[GRASS-SVN] r47825 - grass/trunk/lib/gis
svn_grass at osgeo.org
Mon Aug 22 10:52:52 EDT 2011
Author: martinl
Date: 2011-08-22 07:52:52 -0700 (Mon, 22 Aug 2011)
New Revision: 47825
grass/trunk/lib/gis/rd_cellhd.c
gislib: rd_cellhd.c - add doxygen strings
Modified: grass/trunk/lib/gis/rd_cellhd.c
--- grass/trunk/lib/gis/rd_cellhd.c 2011-08-22 14:47:40 UTC (rev 47824)
+++ grass/trunk/lib/gis/rd_cellhd.c 2011-08-22 14:52:52 UTC (rev 47825)
@@ -1,7 +1,16 @@
-/* read cell header, or window.
- returns NULL if ok, error message otherwise
- note: the error message can be freed using G_free ().
+ \file lib/gis/rd_cellhd.c
+ \brief GIS Library - Read cell header or window
+ (C) 1999-2011 by the GRASS Development Team
+ This program is free software under the GNU General Public License
+ (>=v2). Read the file COPYING that comes with GRASS for details.
+ \author USACERL and others
#include <string.h>
#include <grass/gis.h>
@@ -36,6 +45,13 @@
#define SET(x) flags|=(1<<x)
#define TEST(x) (flags&(1<<x))
+ \bried Read cell header (for internal use only)
+ \param fp file descriptor
+ \param[out] cellhd pointer to Cell_head structure
+ \param is_cellhd ? (unused)
void G__read_Cell_head(FILE * fd, struct Cell_head *cellhd, int is_cellhd)
int count;
@@ -69,7 +85,13 @@
G_free(array);
-/* Read window from NULL terminated array of strings */
+ \brief Read window from NULL terminated array of strings (for internal use only)
+ \param array array of strings
void G__read_Cell_head_array(char **array,
@@ -114,7 +136,7 @@
switch (scan_item(buf, label, value)) {
case -1:
- G_fatal_error(_("Syntax error"));
+ G_fatal_error(_("Syntax error in cell header"));
case 0:
continue;
case 1:
@@ -122,29 +144,29 @@
if (strncmp(label, "proj", 4) == 0) {
if (TEST(F_PROJ))
- G_fatal_error(_("duplicate projection field"));
+ G_fatal_error(_("Duplicate projection field"));
if (!scan_int(value, &cellhd->proj))
SET(F_PROJ);
continue;
if (strncmp(label, "zone", 4) == 0) {
if (TEST(F_ZONE))
- G_fatal_error(_("duplicate zone field"));
+ G_fatal_error(_("Duplicate zone field"));
if (!scan_int(value, &cellhd->zone))
SET(F_ZONE);
continue;
if (!TEST(F_PROJ))
- G_fatal_error(_("projection field missing"));
+ G_fatal_error(_("Field <%s> missing"), "projection");
if (!TEST(F_ZONE))
- G_fatal_error(_("zone field missing"));
+ G_fatal_error(_("Field <%s> missing"), "zone");
/* read the other info */
i = 0;
@@ -152,7 +174,7 @@
G_debug(3, "region item: %s", buf);
case -1:
case 0:
continue;
case 1:
@@ -166,184 +188,184 @@
if (strncmp(label, "nort", 4) == 0) {
if (TEST(F_NORTH))
- G_fatal_error(_("duplicate north field"));
+ G_fatal_error(_("Duplicate north field"));
if (!G_scan_northing(value, &cellhd->north, cellhd->proj))
SET(F_NORTH);
continue;
if (strncmp(label, "sout", 4) == 0) {
if (TEST(F_SOUTH))
- G_fatal_error(_("duplicate south field"));
+ G_fatal_error(_("Duplicate south field"));
if (!G_scan_northing(value, &cellhd->south, cellhd->proj))
SET(F_SOUTH);
continue;
if (strncmp(label, "east", 4) == 0) {
if (TEST(F_EAST))
- G_fatal_error(_("duplicate east field"));
+ G_fatal_error(_("Duplicate east field"));
if (!G_scan_easting(value, &cellhd->east, cellhd->proj))
SET(F_EAST);
continue;
if (strncmp(label, "west", 4) == 0) {
if (TEST(F_WEST))
- G_fatal_error(_("duplicate west field"));
+ G_fatal_error(_("Duplicate west field"));
if (!G_scan_easting(value, &cellhd->west, cellhd->proj))
SET(F_WEST);
continue;
if (strncmp(label, "top", 3) == 0) {
if (TEST(F_TOP))
- G_fatal_error(_("duplicate top field"));
+ G_fatal_error(_("Duplicate top field"));
if (!scan_double(value, &cellhd->top))
SET(F_TOP);
continue;
if (strncmp(label, "bottom", 6) == 0) {
if (TEST(F_BOTTOM))
- G_fatal_error(_("duplicate bottom field"));
+ G_fatal_error(_("Duplicate bottom field"));
if (!scan_double(value, &cellhd->bottom))
SET(F_BOTTOM);
continue;
if (strncmp(label, "e-w ", 4) == 0 && strlen(label) == 9) {
if (TEST(F_EWRES))
- G_fatal_error(_("duplicate e-w resolution field"));
+ G_fatal_error(_("Duplicate e-w resolution field"));
if (!G_scan_resolution(value, &cellhd->ew_res, cellhd->proj))
if (cellhd->ew_res <= 0.0)
SET(F_EWRES);
continue;
if (strncmp(label, "e-w resol3", 10) == 0) {
if (TEST(F_EWRES3))
- G_fatal_error(_("duplicate 3D e-w resolution field"));
+ G_fatal_error(_("Duplicate 3D e-w resolution field"));
if (!G_scan_resolution(value, &cellhd->ew_res3, cellhd->proj))
if (cellhd->ew_res3 <= 0.0)
SET(F_EWRES3);
continue;
if (strncmp(label, "n-s ", 4) == 0 && strlen(label) == 9) {
if (TEST(F_NSRES))
- G_fatal_error(_("duplicate n-s resolution field"));
+ G_fatal_error(_("Duplicate n-s resolution field"));
if (!G_scan_resolution(value, &cellhd->ns_res, cellhd->proj))
if (cellhd->ns_res <= 0.0)
SET(F_NSRES);
continue;
if (strncmp(label, "n-s resol3", 10) == 0) {
if (TEST(F_NSRES3))
- G_fatal_error(_("duplicate 3D n-s resolution field"));
+ G_fatal_error(_("Duplicate 3D n-s resolution field"));
if (!G_scan_resolution(value, &cellhd->ns_res3, cellhd->proj))
if (cellhd->ns_res3 <= 0.0)
SET(F_NSRES3);
continue;
if (strncmp(label, "t-b ", 4) == 0) {
if (TEST(F_TBRES))
- G_fatal_error(_("duplicate t-b resolution field"));
+ G_fatal_error(_("Duplicate t-b resolution field"));
if (!scan_double(value, &cellhd->tb_res))
if (cellhd->tb_res <= 0.0)
SET(F_TBRES);
continue;
if (strncmp(label, "rows", 4) == 0 && strlen(label) == 4) {
if (TEST(F_ROWS))
- G_fatal_error(_("duplicate rows field"));
+ G_fatal_error(_("Duplicate rows field"));
if (!scan_int(value, &cellhd->rows))
if (cellhd->rows <= 0)
SET(F_ROWS);
continue;
if (strncmp(label, "rows3", 5) == 0) {
if (TEST(F_ROWS3))
- G_fatal_error(_("duplicate 3D rows field"));
+ G_fatal_error(_("Duplicate 3D rows field"));
if (!scan_int(value, &cellhd->rows3))
if (cellhd->rows3 <= 0)
SET(F_ROWS3);
continue;
if (strncmp(label, "cols", 4) == 0 && strlen(label) == 4) {
if (TEST(F_COLS))
- G_fatal_error(_("duplicate cols field"));
+ G_fatal_error(_("Duplicate cols field"));
if (!scan_int(value, &cellhd->cols))
if (cellhd->cols <= 0)
SET(F_COLS);
continue;
if (strncmp(label, "cols3", 5) == 0) {
if (TEST(F_COLS3))
- G_fatal_error(_("duplicate 3D cols field"));
+ G_fatal_error(_("Duplicate 3D cols field"));
if (!scan_int(value, &cellhd->cols3))
if (cellhd->cols3 <= 0)
SET(F_COLS3);
continue;
if (strncmp(label, "depths", 6) == 0) {
if (TEST(F_DEPTHS))
- G_fatal_error(_("duplicate depths field"));
+ G_fatal_error(_("Duplicate depths field"));
if (!scan_int(value, &cellhd->depths))
if (cellhd->depths <= 0)
SET(F_DEPTHS);
continue;
if (strncmp(label, "form", 4) == 0) {
if (TEST(F_FORMAT))
- G_fatal_error(_("duplicate format field"));
+ G_fatal_error(_("Duplicate format field"));
if (!scan_int(value, &cellhd->format))
SET(F_FORMAT);
continue;
if (strncmp(label, "comp", 4) == 0) {
if (TEST(F_COMP))
- G_fatal_error(_("duplicate compressed field"));
+ G_fatal_error(_("Duplicate compressed field"));
if (!scan_int(value, &cellhd->compressed))
SET(F_COMP);
continue;
/* check some of the fields */
if (!TEST(F_NORTH))
- G_fatal_error(_("north field missing"));
+ G_fatal_error(_("Field <%s> missing"), "north");
if (!TEST(F_SOUTH))
- G_fatal_error(_("south field missing"));
+ G_fatal_error(_("Field <%s> missing"), "south");
if (!TEST(F_WEST))
- G_fatal_error(_("west field missing"));
+ G_fatal_error(_("Field <%s> missing"), "west");
if (!TEST(F_EAST))
- G_fatal_error(_("east field missing"));
+ G_fatal_error(_("Field <%s> missing"), "east");
if (!TEST(F_EWRES) && !TEST(F_COLS))
- G_fatal_error(_("cols field missing"));
+ G_fatal_error(_("Field <%s> missing"), "cols");
if (!TEST(F_NSRES) && !TEST(F_ROWS))
- G_fatal_error(_("rows field missing"));
+ G_fatal_error(_("Field <%s> missing"), "rows");
/* This next stmt is commented out to allow wr_cellhd.c to write
* headers that will be readable by GRASS 3.1
if ((TEST(F_ROWS) && TEST(F_NSRES))
@@ -354,13 +376,13 @@
/* 3D defined? */
if (TEST(F_EWRES3) || TEST(F_NSRES3) || TEST(F_COLS3) || TEST(F_ROWS3)) {
if (!TEST(F_EWRES3))
- G_fatal_error(_("ewres3 field missing"));
+ G_fatal_error(_("Field <%s> missing"), "ewres3");
if (!TEST(F_NSRES3))
- G_fatal_error(_("nsres3 field missing"));
+ G_fatal_error(_("Field <%s> missing"), "nsres3");
if (!TEST(F_COLS3))
- G_fatal_error(_("cols3 field missing"));
+ G_fatal_error(_("Field <%s> missing"), "cols3");
if (!TEST(F_ROWS3))
- G_fatal_error(_("rows3 field missing"));
+ G_fatal_error(_("Field <%s> missing"), "rows3");
else { /* use 2D */
cellhd->ew_res3 = cellhd->ew_res;
