[GRASS-SVN] r47465 - grass-addons/grass7/gui/wxpython/wx.wms
Sat Aug 6 00:46:23 EDT 2011
Author: sudeepsingh
Date: 2011-08-05 21:46:23 -0700 (Fri, 05 Aug 2011)
New Revision: 47465
   grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py
   grass-addons/grass7/gui/wxpython/wx.wms/ServersList.xml
   grass-addons/grass7/gui/wxpython/wx.wms/TODO
   grass-addons/grass7/gui/wxpython/wx.wms/addserver.py
   grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
some bugs fixed, details in TODO file
Modified: grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py
--- grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py	2011-08-05 19:49:27 UTC (rev 47464)
+++ grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py	2011-08-06 04:46:23 UTC (rev 47465)
@@ -1,11 +1,18 @@
 from BeautifulSoup import BeautifulSoup, Tag, BeautifulStoneSoup
+import os.path
 class ServerData():
     pass
 def initServerInfoBase(fileName):
-    try:
-        f = open(fileName,'r')
+    if(os.path.exists(fileName)):
+        try:
+            os.system('chmod 777 '+fileName)
+            f = open(fileName,'r')
+        except:
+            print 'Unable to open File '+fileName
+            print 'exiting application...'
+            return None, False
         xml = f.read()
         f.close()
         soup = BeautifulStoneSoup(xml)
@@ -13,17 +20,16 @@
         #print 'serverinfolisthere'
         #print serverinfolist
         #print len(serverinfolist)
-    except:
+    else:
         serverinfolist = []
         soup = BeautifulSoup()
         xml = "null"
     if(len(serverinfolist) == 0):
             serverinfo = Tag(soup, "serverinfo")
             soup.insert(0, serverinfo)
-    return soup
+    return soup, True
 def addServerInfo(soup, serverinfo, snamevalue, urlvalue, unamevalue, passwordvalue):
Modified: grass-addons/grass7/gui/wxpython/wx.wms/ServersList.xml
--- grass-addons/grass7/gui/wxpython/wx.wms/ServersList.xml	2011-08-05 19:49:27 UTC (rev 47464)
+++ grass-addons/grass7/gui/wxpython/wx.wms/ServersList.xml	2011-08-06 04:46:23 UTC (rev 47465)
@@ -1,18 +1,4 @@
 <serverinfo>
- <server id="123">
-  <servername>
-   123
-  </servername>
-  <serverurl>
-   123
-  </serverurl>
-  <username>
-   123
-  </username>
-  <password>
-   123
-  </password>
- </server>
  <server id="asd">
   <servername>
    asd
@@ -27,18 +13,6 @@
    asd
   </password>
  </server>
- <server id="āšņ ēčžģ12">
-  <servername>
-   āšņ ēčžģ12
-  </servername>
-  <serverurl>
-   asd12
-  </serverurl>
-  <username>
-  </username>
-  <password>
-  </password>
- </server>
  <server id="ڝڍڑڭڏڧڲ">
   <servername>
    ڝڍڑڭڏڧڲ
Modified: grass-addons/grass7/gui/wxpython/wx.wms/TODO
--- grass-addons/grass7/gui/wxpython/wx.wms/TODO	2011-08-05 19:49:27 UTC (rev 47464)
+++ grass-addons/grass7/gui/wxpython/wx.wms/TODO	2011-08-06 04:46:23 UTC (rev 47465)
@@ -12,6 +12,8 @@
 5.Layers fetched are not being displayed hierarchly, bug known, to be fixed.
+6.In case, on adding or removing a server, if the write to file is unsuccessful, the application removes it from the serverlist, even though is not written in the file.
+So when the application restarts, all the changes done are lost, since data was not written to file successfuly.
 More to be added...
Modified: grass-addons/grass7/gui/wxpython/wx.wms/addserver.py
--- grass-addons/grass7/gui/wxpython/wx.wms/addserver.py	2011-08-05 19:49:27 UTC (rev 47464)
+++ grass-addons/grass7/gui/wxpython/wx.wms/addserver.py	2011-08-06 04:46:23 UTC (rev 47465)
@@ -3,6 +3,7 @@
 # generated by wxGlade 0.6.3 on Thu Jul 14 06:22:35 2011
 import wx
+import os
 from wx.lib.pubsub import Publisher
 from BeautifulSoup import BeautifulSoup, Tag, NavigableString, BeautifulStoneSoup
 from ServerInfoAPIs import addServerInfo, removeServerInfo, updateServerInfo, initServerInfoBase, getAllRows
@@ -56,9 +57,12 @@
             print 'Config File Error, Unable to start application...'
             self.Close()
-        self.soup = initServerInfoBase('ServersList.xml')
+        self.soup, open = initServerInfoBase('ServersList.xml')
+        if(not open):
+            return
         self.Bind(wx.EVT_CLOSE, self.OnQuit)
         self.__populate_URL_List(self.ServerList)
+        Publisher().subscribe(self.onWMSMenuClose, ("WMS_Menu_Close"))
         #sudeep code ends
     def __set_properties(self):
@@ -124,7 +128,7 @@
         for key, value in self.servers.items():
             ComboBox.Append(value.servername+self.name_url_delimiter+value.url)
             #ComboBox.Append(value.servername+" "+value.url)
-        print self.servers
+        #print self.servers
         return
     	''''f = open('serverList.txt','r')
         lines = f.readlines()
@@ -211,7 +215,7 @@
             self.selectedURL = newUrl
             print self.selectedURL
             self.__update_URL_List()
   	    #Update_Url_List(newServerName+" "+newUrl)
         else:
@@ -225,14 +229,17 @@
                 print 'remove successful'
             else:
                 print 'remove unsuccessful'
+                return
             del self.servers[serverName]
             self.ServerNameText.Clear()
             self.PasswordText.Clear()
             self.URLText.Clear()
             self.UsernameText.Clear()
             self.saveXMLData()
             msg = self.servers
             Publisher().sendMessage(("update.serverList"), msg)
@@ -252,15 +259,33 @@
     def saveXMLData(self):
         xml = self.soup.prettify()
-        f = open('ServersList.xml','w')
-        f.write(xml)
-        f.close()
+        try:
+            f = open('templist.xml','w')
+            f.write(xml)
+            f.close()
+        except:
+            print 'Unable to write in templist.xml file, Save not successful'
+            return False
+        try:
+            os.system('chmod 777 ServersList.xml')
+            os.system("cp templist.xml ServersList.xml")
+            #f = open('ServersList.xml','w')
+        except:
+            #print 'cant open file in write mode'
+            print 'cp templist.xml ServersList.xml failed'
+            print 'Save not successful'
+            return False
+        return True
+    def onWMSMenuClose(self, msg):
+        self.Destroy()
+        return
     def OnQuit(self, event): # wxGlade: ServerAdd.<event_handler>
         print 'onQuit pressed'
         self.saveXMLData()
         msg = self.servers
-        Publisher().sendMessage(("update.serverList"), msg)
+        Publisher().sendMessage(("Add_Server_Frame_Closed"), msg)
         self.Destroy()
         #exit()
         #self.Close()
@@ -279,7 +304,7 @@
         print url
         urlarr = url.split(self.name_url_delimiter)
         print urlarr
         if(len(urlarr)==2):
             self.selectedServer = self.servers[unicode(urlarr[0])]
             print self.selectedServer
Modified: grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
--- grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py	2011-08-05 19:49:27 UTC (rev 47464)
+++ grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py	2011-08-06 04:46:23 UTC (rev 47465)
@@ -31,7 +31,7 @@
         self.passwordInput = wx.TextCtrl(self, -1, "", style=wx.TE_PROCESS_TAB|wx.TE_PASSWORD)
         self.GetCapabilities = wx.Button(self, -1, "GetCapabilities")
         self.GetMaps = wx.Button(self, -1, "GetMaps")
-        self.addServer = wx.Button(self, -1, "AddServer")
+        self.addServer = wx.Button(self, -1, "Manage Servers")
         self.__set_properties()
         self.__do_layout()
@@ -52,13 +52,21 @@
         if( not loadConfigFile(self)):
             self.Close()
+            return
+        if(not open):
+            self.Close()
+            return
         self.__populate_Url_List(self.ServerList)
         self.selectedURL="No server selected"
         self.layerTreeRoot = self.LayerTree.AddRoot("Layers")
-        Publisher().subscribe(self.updateServerList, ("update.serverList"))
+        Publisher().subscribe(self.onAddServerFrameClose, ("Add_Server_Frame_Closed"))
+        Publisher().subscribe(self.onUpdateServerListmessage, ("update.serverList"))
+        self.Bind(wx.EVT_CLOSE, self.OnQuit)
+        self.AddServerisClosed = True
         #items = ["a", "b", "c"]
         #itemId = self.LayerTree.AppendItem(self.layerTreeRoot, "item")
         #self.LayerTree.AppendItem(itemId, "inside")
@@ -101,7 +109,7 @@
             #ComboBox.Append(value.servername+" "+self.name_url_delimiter+" "+value.url)
         return
@@ -112,7 +120,7 @@
         return
@@ -151,7 +159,6 @@
             #xml=f.read()
             #f.close()
             #self.statusbar.SetStatusText(xml)
             reslist = parsexml(xml)
             populateLayerTree(xml,self.LayerTree, self.layerTreeRoot)
             #for res in reslist:
@@ -165,6 +172,11 @@
         except URLError, e:
             print 'We failed to reach a server.'
             print 'Reason: ', e.reason
+        except ValueError, e:
+            print 'Value error'
+            print 'Reason: ', e.reason
+        except:
+            print 'urlopen exception, unable to fetch data for getcapabilities'
         else:
             print 'Successful'
             #Sudeep's Code Ends
@@ -252,7 +264,7 @@
         print urlarr
         print urlarr[0]
         #print urlarr[0].encode()
-        self.printDict(self.servers)
+        #self.printDict(self.servers)
         print "OnServerList: done"
         if(len(urlarr)==2):
             self.selectedURL = self.servers[urlarr[0]].url
@@ -285,25 +297,35 @@
         #print "Event handler `OnLayerTreeSelChanged' not implemented"
         event.Skip()
-    def updateServerList(self, msg):
-        Shows the frame and shows the message sent in the
-        text control
-        print 'yoyo'
+    def onAddServerFrameClose(self, msg):
+        self.addServer.Enable()
         self.servers = msg.data
         self.__update_Url_List(self.ServerList)
-        print 'yoyo'
         #frame = self.GetParent()
         #frame.Show()
+    def onUpdateServerListmessage(self, msg):
+        self.servers = msg.data
+        self.__update_Url_List(self.ServerList)
     def OnAddServer(self, event): # wxGlade: wmsFrame.<event_handler>
         print 'before add server call'
+        self.AddServerisClosed = False
+        self.addServer.Disable()
         AddServerFrame(self)
         #print 'after add server call'
         #print "Event handler `OnAddServer' not implemented"
         #event.Skip()
         return
+    def OnQuit(self, event):
+        msg = ""
+        print 'in quit'
+        if(not self.AddServerisClosed):
+            Publisher().sendMessage(("WMS_Menu_Close"), msg)
+        self.Destroy()
+        return
 # end of class wmsFrame
 #Sudeep's Code Starts
