[GRASS-SVN] r47817 -
grass-addons/grass7/raster/r.modis/r.modis.download
svn_grass at osgeo.org
Mon Aug 22 08:58:50 EDT 2011
Author: neteler
Date: 2011-08-22 05:58:50 -0700 (Mon, 22 Aug 2011)
New Revision: 47817
grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.html
grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py
don't crash on missing file; msg cosmetics
Modified: grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.html
--- grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.html 2011-08-22 12:15:44 UTC (rev 47816)
+++ grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.html 2011-08-22 12:58:50 UTC (rev 47817)
@@ -69,7 +69,8 @@
<a href="r.modis.import.html">r.modis.import</a>
<!-- <a href="r.modis.process.html">r.modis.process</a>,-->
</em>
+<a href="https://lpdaac.usgs.gov/lpdaac/products/modis_overview">Map of MODIS Land products' Sinusoidal grid tiling system</a>
<h2>AUTHOR</h2>
Luca Delucchi, Google Summer of Code 2011
Modified: grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py
--- grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py 2011-08-22 12:15:44 UTC (rev 47816)
+++ grass-addons/grass7/raster/r.modis/r.modis.download/r.modis.download.py 2011-08-22 12:58:50 UTC (rev 47817)
@@ -41,7 +41,7 @@
#%option
#% key: product
#% type: string
-#% label: Name of MODIS product
+#% label: Name of MODIS product(s)
#% multiple: yes
#% required: no
#% options: lst_terra_daily_1000, lst_aqua_daily_1000, lst_terra_eight_1000, lst_aqua_eight_1000, lst_terra_daily_6000, lst_aqua_daily_6000, ndvi_terra_sixteen_250, ndvi_aqua_sixteen_250, ndvi_terra_sixteen_500, ndvi_aqua_sixteen_500, snow_terra_daily_500, snow_aqua_daily_500, snow_terra_eight_500, snow_aqua_eight_500
@@ -50,21 +50,22 @@
#%option
#% key: tiles
#% type: string
-#% label: The names of tile/s to download
+#% label: The name(s) of tile(s) to download (comma separated)
+#% description: e.g.: h18v04
#% required: no
#%end
#%option
#% key: startday
#% type: string
#% label: The day to start download
-#% description: If not set the download starts from today and go back 10 days. If not endday the download stops 10 days after the endday
+#% description: Format: YYYY-MM-DD. If not set the download starts from today and go back 10 days. If not endday the download stops 10 days after the endday
#% required: no
#%end
#%option
#% key: endday
#% type: string
-#% label: The day from stop download
-#% description: To use only with startday
+#% label: The day to stop download
+#% description: Format: YYYY-MM-DD. To use only together with startday
#% required: no
#%end
#%option
@@ -154,7 +155,7 @@
user = raw_input(_('Insert username (usually anonymous): '))
passwd = raw_input(_('Insert password (your mail): '))
else:
- grass.fatal(_("Please set folder option if you want pass username " \
+ grass.fatal(_("Please set folder option to want pass username " \
+ "and password by stdin"))
return 0
# set username, password and folder by file
@@ -162,11 +163,14 @@
# open the file and read the the user and password:
# first line is username
# second line is password
- filesett = open(options['setting'],'r')
- fileread = filesett.readlines()
- user = fileread[0].strip()
- passwd = fileread[1].strip()
- filesett.close()
+ if check(options['setting']):
+ filesett = open(options['setting'],'r')
+ fileread = filesett.readlines()
+ user = fileread[0].strip()
+ passwd = fileread[1].strip()
+ filesett.close()
+ else:
+ grass.fatal(_("File <%s> not found") % options['setting'])
# set the folder by option folder
if options['folder'] != '':
if check(options['folder']):
