[GRASS-SVN] r47923 - grass/branches/develbranch_6/lib/db/dbmi_client
Sun Aug 28 15:19:17 EDT 2011
Author: mmetz
Date: 2011-08-28 12:19:16 -0700 (Sun, 28 Aug 2011)
New Revision: 47923
   grass/branches/develbranch_6/lib/db/dbmi_client/delete_tab.c
db_delete_table(): remove code duplication with db_start_driver_open_database() and db_close_database_shutdown_driver()
Modified: grass/branches/develbranch_6/lib/db/dbmi_client/delete_tab.c
--- grass/branches/develbranch_6/lib/db/dbmi_client/delete_tab.c	2011-08-28 19:08:15 UTC (rev 47922)
+++ grass/branches/develbranch_6/lib/db/dbmi_client/delete_tab.c	2011-08-28 19:19:16 UTC (rev 47923)
@@ -29,31 +29,22 @@
 int db_delete_table(const char *drvname, const char *dbname, const char *tblname)
     dbDriver *driver;
-    dbHandle handle;
     dbString sql;
     G_debug(3, "db_delete_table(): driver = %s, db = %s, table = %s\n",
 	    drvname, dbname, tblname);
-    db_init_handle(&handle);
-    db_init_string(&sql);
     /* Open driver and database */
-    driver = db_start_driver(drvname);
+    driver = db_start_driver_open_database(drvname, dbname);
     if (driver == NULL) {
-	G_warning(_("Unable to open driver <%s>"), drvname);
+	G_warning(_("Unable open database <%s> by driver <%s>"), dbname,
+		  drvname);
 	return DB_FAILED;
-    db_set_handle(&handle, dbname, NULL);
-    if (db_open_database(driver, &handle) != DB_OK) {
-	G_warning(_("Unable to open database <%s> by driver <%s>"),
-		  dbname, drvname);
-	db_shutdown_driver(driver);
-	return DB_FAILED;
     /* Delete table */
     /* TODO test if the tables exist */
+    db_init_string(&sql);
     db_set_string(&sql, "drop table ");
     db_append_string(&sql, tblname);
     G_debug(3, db_get_string(&sql));
@@ -61,13 +52,11 @@
     if (db_execute_immediate(driver, &sql) != DB_OK) {
 	G_warning(_("Unable to drop table: '%s'"),
-	db_close_database(driver);
+	db_close_database_shutdown_driver(driver);
 	return DB_FAILED;
     return DB_OK;
