[GRASS-SVN] r47991 - grass/trunk/gui/wxpython/gui_modules
Wed Aug 31 03:10:09 EDT 2011
Author: cmbarton
Date: 2011-08-31 00:10:09 -0700 (Wed, 31 Aug 2011)
New Revision: 47991
   grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
Added some error traps for KeyErrors when unloading or loading maps in wxnviz
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-08-30 21:03:51 UTC (rev 47990)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_mapdisp.py	2011-08-31 07:10:09 UTC (rev 47991)
@@ -1215,7 +1215,10 @@
             errorMsg = _("Unable to unload 3d raster map")
             successMsg = _("3d raster map")
-        id = data[nvizType]['object']['id']
+        if 'object' not in data[nvizType]:
+            return
+        else:
+            id = data[nvizType]['object']['id']
         if unloadFn(id) ==  0:
             self.log.WriteError("%s <%s>" % (errorMsg, layer.name))
@@ -1323,7 +1326,7 @@
         for vecType in vecTypes:
             if 'object' not in data[vecType]:
                 continue
             id = data[vecType]['object']['id']
             if vecType ==  'lines':
@@ -1339,7 +1342,7 @@
             data[vecType].pop('object')
-        if remove:
+        if remove and item in self.layers:
             self.layers.remove(item)
     def OnZoomToMap(self, event):
@@ -1775,6 +1778,13 @@
             data = self.tree.GetPyData(item)[0]['nviz']
+            for datatype in ['surface', 'volume']:
+                if 'object' not in data[datatype]:
+                    return -1
+            for datatype in ['points', 'lines']:
+                if 'object' not in data['vector'][datatype]:
+                    return -1
             if type ==  'raster':
                 return data['surface']['object']['id']
             elif type ==  'vector':
