[GRASS-SVN] r47689 - grass/branches/develbranch_6/ps/ps.map
Wed Aug 17 06:28:27 EDT 2011
Author: hamish
Date: 2011-08-17 03:28:27 -0700 (Wed, 17 Aug 2011)
New Revision: 47689
   grass/branches/develbranch_6/ps/ps.map/do_geogrid.c
   grass/branches/develbranch_6/ps/ps.map/do_grid.c
   grass/branches/develbranch_6/ps/ps.map/getgrid.c
   grass/branches/develbranch_6/ps/ps.map/main.c
   grass/branches/develbranch_6/ps/ps.map/ps_info.h
full RGB support for grid lines
Modified: grass/branches/develbranch_6/ps/ps.map/do_geogrid.c
--- grass/branches/develbranch_6/ps/ps.map/do_geogrid.c	2011-08-17 08:37:36 UTC (rev 47688)
+++ grass/branches/develbranch_6/ps/ps.map/do_geogrid.c	2011-08-17 10:28:27 UTC (rev 47689)
@@ -54,7 +54,7 @@
     /* set color and set line width */
-    set_rgb_color(PS.geogrid_color);
+    set_ps_color(&PS.geogrid_color);
     set_line_width(PS.geogrid_width);
     /* draw horizontal lines in 3 pieces -- lat-lon lines must not
@@ -166,7 +166,7 @@
     /* initialize */
     set_font_name(PS.geogrid_font);
     set_font_size(PS.geogrid_fontsize);
-    set_rgb_color(PS.geogrid_numbers_color);
+    set_ps_color(&PS.geogrid_numbers_color);
     first = 1;
     /* vertical grid numbers
@@ -204,7 +204,7 @@
 	text_box_path(x, y, RIGHT, CENTER, num_text, PS.geogrid_fontsize, 0);
 	set_rgb_color(WHITE);
 	fprintf(PS.fp, "F ");
 	fprintf(PS.fp, "TIB\n");
 	last_bottom = y - PS.geogrid_fontsize;
 	if (first) {
@@ -248,7 +248,7 @@
 	fprintf(PS.fp, "%d bt bb sub D2 add mg sub neg TR TB\n", x);
 	last_right = x + PS.geogrid_fontsize;
Modified: grass/branches/develbranch_6/ps/ps.map/do_grid.c
--- grass/branches/develbranch_6/ps/ps.map/do_grid.c	2011-08-17 08:37:36 UTC (rev 47688)
+++ grass/branches/develbranch_6/ps/ps.map/do_grid.c	2011-08-17 10:28:27 UTC (rev 47689)
@@ -27,7 +27,7 @@
 	return 1;
     /* set color and set line width to 1 */
-    set_rgb_color(PS.grid_color);
+    set_ps_color(&PS.grid_color);
     set_line_width(PS.grid_width);
@@ -85,7 +85,7 @@
 	return 1;
     g_north = floor(PS.w.north / PS.grid) * PS.grid;
@@ -139,7 +139,7 @@
     /* initialize */
     set_font_name(PS.grid_font);
     set_font_size(PS.grid_fontsize);
-    set_rgb_color(PS.grid_numbers_color);
+    set_ps_color(&PS.grid_numbers_color);
     first = 1;
     /* horizontal grid numbers
@@ -172,7 +172,7 @@
 	text_box_path(x, y, LEFT, CENTER, num_text, PS.grid_fontsize, 0);
 	last_bottom = y - PS.grid_fontsize;
 	if (first) {
@@ -211,7 +211,7 @@
 	last_right = x + PS.grid_fontsize;
Modified: grass/branches/develbranch_6/ps/ps.map/getgrid.c
--- grass/branches/develbranch_6/ps/ps.map/getgrid.c	2011-08-17 08:37:36 UTC (rev 47688)
+++ grass/branches/develbranch_6/ps/ps.map/getgrid.c	2011-08-17 10:28:27 UTC (rev 47689)
@@ -5,6 +5,8 @@
 #include <stdlib.h>
 #include <string.h>
+#include <grass/glocale.h>
+#include "clr.h"
 #include "local_proto.h"
 #define KEY(x) (strcmp(x,key)==0)
@@ -29,28 +31,35 @@
 int getgrid(void)
     int spacing;
-    int color = 0, fontsize = PS_FONT_DEFAULT_SIZE;
+    int fontsize = PS_FONT_DEFAULT_SIZE;
+    int ret, r, g, b;
     char temp[30];
     char buf[1024];
     char ch, *key, *data;
+    PSCOLOR color, text_color;
     PS.grid_font = G_store("Helvetica");
     PS.grid_fontsize = 0;
-    PS.grid_color = BLACK;
     PS.grid_numbers = 0;
     PS.grid_cross = 0.;
     PS.grid_width = 0.25;
+    set_color(&color, 0, 0, 0);
+    set_color(&text_color, 0, 0, 0);
     while (input(2, buf, help)) {
 	if (!key_data(buf, &key, &data))
 	    continue;
 	if (KEY("color")) {
-	    color = get_color_number(data);
-	    if (color < 0)
-		error(key, data, "illegal color request");
+	    ret = G_str_to_color(data, &r, &g, &b);
+	    if (ret == 1)
+		set_color(&color, r, g, b);
+	    else if (ret == 2)  /* i.e. "none" */
+		/* unset_color(&color); */
+		error(key, data, _("Unsupported color request"));
 	    else
-		PS.grid_color = color;
+		error(key, data, _("illegal color request"));
 	    continue;
@@ -59,24 +68,32 @@
 	    if (strlen(data) == 0) {
 		spacing = 1;
-		color = BLACK;
 	    switch (sscanf(data, "%d %[^\n]", &spacing, temp)) {
 	    case 1:
-		color = BLACK;
 		break;
 	    case 2:
-		color = get_color_number(temp);
-		if (color < 0)
+		ret = G_str_to_color(temp, &r, &g, &b);
+		if (ret == 1)
+		    set_color(&text_color, r, g, b);
+		else
+		if (ret < 1)
 		    spacing = -1;
 		break;
 	    if (spacing < 0)
-		error(key, data, "illegal numbers request");
+		error(key, data, _("illegal numbers request"));
 	    else {
 		PS.grid_numbers = spacing;
-		PS.grid_numbers_color = color;
+		PS.grid_numbers_color = text_color;
 	    continue;
@@ -104,16 +121,17 @@
 	    if ((sscanf(data, "%lf%c", &PS.grid_width, &ch) < 1) ||
 		(PS.grid_width < 0.)) {
 		PS.grid_width = 1.;
-		error(key, data, "illegal grid width request");
+		error(key, data, _("illegal grid width request"));
 	    if (ch == 'i')
 		PS.grid_width = PS.grid_width / 72.0;
 	    continue;
-	error(key, data, "illegal request (getgrid)");
+	error(key, data, _("illegal request (grid)"));
     PS.grid_fontsize = fontsize;
+    PS.grid_color = color;
     return 0;
@@ -124,27 +142,34 @@
 int getgeogrid(void)
     int spacing;
+    int ret, r, g, b;
     char temp[30];
     char buf[1024];
     PS.geogrid_font = G_store("Helvetica");
     PS.geogrid_fontsize = 0;
-    PS.geogrid_color = BLACK;
     PS.geogrid_numbers = 0;
     PS.geogrid_width = 0.25;
     while (input(2, buf, help2)) {
 	    continue;
 	if (KEY("color")) {
-	    if (color < 0)
+	    if (ret == 1)
 	    else
-		PS.geogrid_color = color;
 	    continue;
@@ -153,25 +178,33 @@
 		spacing = 1;
-		color = BLACK;
 	    case 1:
-		color = BLACK;
 		break;
 	    case 2:
-		if (color < 0)
+		if (ret == 1)
+		else
+		if (ret < 1)
 		    spacing = -1;
 		break;
 	    if (spacing < 0)
 	    else {
 		PS.geogrid_numbers = spacing;
-		PS.geogrid_numbers_color = color;
+		PS.geogrid_numbers_color = text_color;
 	    continue;
@@ -196,16 +229,17 @@
 	    if ((sscanf(data, "%lf%c", &PS.geogrid_width, &ch) < 1) ||
 		(PS.geogrid_width < 0.)) {
 		PS.geogrid_width = 1.;
 	    if (ch == 'i')
 		PS.geogrid_width = PS.geogrid_width / 72.0;
 	    continue;
+	error(key, data, _("illegal request (geogrid)"));
     PS.geogrid_fontsize = fontsize;
+    PS.geogrid_color = color;
     return 0;
Modified: grass/branches/develbranch_6/ps/ps.map/main.c
--- grass/branches/develbranch_6/ps/ps.map/main.c	2011-08-17 08:37:36 UTC (rev 47688)
+++ grass/branches/develbranch_6/ps/ps.map/main.c	2011-08-17 10:28:27 UTC (rev 47689)
@@ -182,8 +182,7 @@
     grp.do_group = 0;
     brd.R = brd.G = brd.B = 0.;
     brd.width = 1.;
     PS.min_y = 72.0 * (PS.page_height - PS.top_marg);
     PS.set_y = 100.0 * PS.min_y;
     PS.cell_fd = -1;
Modified: grass/branches/develbranch_6/ps/ps.map/ps_info.h
--- grass/branches/develbranch_6/ps/ps.map/ps_info.h	2011-08-17 08:37:36 UTC (rev 47688)
+++ grass/branches/develbranch_6/ps/ps.map/ps_info.h	2011-08-17 10:28:27 UTC (rev 47689)
@@ -1,4 +1,5 @@
 #include <grass/gis.h>
+#include "clr.h"
 /* Font sizes */
 #define PS_FONT_MAX_SIZE      50
@@ -42,11 +43,12 @@
     int do_border;
     int do_scalebar;
     int num_psfiles;
-    int grid, grid_color, grid_numbers, grid_numbers_color, grid_fontsize;
+    int grid, grid_numbers, grid_fontsize;
+    PSCOLOR grid_color, grid_numbers_color;
     float grid_cross;
     char geogridunit[64];
-    int geogrid, geogrid_color, geogrid_numbers;
-    int geogrid_numbers_color, geogrid_fontsize;
+    int geogrid, geogrid_numbers, geogrid_fontsize;
+    PSCOLOR geogrid_color, geogrid_numbers_color;
     double grid_width, geogrid_width;
     int do_outline, outline_color;
     int cell_fd;
