[GRASS-SVN] r47899 - in grass/trunk/gui: icons/grass wxpython/gui_modules wxpython/icons
Sat Aug 27 08:20:01 EDT 2011
Author: annakrat
Date: 2011-08-27 05:20:01 -0700 (Sat, 27 Aug 2011)
New Revision: 47899
Added:
   grass/trunk/gui/icons/grass/3d-rotate.png
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
   grass/trunk/gui/wxpython/gui_modules/toolbars.py
   grass/trunk/gui/wxpython/icons/icon.py
wxNviz: add rotate icon, fix small bug in lighting
Added: grass/trunk/gui/icons/grass/3d-rotate.png
(Binary files differ)
Property changes on: grass/trunk/gui/icons/grass/3d-rotate.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-08-27 11:27:30 UTC (rev 47898)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2011-08-27 12:20:01 UTC (rev 47899)
@@ -458,7 +458,7 @@
             self._mgr.AddPane(self.toolbars['map'],
                               wx.aui.AuiPaneInfo().
                               Name("maptoolbar").Caption(_("Map Toolbar")).
-                              ToolbarPane().Top().
+                              ToolbarPane().Top().Name('mapToolbar').
                               LeftDockable(False).RightDockable(False).
                               BottomDockable(False).TopDockable(True).
                               CloseButton(False).Layer(2).
@@ -666,7 +666,18 @@
         # change the cursor
         self.MapWindow.SetCursor(self.cursors["hand"])
+    def OnRotate(self, event):
+        """!Rotate 3D view
+        if self.toolbars['map']:
+            self.toolbars['map'].OnTool(event)
+            self.toolbars['map'].action['desc'] = ''
+        self.MapWindow.mouse['use'] = "rotate"
+        # change the cursor
+        self.MapWindow.SetCursor(self.cursors["hand"])
     def OnErase(self, event):
         """!Erase the canvas
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-08-27 11:27:30 UTC (rev 47898)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-08-27 12:20:01 UTC (rev 47899)
@@ -417,9 +417,6 @@
             size = self.GetClientSize()
             self.SetDrawScalebar((pos[0], size[1] - pos[1]))
-        if self.mouse['use'] == 'pan':
-            pass
         if self.mouse['use'] == 'pointer':
             # get decoration or text id
             self.dragid = None
@@ -443,7 +440,7 @@
             self.DragItem(self.dragid, event)
+        if self.mouse['use'] == 'rotate':
             dx, dy = event.GetX() - self.mouse['tmp'][0], event.GetY() - self.mouse['tmp'][1]
             self.mouse['tmp'] = event.GetPositionTuple()
             angle, x, y, z = self._display.GetRotationParameters(dx, dy)
@@ -501,11 +498,13 @@
                 self.dragid = None
                 self.Refresh(False)
-        elif self.mouse['use'] == 'pan':
+        elif self.mouse['use'] == 'rotate':
             self._display.UnsetRotation()
             self.render['quick'] = False
             self.Refresh(False)
+        event.Skip()
     def OnDClick(self, event):
         """!On mouse double click"""
         if self.mouse['use'] != 'pointer': return
@@ -624,7 +623,7 @@
                                bright = data['bright'] / 100.,
                                ambient = data['ambient'] / 100.)
         self._display.DrawLightingModel()
-        if hasattr(event, 'refresh'):
+        if event.refresh:
             self.Refresh(False)
     def UpdateMap(self, render = True):
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py	2011-08-27 11:27:30 UTC (rev 47898)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py	2011-08-27 12:20:01 UTC (rev 47899)
@@ -2385,7 +2385,7 @@
     def OnLightChange(self, event):
-        """!Position of the light changed"""
+        """!Position of the light changing"""
         winName = self.__GetWindowName(self.win['light'], event.GetId())
         if not winName:
             return
@@ -2396,24 +2396,24 @@
         for win in self.win['light'][winName].itervalues():
             self.FindWindowById(win).SetValue(value)
-        self.PostLightEvent(refresh = False)
+        self.PostLightEvent()
         event.Skip()
     def OnLightChanged(self, event):
-        """!Light"""
-        self.mapWindow.Refresh(False)
+        """!Light changed"""
+        self.PostLightEvent(refresh = True)
     def OnLightColor(self, event):
         """!Color of the light changed"""
         self.mapWindow.light['color'] = tuple(event.GetValue())
-        self.PostLightEvent()
         event.Skip()
     def OnLightValue(self, event):
-        """!Light brightness changed"""
+        """!Light brightness/ambient changing"""
         data = self.mapWindow.light
         self.OnScroll(event, self.win['light'], data)
@@ -4730,7 +4730,7 @@
     def UpdatePos(self, xcoord, ycoord):
         x, y = PositionWindow.UpdatePos(self, xcoord, ycoord)
-        event = wxUpdateLight()
+        event = wxUpdateLight(refresh = False)
         wx.PostEvent(self.mapWindow, event)
         return x, y
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py	2011-08-27 11:27:30 UTC (rev 47898)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py	2011-08-27 12:20:01 UTC (rev 47899)
@@ -75,9 +75,10 @@
         return None
     def CreateTool(self, label, bitmap, kind,
-                   shortHelp, longHelp, handler):
+                   shortHelp, longHelp, handler, pos = -1):
         """!Add tool to the toolbar
+        @param pos if -1 add tool, if > 0 insert at given pos
         @return id of tool
         bmpDisabled = wx.NullBitmap
@@ -86,9 +87,14 @@
             tool = vars(self)[label] = wx.NewId()
             Debug.msg(3, "CreateTool(): tool=%d, label=%s bitmap=%s" % \
                           (tool, label, bitmap))
-            toolWin = self.AddLabelTool(tool, label, bitmap,
-                                        bmpDisabled, kind,
-                                        shortHelp, longHelp)
+            if pos < 0:
+                toolWin = self.AddLabelTool(tool, label, bitmap,
+                                            bmpDisabled, kind,
+                                            shortHelp, longHelp)
+            else:
+                toolWin = self.InsertLabelTool(pos, tool, label, bitmap,
             self.Bind(wx.EVT_TOOL, handler, toolWin)
         else: # separator
             self.AddSeparator()
@@ -175,16 +181,15 @@
         retData = list()
         for args in data:
             retData.append(self._defineTool(*args))
         return retData
-    def _defineTool(self, name = None, icon = None, handler = None, item = wx.ITEM_NORMAL):
+    def _defineTool(self, name = None, icon = None, handler = None, item = wx.ITEM_NORMAL, pos = -1):
         """!Define tool
         if name:
             return (name, icon.GetBitmap(),
                     item, icon.GetLabel(), icon.GetDesc(),
-                    handler)
+                    handler, pos)
         return ("", "", "", "", "", "") # separator
 class MapToolbar(AbstractToolbar):
@@ -307,7 +312,27 @@
                                       self.parent.PrintMenu),
                                      (None, ))
+    def InsertTool(self, data):
+        """!Insert tool to toolbar
+        @param data toolbar data"""
+        data = self._getToolbarData(data)
+        for tool in data:
+            self.CreateTool(*tool)
+        self.Realize()
+        self.parent._mgr.GetPane('mapToolbar').BestSize(self.GetBestSize())
+        self.parent._mgr.Update()
+    def RemoveTool(self, tool):
+        """!Remove tool from toolbar
+        @param tool tool id"""
+        self.DeleteTool(tool)
     def OnSelectTool(self, event):
         """!Select / enable tool available in tools list
@@ -319,6 +344,10 @@
         elif tool == self.toolId['3d'] and \
                 not (self.parent.MapWindow3D and self.parent.IsPaneShown('3d')):
+            self.InsertTool((('rotate', Icons['nviz']['rotate'],
+                              self.parent.OnRotate,
+                              wx.ITEM_CHECK,7),)) # 7 is position
             self.ExitToolbars()
             self.parent.AddNviz()
@@ -332,11 +361,13 @@
         if self.parent.toolbars['vdigit']:
             self.parent.toolbars['vdigit'].OnExit()
         if self.parent.GetLayerManager().IsPaneShown('toolbarNviz'):
+            self.RemoveTool(self.rotate)
             self.parent.RemoveNviz()
     def Enable2D(self, enabled):
         """!Enable/Disable 2D display mode specific tools"""
-        for tool in (self.zoomin,
+        for tool in (self.pan,
+                     self.zoomin,
                      self.zoomout,
                      self.zoomback,
                      self.zoommenu,
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py	2011-08-27 11:27:30 UTC (rev 47898)
+++ grass/trunk/gui/wxpython/icons/icon.py	2011-08-27 12:20:01 UTC (rev 47899)
@@ -333,6 +333,9 @@
                                desc = _('Settings dialog for georectification tool')),
     'nviz' : {
+        'rotate': MetaIcon(img = iconSet.get('3d-rotate', wx.ART_ERROR),
+                             label = _('Rotate 3D scene'),
+                             desc = _('Drag with mouse to rotate 3D scene')),
         'nviz_cmd': MetaIcon(img = iconSet.get('script-save', wx.ART_ERROR),
                              label = _('Generate command for nviz_cmd'),
                              desc = _('Generate command for nviz_cmd based on current state')),
