[GRASS-SVN] r47705 - in grass/branches/develbranch_6: locale/po raster/r.out.arc
Wed Aug 17 09:19:57 EDT 2011
Author: neteler
Date: 2011-08-17 06:19:57 -0700 (Wed, 17 Aug 2011)
New Revision: 47705
   grass/branches/develbranch_6/locale/po/grassmods_ar.po
   grass/branches/develbranch_6/locale/po/grassmods_cs.po
   grass/branches/develbranch_6/locale/po/grassmods_de.po
   grass/branches/develbranch_6/locale/po/grassmods_el.po
   grass/branches/develbranch_6/locale/po/grassmods_es.po
   grass/branches/develbranch_6/locale/po/grassmods_fr.po
   grass/branches/develbranch_6/locale/po/grassmods_hi.po
   grass/branches/develbranch_6/locale/po/grassmods_it.po
   grass/branches/develbranch_6/locale/po/grassmods_ja.po
   grass/branches/develbranch_6/locale/po/grassmods_ko.po
   grass/branches/develbranch_6/locale/po/grassmods_lv.po
   grass/branches/develbranch_6/locale/po/grassmods_mr.po
   grass/branches/develbranch_6/locale/po/grassmods_pl.po
   grass/branches/develbranch_6/locale/po/grassmods_pt.po
   grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
   grass/branches/develbranch_6/locale/po/grassmods_ru.po
   grass/branches/develbranch_6/locale/po/grassmods_sl.po
   grass/branches/develbranch_6/locale/po/grassmods_th.po
   grass/branches/develbranch_6/locale/po/grassmods_tr.po
   grass/branches/develbranch_6/locale/po/grassmods_vi.po
   grass/branches/develbranch_6/locale/po/grassmods_zh.po
   grass/branches/develbranch_6/locale/po/grasswxpy_zh.po
   grass/branches/develbranch_6/raster/r.out.arc/main.c
parser simplification; typo
Modified: grass/branches/develbranch_6/locale/po/grassmods_ar.po
--- grass/branches/develbranch_6/locale/po/grassmods_ar.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_ar.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -8899,7 +8899,7 @@
 msgstr "اسم الملف الراسترى الموجود"
 #: ../raster/r.out.arc/main.c:78
-msgid "Name of an output ARC-GID map (use out=- for stdout)"
+msgid "Name of an output ARC-GRID map (use out=- for stdout)"
 msgstr "اسم الملف الراسترى الجديد"
 #: ../raster/r.out.arc/main.c:85
Modified: grass/branches/develbranch_6/locale/po/grassmods_cs.po
--- grass/branches/develbranch_6/locale/po/grassmods_cs.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_cs.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -8939,7 +8939,7 @@
 msgstr "Název existujícího rastru"
 msgstr ""
 "Název výstupního ARC-GRID souboru (pro standardní výstup pou¾ijte out=-)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_de.po
--- grass/branches/develbranch_6/locale/po/grassmods_de.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_de.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -9046,7 +9046,7 @@
 msgstr "Name einer existierenden Rasterkarte."
 msgstr "Name der Ausgabe ARCGRID-Datei (verwende out=- für stdout)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_el.po
--- grass/branches/develbranch_6/locale/po/grassmods_el.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_el.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -8496,7 +8496,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_es.po
--- grass/branches/develbranch_6/locale/po/grassmods_es.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_es.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -9048,8 +9048,8 @@
 msgstr "Nombre de una capa de mapa ráster existente"
-msgstr "Nombre de un mapa ARC-GID de salida (usar out=- para stdout)"
+msgstr "Nombre de un mapa ARC-GRID de salida (usar out=- para stdout)"
 msgid "Number of decimal places"
Modified: grass/branches/develbranch_6/locale/po/grassmods_fr.po
--- grass/branches/develbranch_6/locale/po/grassmods_fr.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_fr.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -9610,7 +9610,7 @@
 msgstr "Nom de la couche raster existante"
 msgstr "Nom de la couche ARC-GRID à créer (utiliser out=- pour stdout)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_hi.po
--- grass/branches/develbranch_6/locale/po/grassmods_hi.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_hi.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -9159,7 +9159,7 @@
 #, fuzzy
 msgstr "का के लिए"
Modified: grass/branches/develbranch_6/locale/po/grassmods_it.po
--- grass/branches/develbranch_6/locale/po/grassmods_it.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_it.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -8521,8 +8521,8 @@
 msgstr "Nome di una mappa raster esistente"
-msgstr "Nome di output di una mappa ARC-GID (usa out=- per lo standard output)"
+msgstr "Nome di output di una mappa ARC-GRID (usa out=- per lo standard output)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_ja.po
--- grass/branches/develbranch_6/locale/po/grassmods_ja.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_ja.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -8725,8 +8725,8 @@
 msgstr "既存のラスターマップ レイヤー名"
-msgstr "出力する ARC-GID マップ名 (標準出力には out= - を使用する)"
+msgstr "出力する ARC-GRID マップ名 (標準出力には out= - を使用する)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_ko.po
--- grass/branches/develbranch_6/locale/po/grassmods_ko.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_ko.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -8562,7 +8562,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_lv.po
--- grass/branches/develbranch_6/locale/po/grassmods_lv.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_lv.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -8754,7 +8754,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_mr.po
--- grass/branches/develbranch_6/locale/po/grassmods_mr.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_mr.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -8606,7 +8606,7 @@
 msgstr ""
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_pl.po
--- grass/branches/develbranch_6/locale/po/grassmods_pl.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_pl.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -8842,8 +8842,8 @@
 msgstr "Nazwa istniejÄ…cej warstwy mapy rastrowej"
-msgstr "Nazwa wyjściowej mapy ARC-GID (use out=- for stdout)"
+msgstr "Nazwa wyjściowej mapy ARC-GRID (use out=- for stdout)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -9275,8 +9275,8 @@
 msgstr "Nome da camada raster existente"
-msgstr "Nome do mapa ARC-GID de saída (use 'out=-' para saída padrão)"
+msgstr "Nome do mapa ARC-GRID de saída (use 'out=-' para saída padrão)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_pt_br.po
--- grass/branches/develbranch_6/locale/po/grassmods_pt_br.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_pt_br.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -8615,8 +8615,8 @@
Modified: grass/branches/develbranch_6/locale/po/grassmods_ru.po
--- grass/branches/develbranch_6/locale/po/grassmods_ru.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_ru.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -8994,9 +8994,9 @@
 msgstr "Имя существующего растрового слоя"
 msgstr ""
-"Имя выходного слоя ARC-GID (используйте out=- для stdout (стандартного "
+"Имя выходного слоя ARC-GRID (используйте out=- для stdout (стандартного "
 "вывода))"
Modified: grass/branches/develbranch_6/locale/po/grassmods_sl.po
--- grass/branches/develbranch_6/locale/po/grassmods_sl.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_sl.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -9029,7 +9029,7 @@
 msgstr "Ime obstojeèega rastrskega sloja"
 msgstr ""
 "Ime izhodne ARC-GRID datoteke (uporabi out=- za standardni izhod (stdout))"
Modified: grass/branches/develbranch_6/locale/po/grassmods_th.po
--- grass/branches/develbranch_6/locale/po/grassmods_th.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_th.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -8821,8 +8821,8 @@
 msgstr "ชื่อของ ชั้นข้อมูลแผนที่เชิงภาพ ที่มีอยู่"
-msgstr "ชื่อของ แผนที่ผลลัพธ์  ARC-GID (ใช้ out=- สำหรับ stdout)"
+msgstr "ชื่อของ แผนที่ผลลัพธ์  ARC-GRID (ใช้ out=- สำหรับ stdout)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_tr.po
--- grass/branches/develbranch_6/locale/po/grassmods_tr.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_tr.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -8583,7 +8583,7 @@
 msgstr "Mevcut bir raster harita katmanı adı"
 msgstr ""
Modified: grass/branches/develbranch_6/locale/po/grassmods_vi.po
--- grass/branches/develbranch_6/locale/po/grassmods_vi.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_vi.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -8952,8 +8952,8 @@
 msgstr "Tên lớp bản đồ raster hiện có"
-msgstr "Tên bản đồ ARC-GID đầu ra (dùng out=- cho đầu ra tiêu chuẩn)"
+msgstr "Tên bản đồ ARC-GRID đầu ra (dùng out=- cho đầu ra tiêu chuẩn)"
Modified: grass/branches/develbranch_6/locale/po/grassmods_zh.po
--- grass/branches/develbranch_6/locale/po/grassmods_zh.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grassmods_zh.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -8931,7 +8931,7 @@
 msgstr "已有栅格图层的名称"
 msgstr "输出的GRID的名称(out=-用于标准输出)"
Modified: grass/branches/develbranch_6/locale/po/grasswxpy_zh.po
--- grass/branches/develbranch_6/locale/po/grasswxpy_zh.po	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/locale/po/grasswxpy_zh.po	2011-08-17 13:19:57 UTC (rev 47705)
@@ -16584,7 +16584,7 @@
 #~ msgid "Name of an existing raster map layer"
 #~ msgstr "已有栅格图层的名称"
-#~ msgid "Name of an output ARC-GID map (use out=- for stdout)"
+#~ msgid "Name of an output ARC-GRID map (use out=- for stdout)"
 #~ msgstr "输出的GRID的名称(out=-用于标准输出)"
 #~ msgid "Number of decimal places"
Modified: grass/branches/develbranch_6/raster/r.out.arc/main.c
--- grass/branches/develbranch_6/raster/r.out.arc/main.c	2011-08-17 13:18:30 UTC (rev 47704)
+++ grass/branches/develbranch_6/raster/r.out.arc/main.c	2011-08-17 13:19:57 UTC (rev 47705)
@@ -62,20 +62,12 @@
 	_("Converts a raster map layer into an ESRI ARCGRID file.");
     /* Define the different options */
-    parm.map = G_define_option();
-    parm.map->key = "input";
-    parm.map->type = TYPE_STRING;
-    parm.map->required = YES;
-    parm.map->gisprompt = "old,cell,raster";
-    parm.map->description = _("Name of an existing raster map layer");
+    parm.map = G_define_standard_option(G_OPT_R_INPUT);
-    parm.output = G_define_option();
-    parm.output->key = "output";
-    parm.output->type = TYPE_STRING;
-    parm.output->required = YES;
+    parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
     parm.output->gisprompt = "new_file,file,output";
     parm.output->description =
-	_("Name of an output ARC-GID map (use out=- for stdout)");
+	_("Name of an output ARC-GRID map (use out=- for stdout)");
     parm.dp = G_define_option();
     parm.dp->key = "dp";
