[GRASS-SVN] r47735 - grass/branches/develbranch_6/raster3d/r3.out.v5d
Wed Aug 17 18:24:43 EDT 2011
Author: neteler
Date: 2011-08-17 15:24:43 -0700 (Wed, 17 Aug 2011)
New Revision: 47735
   grass/branches/develbranch_6/raster3d/r3.out.v5d/description.html
Milena Nowotarska: i18n cleanup; HTML cleanup
Modified: grass/branches/develbranch_6/raster3d/r3.out.v5d/description.html
--- grass/branches/develbranch_6/raster3d/r3.out.v5d/description.html	2011-08-17 22:24:03 UTC (rev 47734)
+++ grass/branches/develbranch_6/raster3d/r3.out.v5d/description.html	2011-08-17 22:24:43 UTC (rev 47735)
@@ -1,17 +1,22 @@
 <H2>DESCRIPTION</H2>
-Exports <i>G3D</i> grids to <i>v5d</i> format. <i>map</i> is a valid G3D
-grid in the current mapset. <i>output</i> is the name of a v5d file which
-will be written in the current working directory. <a href="http://www.ssec.wisc.edu/~billh/vis5d.html">VIS5D</a>
-is a system for interactive visualization of large 5D gridded data sets
-such as those produced by numerical weather models. One can make isosurfaces,
-contour line slices, colored slices, volume renderings, etc of data in
-a 3D grid, then rotate and animate the images in real time. There's also
-a feature for wind trajectory tracing, a way to make text anotations for
-publications, support for interactive data analysis, etc.
+Exports 3D raster maps to V5D format. The <em>map</em> parameter is a valid
+3D raster map in the current mapset search path. The <em>output</em> parameter is the name
+of a V5D file which will be written in the current working directory.
+<p>
+<a href="http://www.ssec.wisc.edu/~billh/vis5d.html">Vis5D</a> is a system
+for interactive visualization of large 5D gridded data sets such as those
+produced by numerical weather models. The user can make isosurfaces, contour
+line slices, colored slices, volume renderings, etc. of data in a 3D raster map,
+then rotate and animate the images in real time. There's also a feature
+for wind trajectory tracing, a way to make text anotations for publications,
+support for interactive data analysis, etc.
 <h2>SEE ALSO</h2>
-<i><a href="r3.in.v5d.html">r3.in.v5d</a></i>
+<i><a href="r3.in.v5d.html">r3.in.v5d</a>,
+<a href="r3.out.vtk.html">r3.out.vtk</a>
+</i>
 <h2>AUTHOR</h2>
 Jaro Hofierka, GeoModel s.r.o., Slovakia
