[GRASS-SVN] r47720 - grass/branches/releasebranch_6_4/raster3d/r3.gwflow
Wed Aug 17 17:40:45 EDT 2011
Author: neteler
Date: 2011-08-17 14:40:45 -0700 (Wed, 17 Aug 2011)
New Revision: 47720
   grass/branches/releasebranch_6_4/raster3d/r3.gwflow/description.html
   grass/branches/releasebranch_6_4/raster3d/r3.gwflow/main.c
Milena Nowotarska: i18n cleanup; HTML cleanup
Modified: grass/branches/releasebranch_6_4/raster3d/r3.gwflow/description.html
--- grass/branches/releasebranch_6_4/raster3d/r3.gwflow/description.html	2011-08-17 21:32:48 UTC (rev 47719)
+++ grass/branches/releasebranch_6_4/raster3d/r3.gwflow/description.html	2011-08-17 21:40:45 UTC (rev 47720)
@@ -1,24 +1,23 @@
-<H2>DESCRIPTION</H2>
-This numerical program calculates transient, confined groundwater flow in three dimensions
-based on volume maps and the current 3d region resolution.
+<h2>DESCRIPTION</h2>
+This numerical module calculates transient, confined groundwater flow
+in three dimensions based on volume maps and the current 3D region resolution.
 All initial- and boundary-conditions must be provided as
 volume maps.
-<br>
-<br>
-This module calculates the piezometric head and optionally the
+<p>
+The module calculates the piezometric head and optionally the
 groundwater velocity field.
-The vector components can be visualized with paraview if they are exported
+The vector components can be visualized with ParaView if they are exported
 with <em>r3.out.vtk</em>.
-<br>
-<br>
+<p>
 The groundwater flow will always be calculated transient.
-If you want to calculate stady state, set the timestep
+If you want to calculate steady state, set the timestep
 to a large number (billions of seconds) or set the
 specific yield raster maps to zero.
+<h2>NOTES</h2>
-<H2>NOTES</H2>
 The groundwater flow calculation is based on Darcy's law and a
 finite volume discretization. The groundwater flow partial
 differential equation is of the following form:
@@ -37,34 +36,36 @@
 <li>q - inner source in [1/s]</li>
 </ul>
-<br>
-<br>
+<p>
 Two different boundary conditions are implemented,
-the Dirichlet and Neumann conditions. By default the calculation area is surrounded by homogeneous Neumann boundary conditions.
-The calculation and boundary status of single cells can be set with the status map,
-the following cell states are supportet:
+the Dirichlet and Neumann conditions. By default the calculation
+area is surrounded by homogeneous Neumann boundary conditions.
+The calculation and boundary status of single cells can be set with
+the status map, the following cell states are supportet:
 <ul>
-<li>0 == inactive - the cell with status 0 will not be calulated, active cells will have a no flow boundary to an inactive cell</li>
-<li>1 == active - this cell is used for groundwater calculation, inner sources can be defined for those cells</li>
-<li>2 == Dirichlet - cells of this type will have a fixed piezometric head value which do not change over time </li>
+<li>0 == inactive - the cell with status 0 will not be calulated,
+active cells will have a no flow boundary to an inactive cell</li>
+<li>1 == active - this cell is used for groundwater calculation,
+inner sources can be defined for those cells</li>
+<li>2 == Dirichlet - cells of this type will have a fixed piezometric
+head value which do not change over time </li>
 </ul>
-<br>
-<br>
-The groundwater flow equation can be solved with several solvers.
+<p>
+The groundwater flow equation can be solved with several numerical solvers.
 Aditionally a direct Gauss solver and LU solver are available. Those direct solvers
 only work with quadratic matrices, so be careful using them with large maps
-(maps of size 10.000 cells will need more than one gigabyte of ram).
+(maps of size 10.000 cells will need more than one gigabyte of RAM).
-<H2>EXAMPLE</H2>
+<h2>EXAMPLE</h2>
 Use this small script to create a working
 groundwater flow area and data. Make sure you are not in a lat/lon projection.
 <div class="code"><pre>
 # set the region accordingly
-g.region res=25 res3=25 t=100 b=0 n=1000 s=0 w=0 e=1000
+g.region res=25 res3=25 t=100 b=0 n=1000 s=0 w=0 e=1000 -p
 #now create the input raster maps for a confined aquifer
 r3.mapcalc "phead=if(row() == 1 && depth() == 4, 50, 40)"
@@ -74,21 +75,21 @@
 r3.mapcalc "syield=0.0001"
 r.mapcalc  "recharge=0.0"
-r3.gwflow --o -s solver=cg phead=phead status=status hc_x=hydcond hc_y=hydcond  \
+r3.gwflow -s solver=cg phead=phead status=status hc_x=hydcond hc_y=hydcond  \
 hc_z=hydcond q=well s=syield r=recharge output=gwresult dt=8640000 velocity=gwresult_velocity
-# The data can be visulaized with paraview when exported with r3.out.vtk
+# The data can be visualized with ParaView when exported with r3.out.vtk
 r3.out.vtk -p in=gwresult,status vector=gwresult_velocity_x,gwresult_velocity_y,gwresult_velocity_z out=/tmp/gwdata3d.vtk
-#now load the data into paraview
+#now load the data into ParaView
 </pre></div>
-<H2>SEE ALSO</H2>
+<h2>SEE ALSO</h2>
-<EM><A HREF="r.gwflow.html">r.gwflow</A></EM><br>
-<EM><A HREF="r3.out.vtk.html">r3.out.vtk</A></EM><br>
+<em><a href="r.gwflow.html">r.gwflow</a></em><br>
+<em><a href="r3.out.vtk.html">r3.out.vtk</a></em><br>
-<H2>AUTHOR</H2>
+<h2>AUTHOR</h2>
 Soeren Gebbert
 <p><i>Last changed: $Date$</i>
Modified: grass/branches/releasebranch_6_4/raster3d/r3.gwflow/main.c
--- grass/branches/releasebranch_6_4/raster3d/r3.gwflow/main.c	2011-08-17 21:32:48 UTC (rev 47719)
+++ grass/branches/releasebranch_6_4/raster3d/r3.gwflow/main.c	2011-08-17 21:40:45 UTC (rev 47720)
@@ -121,7 +121,7 @@
     param.vector->required = NO;
     param.vector->gisprompt = "new,grid3,3d-raster";
     param.vector->description =
-	_("Calculate the groundwater distance velocity vector field and write the x, y, and z components to maps named name_[xyz]. Name is basename for the new raster3d maps");
+	_("Calculates the groundwater distance velocity vector field and write the x, y and z components to maps named name_[xyz]. Name is basename for the new 3D raster maps.");
     param.dt = N_define_standard_option(N_OPT_CALC_TIME);
@@ -132,7 +132,7 @@
     param.mask = G_define_flag();
     param.mask->key = 'm';
-    param.mask->description = _("Use G3D mask (if exists)");
+    param.mask->description = _("Use 3D raster mask (if exists) with input maps");
     param.sparse = G_define_flag();
     param.sparse->key = 's';
@@ -167,7 +167,7 @@
     module = G_define_module();
     module->keywords = _("raster3d, voxel");
     module->description =
-	_("Numerical calculation program for transient, confined groundwater flow in three dimensions");
+	_("Calculates numerically transient, confined groundwater flow in three dimensions.");
     /* Get parameters from user */
     set_params();
@@ -189,10 +189,9 @@
     if (strcmp(solver, N_SOLVER_DIRECT_GAUSS) == 0 && param.sparse->answer)
 	G_fatal_error(_("The direct Gauss solver do not work with sparse matrices"));
     if (strcmp(solver, N_SOLVER_DIRECT_CHOLESKY) == 0 && param.sparse->answer)
-	G_fatal_error(_("The direct cholesky solver do not work with sparse matrices"));
+	G_fatal_error(_("The direct Cholesky solver do not work with sparse matrices"));
     /*Set the defaults */
     G3d_initDefaults();
@@ -368,10 +367,8 @@
     map = G3d_openCellNew(name, DCELL_TYPE, G3D_USE_CACHE_DEFAULT, region);
     if (map == NULL)
-	G3d_fatalError(_("Error opening g3d map <%s>"), name);
+	G3d_fatalError(_("Unable to create 3D raster map <%s>"), name);
-    G_message(_("Write the result to g3d map <%s>"), name);
     /*if requested set the Mask on */
     if (param.mask->answer) {
 	if (G3d_maskFileExists()) {
@@ -414,7 +411,7 @@
     if (!G3d_closeCell(map))
-	G3d_fatalError(map, NULL, 0, _("Error closing g3d file"));
+	G3d_fatalError(map, NULL, 0, _("Unable to close 3D raster map <%s>"), name);
     return;
