[GRASS-SVN] r47467 - grass/branches/releasebranch_6_4/imagery/i.topo.corr
Sat Aug 6 03:50:17 EDT 2011
Author: neteler
Date: 2011-08-06 00:50:17 -0700 (Sat, 06 Aug 2011)
New Revision: 47467
   grass/branches/releasebranch_6_4/imagery/i.topo.corr/main.c
   grass/branches/releasebranch_6_4/imagery/i.topo.corr/test_i.topo.corr_synthetic_DEM_NC.sh
msg fixes; keyword standardization; test script tuning (percent method looks odd)
Modified: grass/branches/releasebranch_6_4/imagery/i.topo.corr/main.c
--- grass/branches/releasebranch_6_4/imagery/i.topo.corr/main.c	2011-08-06 07:36:01 UTC (rev 47466)
+++ grass/branches/releasebranch_6_4/imagery/i.topo.corr/main.c	2011-08-06 07:50:17 UTC (rev 47467)
@@ -17,6 +17,7 @@
 #include <stdio.h>
 #include <stdlib.h>
+#include <string.h>
 #include <grass/gis.h>
 #include <grass/glocale.h>
@@ -80,9 +81,9 @@
     /* initialize module */
     module = G_define_module();
-    module->description = _("Computes topografic correction of reflectance.");
+    module->description = _("Computes topographic correction of reflectance.");
     module->keywords =
-	_("imagery, topographic correction, Cosine, Minnaert, C-Factor, Percent");
+	_("imagery, terrain, topographic correction");
     /* It defines the different parameters */
@@ -90,7 +91,7 @@
     input->required = NO;
     input->multiple = YES;
     input->description =
-	_("Name of reflectance raster maps to correct topographically");
+	_("Name of reflectance raster maps to be corrected topographically");
     output = G_define_standard_option(G_OPT_R_OUTPUT);
     output->description =
@@ -98,7 +99,7 @@
     base = G_define_standard_option(G_OPT_R_MAP);
     base->key = "basemap";
-    base->description = _("Name of input base raster map (elevation or ilumination)");
+    base->description = _("Name of input base raster map (elevation or illumination)");
     zeni = G_define_option();
     zeni->key = "zenith";
@@ -122,13 +123,13 @@
     ilum = G_define_flag();
     ilum->key = 'i';
-    ilum->description = _("To output sun ilumination terrain model");
+    ilum->description = _("Output sun illumination terrain model");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     if (ilum->answer && azim->answer == NULL)
-	G_fatal_error(_("Solar azimuth is necessary to calculate ilumination terrain model"));
+	G_fatal_error(_("Solar azimuth is necessary to calculate illumination terrain model"));
     if (!ilum->answer && input->answer == NULL)
 	G_fatal_error(_("Reflectance maps are necessary to make topographic correction"));
@@ -235,6 +236,19 @@
 	    /* TODO: better avoid system() */
 	    sprintf(command, "r.colors map=%s color=grey", out.name);
 	    system(command);
+/* new but not functional:
+		struct FPRange range;
+		DCELL min, max;
+		struct Colors grey;
+		G_read_fp_range(out.name, G_mapset(), &range);
+		G_get_fp_range_min_max(&range, &min, &max);
+		G_make_grey_scale_colors(&grey, min, max);
+		G_write_colors(out.name, G_mapset(), &grey);
 	G_close_cell(dem.fd);
Modified: grass/branches/releasebranch_6_4/imagery/i.topo.corr/test_i.topo.corr_synthetic_DEM_NC.sh
--- grass/branches/releasebranch_6_4/imagery/i.topo.corr/test_i.topo.corr_synthetic_DEM_NC.sh	2011-08-06 07:36:01 UTC (rev 47466)
+++ grass/branches/releasebranch_6_4/imagery/i.topo.corr/test_i.topo.corr_synthetic_DEM_NC.sh	2011-08-06 07:50:17 UTC (rev 47467)
@@ -60,29 +60,34 @@
 #making the 'band' reflectance file
 r.mapcalc "myplane_pyr_band = double((myplane_pyr_shaded - 60.)/18.)"
-d.mon stop=x0
+d.mon stop=x0 > /dev/null
 d.mon x0
 d.rast.leg myplane_pyr_band
+echo "Original" | d.text color=black
 ## test it:
 # percent
 METHOD=percent
 i.topo.corr input=myplane_pyr_band output=myplane_pyr_topocorr_${METHOD} basemap=myplane_pyr_illumination zenith=$solarzenith method=$METHOD
-d.mon stop=x1
+d.mon stop=x1 > /dev/null
 d.mon x1
 d.rast.leg myplane_pyr_topocorr_${METHOD}.myplane_pyr_band
+echo "METHOD=percent" | d.text color=black
 # minnaert
 METHOD=minnaert
-d.mon stop=x2
+d.mon stop=x2 > /dev/null
 d.mon x2
+echo "METHOD=minnaert" | d.text color=black
 # c-factor
 METHOD=c-factor
-d.mon stop=x3
+d.mon stop=x3 > /dev/null
 d.mon x3
+echo "METHOD=c-factor" | d.text color=black
+exit 0
