[GRASS-SVN] r47951 - grass/trunk/mswindows
Mon Aug 29 14:34:23 EDT 2011
Author: mmetz
Date: 2011-08-29 11:34:23 -0700 (Mon, 29 Aug 2011)
New Revision: 47951
   grass/trunk/mswindows/GRASS-Installer.nsi
NSIS script: remove fix for grass_config_dir
Modified: grass/trunk/mswindows/GRASS-Installer.nsi
--- grass/trunk/mswindows/GRASS-Installer.nsi	2011-08-29 18:33:26 UTC (rev 47950)
+++ grass/trunk/mswindows/GRASS-Installer.nsi	2011-08-29 18:34:23 UTC (rev 47951)
@@ -880,17 +880,17 @@
 	;replace \ with / in $GIS_DATABASE
 	${StrReplace} "$UNIX_LIKE_GIS_DATABASE_PATH" "\" "/" "$GIS_DATABASE"
-	;create $APPDATA\GRASS7\rc
+	;create $APPDATA\grass7\rc
 	SetShellVarContext current
 	ClearErrors
-	CreateDirectory	$APPDATA\GRASS7
-	FileOpen $0 $APPDATA\GRASS7\rc w
-	IfErrors done_create_GRASS7\rc
+	CreateDirectory	$APPDATA\grass7
+	FileOpen $0 $APPDATA\grass7\rc w
+	IfErrors done_create_grass7\rc
 	FileWrite $0 'GISDBASE: $UNIX_LIKE_GIS_DATABASE_PATH$\r$\n'
 	FileWrite $0 'LOCATION_NAME: demolocation$\r$\n'
 	FileWrite $0 'MAPSET: PERMANENT$\r$\n'
 	FileClose $0
-	done_create_GRASS7\rc:
+	done_create_grass7\rc:
 	;replace gisbase = "/c/OSGeo4W/apps/grass/grass-7.0.svn" in grass70.py with $INSTDIR
 	Push "$INSTDIR\grass70.py" ; file to modify
@@ -903,12 +903,6 @@
 	Push 'config_projshare = "/c/OSGeo4W/share/proj"' ; string that a line must begin with *WS Sensitive*
 	Push 'config_projshare = "$INSTDIR\proj"' ; string to replace whole line with
 	Call ReplaceLineStr
-	;replace grass_config_dirname = ".grass7" i n grass70.py with GRASS7
-	Push "$INSTDIR\grass70.py" ; file to modify
-	Push 'grass_config_dirname = ".grass7"' ; string that a line must begin with *WS Sensitive*
-	Push 'grass_config_dirname = "GRASS7"' ; string to replace whole line with
-	Call ReplaceLineStr
 SectionEnd
