[GRASS-SVN] r47673 - in grass/branches/releasebranch_6_4/raster/r.li: r.li.cwed r.li.daemon r.li.edgedensity r.li.mpa r.li.padcv r.li.padrange r.li.padsd r.li.pielou r.li.renyi
Tue Aug 16 10:08:37 EDT 2011
Author: neteler
Date: 2011-08-16 07:08:37 -0700 (Tue, 16 Aug 2011)
New Revision: 47673
   grass/branches/releasebranch_6_4/raster/r.li/r.li.cwed/cwed.c
   grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/avl.h
   grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c
   grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/index.h
   grass/branches/releasebranch_6_4/raster/r.li/r.li.edgedensity/edgedensity.c
   grass/branches/releasebranch_6_4/raster/r.li/r.li.mpa/mpa.c
   grass/branches/releasebranch_6_4/raster/r.li/r.li.padcv/padcv.c
   grass/branches/releasebranch_6_4/raster/r.li/r.li.padrange/padrange.c
   grass/branches/releasebranch_6_4/raster/r.li/r.li.padsd/padsd.c
   grass/branches/releasebranch_6_4/raster/r.li/r.li.pielou/pielou.c
   grass/branches/releasebranch_6_4/raster/r.li/r.li.renyi/renyi.c
code layout fixes with indent
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.cwed/cwed.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.cwed/cwed.c	2011-08-16 11:48:40 UTC (rev 47672)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.cwed/cwed.c	2011-08-16 14:08:37 UTC (rev 47673)
@@ -434,7 +434,7 @@
 	G_free(mask_corr);
 	G_free(mask_sup);
     G_free(buf_sup);
     return RLI_OK;
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/avl.h
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/avl.h	2011-08-16 11:48:40 UTC (rev 47672)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/avl.h	2011-08-16 14:08:37 UTC (rev 47673)
@@ -14,7 +14,7 @@
 typedef struct avl_node
-    generic_cell key;	/* key field is a CELL or a DCELL or a FCELL */
+    generic_cell key;		/* key field is a CELL or a DCELL or a FCELL */
     long counter;		/* data */
     struct avl_node *father;
     struct avl_node *right_child;
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c	2011-08-16 11:48:40 UTC (rev 47672)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/daemon.c	2011-08-16 14:08:37 UTC (rev 47673)
@@ -104,8 +104,9 @@
     /* strip off leading path if present */
     char testpath[GPATH_MAX];
     sprintf(testpath, "%s%s", G_home(), "/.r.li/history/");
-    if(strncmp(file, testpath, strlen(testpath)) == 0)
+    if (strncmp(file, testpath, strlen(testpath)) == 0)
 	file += strlen(testpath);
     /* TODO: check if this path is portable */
@@ -137,8 +138,7 @@
 	doneDir = G_mkdir(out);
 	if (doneDir == -1 && errno != EEXIST)
-	    G_fatal_error(_("Cannot create %s/.r.li/ directory"),
-			  G_home());
+	    G_fatal_error(_("Cannot create %s/.r.li/ directory"), G_home());
 	sprintf(out, "%s/.r.li/output", G_home());
@@ -240,13 +240,11 @@
 	wait(&status);
 	if (!(WIFEXITED(status)))
-	    G_warning(
-		    _("r.li.worker (pid %i) exited with abnormal status: %i"),
-		    donePid, status);
+	    G_warning(_("r.li.worker (pid %i) exited with abnormal status: %i"),
+		      donePid, status);
 	else
-	    G_verbose_message(
-		    _("r.li.worker (pid %i) terminated successfully"),
-		    donePid);
+	    G_verbose_message(_("r.li.worker (pid %i) terminated successfully"),
+			      donePid);
 	/* remove pipe */
 	if (close(child[j].channel) != 0)
@@ -265,13 +263,11 @@
 	wait(&status);
-	    G_warning(
-		    child[i].pid, status);
+		      child[i].pid, status);
 	else
-		    child[i].pid);
+			      child[i].pid);
 	/* remove pipe */
 	if (close(child[i].channel) != 0)
@@ -406,7 +402,7 @@
 	} while ((token = strtok(NULL, " ")) != NULL &&
-	       strcmp(token, "SAMPLEAREA") == 0);
+		 strcmp(token, "SAMPLEAREA") == 0);
 	close(setup);
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/index.h
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/index.h	2011-08-16 11:48:40 UTC (rev 47672)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.daemon/index.h	2011-08-16 14:08:37 UTC (rev 47673)
@@ -5,7 +5,7 @@
  * \author Claudio Porta, Lucio Davide Spano, Serena Pallecchi students of Computer Science University of Pisa (Italy)
  *                      Commission from Faunalia Pontedera (PI) www.faunalia.it
-  *        Luca Delucchi and Duccio Rocchini, Fondazione Edmund Mach, Italy: r.li.pielou, r.li.renyi
+ *        Luca Delucchi and Duccio Rocchini, Fondazione Edmund Mach, Italy: r.li.pielou, r.li.renyi
  * This program is free software under the GPL (>=v2)
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.edgedensity/edgedensity.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.edgedensity/edgedensity.c	2011-08-16 11:48:40 UTC (rev 47672)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.edgedensity/edgedensity.c	2011-08-16 14:08:37 UTC (rev 47673)
@@ -380,7 +380,7 @@
 	G_free(mask_inf);
 	G_free(mask_corr);
     G_free(buf_sup);
     return RLI_OK;
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.mpa/mpa.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.mpa/mpa.c	2011-08-16 11:48:40 UTC (rev 47672)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.mpa/mpa.c	2011-08-16 14:08:37 UTC (rev 47673)
@@ -173,6 +173,7 @@
     return RLI_OK;
 int calculateD(int fd, area_des ad, double *result)
     DCELL *buf;
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.padcv/padcv.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.padcv/padcv.c	2011-08-16 11:48:40 UTC (rev 47672)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.padcv/padcv.c	2011-08-16 14:08:37 UTC (rev 47673)
@@ -51,6 +51,7 @@
     return calculateIndex(conf->answer, patchAreaDistributionCV, NULL,
 			  raster->answer, output->answer);
 int patchAreaDistributionCV(int fd, char **par, area_des ad, double *result)
     char *mapset;
@@ -94,6 +95,7 @@
     *result = indice;
     return RLI_OK;
 int calculate(int fd, area_des ad, double *result)
     CELL *buf;
@@ -491,6 +493,7 @@
     G_free(buf_sup);
     return RLI_OK;
     DCELL *buf;
@@ -884,6 +887,7 @@
     *result = indice;
     return RLI_OK;
 int calculateF(int fd, area_des ad, double *result)
     FCELL *buf;
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.padrange/padrange.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.padrange/padrange.c	2011-08-16 11:48:40 UTC (rev 47672)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.padrange/padrange.c	2011-08-16 14:08:37 UTC (rev 47673)
@@ -51,6 +51,7 @@
     return calculateIndex(conf->answer, patchAreaDistributionRANGE, NULL,
 int patchAreaDistributionRANGE(int fd, char **par, area_des ad,
 			       double *result)
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.padsd/padsd.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.padsd/padsd.c	2011-08-16 11:48:40 UTC (rev 47672)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.padsd/padsd.c	2011-08-16 14:08:37 UTC (rev 47673)
@@ -49,6 +49,7 @@
     return calculateIndex(conf->answer, patchAreaDistributionSD, NULL,
 int patchAreaDistributionSD(int fd, char **par, area_des ad, double *result)
     char *mapset;
@@ -92,6 +93,7 @@
     *result = indice;
     return RLI_OK;
     CELL *buf;
@@ -882,6 +884,7 @@
     *result = indice;
     return RLI_OK;
     FCELL *buf;
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.pielou/pielou.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.pielou/pielou.c	2011-08-16 11:48:40 UTC (rev 47672)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.pielou/pielou.c	2011-08-16 14:08:37 UTC (rev 47673)
@@ -390,6 +390,7 @@
     AVL_table *array;
     generic_cell cc;
     generic_cell cc_passage;	/*add to compute the number of class */
     cc.t = DCELL_TYPE;
     /* open mask if needed */
@@ -612,6 +613,7 @@
     AVL_table *array;
     generic_cell cc;
     cc.t = FCELL_TYPE;
Modified: grass/branches/releasebranch_6_4/raster/r.li/r.li.renyi/renyi.c
--- grass/branches/releasebranch_6_4/raster/r.li/r.li.renyi/renyi.c	2011-08-16 11:48:40 UTC (rev 47672)
+++ grass/branches/releasebranch_6_4/raster/r.li/r.li.renyi/renyi.c	2011-08-16 14:08:37 UTC (rev 47673)
@@ -156,6 +156,7 @@
     avl_tree albero = NULL;
     AVL_table *array;
     generic_cell uc;
     uc.t = CELL_TYPE;
@@ -302,7 +303,7 @@
     for (i = 0; i < m; i++) {
 	t = (double)(array[i]->tot);
 	p = t / area;
-	G_debug(1,"Valore p: %g, valore pow: %g",p,pow(p,alpha_double));
+	G_debug(1, "Valore p: %g, valore pow: %g", p, pow(p, alpha_double));
 	somma = somma + pow(p, alpha_double);
@@ -347,6 +348,7 @@
     AVL_table *array;
     generic_cell uc;
     uc.t = DCELL_TYPE;
@@ -494,7 +496,7 @@
 	p = t / area;
@@ -541,6 +543,7 @@
     AVL_table *array;
     generic_cell uc;
     uc.t = FCELL_TYPE;
@@ -691,7 +694,7 @@
 	p = t / area;
