[GRASS-SVN] r47857 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Tue Aug 23 14:58:55 EDT 2011
Author: martinl
Date: 2011-08-23 11:58:55 -0700 (Tue, 23 Aug 2011)
New Revision: 47857
grass/trunk/lib/vector/Vlib/write_ogr.c
vlib: define field width for character type
simplify sqltype_to_ogrtype()
Modified: grass/trunk/lib/vector/Vlib/write_ogr.c
--- grass/trunk/lib/vector/Vlib/write_ogr.c 2011-08-23 18:44:44 UTC (rev 47856)
+++ grass/trunk/lib/vector/Vlib/write_ogr.c 2011-08-23 18:58:55 UTC (rev 47857)
@@ -363,7 +363,7 @@
dbDriver *create_table(OGRLayerH hLayer, const struct field_info *Fi)
int col, ncols;
- int sqltype, ogrtype;
+ int sqltype, ogrtype, length;
const char *colname;
@@ -416,7 +416,8 @@
colname = db_get_column_name(column);
sqltype = db_get_column_sqltype(column);
ogrtype = sqltype_to_ogrtype(sqltype);
+ length = db_get_column_length(column);
if (strcmp(OGR_L_GetFIDColumn(hLayer), colname) == 0 ||
OGR_FD_GetFieldIndex(hFeatureDefn, colname) > -1) {
/* field already exists */
@@ -424,7 +425,9 @@
hFieldDefn = OGR_Fld_Create(colname, ogrtype);
- /* OGR_Fld_SetWidth(hFieldDefn, length); */
+ /* GDAL 1.9.0 (r22968) uses VARCHAR instead of CHAR */
+ if (ogrtype == OFTString && length > 0)
+ OGR_Fld_SetWidth(hFieldDefn, length);
if (OGR_L_CreateField(hLayer, hFieldDefn, TRUE) != OGRERR_NONE) {
G_warning(_("Creating field <%s> failed"), colname);
db_close_database_shutdown_driver(driver);
@@ -442,7 +445,7 @@
int j, ogrfieldnum;
char buf[2000];
- int ncol, colsqltype, colctype, more;
+ int ncol, sqltype, ctype, ogrtype, more;
const char *fidcol, *colname;
dbTable *table;
dbString dbstring;
@@ -502,15 +505,15 @@
G_debug(2, "col %d : val = %s", j,
db_get_string(&dbstring));
- colsqltype = db_get_column_sqltype(column);
- colctype = db_sqltype_to_Ctype(colsqltype);
- G_debug(2, " colctype = %d", colctype);
+ sqltype = db_get_column_sqltype(column);
+ ctype = db_sqltype_to_Ctype(sqltype);
+ ogrtype = sqltype_to_ogrtype(sqltype);
+ G_debug(2, " colctype = %d", ctype);
ogrfieldnum = OGR_F_GetFieldIndex(Ogr_feature, colname);
if (ogrfieldnum < 0) {
/* create field if not exists */
- hFieldDefn = OGR_Fld_Create(colname,
- sqltype_to_ogrtype(colsqltype));
+ hFieldDefn = OGR_Fld_Create(colname, ogrtype);
if (OGR_L_CreateField(Ogr_layer, hFieldDefn, TRUE) != OGRERR_NONE)
G_warning(_("Unable to create field <%s>"), colname);
@@ -521,7 +524,7 @@
/* prevent writing NULL values */
if (!db_test_value_isnull(value)) {
- switch (colctype) {
+ switch (ctype) {
case DB_C_TYPE_INT:
OGR_F_SetFieldInteger(Ogr_feature, ogrfieldnum,
db_get_value_int(value));
@@ -553,30 +556,29 @@
int sqltype_to_ogrtype(int sqltype)
- switch(sqltype) {
- case DB_SQL_TYPE_CHARACTER:
- case DB_SQL_TYPE_TEXT:
- return OFTString;
- case DB_SQL_TYPE_SMALLINT:
- case DB_SQL_TYPE_INTEGER:
- case DB_SQL_TYPE_SERIAL:
- return OFTInteger;
- case DB_SQL_TYPE_REAL:
- case DB_SQL_TYPE_DOUBLE_PRECISION:
- case DB_SQL_TYPE_DECIMAL:
- case DB_SQL_TYPE_NUMERIC:
- return OFTReal;
- case DB_SQL_TYPE_DATE:
- return OFTDate;
- case DB_SQL_TYPE_TIME:
- return OFTTime;
- case DB_SQL_TYPE_TIMESTAMP:
- return OFTDateTime;
- case DB_SQL_TYPE_INTERVAL:
- return OFTString; /* ??? */
+ int ctype, ogrtype;
+ switch(ctype) {
+ case DB_C_TYPE_INT:
+ ogrtype = OFTInteger;
+ break;
+ case DB_C_TYPE_DOUBLE:
+ ogrtype = OFTReal;
+ break;
+ case DB_C_TYPE_STRING:
+ ogrtype = OFTString;
+ break;
+ case DB_C_TYPE_DATETIME:
+ break;
+ default:
+ break;
- return OFTString;
+ return ogrtype;
#endif /* HAVE_OGR */
