[GRASS-SVN] r47626 - grass/trunk/vector/v.colors
Sun Aug 14 07:40:41 EDT 2011
Author: martinl
Date: 2011-08-14 04:40:41 -0700 (Sun, 14 Aug 2011)
New Revision: 47626
Added:
   grass/trunk/vector/v.colors/thumbnails.py
   grass/trunk/vector/v.colors/Makefile
v.colors: thumbnails added (based on r.colors)
Modified: grass/trunk/vector/v.colors/Makefile
--- grass/trunk/vector/v.colors/Makefile	2011-08-14 11:37:46 UTC (rev 47625)
+++ grass/trunk/vector/v.colors/Makefile	2011-08-14 11:40:41 UTC (rev 47626)
@@ -10,3 +10,17 @@
 include $(MODULE_TOPDIR)/include/Make/Module.make
 default: cmd
+# Insert thumbnail previews
+v.colors.tmp.html: $(BIN)/v.colors$(EXE) thumbnails.py
+	$(call htmldesc,$<,$@)
+	sed 's!^<DD><b>\([a-z0-9.]*\)</b>:!<DD><img width="80" height="12" src="Colortable_\1.png"> <b>\1</b>:!' "$@" > "$@.tmp"
+	mv -f "$@.tmp" "$@"
+	$(MAKE) thumbnails
+thumbnails: $(BIN)/r.mapcalc$(EXE)
+	-$(call run_grass, ./thumbnails.py)
+.PHONY: thumbnails
+.INTERMEDIATE: v.colors.tmp.html
Copied: grass/trunk/vector/v.colors/thumbnails.py (from rev 47595, grass/trunk/raster/r.colors/thumbnails.py)
--- grass/trunk/vector/v.colors/thumbnails.py	                        (rev 0)
+++ grass/trunk/vector/v.colors/thumbnails.py	2011-08-14 11:40:41 UTC (rev 47626)
@@ -0,0 +1,188 @@
+#!/usr/bin/env python
+import sys
+import os
+import atexit
+import string
+import array
+import grass.script as grass
+tmp_img = None
+tmp_grad_abs = None
+tmp_grad_rel = None
+height = 85
+width = 15
+def cleanup():
+    if tmp_img:
+	grass.try_remove(tmp_img)
+    if tmp_grad_rel:
+	grass.run_command('g.remove', rast = tmp_grad_rel, quiet = True)
+    if tmp_grad_abs:
+	grass.run_command('g.remove', rast = tmp_grad_abs, quiet = True)
+# def rotate(src, dst):
+#     grass.call(["convert", "-rotate", "90", src, dst])
+def read_ppm(src):
+    fh = open(src, "rb")
+    text = fh.read()
+    fh.close()
+    i = 0
+    j = text.find('\n', i)
+    if text[i:j] != 'P6':
+	raise IOError
+    i = j + 1
+    w, h = text[i:j].split()
+    if int(w) != width or int(h) != height:
+	raise IOError
+    i = j + 1
+    maxval = text[i:j]
+    if int(maxval) != 255:
+	raise IOError
+    i = j + 1
+    return array.array('B', text[i:])
+def write_ppm(dst, data):
+    w = height
+    h = width
+    fh = open(dst, "wb")
+    fh.write("P6\n%d %d\n%d\n" % (w, h, 255))
+    data.tofile(fh)
+    fh.close()
+def rotate_ppm(srcd):
+    dstd = array.array('B', len(srcd) * '\0')
+    for y in xrange(height):
+	for x in xrange(width):
+	    for c in xrange(3):
+		dstd[(x * height + (height - 1 - y)) * 3 + c] = srcd[(y * width + x) * 3 + c]
+    return dstd
+def flip_ppm(srcd):
+    stride = width * 3
+	dy = (height - 1 - y)
+	dstd[dy * stride:(dy + 1) * stride] = srcd[y * stride:(y + 1) * stride]
+    return dstd
+def ppmtopng(dst, src):
+    if grass.find_program("g.ppmtopng", ["help"]):
+	grass.run_command('g.ppmtopng', input = src, output = dst, quiet = True)
+    elif grass.find_program("pnmtopng"):
+	fh = open(dst, 'wb')
+	grass.call(["pnmtopng", src], stdout = fh)
+	fh.close()
+    elif grass.find_program("convert"):
+	grass.call(["convert", src, dst])
+    else:
+	grass.fatal(_("Cannot find g.ppmtopng, pnmtopng or convert"))
+def convert_and_rotate(src, dst, flip = False):
+    ppm = read_ppm(src)
+    if flip:
+	ppm = flip_ppm(ppm)
+    ppm = rotate_ppm(ppm)
+    write_ppm(tmp_img, ppm)
+    ppmtopng(dst, tmp_img)
+def make_gradient(path):
+    fh = open(path)
+    text = fh.read()
+    fh.close()
+    lines = text.splitlines()
+    records = list()
+    for line in lines:
+	if line.startswith("#"):
+	    # skip comments
+	    continue
+	records.append(line.split())
+    records = [record for record in records if record[0] != 'nv']
+    relative = False
+    absolute = False
+    for record in records:
+	if record[0].endswith("%"):
+	    relative = True
+	    record[0] = record[0].rstrip("%")
+	else:
+	    absolute = True
+    if absolute:
+	if relative:
+	    minval = -0.04
+	    maxval = 0.04
+	else:
+	    minval = float(records[0][0])
+	    maxval = float(records[-1][0])
+	    maxval = min(maxval, 2500000)
+	grad = tmp_grad_abs
+	grass.mapcalc("$grad = if(row()==1, float($min), float($max))",
+		      grad = tmp_grad_abs, min = minval, max = maxval, quiet = True)
+    else:
+	grad = tmp_grad_rel
+    return grad
+def make_image(output_dir, table, grad, discrete = False):
+    if discrete:
+	lines, cols = height, 1
+    else:
+	lines, cols = None, None
+    grass.run_command("r.colors", map = grad, color = table, quiet = True)
+    grass.run_command("d.colortable", flags = 'n', map = grad, lines = lines, cols = cols, quiet = True)
+    outfile = os.path.join(output_dir, "Colortable_%s.png" % table)
+    convert_and_rotate(tmp_img, outfile, discrete)
+def main():
+    global tmp_img, tmp_grad_abs, tmp_grad_rel
+    os.environ['GRASS_OVERWRITE'] = '1'
+    color_dir = os.path.join(os.environ['GISBASE'], "etc", "colors")
+    output_dir = os.path.join(os.environ['GISBASE'], "docs", "html")
+    if not os.path.exists(output_dir):
+	os.makedirs(output_dir)
+    pid = os.getpid()
+    tmp_grad_abs = "tmp_grad_abs_%d" % pid
+    tmp_grad_rel = "tmp_grad_rel_%d" % pid
+    tmp_img = grass.tempfile() + ".ppm"
+    os.environ['GRASS_WIDTH'] = '%d' % width
+    os.environ['GRASS_HEIGHT'] = '%d' % height
+    os.environ['GRASS_FRAME'] = '%f,%f,%f,%f' % (0,height,0,width)
+    os.environ['GRASS_PNGFILE'] = tmp_img
+    os.environ['GRASS_TRUECOLOR'] = 'TRUE'
+    os.environ['GRASS_PNG_READ'] = 'FALSE'
+    os.environ['GRASS_PNG_MAPPED'] = 'FALSE'
+    os.environ['GRASS_TRANSPARENT'] = 'FALSE'
+    os.environ['GRASS_BACKGROUNDCOLOR'] = 'ffffff'
+    os.environ['GRASS_RENDER_IMMEDIATE'] = 'cairo'
+    for var in ['GRASS_LINE_WIDTH', 'GRASS_ANTIALIAS']:
+	if var in os.environ:
+	    del os.environ[var]
+    grass.use_temp_region()
+    grass.run_command('g.region', rows = 100, cols = 100)
+    grass.mapcalc("$grad = row()/1.0", grad = tmp_grad_rel, quiet = True)
+    for table in os.listdir(color_dir):
+	path = os.path.join(color_dir, table)
+	grad = make_gradient(path)
+	make_image(output_dir, table, grad)
+    grass.mapcalc("$grad = row()", grad = tmp_grad_abs, quiet = True)
+    for table in ['grey.eq', 'grey.log', 'random']:
+	make_image(output_dir, table, tmp_grad_abs, True)
+if __name__ == "__main__":
+    atexit.register(cleanup)
+    main()
