[GRASS-SVN] r48005 - grass/trunk/raster/r.external
Wed Aug 31 14:09:56 EDT 2011
Author: martinl
Date: 2011-08-31 11:09:56 -0700 (Wed, 31 Aug 2011)
New Revision: 48005
Added:
   grass/trunk/raster/r.external/link.c
   grass/trunk/raster/r.external/list.c
   grass/trunk/raster/r.external/proj.c
   grass/trunk/raster/r.external/proto.h
   grass/trunk/raster/r.external/window.c
   grass/trunk/raster/r.external/main.c
r.external: split into more c-files
Added: grass/trunk/raster/r.external/link.c
--- grass/trunk/raster/r.external/link.c	                        (rev 0)
+++ grass/trunk/raster/r.external/link.c	2011-08-31 18:09:56 UTC (rev 48005)
@@ -0,0 +1,237 @@
+#include <grass/gis.h>
+#include <grass/glocale.h>
+#include <gdal.h>
+#include "proto.h"
+void query_band(GDALRasterBandH hBand, const char *output, int exact_range,
+		struct Cell_head *cellhd, struct band_info *info)
+    int bGotMin, bGotMax;
+    info->gdal_type = GDALGetRasterDataType(hBand);
+    info->null_val = GDALGetRasterNoDataValue(hBand, &info->has_null);
+    cellhd->compressed = 0;
+    switch (info->gdal_type) {
+    case GDT_Float32:
+	info->data_type = FCELL_TYPE;
+	cellhd->format = -1;
+	break;
+    case GDT_Float64:
+	info->data_type = DCELL_TYPE;
+	break;
+    case GDT_Byte:
+	info->data_type = CELL_TYPE;
+	cellhd->format = 0;
+	break;
+    case GDT_Int16:
+    case GDT_UInt16:
+	cellhd->format = 1;
+	break;
+    case GDT_Int32:
+    case GDT_UInt32:
+	cellhd->format = 3;
+	break;
+    default:
+	G_fatal_error(_("Complex types not supported"));
+	break;
+    info->range[0] = GDALGetRasterMinimum(hBand, &bGotMin);
+    info->range[1] = GDALGetRasterMaximum(hBand, &bGotMax);
+    if(!(bGotMin && bGotMax))
+	GDALComputeRasterMinMax(hBand, !exact_range, info->range);
+    Rast_init_colors(&info->colors);
+    if (GDALGetRasterColorTable(hBand) != NULL) {
+	GDALColorTableH hCT;
+	int count, i;
+	G_verbose_message(_("Copying color table for %s"), output);
+	hCT = GDALGetRasterColorTable(hBand);
+	count = GDALGetColorEntryCount(hCT);
+	for (i = 0; i < count; i++) {
+	    GDALColorEntry sEntry;
+	    GDALGetColorEntryAsRGB(hCT, i, &sEntry);
+	    if (sEntry.c4 == 0)
+		continue;
+	    Rast_set_c_color(i, sEntry.c1, sEntry.c2, sEntry.c3, &info->colors);
+    else {
+	if (info->gdal_type == GDT_Byte) {
+	    /* set full 0..255 range to grey scale: */
+	    G_verbose_message(_("Setting grey color table for <%s> (full 8bit range)"),
+			      output);
+	    Rast_make_grey_scale_colors(&info->colors, 0, 255);
+	else  {
+	    /* set data range to grey scale: */
+	    G_verbose_message(_("Setting grey color table for <%s> (data range)"),
+			      output);
+				     (int) info->range[0], (int) info->range[1]);
+void make_cell(const char *output, const struct band_info *info)
+    FILE *fp;
+    fp = G_fopen_new("cell", output);
+    if (!fp)
+	G_fatal_error(_("Unable to create cell/%s file"), output);
+    fclose(fp);
+    if (info->data_type == CELL_TYPE)
+	return;
+    fp = G_fopen_new("fcell", output);
+    if (!fp)
+	G_fatal_error(_("Unable to create fcell/%s file"), output);
+    fclose(fp);
+void make_link(const char *input, const char *output, int band,
+	       const struct band_info *info, int flip)
+    struct Key_Value *key_val = G_create_key_value();
+    char null_str[256], type_str[8], band_str[8];
+    FILE *fp;
+    sprintf(band_str, "%d", band);
+    if (info->has_null) {
+	    sprintf(null_str, "%d", (int) info->null_val);
+	else
+	    sprintf(null_str, "%.22g", info->null_val);
+    else
+	strcpy(null_str, "none");
+    sprintf(type_str, "%d", info->gdal_type);
+    G_set_key_value("file", input, key_val);
+    G_set_key_value("band", band_str, key_val);
+    G_set_key_value("null", null_str, key_val);
+    G_set_key_value("type", type_str, key_val);
+    if (flip & FLIP_H)
+	G_set_key_value("hflip", "yes", key_val);
+    if (flip & FLIP_V)
+	G_set_key_value("vflip", "yes", key_val);
+    fp = G_fopen_new_misc("cell_misc", "gdal", output);
+    if (!fp)
+	G_fatal_error(_("Unable to create cell_misc/%s/gdal file"), output);
+    if (G_fwrite_key_value(fp, key_val) < 0)
+	G_fatal_error(_("Error writing cell_misc/%s/gdal file"), output);
+    fclose(fp);
+void write_fp_format(const char *output, const struct band_info *info)
+    struct Key_Value *key_val;
+    const char *type;
+    FILE *fp;
+	return;
+    key_val = G_create_key_value();
+    type = (info->data_type == FCELL_TYPE)
+	? "float"
+	: "double";
+    G_set_key_value("type", type, key_val);
+    G_set_key_value("byte_order", "xdr", key_val);
+    fp = G_fopen_new_misc("cell_misc", "f_format", output);
+    if (!fp)
+	G_fatal_error(_("Unable to create cell_misc/%s/f_format file"), output);
+	G_fatal_error(_("Error writing cell_misc/%s/f_format file"), output);
+    fclose(fp);
+    G_free_key_value(key_val);
+void write_fp_quant(const char *output)
+    struct Quant quant;
+    Rast_quant_init(&quant);
+    Rast_quant_round(&quant);
+    Rast_write_quant(output, G_mapset(), &quant);
+void create_map(const char *input, int band, const char *output,
+		struct Cell_head *cellhd, struct band_info *info,
+		const char *title, int flip)
+    struct History history;
+    struct Categories cats;
+    Rast_put_cellhd(output, cellhd);
+    make_cell(output, info);
+    make_link(input, output, band, info, flip);
+    if (info->data_type == CELL_TYPE) {
+	struct Range range;
+	range.min = (CELL)info->range[0];
+	range.max = (CELL)info->range[1];
+	range.first_time = 0;
+	Rast_write_range(output, &range);
+    else {
+	struct FPRange fprange;
+	fprange.min = info->range[0];
+	fprange.max = info->range[1];
+	fprange.first_time = 0;
+	Rast_write_fp_range(output, &fprange);
+	write_fp_format(output, info);
+	write_fp_quant(output);
+    G_verbose_message(_("Creating support files for %s"), output);
+    Rast_short_history(output, "raster", &history);
+    Rast_command_history(&history);
+    Rast_write_history(output, &history);
+    Rast_write_colors(output, G_mapset(), &info->colors);
+    Rast_init_cats(NULL, &cats);
+    Rast_write_cats((char *)output, &cats);
+    if (title)
+	Rast_put_cell_title(output, title);
+    G_done_msg(_("Link to raster map <%s> created."), output);
Property changes on: grass/trunk/raster/r.external/link.c
___________________________________________________________________
Added: svn:mime-type
   + text/x-csrc
Added: svn:eol-style
   + native
Added: grass/trunk/raster/r.external/list.c
--- grass/trunk/raster/r.external/list.c	                        (rev 0)
+++ grass/trunk/raster/r.external/list.c	2011-08-31 18:09:56 UTC (rev 48005)
@@ -0,0 +1,38 @@
+#include <stdio.h>
+#include <gdal.h>
+#include "proto.h"
+void list_formats(void)
+    /*      List supported formats and exit.                                */
+    /*         code from GDAL 1.2.5  gcore/gdal_misc.cpp                    */
+    /*         Copyright (c) 1999, Frank Warmerdam                          */
+    int iDr;
+    G_message(_("Supported formats:"));
+    for (iDr = 0; iDr < GDALGetDriverCount(); iDr++) {
+	GDALDriverH hDriver = GDALGetDriver(iDr);
+	const char *pszRWFlag;
+	if (GDALGetMetadataItem(hDriver, GDAL_DCAP_CREATE, NULL))
+	    pszRWFlag = "rw+";
+	else if (GDALGetMetadataItem(hDriver, GDAL_DCAP_CREATECOPY, NULL))
+	    pszRWFlag = "rw";
+	else
+	    pszRWFlag = "ro";
+	fprintf(stdout, " %s (%s): %s\n",
+		GDALGetDriverShortName(hDriver),
+		pszRWFlag, GDALGetDriverLongName(hDriver));
Property changes on: grass/trunk/raster/r.external/list.c
   + text/x-csrc
   + native
Modified: grass/trunk/raster/r.external/main.c
--- grass/trunk/raster/r.external/main.c	2011-08-31 16:29:25 UTC (rev 48004)
+++ grass/trunk/raster/r.external/main.c	2011-08-31 18:09:56 UTC (rev 48005)
@@ -4,10 +4,11 @@
  * MODULE:       r.external
  * AUTHOR(S):    Glynn Clements, based on r.in.gdal
+ *               List GDAL layers by Martin Landa <landa.martin gmail.com> 8/2011
  * PURPOSE:      Link raster map into GRASS utilizing the GDAL library.
- * COPYRIGHT:    (C) 2008, 2010 by Glynn Clements and the GRASS Development Team
+ * COPYRIGHT:    (C) 2008, 2010-2011 by Glynn Clements and the GRASS Development Team
  *               This program is free software under the GNU General Public
  *               License (>=v2). Read the file COPYING that comes with GRASS
@@ -22,490 +23,16 @@
 #include <grass/raster.h>
 #include <grass/imagery.h>
-#include <grass/gprojects.h>
-#include "gdal.h"
-#include "ogr_srs_api.h"
+#include <gdal.h>
+#include <ogr_srs_api.h>
-#undef MIN
-#undef MAX
-#define MIN(a,b)      ((a) < (b) ? (a) : (b))
-#define MAX(a,b)      ((a) > (b) ? (a) : (b))
+#include "proto.h"
-struct band_info
-    RASTER_MAP_TYPE data_type;
-    GDALDataType gdal_type;
-    int has_null;
-    double null_val;
-    double range[2];
-    struct Colors colors;
-enum flip {
-    FLIP_H = 1,
-    FLIP_V = 2,
-static void list_formats(void)
-    /*      List supported formats and exit.                                */
-    /*         code from GDAL 1.2.5  gcore/gdal_misc.cpp                    */
-    /*         Copyright (c) 1999, Frank Warmerdam                          */
-    int iDr;
-    G_message(_("Supported formats:"));
-    for (iDr = 0; iDr < GDALGetDriverCount(); iDr++) {
-	GDALDriverH hDriver = GDALGetDriver(iDr);
-	const char *pszRWFlag;
-	if (GDALGetMetadataItem(hDriver, GDAL_DCAP_CREATE, NULL))
-	    pszRWFlag = "rw+";
-	else if (GDALGetMetadataItem(hDriver, GDAL_DCAP_CREATECOPY, NULL))
-	    pszRWFlag = "rw";
-	else
-	    pszRWFlag = "ro";
-	fprintf(stdout, " %s (%s): %s\n",
-		GDALGetDriverShortName(hDriver),
-		pszRWFlag, GDALGetDriverLongName(hDriver));
-static void check_projection(struct Cell_head *cellhd, GDALDatasetH hDS, int override)
-    struct Cell_head loc_wind;
-    struct Key_Value *proj_info = NULL, *proj_units = NULL;
-    struct Key_Value *loc_proj_info = NULL, *loc_proj_units = NULL;
-    int projcomp_error = 0;
-    char error_msg[8096];
-    /* Projection only required for checking so convert non-interactively */
-    if (GPJ_wkt_to_grass(cellhd, &proj_info,
-			 &proj_units, GDALGetProjectionRef(hDS), 0) < 0)
-	G_warning(_("Unable to convert input raster map projection information to "
-		    "GRASS format for checking"));
-    else {
-	/*      Does the projection of the current location match the           */
-	/*      dataset?                                                        */
-	G_get_window(&loc_wind);
-	if (loc_wind.proj != PROJECTION_XY) {
-	    loc_proj_info = G_get_projinfo();
-	    loc_proj_units = G_get_projunits();
-	if (override) {
-	    cellhd->proj = loc_wind.proj;
-	    cellhd->zone = loc_wind.zone;
-	    G_warning(_("Over-riding projection check"));
-	else if (loc_wind.proj != cellhd->proj ||
-		 (projcomp_error = G_compare_projections(
-		      loc_proj_info, loc_proj_units, proj_info, proj_units)) < 0) {
-	    int i_value;
-	    strcpy(error_msg,
-		   _("Projection of dataset does not"
-		     " appear to match current location.\n\n"));
-	    /* TODO: output this info sorted by key: */
-	    if (loc_proj_info != NULL) {
-		strcat(error_msg, _("Location PROJ_INFO is:\n"));
-		for (i_value = 0;
-		     loc_proj_info != NULL &&
-			 i_value < loc_proj_info->nitems; i_value++)
-		    sprintf(error_msg + strlen(error_msg), "%s: %s\n",
-			    loc_proj_info->key[i_value],
-			    loc_proj_info->value[i_value]);
-		strcat(error_msg, "\n");
-	    if (proj_info != NULL) {
-		strcat(error_msg, _("Dataset PROJ_INFO is:\n"));
-		for (i_value = 0;
-		     proj_info != NULL && i_value < proj_info->nitems;
-		     i_value++)
-			    proj_info->key[i_value],
-			    proj_info->value[i_value]);
-		strcat(error_msg, "\nERROR: ");
-		switch (projcomp_error) {
-		case -1:
-		    strcat(error_msg, "proj\n");
-		    break;
-		case -2:
-		    strcat(error_msg, "units\n");
-		    break;
-		case -3:
-		    strcat(error_msg, "datum\n");
-		    break;
-		case -4:
-		    strcat(error_msg, "ellps\n");
-		    break;
-		case -5:
-		    strcat(error_msg, "zone\n");
-		    break;
-	    else {
-		strcat(error_msg, _("Import dataset PROJ_INFO is:\n"));
-		if (cellhd->proj == PROJECTION_XY)
-			    "cellhd.proj = %d (unreferenced/unknown)\n",
-			    cellhd->proj);
-		else if (cellhd->proj == PROJECTION_LL)
-			    "cellhd.proj = %d (lat/long)\n", cellhd->proj);
-		else if (cellhd->proj == PROJECTION_UTM)
-			    "cellhd.proj = %d (UTM), zone = %d\n",
-			    cellhd->proj, cellhd->zone);
-		else if (cellhd->proj == PROJECTION_SP)
-			    "cellhd.proj = %d (State Plane), zone = %d\n",
-		else
-			    "cellhd.proj = %d (unknown), zone = %d\n",
-	    strcat(error_msg,
-		   _("\nYou can use the -o flag to r.external to override this check and "
-		     "use the location definition for the dataset.\n"));
-	    strcat(error_msg,
-		   _("Consider generating a new location from the input dataset using "
-		     "the 'location' parameter.\n"));
-	    G_fatal_error(error_msg);
-	else {
-	    G_message(_("Projection of input dataset and current location "
-			"appear to match"));
-static void setup_window(struct Cell_head *cellhd, GDALDatasetH hDS, int *flip)
-    /*      Set up the window representing the data we have.                */
-    double adfGeoTransform[6];
-    cellhd->rows = GDALGetRasterYSize(hDS);
-    cellhd->rows3 = GDALGetRasterYSize(hDS);
-    cellhd->cols = GDALGetRasterXSize(hDS);
-    cellhd->cols3 = GDALGetRasterXSize(hDS);
-    if (GDALGetGeoTransform(hDS, adfGeoTransform) == CE_None) {
-	if (adfGeoTransform[2] != 0.0 || adfGeoTransform[4] != 0.0)
-	    G_fatal_error(_("Input raster map is rotated - cannot import. "
-			    "You may use 'gdalwarp' to transform the map to North-up."));
-	if (adfGeoTransform[1] <= 0.0) {
-	    G_message(_("Applying horizontal flip"));
-	    *flip |= FLIP_H;
-	if (adfGeoTransform[5] >= 0.0) {
-	    G_message(_("Applying vertical flip"));
-	    *flip |= FLIP_V;
-	cellhd->north = adfGeoTransform[3];
-	cellhd->ns_res = fabs(adfGeoTransform[5]);
-	cellhd->ns_res3 = fabs(adfGeoTransform[5]);
-	cellhd->south = cellhd->north - cellhd->ns_res * cellhd->rows;
-	cellhd->west = adfGeoTransform[0];
-	cellhd->ew_res = fabs(adfGeoTransform[1]);
-	cellhd->ew_res3 = fabs(adfGeoTransform[1]);
-	cellhd->east = cellhd->west + cellhd->cols * cellhd->ew_res;
-	cellhd->top = 1.;
-	cellhd->bottom = 0.;
-	cellhd->tb_res = 1.;
-	cellhd->depths = 1;
-    else {
-	cellhd->north = cellhd->rows;
-	cellhd->south = 0.0;
-	cellhd->ns_res = 1.0;
-	cellhd->ns_res3 = 1.0;
-	cellhd->west = 0.0;
-	cellhd->east = cellhd->cols;
-	cellhd->ew_res = 1.0;
-	cellhd->ew_res3 = 1.0;
-	cellhd->top = 1.;
-static void update_default_window(struct Cell_head *cellhd)
-    /*      Extend current window based on dataset.                         */
-    struct Cell_head def_wind;
-    G_get_default_window(&def_wind);
-    def_wind.north = MAX(def_wind.north, cellhd->north);
-    def_wind.south = MIN(def_wind.south, cellhd->south);
-    def_wind.west = MIN(def_wind.west, cellhd->west);
-    def_wind.east = MAX(def_wind.east, cellhd->east);
-    def_wind.rows = (int)ceil((def_wind.north - def_wind.south)
-			      / def_wind.ns_res);
-    def_wind.south = def_wind.north - def_wind.rows * def_wind.ns_res;
-    def_wind.cols = (int)ceil((def_wind.east - def_wind.west)
-			      / def_wind.ew_res);
-    def_wind.east = def_wind.west + def_wind.cols * def_wind.ew_res;
-    G__put_window(&def_wind, "../PERMANENT", "DEFAULT_WIND");
-static void query_band(GDALRasterBandH hBand, const char *output, int exact_range,
-		       struct Cell_head *cellhd, struct band_info *info)
-    int bGotMin, bGotMax;
-    info->gdal_type = GDALGetRasterDataType(hBand);
-    info->null_val = GDALGetRasterNoDataValue(hBand, &info->has_null);
-    cellhd->compressed = 0;
-    switch (info->gdal_type) {
-    case GDT_Float32:
-	info->data_type = FCELL_TYPE;
-	cellhd->format = -1;
-	break;
-    case GDT_Float64:
-	info->data_type = DCELL_TYPE;
-	break;
-    case GDT_Byte:
-	info->data_type = CELL_TYPE;
-	cellhd->format = 0;
-	break;
-    case GDT_Int16:
-    case GDT_UInt16:
-	cellhd->format = 1;
-	break;
-    case GDT_Int32:
-    case GDT_UInt32:
-	cellhd->format = 3;
-	break;
-    default:
-	G_fatal_error(_("Complex types not supported"));
-	break;
-    info->range[0] = GDALGetRasterMinimum(hBand, &bGotMin);
-    info->range[1] = GDALGetRasterMaximum(hBand, &bGotMax);
-    if(!(bGotMin && bGotMax))
-	GDALComputeRasterMinMax(hBand, !exact_range, info->range);
-    Rast_init_colors(&info->colors);
-    if (GDALGetRasterColorTable(hBand) != NULL) {
-	GDALColorTableH hCT;
-	int count, i;
-	G_verbose_message(_("Copying color table for %s"), output);
-	hCT = GDALGetRasterColorTable(hBand);
-	count = GDALGetColorEntryCount(hCT);
-	for (i = 0; i < count; i++) {
-	    GDALColorEntry sEntry;
-	    GDALGetColorEntryAsRGB(hCT, i, &sEntry);
-	    if (sEntry.c4 == 0)
-		continue;
-	    Rast_set_c_color(i, sEntry.c1, sEntry.c2, sEntry.c3, &info->colors);
-    else {
-	if (info->gdal_type == GDT_Byte) {
-	    /* set full 0..255 range to grey scale: */
-	    G_verbose_message(_("Setting grey color table for <%s> (full 8bit range)"),
-			      output);
-	    Rast_make_grey_scale_colors(&info->colors, 0, 255);
-	else  {
-	    /* set data range to grey scale: */
-	    G_verbose_message(_("Setting grey color table for <%s> (data range)"),
-			      output);
-				     (int) info->range[0], (int) info->range[1]);
-static void make_cell(const char *output, const struct band_info *info)
-    FILE *fp;
-    fp = G_fopen_new("cell", output);
-    if (!fp)
-	G_fatal_error(_("Unable to create cell/%s file"), output);
-    fclose(fp);
-    if (info->data_type == CELL_TYPE)
-	return;
-    fp = G_fopen_new("fcell", output);
-    if (!fp)
-	G_fatal_error(_("Unable to create fcell/%s file"), output);
-    fclose(fp);
-static void make_link(const char *input, const char *output, int band,
-		      const struct band_info *info, int flip)
-    struct Key_Value *key_val = G_create_key_value();
-    char null_str[256], type_str[8], band_str[8];
-    FILE *fp;
-    sprintf(band_str, "%d", band);
-    if (info->has_null) {
-	    sprintf(null_str, "%d", (int) info->null_val);
-	else
-	    sprintf(null_str, "%.22g", info->null_val);
-    else
-	strcpy(null_str, "none");
-    sprintf(type_str, "%d", info->gdal_type);
-    G_set_key_value("file", input, key_val);
-    G_set_key_value("band", band_str, key_val);
-    G_set_key_value("null", null_str, key_val);
-    G_set_key_value("type", type_str, key_val);
-    if (flip & FLIP_H)
-	G_set_key_value("hflip", "yes", key_val);
-    if (flip & FLIP_V)
-	G_set_key_value("vflip", "yes", key_val);
-    fp = G_fopen_new_misc("cell_misc", "gdal", output);
-    if (!fp)
-	G_fatal_error(_("Unable to create cell_misc/%s/gdal file"), output);
-    if (G_fwrite_key_value(fp, key_val) < 0)
-	G_fatal_error(_("Error writing cell_misc/%s/gdal file"), output);
-    fclose(fp);
-static void write_fp_format(const char *output, const struct band_info *info)
-    struct Key_Value *key_val;
-    const char *type;
-    FILE *fp;
-	return;
-    key_val = G_create_key_value();
-    type = (info->data_type == FCELL_TYPE)
-	? "float"
-	: "double";
-    G_set_key_value("type", type, key_val);
-    G_set_key_value("byte_order", "xdr", key_val);
-    fp = G_fopen_new_misc("cell_misc", "f_format", output);
-    if (!fp)
-	G_fatal_error(_("Unable to create cell_misc/%s/f_format file"), output);
-	G_fatal_error(_("Error writing cell_misc/%s/f_format file"), output);
-    fclose(fp);
-    G_free_key_value(key_val);
-static void write_fp_quant(const char *output)
-    struct Quant quant;
-    Rast_quant_init(&quant);
-    Rast_quant_round(&quant);
-    Rast_write_quant(output, G_mapset(), &quant);
-static void create_map(const char *input, int band, const char *output,
-		       struct Cell_head *cellhd, struct band_info *info,
-		       const char *title, int flip)
-    struct History history;
-    struct Categories cats;
-    Rast_put_cellhd(output, cellhd);
-    make_cell(output, info);
-    make_link(input, output, band, info, flip);
-    if (info->data_type == CELL_TYPE) {
-	struct Range range;
-	range.min = (CELL)info->range[0];
-	range.max = (CELL)info->range[1];
-	range.first_time = 0;
-	Rast_write_range(output, &range);
-    else {
-	struct FPRange fprange;
-	fprange.min = info->range[0];
-	fprange.max = info->range[1];
-	fprange.first_time = 0;
-	Rast_write_fp_range(output, &fprange);
-	write_fp_format(output, info);
-	write_fp_quant(output);
-    G_verbose_message(_("Creating support files for %s"), output);
-    Rast_short_history(output, "raster", &history);
-    Rast_command_history(&history);
-    Rast_write_history(output, &history);
-    Rast_write_colors(output, G_mapset(), &info->colors);
-    Rast_init_cats(NULL, &cats);
-    Rast_write_cats((char *)output, &cats);
-    if (title)
-	Rast_put_cell_title(output, title);
-    G_message(_("Link to raster map <%s> created"), output);
 int main(int argc, char *argv[])
-    char *input;
-    char *source;
-    char *output;
+    const char *input, *source, *output;
     char *title;
     struct Cell_head cellhd;
     GDALDatasetH hDS;
@@ -514,7 +41,9 @@
     struct {
 	struct Option *input, *source, *output, *band, *title;
     } parm;
-    struct Flag *flag_o, *flag_f, *flag_e, *flag_r, *flag_h, *flag_v;
+    struct {
+	struct Flag *o, *f, *e, *r, *h, *v;
+    } flag;
     int min_band, max_band, band;
     struct band_info info;
     int flip;
@@ -528,17 +57,21 @@
     G_add_keyword(_("input"));
     G_add_keyword(_("external"));
     module->description =
-	_("Link GDAL supported raster data as a pseudo GRASS raster map.");
+	_("Links GDAL supported raster data as a pseudo GRASS raster map.");
     parm.input = G_define_standard_option(G_OPT_F_INPUT);
-    parm.input->description = _("Raster file to be linked");
+    parm.input->description = _("Name of raster file to be linked");
+    parm.input->required = NO;
+    parm.input->guisection = _("Input");
     parm.source = G_define_option();
     parm.source->key = "source";
     parm.source->description = _("Name of non-file GDAL data source");
     parm.source->required = NO;
     parm.source->type = TYPE_STRING;
+    parm.source->key_desc = "name";
+    parm.source->guisection = _("Input");
     parm.output = G_define_standard_option(G_OPT_R_OUTPUT);
     parm.band = G_define_option();
@@ -546,6 +79,7 @@
     parm.band->type = TYPE_INTEGER;
     parm.band->required = NO;
     parm.band->description = _("Band to select (default: all)");
+    parm.band->guisection = _("Input");
     parm.title = G_define_option();
     parm.title->key = "title";
@@ -555,39 +89,39 @@
     parm.title->description = _("Title for resultant raster map");
     parm.title->guisection = _("Metadata");
-    flag_o = G_define_flag();
-    flag_o->key = 'o';
-    flag_o->description =
+    flag.f = G_define_flag();
+    flag.f->key = 'f';
+    flag.f->description = _("List supported formats and exit");
+    flag.f->guisection = _("Print");
+    flag.f->suppress_required = YES;
+    flag.o = G_define_flag();
+    flag.o->key = 'o';
+    flag.o->description =
 	_("Override projection (use location's projection)");
-    flag_e = G_define_flag();
-    flag_e->key = 'e';
-    flag_e->description = _("Extend location extents based on new dataset");
+    flag.e = G_define_flag();
+    flag.e->key = 'e';
+    flag.e->description = _("Extend location extents based on new dataset");
-    flag_r = G_define_flag();
-    flag_r->key = 'r';
-    flag_r->description = _("Require exact range");
+    flag.r = G_define_flag();
+    flag.r->key = 'r';
+    flag.r->description = _("Require exact range");
-    flag_f = G_define_flag();
-    flag_f->key = 'f';
-    flag_f->description = _("List supported formats and exit");
-    flag_f->guisection = _("Print");
-    flag_f->suppress_required = YES;
-    flag_h = G_define_flag();
-    flag_h->key = 'h';
-    flag_h->description = _("Flip horizontally");
+    flag.h = G_define_flag();
+    flag.h->key = 'h';
+    flag.h->description = _("Flip horizontally");
-    flag_v = G_define_flag();
-    flag_v->key = 'v';
-    flag_v->description = _("Flip vertically");
+    flag.v = G_define_flag();
+    flag.v->key = 'v';
+    flag.v->description = _("Flip vertically");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
     GDALAllRegister();
-    if (flag_f->answer) {
+    if (flag.f->answer) {
 	list_formats();
 	exit(EXIT_SUCCESS);
@@ -597,9 +131,9 @@
     output = parm.output->answer;
     flip = 0;
-    if (flag_h->answer)
+    if (flag.h->answer)
 	flip |= FLIP_H;
-    if (flag_v->answer)
+    if (flag.v->answer)
 	flip |= FLIP_V;
     if (parm.title->answer) {
@@ -610,14 +144,13 @@
 	title = NULL;
     if (!input && !source)
-	G_fatal_error(_("Name for input source not specified"));
+	G_fatal_error(_("One of options <%s> or <%s> must be given"),
+		      parm.input->key, parm.source->key);
     if (input && source)
-	G_fatal_error(_("input= and source= are mutually exclusive"));
-    if (!output)
-	G_fatal_error(_("Name for output raster map not specified"));
+	G_fatal_error(_("Option <%s> and <%s> are mutually exclusive"),
     if (input && !G_is_absolute_path(input)) {
 	char path[GPATH_MAX];
 	getcwd(path, sizeof(path));
@@ -635,7 +168,7 @@
     setup_window(&cellhd, hDS, &flip);
-    check_projection(&cellhd, hDS, flag_o->answer);
+    check_projection(&cellhd, hDS, flag.o->answer);
     Rast_set_window(&cellhd);
@@ -655,7 +188,8 @@
     for (band = min_band; band <= max_band; band++) {
 	char *output2, *title2 = NULL;
-	G_message("Importing band %d of %d...", band, GDALGetRasterCount( hDS ));
+	G_message(_("Reading band %d of %d..."),
+		  band, GDALGetRasterCount( hDS ));
 	hBand = GDALGetRasterBand(hDS, band);
 	if (!hBand)
@@ -674,14 +208,14 @@
 		title2 = G_store(title);
-	query_band(hBand, output2, flag_r->answer, &cellhd, &info);
+	query_band(hBand, output2, flag.r->answer, &cellhd, &info);
 	create_map(input, band, output2, &cellhd, &info, title, flip);
 	G_free(output2);
 	G_free(title2);
-    if (flag_e->answer)
+    if (flag.e->answer)
 	update_default_window(&cellhd);
     /* Create the imagery group if multiple bands are imported */
@@ -693,4 +227,3 @@
     exit(EXIT_SUCCESS);
Property changes on: grass/trunk/raster/r.external/main.c
   + text/x-csrc
Added: grass/trunk/raster/r.external/proj.c
--- grass/trunk/raster/r.external/proj.c	                        (rev 0)
+++ grass/trunk/raster/r.external/proj.c	2011-08-31 18:09:56 UTC (rev 48005)
@@ -0,0 +1,119 @@
+#include <grass/gprojects.h>
+#include <gdal.h>
+void check_projection(struct Cell_head *cellhd, GDALDatasetH hDS, int override)
+    struct Cell_head loc_wind;
+    struct Key_Value *proj_info = NULL, *proj_units = NULL;
+    struct Key_Value *loc_proj_info = NULL, *loc_proj_units = NULL;
+    int projcomp_error = 0;
+    char error_msg[8096];
+    /* Projection only required for checking so convert non-interactively */
+    if (GPJ_wkt_to_grass(cellhd, &proj_info,
+			 &proj_units, GDALGetProjectionRef(hDS), 0) < 0)
+	G_warning(_("Unable to convert input raster map projection information to "
+		    "GRASS format for checking"));
+    else {
+	/*      Does the projection of the current location match the           */
+	/*      dataset?                                                        */
+	G_get_window(&loc_wind);
+	if (loc_wind.proj != PROJECTION_XY) {
+	    loc_proj_info = G_get_projinfo();
+	    loc_proj_units = G_get_projunits();
+	if (override) {
+	    cellhd->proj = loc_wind.proj;
+	    cellhd->zone = loc_wind.zone;
+	    G_warning(_("Over-riding projection check"));
+	else if (loc_wind.proj != cellhd->proj ||
+		 (projcomp_error = G_compare_projections(
+		      loc_proj_info, loc_proj_units, proj_info, proj_units)) < 0) {
+	    int i_value;
+	    strcpy(error_msg,
+		   _("Projection of dataset does not"
+		     " appear to match current location.\n\n"));
+	    /* TODO: output this info sorted by key: */
+	    if (loc_proj_info != NULL) {
+		strcat(error_msg, _("Location PROJ_INFO is:\n"));
+		for (i_value = 0;
+		     loc_proj_info != NULL &&
+			 i_value < loc_proj_info->nitems; i_value++)
+		    sprintf(error_msg + strlen(error_msg), "%s: %s\n",
+			    loc_proj_info->key[i_value],
+			    loc_proj_info->value[i_value]);
+		strcat(error_msg, "\n");
+	    if (proj_info != NULL) {
+		strcat(error_msg, _("Dataset PROJ_INFO is:\n"));
+		for (i_value = 0;
+		     proj_info != NULL && i_value < proj_info->nitems;
+		     i_value++)
+			    proj_info->key[i_value],
+			    proj_info->value[i_value]);
+		strcat(error_msg, "\nERROR: ");
+		switch (projcomp_error) {
+		case -1:
+		    strcat(error_msg, "proj\n");
+		    break;
+		case -2:
+		    strcat(error_msg, "units\n");
+		    break;
+		case -3:
+		    strcat(error_msg, "datum\n");
+		    break;
+		case -4:
+		    strcat(error_msg, "ellps\n");
+		    break;
+		case -5:
+		    strcat(error_msg, "zone\n");
+		    break;
+	    else {
+		strcat(error_msg, _("Import dataset PROJ_INFO is:\n"));
+		if (cellhd->proj == PROJECTION_XY)
+			    "cellhd.proj = %d (unreferenced/unknown)\n",
+			    cellhd->proj);
+		else if (cellhd->proj == PROJECTION_LL)
+			    "cellhd.proj = %d (lat/long)\n", cellhd->proj);
+		else if (cellhd->proj == PROJECTION_UTM)
+			    "cellhd.proj = %d (UTM), zone = %d\n",
+			    cellhd->proj, cellhd->zone);
+		else if (cellhd->proj == PROJECTION_SP)
+			    "cellhd.proj = %d (State Plane), zone = %d\n",
+		else
+			    "cellhd.proj = %d (unknown), zone = %d\n",
+	    strcat(error_msg,
+		   _("\nYou can use the -o flag to r.external to override this check and "
+		     "use the location definition for the dataset.\n"));
+	    strcat(error_msg,
+		   _("Consider generating a new location from the input dataset using "
+		     "the 'location' parameter.\n"));
+	    G_fatal_error(error_msg);
+	else {
+	    G_message(_("Projection of input dataset and current location "
+			"appear to match"));
Property changes on: grass/trunk/raster/r.external/proj.c
   + text/x-csrc
   + native
Added: grass/trunk/raster/r.external/proto.h
--- grass/trunk/raster/r.external/proto.h	                        (rev 0)
+++ grass/trunk/raster/r.external/proto.h	2011-08-31 18:09:56 UTC (rev 48005)
@@ -0,0 +1,44 @@
+#include <grass/raster.h>
+#undef MIN
+#undef MAX
+#define MIN(a,b)      ((a) < (b) ? (a) : (b))
+#define MAX(a,b)      ((a) > (b) ? (a) : (b))
+struct band_info
+    RASTER_MAP_TYPE data_type;
+    GDALDataType gdal_type;
+    int has_null;
+    double null_val;
+    double range[2];
+    struct Colors colors;
+enum flip {
+    FLIP_H = 1,
+    FLIP_V = 2,
+/* link.c */
+void query_band(GDALRasterBandH, const char *, int,
+		struct Cell_head *, struct band_info *);
+void make_cell(const char *, const struct band_info *);
+void make_link(const char *, const char *, int,
+	       const struct band_info *, int);
+void write_fp_format(const char *, const struct band_info *);
+void write_fp_quant(const char *);
+void create_map(const char *, int, const char *,
+		struct Cell_head *, struct band_info *,
+		const char *, int);
+/* list.c */
+void list_layers(FILE *, const char *);
+void list_formats(void);
+/* proj.c */
+void check_projection(struct Cell_head *, GDALDatasetH, int);
+/* window.c */
+void setup_window(struct Cell_head *, GDALDatasetH, int *);
+void update_default_window(struct Cell_head *);
Added: grass/trunk/raster/r.external/window.c
--- grass/trunk/raster/r.external/window.c	                        (rev 0)
+++ grass/trunk/raster/r.external/window.c	2011-08-31 18:09:56 UTC (rev 48005)
@@ -0,0 +1,87 @@
+#include <gdal.h>
+#include "proto.h"
+void setup_window(struct Cell_head *cellhd, GDALDatasetH hDS, int *flip)
+    /*      Set up the window representing the data we have.                */
+    double adfGeoTransform[6];
+    cellhd->rows = GDALGetRasterYSize(hDS);
+    cellhd->rows3 = GDALGetRasterYSize(hDS);
+    cellhd->cols = GDALGetRasterXSize(hDS);
+    cellhd->cols3 = GDALGetRasterXSize(hDS);
+    if (GDALGetGeoTransform(hDS, adfGeoTransform) == CE_None) {
+	if (adfGeoTransform[2] != 0.0 || adfGeoTransform[4] != 0.0)
+	    G_fatal_error(_("Input raster map is rotated - cannot import. "
+			    "You may use 'gdalwarp' to transform the map to North-up."));
+	if (adfGeoTransform[1] <= 0.0) {
+	    G_message(_("Applying horizontal flip"));
+	    *flip |= FLIP_H;
+	if (adfGeoTransform[5] >= 0.0) {
+	    G_message(_("Applying vertical flip"));
+	    *flip |= FLIP_V;
+	cellhd->north = adfGeoTransform[3];
+	cellhd->ns_res = fabs(adfGeoTransform[5]);
+	cellhd->ns_res3 = fabs(adfGeoTransform[5]);
+	cellhd->south = cellhd->north - cellhd->ns_res * cellhd->rows;
+	cellhd->west = adfGeoTransform[0];
+	cellhd->ew_res = fabs(adfGeoTransform[1]);
+	cellhd->ew_res3 = fabs(adfGeoTransform[1]);
+	cellhd->east = cellhd->west + cellhd->cols * cellhd->ew_res;
+	cellhd->top = 1.;
+	cellhd->bottom = 0.;
+	cellhd->tb_res = 1.;
+	cellhd->depths = 1;
+    else {
+	cellhd->north = cellhd->rows;
+	cellhd->south = 0.0;
+	cellhd->ns_res = 1.0;
+	cellhd->ns_res3 = 1.0;
+	cellhd->west = 0.0;
+	cellhd->east = cellhd->cols;
+	cellhd->ew_res = 1.0;
+	cellhd->ew_res3 = 1.0;
+	cellhd->top = 1.;
+void update_default_window(struct Cell_head *cellhd)
+    /*      Extend current window based on dataset.                         */
+    struct Cell_head def_wind;
+    G_get_default_window(&def_wind);
+    def_wind.north = MAX(def_wind.north, cellhd->north);
+    def_wind.south = MIN(def_wind.south, cellhd->south);
+    def_wind.west = MIN(def_wind.west, cellhd->west);
+    def_wind.east = MAX(def_wind.east, cellhd->east);
+    def_wind.rows = (int)ceil((def_wind.north - def_wind.south)
+			      / def_wind.ns_res);
+    def_wind.south = def_wind.north - def_wind.rows * def_wind.ns_res;
+    def_wind.cols = (int)ceil((def_wind.east - def_wind.west)
+			      / def_wind.ew_res);
+    def_wind.east = def_wind.west + def_wind.cols * def_wind.ew_res;
+    G__put_window(&def_wind, "../PERMANENT", "DEFAULT_WIND");
Property changes on: grass/trunk/raster/r.external/window.c
   + text/x-csrc
   + native
