple database tables. This number determines which table to use.
-#% answer: 1
-#% required : no
 #%end
 #%option
@@ -47,7 +35,7 @@
 #% type: string
 #% label: Name and type of the new column(s) ('name type [,name type, ...]')
 #% description: Data types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE
-#% required : yes
+#% required: yes
 #%end
 import sys
Modified: grass/trunk/scripts/v.db.addtable/v.db.addtable.py
--- grass/trunk/scripts/v.db.addtable/v.db.addtable.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.db.addtable/v.db.addtable.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -14,41 +14,35 @@
-#%Module
-#%  description: Creates and connects a new attribute table to a given layer of an existing vector map.
-#%End
-#%option
-#% key: map
-#% type: string
-#% description: Vector map for which to add new attribute table
-#% required : yes
-#% key_desc : name
+#%module
+#% description: Creates and connects a new attribute table to a given layer of an existing vector map.
 #%end
-#%option
+#%end
+#%option
 #% key: table
 #% type: string
 #% description: Name of new attribute table (default: vector map name)
 #% required : no
 #%end
-#%option
+#%option
 #% key: layer
-#% description: Layer where to add new attribute table
+#% type: integer
+#% description: Layer number where to add new attribute table
 #% answer: 1
-#% required : no
+#% required: no
 #%end
 #%option
 #% key: columns
 #% type: string
 #% description: Name and type of the new column(s) (types depend on database backend, but all support VARCHAR(), INT, DOUBLE PRECISION and DATE)
 #% answer: cat integer
-#% required : no
-#% multiple : yes
-#% key_desc : name type
+#% required: no
+#% multiple: yes
+#% key_desc: name type
 #%end
 import sys
Modified: grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py
--- grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.db.dropcolumn/v.db.dropcolumn.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -18,35 +18,23 @@
-#%Module
-#%  description: Drops a column from the attribute table connected to a given vector map.
-#%End
+#%module
+#% description: Drops a column from the attribute table connected to a given vector map.
+#%end
-#%option
 #% key: map
-#% type: string
-#% key_desc : name
-#% description: Vector map for which to drop attribute column
-#% required : yes
 #%end
-#%option
-#% key: layer
-#% description: Layer where to drop column
-#% answer: 1
-#% required : no
 #%end
-#%option
-#% key: column
-#% description: Name of the column to drop
-#% required : yes
+#% description: Name of attribute column to drop
+#% required: yes
 #%end
 import sys
Modified: grass/trunk/scripts/v.db.droprow/v.db.droprow.py
--- grass/trunk/scripts/v.db.droprow/v.db.droprow.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.db.droprow/v.db.droprow.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -16,43 +16,23 @@
 #%module
-#% description: Removes a vector object (point, line, area, face etc.) from a vector map through attribute selection.
+#% description: Removes a vector feature from a vector map through attribute selection.
 #% keywords: vector
 #%end
-#%option
-#% key: input
-#% type: string
-#% key_desc : name
-#% description: Vector map for which to drop vector objects
-#% required : yes
 #%end
-#%option
-#% key: output
-#% type: string
-#% key_desc : name
-#% required : yes
 #%end
-#%option
-#% key: layer
-#% type: integer
-#% description: Layer of attribute table to use for selection
-#% answer: 1
-#% required : no
+#% required :yes
 #%end
-#%option
-#% key: where
-#% type: string
-#% description: WHERE conditions for vector delete, without 'where' keyword (e.g. "elevation IS NULL")
-#% required : yes
 #%end
 import sys
Modified: grass/trunk/scripts/v.db.droptable/v.db.droptable.py
--- grass/trunk/scripts/v.db.droptable/v.db.droptable.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.db.droptable/v.db.droptable.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -25,24 +25,12 @@
 #%  key: f
 #%  description: Force removal (required for actual deletion of table)
 #%end
-#%option
-#% key: map
-#% type: string
-#% description: Vector map from which to remove attribute table
-#% required : yes
 #%end
-#%option
-#% key: table
-#% type: string
-#% description: Name of existing attribute table (default: vector map name)
-#% required : no
+#% description: Table name (default: vector map name)
 #%end
-#%option
-#% key: layer
-#% description: Layer from which to drop linked attribute table
-#% answer: 1
 #% required : no
 #%end
Modified: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.db.join/v.db.join.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -14,56 +14,39 @@
-#%Module
+#%module
 #% description: Allows to join a table to a vector map table.
 #% keywords: vector
-#%End
+#%end
-#%option
-#% key: map
-#% type: string
-#% key_desc : name
 #% description: Vector map to which to join other table
-#% required : yes
 #% guidependency: layer,column
 #%end
-#%option
-#% key: layer
-#% type: integer
 #% description: Layer where to join
-#% answer: 1
-#% required : no
 #% guidependency: column
 #%end
-#%option
-#% key: column
-#% type: string
-#% description: Join column in map table
+#% description: Join column in table
 #% required : yes
 #%end
-#%option
 #% key: otable
-#% type: string
 #% description: Other table name
-#% required : yes
+#% required: yes
 #% guidependency: ocolumn
 #%end
-#%option
 #% key: ocolumn
-#% type: string
 #% description: Join column in other table
-#% required : yes
+#% required: yes
 #%end
 import sys
Modified: grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py
--- grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.db.reconnect.all/v.db.reconnect.all.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -13,36 +13,30 @@
-#%Module
+#%module
 #% description: Reconnects vectors to a new database.
 #% keywords: vector
-#%End
-#%option
+#%end
+#%option G_OPT_DB_DATABASE
 #% key: old_database
-#% type: string
 #% description: Name of old database
-#% required : yes
-#%END
-#%option
+#% required: yes
+#%end
 #% key: new_database
-#% type: string
 #% description: Name of new database
-#% required : yes
-#%END
-#%option
+#% required: yes
+#%end
+#%option G_OPT_DB_SCHEMA
 #% key: old_schema
-#% type: string
-#% description: Old schema
-#% required : no
-#%END
-#%option
+#% description: Old database schema
+#%end
 #% key: new_schema
-#% type: string
-#% description: New schema
-#% required : no
-#%END
+#% description: New database schema
+#%end
 import sys
 import os
Modified: grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py
--- grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.db.renamecolumn/v.db.renamecolumn.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -20,32 +20,21 @@
-#%Module
-#%  description: Renames a column in the attribute table connected to a given vector map.
-#%End
-#%option
-#% key: map
-#% type: string
-#% key_desc : name
-#% description: Vector map for which to rename attribute column
-#% required : yes
+#%module
+#% description: Renames a column in the attribute table connected to a given vector map.
 #%end
-#%option
-#% key: layer
-#% description: Layer where to rename column
-#% answer: 1
-#% required : no
 #%end
-#%option
+#%end
+#%option
 #% key: column
 #% type: string
 #% description: Old and new name of the column (old,new)
-#% required : yes
+#% required: yes
 #% multiple: no
 #% key_desc: oldcol,newcol
 #%end
Modified: grass/trunk/scripts/v.db.univar/v.db.univar.py
--- grass/trunk/scripts/v.db.univar/v.db.univar.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.db.univar/v.db.univar.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -16,55 +16,34 @@
-#%Module
+#%module
 #% description: Calculates univariate statistics on selected table column for a GRASS vector map.
 #% keywords: vector
-#%End
+#%end
 #%flag
-#%  key: e
-#%  description: Extended statistics (quartiles and 90th percentile)
-#%END
+#% key: e
+#% description: Extended statistics (quartiles and 90th percentile)
+#%end
 #%flag
-#%  key: g
-#%  description: Print stats in shell script style
-#%END
-#%option
+#% key: g
+#% description: Print stats in shell script style
+#%end
 #% key: table
-#% type: string
-#% description: Name of data table
-#% required : yes
-#%End
-#%option
-#% key: column
-#% type: string
-#% description: Column on which to calculate statistics (must be numeric)
-#% required : yes
+#% required: yes
 #%end
-#%option
-#% key: database
-#% type: string
-#% gisprompt: old_dbname,dbname,dbname
-#% answer: DEFAULT_DBNAME
-#% description: Database/directory for table
-#% required : no
+#% description: Name of attribute column on which to calculate statistics (must be numeric)
+#% required: yes
 #%end
-#%option
-#% key: driver
-#% type: string
-#% gisprompt: old_dbdriver,dbdriver,dbdriver
-#% options: dbf,odbc,ogr,sqlite
-#% description: Database driver
-#% required : no
 #%end
-#%option
-#% key: where
-#% type: string
-#% required : no
+#%option G_OPT_DB_DRIVER
+#% options: dbf,odbc,ogr,sqlite,pg
 #%end
+#%end
 #%option
 #% key: percentile
 #% type: double
Modified: grass/trunk/scripts/v.db.update/v.db.update.py
--- grass/trunk/scripts/v.db.update/v.db.update.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.db.update/v.db.update.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -15,58 +15,32 @@
-#%Module
-#%  description: Allows to update a column in the attribute table connected to a vector map.
-#%End
-#%option
-#% key: map
-#% type: string
-#% required : yes
-#% key_desc: name
+#%module
+#% description: Allows to update a column in the attribute table connected to a vector map.
 #%end
-#%option
-#% key: layer
-#% type: string
-#% label: Layer number or name
-#% description: A single vector map can be connected to multiple database tables. This number determines which table to use. Layer name for direct OGR access.
-#% answer: 1
-#% required : no
-#% key_desc: name
 #%end
-#%option
+#%end
 #% key: column
-#% type: string
-#% description: Name of column to update
-#% required : yes
-#% key_desc: name
+#% description: Name of attribute column to update
+#% required: yes
 #%end
 #%option
 #% key: value
 #% type: string
 #% description: Value to update the column with, can be (combination of) other column(s)
-#% required : no
+#% required: no
 #%end
-#%option
 #% key: qcolumn
-#% type: string
-#% description: Name of column to query
-#% required : no
-#% key_desc: name
+#% description: Name of attrubute column to query
 #%end
-#%option
-#% key: where
-#% type: string
-#% label: WHERE conditions of SQL statement without 'where' keyword
-#% description: Example: income < 1000 and inhab >= 10000
-#% required : no
 #%end
 import sys
Modified: grass/trunk/scripts/v.dissolve/v.dissolve.py
--- grass/trunk/scripts/v.dissolve/v.dissolve.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.dissolve/v.dissolve.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -15,45 +15,23 @@
-#%Module
+#%module
 #% description: Dissolves boundaries between adjacent areas sharing a common category number or attribute.
 #% keywords: vector
 #% keywords: area
 #% keywords: dissolve
-#%End
-#%option
-#% key: input
-#% type: string
-#% key_desc: name
-#% required: yes
 #%end
-#%option
-#% key: output
-#% type: string
-#% key_desc: name
-#% required: yes
 #%end
-#%option
-#% key: layer
-#% type: string
+#%option G_OPT_V_FIELD_ALL
 #% label: Layer number or name. If -1, all layers are extracted.
-#% answer: 1
-#% gisprompt: old_layer,layer,layer_all
-#% required : no
+#% required: no
 #%end
-#%option
-#% key: column
-#% type: string
-#% description: Name of column used to dissolve common boundaries
-#% required : no
+#% description: Name of attribute column used to dissolve common boundaries
 #%end
+#%end
 import sys
 import os
 import atexit
Modified: grass/trunk/scripts/v.in.e00/v.in.e00.py
--- grass/trunk/scripts/v.in.e00/v.in.e00.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.in.e00/v.in.e00.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -21,34 +21,19 @@
 # REQUIREMENTS:
 #      -  avcimport: http://avce00.maptools.org
-#%Module
-#%  description: Import E00 file into a vector map.
-#%End
-#%flag
-#%  key: v
-#%  description: Verbose mode
+#%module
+#% description: Imports E00 file into a vector map.
 #%end
-#%option
-#% key: file
-#% type: string
-#% description: E00 file
-#% required : yes
+#% description: Name of input E00 file
 #%end
-#%option
-#% key: type
-#% type: string
 #% options: point,line,area
-#% description: Input type point, line or area
-#% required : yes
+#% required: yes
 #%end
-#%option
-#% key: vect
-#% type: string
 #% required : no
 #%end
Modified: grass/trunk/scripts/v.in.geonames/v.in.geonames.py
--- grass/trunk/scripts/v.in.geonames/v.in.geonames.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.in.geonames/v.in.geonames.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -22,28 +22,17 @@
 #       fix spurious char stuff in elevation column
-#%Module
-#%  description: Imports geonames.org country files into a GRASS vector points map.
-#%  keywords: gazetteer
-#%End
-#%option
-#% key: input
-#% type: string
-#% key_desc: name
-#% description: Uncompressed geonames file from (with .txt extension)
-#% required : yes
+#%module
+#% description: Imports geonames.org country files into a vector points map.
+#% keywords: gazetteer
 #%end
-#%option
-#% key: output
-#% type: string
-#% key_desc: name
-#% required : yes
+#% description: Name of uncompressed geonames file (with .txt extension)
 #%end
+#%end
 import sys
 import os
Modified: grass/trunk/scripts/v.in.gns/v.in.gns.py
--- grass/trunk/scripts/v.in.gns/v.in.gns.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.in.gns/v.in.gns.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -24,26 +24,18 @@
 #                 e.g. FC (Feature Classification)
-#%Module
-#%  description: Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map.
-#%End
-#%option
-#% key: file
-#% type: string
-#% description: Uncompressed GNS file from NGA (with .txt extension)
-#% required : yes
+#%module
+#% description: Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map.
 #%end
-#%option
-#% key: vect
-#% type: string
-#% required : no
+#% description: Name of input uncompressed GNS file from NGA (with .txt extension)
 #%end
+#% required: no
+#%end
 import sys
 import os
Modified: grass/trunk/scripts/v.in.lines/v.in.lines.py
--- grass/trunk/scripts/v.in.lines/v.in.lines.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.in.lines/v.in.lines.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -15,36 +15,21 @@
 #               for details.
-#%Module
-#% description: Import ASCII x,y[,z] coordinates as a series of lines.
+#%module
+#% description: Imports ASCII x,y[,z] coordinates as a series of lines.
 #% keywords: vector
 #% keywords: import
-#%End
+#%end
 #%flag
 #% key: z
 #% description: Create a 3D line from 3 column data
 #%end
-#%option
-#% key: input
-#% type: string
 #% description: Name of input file (or "-" to read from stdin)
-#% required : yes
 #%end
-#%option
-#% key: output
-#% type: string
-#% required : yes
 #%end
-#%option
-#% key: fs
-#% type: string
-#% answer: |
-#% required: no
 #%end
 import sys
Modified: grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py
--- grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.in.mapgen/v.in.mapgen.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -23,32 +23,25 @@
 #                    http://www.ngdc.noaa.gov/mgg/shorelines/shorelines.html
-#%Module
-#%  description: Imports Mapgen or Matlab-ASCII vector maps into GRASS.
-#%End
+#%module
+#% description: Imports Mapgen or Matlab-ASCII vector maps into GRASS.
+#%end
 #%flag
-#%  key: f
-#%  description: Input map is in Matlab format
+#% key: f
+#% description: Input map is in Matlab format
 #%end
 #%flag
-#%  key: z
-#%  description: Create a 3D vector points map from 3 column Matlab data
+#% key: z
+#% description: Create a 3D vector points map from 3 column Matlab data
 #%end
-#%option
-#% key: input
-#% type: string
 #% description: Name of input file in Mapgen/Matlab format
-#% required : yes
 #%end
-#%option
-#% key: output
-#% type: string
 #% description: Name for output vector map (omit for display to stdout)
-#% required : no
+#% required: no
 #%end
 import sys
Modified: grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py
--- grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.in.sites.all/v.in.sites.all.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -13,12 +13,12 @@
-#%Module
+#%module
 #% description: Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps.
 #% keywords: sites
 #% keywords: vector
 #% keywords: import
-#%End
+#%end
 import sys
 from grass.script import core as grass
Modified: grass/trunk/scripts/v.in.wfs/v.in.wfs.py
--- grass/trunk/scripts/v.in.wfs/v.in.wfs.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.in.wfs/v.in.wfs.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -18,7 +18,7 @@
 #%Module
-#% description: Import GetFeature from WFS.
+#% description: Imports GetFeature from WFS.
 #% keywords: vector
 #% keywords: import
 #% keywords: wfs
@@ -27,13 +27,9 @@
 #% key: url
 #% type: string
 #% description: GetFeature URL starting with 'http'
+#% required: yes
 #%end
-#%option
-#% key: output
-#% type: string
-#% required : yes
 #%end
 import os
Modified: grass/trunk/scripts/v.krige/v.krige.py
--- grass/trunk/scripts/v.krige/v.krige.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.krige/v.krige.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -18,28 +18,21 @@
 ## g.parser informations
 #%module
-#% description: Performs ordinary or block kriging.
-#% keywords: vector, interpolation, kriging
+#% description: Performs ordinary or block kriging for vector maps.
+#% keywords: raster
+#% keywords: interpolation
+#% keywords: kriging
 #%end
-#%option
-#% key: input
-#% type: string
 #% description: Name of point vector map containing sample data
-#% required: yes
 #%end
-#%option
-#% key: column
-#% type: string
 #% description: Name of attribute column with numerical value to be interpolated
-#% required : yes
+#% required: yes
 #%end
-#%option
-#% key: output
-#% type: string
-#% gisprompt: new,cell,raster
+#%option G_OPT_R_OUTPUT
 #% label: Name for output raster map
 #% description: If omitted, will be <input name>_kriging
 #% required : no
@@ -90,10 +83,8 @@
 #% description: Automatically fixed if not set
 #% required : no
 #%end
-#%option
 #% key: output_var
-#% type: string
 #% label: Name for output variance raster map
 #% description: If omitted, will be <input name>_kriging_var
 #% required : no
Modified: grass/trunk/scripts/v.out.gps/v.out.gps.py
--- grass/trunk/scripts/v.out.gps/v.out.gps.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.out.gps/v.out.gps.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -56,27 +56,13 @@
 ##%  description: Export altitude from 3D vector's z-coordinate
 ##%end
-#%option
-#% key: input
-#% type: string
-#% required: yes
 #%end
-#%option
-#% key: type
-#% type: string
-#% description: Feature type(s)
 #% options: point,centroid,line,boundary
-#% multiple: yes
 #%end
-#%option
-#% key: output
-#% type: string
+#%option G_OPT_F_OUTPUT
 #% description: Name for output file or GPS device
-#% gisprompt: new_file,file,output
-#% key_desc: name
-#% required: yes
 #%end
 #%option
 #% key: format
@@ -84,21 +70,11 @@
 #% description: GpsBabel supported output format
 #% answer: gpx
 #%end
-#%option
-#% key: layer
-#% type: integer
-#% answer: 1
-#% required : no
+#% required: no
 #% guisection: Subset
 #%end
-#%option
-#% key: where
-#% type: string
-#% required : no
 #%end
Modified: grass/trunk/scripts/v.rast.stats/v.rast.stats.py
--- grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.rast.stats/v.rast.stats.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -30,31 +30,13 @@
 #% key: e
 #% description: Calculate extended statistics
 #%end
-#%option
-#% key: vector
-#% type: string
-#% key_desc: name
-#% gisprompt: old,vector,vector
-#% label: Name of input vector polygon map
-#% description: Data source for OGR access
-#% required : yes
+#%option G_OPT_V_MAP
 #%end
-#%option
-#% key: layer
-#% type: integer
-#% description: A single vector map can be connected to multiple database tables. This number determines which table to use. Layer name for OGR access.
-#% gisprompt: old,layer,layer
-#% answer: 1
-#% required : no
 #%end
-#%option
 #% key: raster
-#% type: string
-#% key_desc: name
-#% gisprompt: old,cell,raster
 #% description: Name of input raster map to calculate statistics from
-#% required : yes
 #%end
 #%option
 #% key: column_prefix
Modified: grass/trunk/scripts/v.report/v.report.py
--- grass/trunk/scripts/v.report/v.report.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.report/v.report.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -13,37 +13,24 @@
-#%Module
-#%  description: Reports geometry statistics for vector maps.
-#%  keywords: geometry
-#%End
-#%Flag
+#%module
+#% description: Reports geometry statistics for vector maps.
+#% keywords: geometry
+#%end
+#%flag
 #% key: r
 #% description: Reverse sort the result
-#%End
-#%Flag
+#%end
+#%flag
 #% key: s
 #% description: Sort the result
-#%End
-#%option
-#% key: map
-#% type: string
-#% label: Name of input vector map
-#% required: yes
 #%end
-#%option
-#% key: layer
-#% type: string
-#% answer: 1
-#% required: no
 #%end
+#%end
 #%option
 #% key: option
 #% type: string
@@ -51,12 +38,8 @@
 #% options: area,length,coor
 #% required: yes
 #%end
-#%option
-#% key: units
-#% type: string
-#% description: Units
 #% options: miles,feet,meters,kilometers,acres,hectares,percent
-#% required: no
 #%end
 import sys
Modified: grass/trunk/scripts/v.what.vect/v.what.vect.py
--- grass/trunk/scripts/v.what.vect/v.what.vect.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/v.what.vect/v.what.vect.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -13,54 +13,33 @@
-#%Module
-#%  description: Uploads vector values at positions of vector points to the table.
-#%End
+#%module
+#% description: Uploads vector values at positions of vector points to the table.
+#%end
-#%option
-#% key: vector
-#% type: string
-#% key_desc: name
-#% description: Vector map to modify
-#% required : yes
 #%end
-#%option
-#% key: layer
-#% type: integer
-#% description: Layer in the vector to be modified
-#% answer: 1
-#% required : no
 #%end
-#%option
-#% key: column
-#% type: string
-#% description: Column to be updated with the query result
-#% required : yes
+#%option G_OPT_DB_COLUMN
+#% description: Name of attribute column to be updated with the query result
+#% required: yes
 #%end
-#%option
-#% key: qvector
-#% type: string
-#% key_desc: name
-#% description: Vector map to be queried
+#% key: qmap
+#% description: Name of vector map to be queried
 #% required : yes
 #%end
-#%option
 #% key: qlayer
-#% type: integer
-#% description: Layer of the query vector containing data
-#% answer: 1
-#% required : no
 #%end
-#%option
 #% key: qcolumn
-#% type: string
-#% description: Column to be queried
-#% required : yes
+#% description: Name of attribute column to be queried
+#% required: yes
 #%end
 #%option
 #% key: dmax
Modified: grass/trunk/scripts/wxpyimgview/wxpyimgview.py
--- grass/trunk/scripts/wxpyimgview/wxpyimgview.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/wxpyimgview/wxpyimgview.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -18,27 +18,23 @@
-#%Module
-#% description: View BMP images from the PNG driver.
+#%module
+#% description: Views BMP images from the PNG driver.
 #% keywords: display
 #% keywords: raster
-#%End
-#%Option
+#%end
 #% key: image
-#% type: string
-#% required: yes
-#% multiple: no
-#% description: Image file
-#%End
-#%Option
+#% description: Name of input image file
+#%end
+#%option
 #% key: percent
 #% type: integer
 #% required: no
 #% multiple: no
 #% description: Percentage of CPU time to use
 #% answer: 10
-#%End
+#%end
 import sys
 import os
Modified: grass/trunk/scripts/wxpyimgview/wxpyimgview_gui.py
--- grass/trunk/scripts/wxpyimgview/wxpyimgview_gui.py	2011-08-04 09:46:43 UTC (rev 47425)
+++ grass/trunk/scripts/wxpyimgview/wxpyimgview_gui.py	2011-08-04 11:38:53 UTC (rev 47426)
@@ -18,27 +18,23 @@
-#%Module
+#%module
 #% keywords: raster
-#%End
-#%Option
+#%end
 #% key: image
-#% type: string
-#% required: yes
-#% multiple: no
-#%End
-#%Option
+#%end
+#%option
 #% key: percent
 #% type: integer
 #% required: no
 #% multiple: no
 #% answer: 10
-#%End
+#%end
 import sys
 import struct
