[GRASS-SVN] r47926 - grass-addons/grass7/gui/wxpython/wx.wms
Sun Aug 28 16:51:26 EDT 2011
Author: sudeepsingh
Date: 2011-08-28 13:51:26 -0700 (Sun, 28 Aug 2011)
New Revision: 47926
   grass-addons/grass7/gui/wxpython/wx.wms/parse.py
   grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
Layers Displayed Hierarchialy now, unstable version, to be modified
Modified: grass-addons/grass7/gui/wxpython/wx.wms/parse.py
--- grass-addons/grass7/gui/wxpython/wx.wms/parse.py	2011-08-28 19:53:58 UTC (rev 47925)
+++ grass-addons/grass7/gui/wxpython/wx.wms/parse.py	2011-08-28 20:51:26 UTC (rev 47926)
@@ -24,9 +24,18 @@
 from grass.script import core as grass
 from BeautifulSoup import BeautifulSoup, BeautifulStoneSoup
 import re
+from xml.dom.minidom import parse, parseString
 from urllib2 import Request, urlopen, URLError, HTTPError
+key = 0
+class newLayerData():
+	name = None
+	title = None
+	abstract = None
+	srsList = None
 class LayerData():
 	name = None
 	title = None
@@ -137,8 +146,39 @@
 	xml = f.read()
 	soup = BeautifulSoup(xml)
 	dfs(soup,LayerTree, layerTreeRoot)
+def test(xml,LayerTree,layerTreeRoot):
+	f = open('/home/sudeep/in3.xml','w')
+	f.write(xml)
+	f.close()
+	f = open('/home/sudeep/in3.xml','r')
+	xml1=f.read()
+	#xml1=xml
+	#xml='<root> '+xml1+' </root>'
+	a=xml1.find('<WMT_MS_Capabilities')
+	print 'a1='+str(a)
+	if(a==-1):
+		print 'a2='+str(a)
+		a=xml1.find('<wmt_ms_capabilities')
+	if(a==-1):
+		print 'a3='+str(a)
+		print 'serious mix up'
+		return
+	print 'a4='+str(a)
+	#print xml1[a:]
+	dom=parseString(xml1)
+	root=dom.firstChild
+	lData = {}
+	global key
+	key = 0
+	dfs1(dom,LayerTree,layerTreeRoot,lData)
+	return lData
 def dfs(root,LayerTree, ltr):
 	if not hasattr(root, 'contents'):
 		print root.string
 		return
@@ -155,6 +195,66 @@
 			dfs(child, LayerTree, id)
     		return
+def getAttributeLayers(node, attribute):
+	Attribute = attribute.capitalize()
+	l=node.getElementsByTagName(attribute)
+	g=None
+	if(len(l)>0):
+		g=l[0].firstChild
+	else:
+		l=node.getElementsByTagName(Attribute)
+		if(len(l)>0):
+			g=l[0].firstChild
+	if(g is not None):
+		return unicode(g.nodeValue)
+	else:
+		return None
+def dfs1(node,LayerTree, ltr,lData):
+	global key
+	if ( hasattr(node,'data')):
+		return
+	id = ltr
+	if(hasattr(node,'tagName')):
+		if(node.tagName == 'Layer' or node.tagName == 'layer'):
+		   	name = getAttributeLayers(node, 'name')
+		   	if(name is not None):
+		 		lData[str(key)] = newLayerData()
+		   		title = getAttributeLayers(node, 'title')
+		   		abstract = getAttributeLayers(node, 'abstract')
+		   		if(title is None):
+		   			title = unicode('')
+		   		else:
+		   			title = ':'+title
+		   		if(abstract is None):
+		   			abstract = unicode('')
+		   		else:
+		   			abstract = ':'+abstract
+		   		description = unicode(str(key)+'-'+name+title+abstract)
+		   		id = LayerTree.AppendItem(ltr,description)
+		   		SRS = node.getElementsByTagName('SRS')
+		   		srsList = []
+		   		for srs in SRS:
+		   			#print srs.toxml()
+		   			#print srs.firstChild.nodeValue
+		   			srsList += [str(srs.firstChild.nodeValue)[5:]]
+		   		print srsList
+		   		lData[str(key)].name = name
+		   		lData[str(key)].abstract = abstract
+		   		lData[str(key)].title = title
+		   		lData[str(key)].srsList = srsList
+		   		key = key + 1
+	for child in node.childNodes:
+		dfs1(child,LayerTree,id,lData)
+	return
 def parseGrass_Region(grassRegion, dir):
 	grassRegion = 'n-s resol: 26.266417; n-s resol3: 100; rows: 533; north: 4928000.0; t-b resol: 1; zone: 13; bottom: 0; rows3: 140; west: 590000.0; top: 1; cols: 698; cols3: 190; depths: 1; e-w resol: 27.220630; proj: 1; e-w resol3: 100; east: 609000.0; south: 4914000.0;'
 	width = '698'
Modified: grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
--- grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py	2011-08-28 19:53:58 UTC (rev 47925)
+++ grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py	2011-08-28 20:51:26 UTC (rev 47926)
@@ -35,6 +35,14 @@
 from LoadConfig import loadConfigFile
+    name = None
+    title = None
+    abstract = None
+    srsList = None
 class LayerData():
     name = None
     title = None
@@ -77,6 +85,33 @@
 class Message():
     pass
+class ManageLayerTree():
+    def getAllChild(self,LayerTree, parentId):
+        children = []
+        currentchild,obj = LayerTree.GetFirstChild(parentId)
+        while(1):
+                if(not currentchild.IsOk()):
+                    break
+                children += [currentchild]
+                nextchild = LayerTree.GetNextSibling(currentchild)
+                currentchild = nextchild
+        return children
+    def layerTreeItemDFS(self,parent,LayerTree,nodeId):
+        if(not nodeId.IsOk()):
+            return
+        currentLayerDetails = LayerTree.GetItemText(nodeId)
+        currentLayerName = (currentLayerDetails.split(':')[0]).split('-')[1]
+        currentLayerKey = (currentLayerDetails.split(':')[0]).split('-')[0]
+        parent.epsgList.Append('<'+currentLayerName+'>')
+        listEPSG = parent.layerDataDict1[currentLayerKey].srsList
+        parent.epsgList.AppendItems(listEPSG)
+        parent.layersString += ',' + currentLayerName
+        allChild = self.getAllChild(LayerTree, nodeId)
+        for child in allChild:
+            self.layerTreeItemDFS(parent,LayerTree,child)
 class wmsFrame(wx.Frame):
     def __init__(self, *args, **kwds):
         # begin wxGlade: wmsFrame.__init__
@@ -131,6 +166,7 @@
         self.Bind(wx.EVT_CLOSE, self.OnQuit)
         self.AddServerisClosed = True
         self.layerName = ""
+        self.layerDataDict1 = {}
         self.selectedEPSG = None
     def __set_properties(self):
@@ -215,9 +251,11 @@
                 return
             layerDataDict = parsexml2(xml)
             ld = LayerData()
-            ld.appendLayerTree(layerDataDict, self.LayerTree, self.layerTreeRoot)
+            #ld.appendLayerTree(layerDataDict, self.LayerTree, self.layerTreeRoot)
             self.keyToEPSGCodes = ld.setKeyToEPSGCodes(layerDataDict)
+            self.layerDataDict1 = test(xml,self.LayerTree,self.layerTreeRoot)
+            print self.layerDataDict1
             self.LayerTree.Expand(self.layerTreeRoot)
         except HTTPError, e:
             message = 'The server couldn\'t fulfill the request.'
@@ -272,12 +310,12 @@
             return
         bbox = self.getBBOXParameters()
-        bbox = '584344,397868,585500,398500'
+        #bbox = '584344,397868,585500,398500'
         self.url_in = self.selectedURL
         getMap_request_url = self.url_in
         getMap_request_url += '?service=WMS&request=GetMap&version=1.1.1&format=image/png&width=800&height=600&srs=EPSG:'+self.selectedEPSG+'&layers='
         getMap_request_url += self.layerName+'&bbox='+bbox
+        print getMap_request_url
         req = Request(getMap_request_url)
         try:
             message = 'GetMaps request sent. Waiting for response...'
@@ -374,6 +412,9 @@
     def OnServerListEnter(self, event): # wxGlade: wmsFrame.<event_handler>
         event.Skip()
     def OnLayerTreeSelChanged(self, event): # wxGlade: wmsFrame.<event_handler>"
         self.epsgList.Clear()
@@ -381,7 +422,23 @@
         self.selectedLayerList = []
         keys =[]
         self.layerName = ""
+        print len(self.LayerTree.GetSelections())
+        res = ''
+        self.layersString=''
+        manageLT = ManageLayerTree()
         for sellayer in self.LayerTree.GetSelections():
+            #res = res + ','+self.LayerTree.GetItemText(sellayer)
+            manageLT.layerTreeItemDFS(self,self.LayerTree, sellayer)
+            #print child
+        print self.layersString[1:]
+        self.layerName = self.layersString[1:]
+        self.selectedEPSG = None
+        for sellayer in self.LayerTree.GetSelections():
             layerNameString = self.LayerTree.GetItemText(sellayer)
             layerNameStringList = layerNameString.split(':')
             if(len(layerNameStringList)==0):
@@ -403,7 +460,7 @@
         self.layerName = self.layerName[1:]
         event.Skip()
     def OnAddServer(self, event): # wxGlade: wmsFrame.<event_handler>
@@ -483,6 +540,7 @@
 # end of class wmsFrame
 def DisplayWMSMenu():
+        #print os.environ
         app = wx.PySimpleApp(0)
         wx.InitAllImageHandlers()
         wms_Frame = wmsFrame(None, -1, "")
