[GRASS-SVN] r47556 - grass/trunk/gui/wxpython/gui_modules
Thu Aug 11 16:14:07 EDT 2011
Author: cmbarton
Date: 2011-08-11 13:14:07 -0700 (Thu, 11 Aug 2011)
New Revision: 47556
   grass/trunk/gui/wxpython/gui_modules/colorrules.py
Fixing various bugs
Modified: grass/trunk/gui/wxpython/gui_modules/colorrules.py
--- grass/trunk/gui/wxpython/gui_modules/colorrules.py	2011-08-11 19:21:47 UTC (rev 47555)
+++ grass/trunk/gui/wxpython/gui_modules/colorrules.py	2011-08-11 20:14:07 UTC (rev 47556)
@@ -1050,7 +1050,7 @@
         self.cb_color_att.SetSelection(0)
         self.properties['source_rgb'] = self.cb_color_att.GetString(0)
         self.cb_rgb_col.InsertColumns(vector = self.inmap, layer = vlayer, type = ["character"], dbInfo = self.dbInfo)
-        self.cb_rgb_col.Delete(self.cb_rgb_col.FindString(self.properties['source_rgb']))
+#        self.cb_rgb_col.Delete(self.cb_rgb_col.FindString(self.properties['source_rgb']))
         found = self.cb_rgb_col.FindString('GRASSRGB')
         if found != wx.NOT_FOUND:
             self.cb_rgb_col.SetSelection(found)
@@ -1244,6 +1244,7 @@
                         input = gtemp)
         return True
 ##    def ColorFromString(self, rgb):
 ##        """!Convert color string '255:255:255' to tuple"""
 ##        try:
@@ -1580,9 +1581,12 @@
         @return True on success otherwise False
-        ret = self.CreateColorTable()
+        ret = VectorColorTable.CreateColorTable(self)
         if not ret:
-            GMessage(parent = self, message = _("No color rules given."))
+            gcmd.GMessage(parent = self, message = _("No color rules given."))
+        ret = self.CreateSizeTable()
+        if not ret:
+            gcmd.GMessage(parent = self, message = _("No size rules given."))
         data = self.parent.GetLayerData(nvizType = 'vector')
         data['vector']['points']['thematic']['layer'] = int(self.properties['layer'])
@@ -1605,8 +1609,8 @@
         return ret
-    def CreateColorTable(self, force = False):
-        """!Creates color table
+    def CreateSizeTable(self, force = False):
+        """!Creates size table
         @return False on failure
