[GRASS-SVN] r49854 - grass-addons/grass6/raster/mcda/r.mcda.ahp
Wed Dec 21 17:46:36 EST 2011
Author: gianluca
Date: 2011-12-21 14:46:36 -0800 (Wed, 21 Dec 2011)
New Revision: 49854
   grass-addons/grass6/raster/mcda/r.mcda.ahp/description.html
Modified: grass-addons/grass6/raster/mcda/r.mcda.ahp/description.html
--- grass-addons/grass6/raster/mcda/r.mcda.ahp/description.html	2011-12-21 17:28:25 UTC (rev 49853)
+++ grass-addons/grass6/raster/mcda/r.mcda.ahp/description.html	2011-12-21 22:46:36 UTC (rev 49854)
@@ -1,8 +1,3 @@
-<html>
-<head>
-<meta http-equiv="Content-Type" content="text/html; charset=us-ascii">
-</head>
-<body>
 <h2>DESCRIPTION</h2>
 <p>The <em>r.mcda.ahp</em> Generate a raster map classified with analytic hierarchy process (AHP) [Saaty, 1977 and Saaty &amp; Vargas, 1991]</p>
 <em>(GRASS python Script)</em>
@@ -19,16 +14,20 @@
 <p>#end file</p>
 The first row and first column are related to the first criteria (reclass_slope in our case); the second row and second column are related to the second criteria (reclass_sand in our case) and the third row and third column are related to the third criteria
  ( reclass_elev in our cas), and so on.
+<p>In the work directory should be generated a log.txt file were you can find additional information like: eigenvectors, eigenvalues, weights</p>
 <h2>TODO</h2>
 <h2>SEE ALSO</h2>
-<em><a href="UrlBlockedError.aspx" target="_blank">r.roughset</a>, <a href="UrlBlockedError.aspx" target="_blank">
-r.mcda.regime</a>, <a href="UrlBlockedError.aspx" target="_blank">r.mcda.fuzzy</a>
-<a href="UrlBlockedError.aspx" target="_blank">r.mcda.electre</a>, <a href="UrlBlockedError.aspx" target="_blank">
-r.in.drsa</a> <a href="UrlBlockedError.aspx" target="_blank">r.in.drsa</a> <a href="UrlBlockedError.aspx" target="_blank">
-r.in.drsa</a> </em>
+<em>
+<a href="r.roughset.html">r.roughset</a>,
+<a href="r.mcda.regime.html">r.mcda.regime</a>,
+<a href="r.mcda.fuzzy.html">r.mcda.fuzzy</a>
+<a href="r.mcda.electre.html">r.mcda.electre</a>,
+<a href="r.mcda.roughset.html">r.mcda.roughset</a>
+<a href="r.in.drsa.html">r.in.drsa</a>
+<a href="r.to.drsa.html">r.to.drsa</a>
+</em>
 <h2>AUTHORS</h2>
 Antonio Boggia - Gianluca Massei<br>
 Department of Economics and Appraisal - University of Perugia - Italy
-<p><i>Last changed: $Date: 2011-12-15 22:56:45 &#43;0100 ( 15 dic 2011) $</i> </p>
-</body>
-</html>
+<p><i>Last changed: $Date: 2011-02-21 18:33:36 +0100 (mer, 21 dic 2011) $</i>
