[GRASS-SVN] r47445 - in grass/branches/releasebranch_6_4:
gui/wxpython/gui_modules lib/python
svn_grass at osgeo.org
Thu Aug 4 11:22:17 EDT 2011
Author: martinl
Date: 2011-08-04 08:22:17 -0700 (Thu, 04 Aug 2011)
New Revision: 47445
grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
grass/branches/releasebranch_6_4/lib/python/core.py
grass/branches/releasebranch_6_4/lib/python/task.py
pythonlib: list_grouped() - check for search path optional
(merge r47439, r47441 & r47443 from devbr6)
Modified: grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py
--- grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py 2011-08-04 15:21:50 UTC (rev 47444)
+++ grass/branches/releasebranch_6_4/gui/wxpython/gui_modules/gselect.py 2011-08-04 15:22:17 UTC (rev 47445)
@@ -268,10 +268,6 @@
# get current mapset
curr_mapset = grass.gisenv()['MAPSET']
- # list of mapsets in current location
- if mapsets is None:
- mapsets = utils.ListOfMapsets(get = 'accessible')
# map element types to g.mlist types
elementdict = {'cell':'rast',
'raster':'rast',
@@ -322,18 +318,22 @@
self.AddItem(_('Not selectable element'))
return
- # get directory tree nodes
- # reorder mapsets based on search path (TODO)
- for i in range(len(mapsets)):
- if i > 0 and mapsets[i] == curr_mapset:
- mapsets[i] = mapsets[0]
- mapsets[0] = curr_mapset
if globalvar.have_mlist:
- filesdict = grass.mlist_grouped(elementdict[element])
+ filesdict = grass.mlist_grouped(elementdict[element],
+ check_search_path = False)
else:
- filesdict = grass.list_grouped(elementdict[element])
+ filesdict = grass.list_grouped(elementdict[element],
+ # list of mapsets in current location
+ if mapsets is None:
+ mapsets = grass.mapsets()
+ # current mapset first
+ if curr_mapset in mapsets and mapsets[0] != curr_mapset:
+ mapsets.remove(curr_mapset)
+ mapsets.insert(0, curr_mapset)
first_mapset = None
for mapset in mapsets:
mapset_node = self.AddItem('Mapset: ' + mapset)
Modified: grass/branches/releasebranch_6_4/lib/python/core.py
--- grass/branches/releasebranch_6_4/lib/python/core.py 2011-08-04 15:21:50 UTC (rev 47444)
+++ grass/branches/releasebranch_6_4/lib/python/core.py 2011-08-04 15:22:17 UTC (rev 47445)
@@ -599,7 +599,7 @@
# interface to g.list
-def list_grouped(type):
+def list_grouped(type, check_search_path = True):
"""!List elements grouped by mapsets.
Returns the output from running g.list, as a dictionary where the
@@ -612,14 +612,16 @@
@endcode
@param type element type (rast, vect, rast3d, region, ...)
+ @param check_search_path True to add mapsets for the search path with no found elements
@return directory of mapsets/elements
dashes_re = re.compile("^----+$")
mapset_re = re.compile("<(.*)>")
result = {}
- for mapset in mapsets(accessible = True):
- result[mapset] = []
+ if check_search_path:
+ for mapset in mapsets(accessible = True):
+ result[mapset] = []
mapset = None
for line in read_command("g.list", type = type).splitlines():
@@ -630,6 +632,8 @@
m = mapset_re.search(line)
if m:
mapset = m.group(1)
+ if mapset not in result.keys():
continue
if mapset:
result[mapset].extend(line.split())
@@ -679,7 +683,7 @@
# interface to g.mlist
-def mlist_grouped(type, pattern = None):
+def mlist_grouped(type, pattern = None, check_search_path = True):
"""!List of elements grouped by mapsets.
Returns the output from running g.mlist, as a dictionary where the
@@ -693,12 +697,14 @@
@param pattern pattern string
result = {}
mapset = None
for line in read_command("g.mlist", flags = "m",
@@ -709,7 +715,10 @@
warning(_("Invalid element '%s'") % line)
continue
- result[mapset].append(name)
+ if mapset in result:
+ result[mapset].append(name)
+ else:
+ result[mapset] = [name, ]
return result
Modified: grass/branches/releasebranch_6_4/lib/python/task.py
--- grass/branches/releasebranch_6_4/lib/python/task.py 2011-08-04 15:21:50 UTC (rev 47444)
+++ grass/branches/releasebranch_6_4/lib/python/task.py 2011-08-04 15:22:17 UTC (rev 47445)
@@ -430,12 +430,12 @@
cmdout, cmderr = Popen([cmd, '--interface-description'], stdout = PIPE,
stderr = PIPE).communicate()
except OSError, e:
- raise ScriptError, _("Unable to fetch interface description for command '%s'."
- "\n\nDetails: %s") % (cmd, e)
+ raise ScriptError, _("Unable to fetch interface description for command '%(cmd)s'."
+ "\n\nDetails: %(det)s") % { 'cmd' : cmd, 'det' : e }
if cmderr and cmderr[:7] != 'WARNING':
- "\n\nDetails: %s") % (cmd, decode(cmderr))
+ "\n\nDetails: %(det)s") % { 'cmd': cmd, 'det' : decode(cmderr) }
return cmdout.replace('grass-interface.dtd', os.path.join(os.getenv('GISBASE'), 'etc', 'grass-interface.dtd'))
