[GRASS-SVN] r47524 - in grass/trunk: include lib/raster
Wed Aug 10 06:09:37 EDT 2011
Author: martinl
Date: 2011-08-10 03:09:37 -0700 (Wed, 10 Aug 2011)
New Revision: 47524
   grass/trunk/include/gis.h
   grass/trunk/include/raster.h
   grass/trunk/include/rasterdefs.h
   grass/trunk/lib/raster/color_read.c
gislib/rasterlib: struct Colors moved to gislib
		  Rast__read_colors() added
Modified: grass/trunk/include/gis.h
--- grass/trunk/include/gis.h	2011-08-10 10:09:01 UTC (rev 47523)
+++ grass/trunk/include/gis.h	2011-08-10 10:09:37 UTC (rev 47524)
@@ -397,6 +397,73 @@
     int pid;
+typedef int CELL;
+typedef double DCELL;
+typedef float FCELL;
+struct _Color_Value_
+    DCELL value;
+    unsigned char red;
+    unsigned char grn;
+    unsigned char blu;
+struct _Color_Rule_
+    struct _Color_Value_ low, high;
+    struct _Color_Rule_ *next;
+    struct _Color_Rule_ *prev;
+struct _Color_Info_
+    struct _Color_Rule_ *rules;
+    int n_rules;
+    struct
+	unsigned char *red;
+	unsigned char *grn;
+	unsigned char *blu;
+	unsigned char *set;
+	int nalloc;
+	int active;
+    } lookup;
+    struct
+	DCELL *vals;
+	/* pointers to color rules corresponding to the intervals btwn vals */
+	struct _Color_Rule_ **rules;
+	int nalloc;
+	int active;
+    } fp_lookup;
+    DCELL min, max;
+struct Colors
+    int version;		/* set by read_colors: -1=old,1=new */
+    DCELL shift;
+    int invert;
+    int is_float;		/* defined on floating point raster data? */
+    int null_set;		/* the colors for null are set? */
+    unsigned char null_red;
+    unsigned char null_grn;
+    unsigned char null_blu;
+    int undef_set;		/* the colors for cells not in range are set? */
+    unsigned char undef_red;
+    unsigned char undef_grn;
+    unsigned char undef_blu;
+    struct _Color_Info_ fixed;
+    struct _Color_Info_ modular;
+    DCELL cmin;
+    DCELL cmax;
+    int organizing;
 /*============================== Prototypes ================================*/
 /* Since there are so many prototypes for the gis library they are stored */
Modified: grass/trunk/include/raster.h
--- grass/trunk/include/raster.h	2011-08-10 10:09:01 UTC (rev 47523)
+++ grass/trunk/include/raster.h	2011-08-10 10:09:37 UTC (rev 47524)
@@ -17,10 +17,6 @@
 #define CUBIC     3		/* cubic interpolation             */
 /*** typedefs ***/
-typedef int CELL;
-typedef double DCELL;
-typedef float FCELL;
 typedef int RASTER_MAP_TYPE;
 /* for G_get_raster_sample() */
@@ -224,70 +220,6 @@
 struct GDAL_link;
-struct _Color_Value_
-    DCELL value;
-    unsigned char red;
-    unsigned char grn;
-    unsigned char blu;
-struct _Color_Rule_
-    struct _Color_Value_ low, high;
-    struct _Color_Rule_ *next;
-    struct _Color_Rule_ *prev;
-struct _Color_Info_
-    struct _Color_Rule_ *rules;
-    int n_rules;
-    struct
-	unsigned char *red;
-	unsigned char *grn;
-	unsigned char *blu;
-	unsigned char *set;
-	int nalloc;
-	int active;
-    } lookup;
-    struct
-	DCELL *vals;
-	/* pointers to color rules corresponding to the intervals btwn vals */
-	struct _Color_Rule_ **rules;
-	int nalloc;
-	int active;
-    } fp_lookup;
-    DCELL min, max;
-struct Colors
-    int version;		/* set by read_colors: -1=old,1=new */
-    DCELL shift;
-    int invert;
-    int is_float;		/* defined on floating point raster data? */
-    int null_set;		/* the colors for null are set? */
-    unsigned char null_red;
-    unsigned char null_grn;
-    unsigned char null_blu;
-    int undef_set;		/* the colors for cells not in range are set? */
-    unsigned char undef_red;
-    unsigned char undef_grn;
-    unsigned char undef_blu;
-    struct _Color_Info_ fixed;
-    struct _Color_Info_ modular;
-    DCELL cmin;
-    DCELL cmax;
-    int organizing;
 typedef struct
     unsigned char r, g, b, a;	/* red, green, blue, and alpha */
Modified: grass/trunk/include/rasterdefs.h
--- grass/trunk/include/rasterdefs.h	2011-08-10 10:09:01 UTC (rev 47523)
+++ grass/trunk/include/rasterdefs.h	2011-08-10 10:09:37 UTC (rev 47524)
@@ -185,6 +185,7 @@
 /* color_read.c */
 int Rast_read_colors(const char *, const char *, struct Colors *);
+int Rast__read_colors(const char *, const char *, const char *, struct Colors *);
 void Rast_mark_colors_as_fp(struct Colors *);
 /* color_remove.c */
Modified: grass/trunk/lib/raster/color_read.c
--- grass/trunk/lib/raster/color_read.c	2011-08-10 10:09:01 UTC (rev 47523)
+++ grass/trunk/lib/raster/color_read.c	2011-08-10 10:09:37 UTC (rev 47524)
@@ -1,16 +1,16 @@
- * \file raster/color_read.c
- * \brief Raster Library - Read color table of raster map
- * (C) 1999-2009 by the GRASS Development Team
- * This program is free software under the GNU General Public
- * License (>=v2). Read the file COPYING that comes with GRASS
- * for details.
- * \author USACERL and many others
+  \file lib/raster/color_read.c
+  \brief Raster Library - Read color table of raster map
+  (C) 1999-2009, 2011 by the GRASS Development Team
+  This program is free software under the GNU General Public
+  License (>=v2). Read the file COPYING that comes with GRASS
+  for details.
+  \author USACERL and many others
 #include <string.h>
@@ -18,42 +18,40 @@
 #include <grass/raster.h>
 #include <grass/glocale.h>
-static int read_colors(const char *, const char *, const char *,
-		       struct Colors *);
 static int read_new_colors(FILE *, struct Colors *);
 static int read_old_colors(FILE *, struct Colors *);
- * \brief Read raster map layer color table
- * The color table for the raster map <i>name</i> in the specified
- * <i>mapset</i> is read into the <i>colors</i> structure. If the data
- * layer has no color table, a default color table is generated and 0
- * is returned. If there is an error reading the color table, a
- * diagnostic message is printed and -1 is returned. If the color
- * table is read ok, 1 is returned.
- * This routine reads the rules from the color file. If the input
- * raster map is is a floating-point map it calls
- * Rast_mark_colors_as_fp().
- *  Note: If a secondary color file for map name <i>name</i> exists in
- *  the current project, that color file is read.  This allows the
- *  user to define their own color lookup tables for cell maps found
- *  in other mapsets.
- *  Warning message is printed if the color file is
- *  missing or invalid.
- * \param name map name
- * \param mapset mapset name
- * \param[out] colors pointer to Colors structure
- * \return -1 on error
- * \return 0 if missing, but default colors generated
- * \return 1 on success
+  \brief Read color table of raster map
+  The color table for the raster map <i>name</i> in the specified
+  <i>mapset</i> is read into the <i>colors</i> structure. If the data
+  layer has no color table, a default color table is generated and 0
+  is returned. If there is an error reading the color table, a
+  diagnostic message is printed and -1 is returned. If the color
+  table is read ok, 1 is returned.
+  This routine reads the rules from the color file. If the input
+  raster map is is a floating-point map it calls
+  Rast_mark_colors_as_fp().
+  Note: If a secondary color file for map name <i>name</i> exists in
+  the current project, that color file is read.  This allows the
+  user to define their own color lookup tables for cell maps found
+  in other mapsets.
+  Warning message is printed if the color file is
+  missing or invalid.
+  \param name map name
+  \param mapset mapset name
+  \param[out] colors pointer to Colors structure
+  \return -1 on error
+  \return 0 if missing, but default colors generated
+  \return 1 on success
 int Rast_read_colors(const char *name, const char *mapset,
 		     struct Colors *colors)
@@ -78,11 +76,11 @@
     /* first look for secondary color table in current mapset */
     sprintf(buf, "colr2/%s", mapset);
-    if (read_colors(buf, name, G_mapset(), colors) >= 0)
+    if (Rast__read_colors(buf, name, G_mapset(), colors) >= 0)
 	return 1;
     /* now look for the regular color table */
-    switch (read_colors("colr", name, mapset, colors)) {
+    switch (Rast__read_colors("colr", name, mapset, colors)) {
     case -2:
 	if (!fp) {
 	    if (Rast_read_range(name, mapset, &range) >= 0) {
@@ -115,8 +113,8 @@
     return -1;
-static int read_colors(const char *element, const char *name,
-		       const char *mapset, struct Colors *colors)
+int Rast__read_colors(const char *element, const char *name,
+		      const char *mapset, struct Colors *colors)
     FILE *fd;
     int stat;
