[GRASS-SVN] r49993 - grass-addons/grass6/raster/r.basin
Fri Dec 30 14:51:18 EST 2011
Author: madi
Date: 2011-12-30 11:51:17 -0800 (Fri, 30 Dec 2011)
New Revision: 49993
   grass-addons/grass6/raster/r.basin/description.html
   grass-addons/grass6/raster/r.basin/r.basin.py
general improvements, controls added
Modified: grass-addons/grass6/raster/r.basin/description.html
--- grass-addons/grass6/raster/r.basin/description.html	2011-12-30 17:49:00 UTC (rev 49992)
+++ grass-addons/grass6/raster/r.basin/description.html	2011-12-30 19:51:17 UTC (rev 49993)
@@ -3,6 +3,11 @@
 starting from the digital elevation model and the coordinates of
 the basin's closing section.
+<h3>Important:</h3>
+<p>The closing section's coordinates must belong to the river network generated by
+<a href="r.stream.extract.html">r.stream.extract</a>. It is suggested to run it
+before.</p>
 <h3>Morphometric parameters of basin</h3>
 <p>The main parameters are:
 <ul>
Modified: grass-addons/grass6/raster/r.basin/r.basin.py
--- grass-addons/grass6/raster/r.basin/r.basin.py	2011-12-30 17:49:00 UTC (rev 49992)
+++ grass-addons/grass6/raster/r.basin/r.basin.py	2011-12-30 19:51:17 UTC (rev 49993)
@@ -5,10 +5,12 @@
 # MODULE:      r.basin.py
 # AUTHOR(S):   Margherita Di Leo, Massimo Di Stefano
 # PURPOSE:     Morphometric characterization of river basins
-# COPYRIGHT:   (C) 2010 by the GRASS Development Team
+# COPYRIGHT:   (C) 2010 by Margherita Di Leo & Massimo Di Stefano
+#              dileomargherita at gmail.com
 #              This program is free software under the GNU General Public
-#              License (>=v2). Read the file COPYING that comes with GRASS
+#              License (>=v3.0) and comes with ABSOLUTELY NO WARRANTY.
+#              See the file COPYING that comes with GRASS
 #              for details.
@@ -55,7 +57,7 @@
 #%end
 #%flag
 #% key: a
-#% description: Use default Threshold (1km^2)
+#% description: Use default threshold (1km^2)
 #%END
 #%flag
 #% key: c
@@ -93,7 +95,7 @@
     r_shreve = prefix+'_shreve'
     r_horton = prefix+'_horton'
     r_hack = prefix+'_hack'
-    r_distance = prefix+'_distance'
+    r_distance = prefix+'_dist2out'
     r_hillslope_distance = prefix+'_hillslope_distance'
     r_height_average = prefix+'_height_average'
     r_aspect_mod = prefix+'_aspect_mod'
@@ -106,16 +108,26 @@
     r_average_hillslope = prefix+'_average_hillslope'
     r_mainchannel_dim = prefix+'_mainchannel_dim'
     r_outlet = prefix+'_r_outlet'
-    v_outlet = prefix+'_v_outlet'
+    v_outlet = prefix+'_outlet'
     v_basin = prefix+'_basin'
     v_centroid1 = prefix+'_centroid1'
     v_mainchannel = prefix+'_mainchannel'
     v_mainchannel_dim = prefix+'_mainchannel_dim'
     v_network = prefix+'_network'
-    v_stream_e = prefix+'_stream_e'
     v_ord_1 = prefix+'_ord_1'
     grass.run_command('g.remove' , rast = 'MASK')
+    # Save current region
+    grass.read_command('g.region', flags = 'p', save = 'original')
+    # Watershed SFD
+    grass.run_command('r.watershed', elevation = r_elevation,
+                                     accumulation = r_accumulation,
+                                     drainage = r_drainage,
+                                     convergence = 5,
+                                     flags = 'a',
+                                     overwrite = True)
     # Managing flag
     if autothreshold :
         info_region = grass.read_command('g.region', flags = 'p', rast = '%s' % (r_elevation))
@@ -126,300 +138,446 @@
     else :
         th = options['threshold']
-    # Watershed SFD
-    grass.run_command('r.watershed', elevation = r_elevation , threshold = th , accumulation = r_accumulation , drainage = r_drainage , stream = r_stream+'_nothin' , convergence = 5, flags = 'a')
     # Stream extraction
-    grass.run_command('r.stream.extract', elevation = r_elevation, accumulation = r_accumulation, threshold = th, d8cut = 'infinity', mexp = 0, stream_rast = r_stream_e, stream_vect = v_stream_e, direction = r_drainage_e, overwrite = True)
+    grass.run_command('r.stream.extract', elevation = r_elevation,
+                                          threshold = th,
+                                          d8cut = 'infinity',
+                                          mexp = 0,
+                                          stream_rast = r_stream_e,
+                                          direction = r_drainage_e,
+                                          overwrite = True)
+    try:
-    # Delineation of basin
-    grass.run_command('r.stream.basins', dir = r_drainage , basins = r_basin , coors = '%s,%s' % (east , north) )
-    grass.message( "Delineation of basin done" )
+        # Delineation of basin
+        grass.run_command('r.stream.basins', dir = r_drainage,
+                                             basins = r_basin,
+                                             coors = '%s,%s' % (east , north),
+                                             overwrite = True)
+        grass.message( "Delineation of basin done" )
+        # Mask and cropping
+        elevation_name = r_elevation = r_elevation.split('@')[0]
+        grass.mapcalc("$r_mask = $r_basin / $r_basin",
+                       r_mask = r_mask,
+                       r_basin = r_basin)
+        grass.mapcalc("$r_accumulation = $r_accumulation / $r_mask",
+                       r_accumulation = r_accumulation,
+                       r_mask = r_mask)
+        grass.mapcalc("$r_drainage = $r_drainage / $r_mask",
+                       r_drainage = r_drainage,
+                       r_mask = r_mask)
+        grass.mapcalc("$r_elevation_crop = $r_elevation * $r_mask",
+                       r_mask = r_mask,
+                       r_elevation = r_elevation,
+                       r_elevation_crop = 'r_elevation_crop')
+        grass.mapcalc("$r_drainage_e = $r_drainage_e * $r_mask",
+                       r_mask = r_mask,
+                       r_drainage_e = r_drainage_e)
+        grass.mapcalc("$r_stream_e = $r_stream_e * $r_mask",
+                       r_mask = r_mask,
+                       r_stream_e = r_stream_e)
+        grass.run_command('r.thin', input = r_stream_e,
+                                    output = r_stream_e+'_thin',
+                                    overwrite = True)
+        grass.run_command('r.to.vect', input = r_stream_e+'_thin',
+                                       output = v_network,
+                                       feature = 'line',
+                                       overwrite = True)
-    # Backup and mask
-    elevation_name = r_elevation = r_elevation.split('@')[0]
-    grass.run_command('g.copy', rast = r_elevation+','+elevation_name+'_crop')
-    grass.run_command('r.mapcalculator', amap = r_basin , formula = '%s/%s' % (r_basin, r_basin) , outfile = r_mask, overwrite = True)
-    grass.run_command('r.mapcalculator', amap = r_accumulation , formula = '%s*%s' % (r_accumulation, r_mask) , outfile = r_accumulation, overwrite = True)
-    grass.run_command('r.mapcalculator', amap = r_drainage , formula = '%s*%s' % (r_drainage, r_mask) , outfile = r_drainage, overwrite = True)
-    grass.run_command('r.mapcalculator', amap = r_stream+'_nothin' , formula = '%s*%s' % (r_stream+'_nothin', r_mask) , outfile = r_stream+'_nothin', overwrite = True)
-    grass.run_command('r.mapcalculator', amap = r_elevation , formula = '%s*%s' % (r_elevation, r_mask) , outfile = r_elevation+'_crop', overwrite = True)
-    grass.run_command('r.mapcalculator', amap = r_drainage_e , formula = '%s*%s' % (r_drainage_e, r_mask) , outfile = r_drainage_e, overwrite = True)
-    grass.run_command('r.mapcalculator', amap = r_stream_e , formula = '%s*%s' % (r_stream_e, r_mask) , outfile = r_stream_e, overwrite = True)
-    grass.run_command('r.thin', input = r_stream_e , output = r_stream_e+'_thin' )
-    grass.run_command('r.to.vect', input = r_stream_e+'_thin' , output = v_network , feature = 'line' )
-    # Creation of slope and aspect maps
-    grass.run_command('r.slope.aspect', elevation = r_elevation+'_crop' , slope = r_slope , aspect = r_aspect )
+        # Creation of slope and aspect maps
+        grass.run_command('r.slope.aspect', elevation = 'r_elevation_crop',
+                                            slope = r_slope,
+                                            aspect = r_aspect,
+                                            overwrite = True)
-    # Basin mask (vector)
-    grass.run_command('r.to.vect', input = r_basin , output = v_basin , feature = 'area' )
-    grass.run_command('v.to.db', map = v_basin , type = 'line,boundary' , layer = 1, qlayer = 1, option = 'perimeter' , units = 'kilometers', columns = 'cat', qcolumn = 'cat')
+        # Basin mask (vector)
+        grass.run_command('r.to.vect', input = r_basin,
+                                       output = v_basin,
+                                       feature = 'area',
+                                       overwrite = True)
+        grass.run_command('v.to.db', map = v_basin,
+                                 type = 'line,boundary',
+                                 layer = 1,
+                                 qlayer = 1,
+                                 option = 'perimeter',
+                                 units = 'kilometers',
+                                 columns = 'cat',
+                                 qcolumn = 'cat',
+                                 overwrite = True)
-    # Creation of order maps: strahler, horton, hack, shreeve
-    grass.message( "Creating %s" % r_hack )
-    grass.run_command('r.stream.order', stream = r_stream_e , dir = r_drainage_e , strahler = r_strahler , shreve = r_shreve , horton = r_horton , hack = r_hack )
+        # Creation of order maps: strahler, horton, hack, shreeve
+        grass.message( "Creating %s" % r_hack )
+        grass.run_command('r.stream.order', stream = r_stream_e,
+                                        dir = r_drainage_e,
+                                        strahler = r_strahler,
+                                        shreve = r_shreve,
+                                        horton = r_horton,
+                                        hack = r_hack,
+                                        overwrite = True)
-    # Distance to outlet
-    grass.write_command('v.in.ascii', output = v_outlet, stdin = "%s|%s|9999"  % (east, north) )
-    grass.run_command('v.to.rast', input = v_outlet, output = r_outlet , use = 'cat' , type = 'point,line,area' , layer = 1 , value = 1 , rows = 4096)
-    grass.run_command('r.stream.distance', stream = r_outlet , dir = r_drainage , flags = 'o' , distance = r_distance )
+        # Distance to outlet
+        grass.write_command('v.in.ascii', output = v_outlet,
+                                      stdin = "%s|%s|9999"  % (east, north),
+                                      overwrite = True)
+        grass.run_command('v.to.rast', input = v_outlet,
+                                   output = r_outlet,
+                                   use = 'cat',
+                                   type = 'point',
+                                   layer = 1,
+                                   value = 1,
+                                   rows = 4096,
+                                   overwrite = True)
+        grass.run_command('r.stream.distance', stream = r_outlet,
+                                           dir = r_drainage,
+                                           flags = 'o',
+                                           distance = r_distance,
+                                           overwrite = True)
-    # Width Function
-    grass.run_command('r.wf.py', map = r_distance, image = prefix)
+        # Width Function
+        grass.run_command('r.wf.py', map = r_distance,
+                                 image = prefix)
-    # Ipsographic curve
-    grass.run_command('r.ipso.py', map = r_elevation+'_crop', image = prefix, flags = 'ab')
+        # Ipsographic curve
+        grass.run_command('r.ipso.py', map = 'r_elevation_crop',
+                                   image = prefix,
+                                   flags = 'ab')
-    # Creation of map of hillslope distance to river network
-    grass.run_command('r.stream.distance', stream = r_stream+'_nothin' , dir = r_drainage , dem = r_elevation+'_crop' , distance = r_hillslope_distance )
+        # Creation of map of hillslope distance to river network
+        grass.run_command('r.stream.distance', stream = r_stream_e,
+                                           dir = r_drainage,
+                                           dem = 'r_elevation_crop' ,
+                                           distance = r_hillslope_distance,
+                                           overwrite = True)
-    # Mean elevation
-    grass.run_command('r.average' , base = r_basin , cover = r_elevation+'_crop' , output = r_height_average)
-    mean_elev = float(grass.read_command('r.info' , flags = 'r' , map = r_height_average).split('\n')[0].split('=')[1])
+        # Mean elevation
+        grass.run_command('r.average' , base = r_basin,
+                                    cover = 'r_elevation_crop',
+                                    output = r_height_average,
+                                    overwrite = True)
+        mean_elev = float(grass.read_command('r.info', flags = 'r',
+                                                   map = r_height_average).split('\n')[0].split('=')[1])
-    # In Grass the aspect categories represent the number degrees of east and they increase counterclockwise:
-    # 90deg is North, 180 is West, 270 is South 360 is East. The aspect value 0 is used to indicate undefined aspect in flat areas with slope=0.
-    # We calculate the number of degree from north, increasing counterclockwise.
-    grass.run_command('r.mapcalculator', amap = r_aspect , formula = 'if(%s>90,450-%s,90-%s)' % (r_aspect, r_aspect, r_aspect) , outfile = r_aspect_mod)
+        # In Grass, aspect categories represent the number degrees of east and they increase
+        # counterclockwise: 90deg is North, 180 is West, 270 is South 360 is East.
+        # The aspect value 0 is used to indicate undefined aspect in flat areas with slope=0.
+        # We calculate the number of degree from north, increasing counterclockwise.
+        grass.mapcalc("$r_aspect_mod = if($r_aspect > 90, 450 - $r_aspect, 90 - $r_aspect)",
+                  r_aspect = r_aspect,
+                  r_aspect_mod = r_aspect_mod)
-    # Centroid and mean slope
-    baricenter_slope_baricenter = grass.read_command('r.volume', data = r_slope ,clump = r_basin , centroids = v_centroid1)
-    baricenter_slope_baricenter = baricenter_slope_baricenter.split()
-    mean_slope = baricenter_slope_baricenter[28]
-    baricenter_aspect_baricenter = grass.read_command('r.volume', data = r_aspect ,clump = r_basin )
-    baricenter_aspect_baricenter = baricenter_aspect_baricenter.split()
-    basin_average_aspect = baricenter_aspect_baricenter[28]
+        # Centroid and mean slope
+        baricenter_slope_baricenter = grass.read_command('r.volume', data = r_slope,
+        clump = r_basin,
+        centroids = v_centroid1,
+        overwrite = True)
+        baricenter_slope_baricenter = baricenter_slope_baricenter.split()
+        mean_slope = baricenter_slope_baricenter[28]
+        baricenter_aspect_baricenter = grass.read_command('r.volume', data = r_aspect,
+        clump = r_basin )
+        baricenter_aspect_baricenter = baricenter_aspect_baricenter.split()
+        basin_average_aspect = baricenter_aspect_baricenter[28]
-    # Rectangle containing basin
-    basin_east = baricenter_slope_baricenter[31]
-    basin_north = baricenter_slope_baricenter[32]
-    info_region_basin = grass.read_command('g.region', vect = options['prefix']+'_'+mapname[0]+'_basin' ,flags = 'm')
-    dict_region_basin = dict(x.split('=', 1) for x in info_region_basin.split('\n') if '=' in x)
-    basin_resolution = float(dict_region_basin['nsres'])
-    x_massimo = float(dict_region_basin['n']) + (basin_resolution * 10)
-    x_minimo = float(dict_region_basin['w']) - (basin_resolution * 10)
-    y_massimo = float(dict_region_basin['e']) + (basin_resolution * 10)
-    y_minimo = float(dict_region_basin['s']) - (basin_resolution * 10)
-    nw = dict_region_basin['w'] , dict_region_basin['n']
-    se = dict_region_basin['e'] , dict_region_basin['s']
+        # Rectangle containing basin
+        basin_east = baricenter_slope_baricenter[31]
+        basin_north = baricenter_slope_baricenter[32]
+        info_region_basin = grass.read_command('g.region',
+                                            vect = options['prefix']+'_'+mapname[0]+'_basin',
+                                            flags = 'm')
+        dict_region_basin = dict(x.split('=', 1) for x in info_region_basin.split('\n') if '=' in x)
+        basin_resolution = float(dict_region_basin['nsres'])
+        x_massimo = float(dict_region_basin['n']) + (basin_resolution * 10)
+        x_minimo = float(dict_region_basin['w']) - (basin_resolution * 10)
+        y_massimo = float(dict_region_basin['e']) + (basin_resolution * 10)
+        y_minimo = float(dict_region_basin['s']) - (basin_resolution * 10)
+        nw = dict_region_basin['w'], dict_region_basin['n']
+        se = dict_region_basin['e'], dict_region_basin['s']
-    # Area and perimeter of basin
-    report_basin = grass.read_command('v.report', map = v_basin , layer = 1 , option = 'area' , units = 'kilometers')
-    report_basin = report_basin.replace('\n',' ')
-    report_basin = report_basin.split()
-    area_basin = float(report_basin[1].split('|')[3])
-    report_basin = grass.read_command('v.report', map = v_basin , layer = 1 , option = 'length' , units = 'meters')
-    perimeter_basin = float(report_basin.split('\n')[1].split('|')[0])
+        # Area and perimeter of basin
+        report_basin = grass.read_command('v.report', map = v_basin,
+                                                  layer = 1,
+                                                  option = 'area',
+                                                  units = 'kilometers')
+        report_basin = report_basin.replace('\n',' ')
+        report_basin = report_basin.split()
+        area_basin = float(report_basin[1].split('|')[3])
+                                                  layer = 1,
+                                                  option = 'length',
+                                                  units = 'meters')
+        perimeter_basin = float(report_basin.split('\n')[1].split('|')[0])
-    # Directing vector
-    delta_x = abs(float(basin_east) - east)
-    delta_y = abs(float(basin_north) - north)
-    L_orienting_vect = math.sqrt((delta_x**2)+(delta_y**2)) / 1000
+        # Directing vector
+        delta_x = abs(float(basin_east) - east)
+        delta_y = abs(float(basin_north) - north)
+        L_orienting_vect = math.sqrt((delta_x**2)+(delta_y**2)) / 1000
-    # Prevalent orientation
-    prevalent_orientation = math.atan(delta_y/delta_x)
+        # Prevalent orientation
+        prevalent_orientation = math.atan(delta_y/delta_x)
-    # Compactness coefficient
-    C_comp = perimeter_basin / ( 2 * math.sqrt( area_basin / math.pi))
+        # Compactness coefficient
+        C_comp = perimeter_basin / ( 2 * math.sqrt( area_basin / math.pi))
-    # Circularity ratio
-    R_c = ( 4 * math.pi * area_basin ) / (perimeter_basin **2)
+        # Circularity ratio
+        R_c = ( 4 * math.pi * area_basin ) / (perimeter_basin **2)
-    # Mainchannel
-    grass.run_command('r.mapcalculator', amap = r_hack , formula = 'if(%s==1,1,null())' % (r_hack) , outfile = r_mainchannel)
-    grass.run_command('r.thin', input = r_mainchannel , output = r_mainchannel+'_thin' )
-    grass.run_command('r.to.vect', input = r_mainchannel+'_thin' , output = v_mainchannel , feature = 'line' , flags = 'v')
-    param_mainchannel = grass.read_command('v.what', map = v_mainchannel , east_north = '%s,%s' % (east,north) )
-    dict_mainchannel = dict(x.split(':', 1) for x in param_mainchannel.split('\n')if ':' in x)
-    mainchannel = float(dict_mainchannel['Length']) / 1000
+        # Mainchannel
+        grass.mapcalc("$r_mainchannel = if($r_hack==1,1,null())",
+                  r_hack = r_hack,
+                  r_mainchannel = r_mainchannel)
+        grass.run_command('r.thin', input = r_mainchannel,
+                                output = r_mainchannel+'_thin',
+                                overwrite = True)
+        grass.run_command('r.to.vect', input = r_mainchannel+'_thin',
+                                   output = v_mainchannel,
+                                   feature = 'line',
+                                   flags = 'v',
+                                   overwrite = True)
+        param_mainchannel = grass.read_command('v.what', map = v_mainchannel,
+                                                     east_north = '%s,%s' % (east,north) )
+        dict_mainchannel = dict(x.split(':', 1) for x in param_mainchannel.split('\n')if ':' in x)
+        mainchannel = float(dict_mainchannel['Length']) / 1000
-    # Topological Diameter
-    grass.run_command('r.mapcalculator', amap = r_shreve , formula = '-(%s - %s)' % (r_mainchannel,r_shreve) , outfile = r_mainchannel_dim)
-    grass.run_command('r.thin', input = r_mainchannel_dim , output = r_mainchannel_dim+'_thin' )
-    grass.run_command('r.to.vect', input = r_mainchannel_dim+'_thin' , output = v_mainchannel_dim , feature = 'line' , flags = 'v')
-    try:
-        D_topo = float(grass.read_command('v.info', map = v_mainchannel_dim, layer = 1, flags = 't').split('\n')[2].split('=')[1])
-    except:
-        D_topo = 1
-        grass.message( "Topological Diameter = WARNING" )
+        # Topological Diameter
+        #grass.run_command('r.mapcalculator', amap = r_shreve , formula = '-(%s - %s)' % (r_mainchannel, r_shreve) , outfile = r_mainchannel_dim)
+        grass.mapcalc("$r_mainchannel_dim = -($r_mainchannel - $r_shreve) + 1",
+                  r_mainchannel_dim = r_mainchannel_dim,
+                  r_shreve = r_shreve,
+        grass.run_command('r.thin', input = r_mainchannel_dim,
+                                output = r_mainchannel_dim + '_thin',
+                                overwrite = True)
+        grass.run_command('r.to.vect', input = r_mainchannel_dim + '_thin',
+                                   output = v_mainchannel_dim,
+                                   feature = 'line',
+                                   flags = 'v',
+                                   overwrite = True)
+        try:
+            D_topo1 = grass.read_command('v.info', map = v_mainchannel_dim,
+                                               layer = 1,
+                                               flags = 't')
+            D_topo = float(D_topo1.split('\n')[2].split('=')[1])
+        except:
+            D_topo = 1
+            grass.message( "Topological Diameter = WARNING" )
-    # Mean slope of mainchannel
-    grass.run_command('v.to.points', flags='n', input = v_mainchannel_dim, output = v_mainchannel_dim+'_point', type = 'line')
-    vertex = grass.read_command('v.out.ascii', verbose = True , input = v_mainchannel_dim+'_point').strip().split('\n')
-    nodi = zeros((len(vertex),4),float)
-    pendenze = []
-    for i in range(len(vertex)):
-        x, y = float(vertex[i].split('|')[0]) , float(vertex[i].split('|')[1])
-        vertice = grass.read_command('r.what', verbose = True , input = r_elevation+'_crop', east_north='%s,%s' % (x,y)).replace('\n','').replace('||','|').split('|')
-        nodi[i,0],nodi[i,1], nodi[i,2] = float(vertice[0]), float(vertice[1]), float(vertice[2])
-    for i in range(0,len(vertex)-1,2):
-        dist = math.sqrt(math.fabs((nodi[i,0] - nodi[i+1,0]))**2 + math.fabs((nodi[i,1] - nodi[i+1,1]))**2)
-        deltaz = math.fabs(nodi[i,2]-nodi[i+1,2])
-        # Control to prevent float division by zero (dist=0)
-        try:
-            pendenza = deltaz / dist
-            pendenze.append(pendenza)
-            mainchannel_slope = sum(pendenze) / len(pendenze) * 100
-        except :
-            grass.message( "Mean slope of mainchannel = WARNING" )
+        # Mean slope of mainchannel
+        grass.run_command('v.to.points', flags='n',
+                                     input = v_mainchannel_dim,
+                                     output = v_mainchannel_dim+'_point',
+                                     type = 'line',
+                                     overwrite = True)
+        vertex = grass.read_command('v.out.ascii', verbose = True,
+                                               input = v_mainchannel_dim+'_point').strip().split('\n')
+        nodi = zeros((len(vertex),4),float)
+        pendenze = []
+        for i in range(len(vertex)):
+            x, y = float(vertex[i].split('|')[0]) , float(vertex[i].split('|')[1])
+            vertice1 = grass.read_command('r.what', verbose = True,
+                                               input = 'r_elevation_crop',
+                                               east_north='%s,%s' % (x,y))
+            vertice = vertice1.replace('\n','').replace('||','|').split('|')
+            nodi[i,0],nodi[i,1], nodi[i,2] = float(vertice[0]), float(vertice[1]), float(vertice[2])
+        for i in range(0,len(vertex)-1,2):
+            dist = math.sqrt(math.fabs((nodi[i,0] - nodi[i+1,0]))**2 + math.fabs((nodi[i,1] - nodi[i+1,1]))**2)
+            deltaz = math.fabs(nodi[i,2] - nodi[i+1,2])
+            # Control to prevent float division by zero (dist=0)
+            try:
+                pendenza = deltaz / dist
+                pendenze.append(pendenza)
+                mainchannel_slope = sum(pendenze) / len(pendenze) * 100
+            except :
+	    	    pass
+                #grass.message( "Mean slope of mainchannel = WARNING" )
-    # Elongation Ratio
-    R_al = (2 * math.sqrt( area_basin / math.pi) ) / mainchannel
+        # Elongation Ratio
+        R_al = (2 * math.sqrt( area_basin / math.pi) ) / mainchannel
-    # Shape factor
-    S_f = area_basin / mainchannel
+        # Shape factor
+        S_f = area_basin / mainchannel
-    # Characteristic altitudes
-    height_basin_average = grass.read_command('r.what' , input = r_height_average , cache = 500 , east_north = '%s,%s' % (east , north ))
-    height_basin_average = height_basin_average.replace('\n','')
-    height_basin_average = float(height_basin_average.split('|')[-1])
-    minmax_height_basin = grass.read_command('r.info' , flags = 'r' , map = r_elevation+'_crop')
-    minmax_height_basin = minmax_height_basin.strip().split('\n')
-    min_height_basin , max_height_basin = float(minmax_height_basin[0].split('=')[-1]) , float(minmax_height_basin[1].split('=')[-1])
-    H1 = max_height_basin
-    H2 = min_height_basin
-    HM = H1 - H2
+        # Characteristic altitudes
+        height_basin_average = grass.read_command('r.what', input = r_height_average ,
+                                                        cache = 500 ,
+                                                        east_north = '%s,%s' % (east , north ))
+        height_basin_average = height_basin_average.replace('\n','')
+        height_basin_average = float(height_basin_average.split('|')[-1])
+        minmax_height_basin = grass.read_command('r.info', flags = 'r',
+                                                       map = 'r_elevation_crop')
+        minmax_height_basin = minmax_height_basin.strip().split('\n')
+        min_height_basin, max_height_basin = float(minmax_height_basin[0].split('=')[-1]), float(minmax_height_basin[1].split('=')[-1])
+        H1 = max_height_basin
+        H2 = min_height_basin
+        HM = H1 - H2
-    # Concentration time (Giandotti, 1934)
-    t_c = ((4 * math.sqrt(area_basin)) + (1.5 * mainchannel)) / (0.8 * math.sqrt(HM))
+        # Concentration time (Giandotti, 1934)
+        t_c = ((4 * math.sqrt(area_basin)) + (1.5 * mainchannel)) / (0.8 * math.sqrt(HM))
-    # Mean hillslope length
-    grass.run_command('r.average', cover = r_stream_e, base = r_mask, output = r_average_hillslope)
-    mean_hillslope_length = float(grass.read_command('r.info' , flags = 'r' , map = r_average_hillslope).split('\n')[0].split('=')[1])
+        # Mean hillslope length
+        grass.run_command('r.average', cover = r_stream_e,
+                                   base = r_mask,
+                                   output = r_average_hillslope,
+                                   overwrite = True)
+        mean_hillslope_length = float(grass.read_command('r.info', flags = 'r',
+                                                               map = r_average_hillslope).split('\n')[0].split('=')[1])
-    # Magnitudo
-    grass.run_command('r.mapcalculator', amap = r_strahler , formula = 'if(%s==1,1,null())' % (r_strahler) , outfile = r_ord_1)
-    grass.run_command('r.thin', input = r_ord_1 , output = r_ord_1+'_thin', iterations = 200 )
-    grass.run_command('r.to.vect', input = r_ord_1+'_thin' , output = v_ord_1 , feature = 'line', flags = 'v' )
-    magnitudo = float(grass.read_command('v.info', map = v_ord_1, layer = 1, flags = 't').split('\n')[2].split('=')[1])
+        # Magnitudo
+        grass.run_command('r.mapcalculator', amap = r_strahler , formula = 'if(%s==1,1,null())' % (r_strahler) , outfile = r_ord_1)
+        grass.mapcalc("$r_ord_1 = if($r_strahler==1,1,null())",
+                  r_ord_1 = r_ord_1,
+                  r_strahler = r_strahler)
+        grass.run_command('r.thin', input = r_ord_1,
+                                output = r_ord_1+'_thin',
+                                iterations = 200,
+                                overwrite = True)
+        grass.run_command('r.to.vect', input = r_ord_1+'_thin',
+                                   output = v_ord_1,
+                                   feature = 'line',
+                                   flags = 'v',
+                                   overwrite = True)
+        magnitudo = float(grass.read_command('v.info', map = v_ord_1,
+                                                   layer = 1,
+                                                   flags = 't').split('\n')[2].split('=')[1])
-    # First order stream frequency
-    FSF = magnitudo/area_basin
+        # First order stream frequency
+        FSF = magnitudo / area_basin
-    # Statistics
-    stream_stats = grass.read_command('r.stream.stats', stream = r_strahler, dir = r_drainage_e, dem = r_elevation+'_crop' )
-    grass.message( "output r.stream.stats %s" % stream_stats )
-    stream_stats_summary = stream_stats.split('\n')[4].split('|')
-    stream_stats_mom = stream_stats.split('\n')[8].split('|')
-    Max_order , Num_streams , Len_streams , Stream_freq = stream_stats_summary[0] , stream_stats_summary[1] , stream_stats_summary[2] , stream_stats_summary[5]
-    Bif_ratio , Len_ratio , Area_ratio , Slope_ratio = stream_stats_mom[0] , stream_stats_mom[1] , stream_stats_mom[2] , stream_stats_mom[3]
-    drainage_density = float(Len_streams) / float(area_basin)
+        # Statistics
+        stream_stats = grass.read_command('r.stream.stats', stream = r_strahler,
+                                                        dem = 'r_elevation_crop' )
+        grass.message( "output r.stream.stats %s" % stream_stats )
+        stream_stats_summary = stream_stats.split('\n')[4].split('|')
+        stream_stats_mom = stream_stats.split('\n')[8].split('|')
+        Max_order , Num_streams , Len_streams , Stream_freq = stream_stats_summary[0] , stream_stats_summary[1] , stream_stats_summary[2] , stream_stats_summary[5]
+        Bif_ratio , Len_ratio , Area_ratio , Slope_ratio = stream_stats_mom[0] , stream_stats_mom[1] , stream_stats_mom[2] , stream_stats_mom[3]
+        drainage_density = float(Len_streams) / float(area_basin)
-    # Cleaning up
-    grass.run_command('g.remove', rast = r_height_average)
-    grass.run_command('g.remove', rast = r_aspect_mod)
-    grass.run_command('g.remove', rast = r_mainchannel)
-    grass.run_command('g.remove', rast = r_stream_e)
-    grass.run_command('g.remove', rast = r_drainage_e)
-    grass.run_command('g.remove', rast = r_mask)
-    grass.run_command('g.remove', rast = r_ord_1)
-    grass.run_command('g.remove', rast = r_average_hillslope)
-    grass.run_command('g.remove', rast = r_mainchannel_dim)
-    grass.run_command('g.remove', rast = r_outlet)
-    grass.run_command('g.remove', rast = r_basin)
-    grass.run_command('g.remove', rast = prefix+'_mainchannel_thin')
-    grass.run_command('g.remove', rast = prefix+'_mainchannel_dim_thin')
-    grass.run_command('g.remove', rast = prefix+'_ord_1_thin')
-    grass.run_command('g.remove', rast = prefix+'_stream_nothin')
-    grass.run_command('g.remove', rast = prefix+'_stream_e_thin')
-    grass.run_command('g.remove', vect = v_mainchannel_dim+'_point')
-    grass.run_command('g.remove', vect = v_centroid1)
-    grass.run_command('g.remove', vect = v_mainchannel_dim)
-    grass.run_command('g.remove', vect = v_ord_1)
+        # Cleaning up
+        grass.run_command('g.remove', rast = 'r_elevation_crop')
+        grass.run_command('g.remove', rast = r_height_average)
+        grass.run_command('g.remove', rast = r_aspect_mod)
+        grass.run_command('g.remove', rast = r_mainchannel)
+        grass.run_command('g.remove', rast = r_stream_e)
+        grass.run_command('g.remove', rast = r_drainage_e)
+        grass.run_command('g.remove', rast = r_mask)
+        grass.run_command('g.remove', rast = r_ord_1)
+        grass.run_command('g.remove', rast = r_average_hillslope)
+        grass.run_command('g.remove', rast = r_mainchannel_dim)
+        grass.run_command('g.remove', rast = r_outlet)
+        grass.run_command('g.remove', rast = r_basin)
+        grass.run_command('g.remove', rast = prefix+'_mainchannel_thin')
+        grass.run_command('g.remove', rast = prefix+'_mainchannel_dim_thin')
+        grass.run_command('g.remove', rast = prefix+'_ord_1_thin')
+        grass.run_command('g.remove', rast = prefix+'_stream_e_thin')
+        grass.run_command('g.remove', vect = v_mainchannel_dim+'_point')
+        grass.run_command('g.remove', vect = v_centroid1)
+        grass.run_command('g.remove', vect = v_mainchannel_dim)
+        grass.run_command('g.remove', vect = v_ord_1)
-    if nomap :
-        grass.run_command('g.remove', vect = v_outlet)
-        grass.run_command('g.remove', vect = v_basin)
-        grass.run_command('g.remove', vect = v_mainchannel)
-        grass.run_command('g.remove', vect = v_stream_e)
-        grass.run_command('g.remove', rast = r_accumulation)
-        grass.run_command('g.remove', rast = r_drainage)
-        grass.run_command('g.remove', rast = r_aspect)
-        grass.run_command('g.remove', rast = r_strahler)
-        grass.run_command('g.remove', rast = r_shreve)
-        grass.run_command('g.remove', rast = r_horton)
-        grass.run_command('g.remove', rast = r_hack)
-        grass.run_command('g.remove', rast = r_distance)
-        grass.run_command('g.remove', rast = r_hillslope_distance)
-        grass.run_command('g.remove', rast = r_slope)
+        if nomap :
+            grass.run_command('g.remove', vect = v_outlet)
+            grass.run_command('g.remove', vect = v_basin)
+            grass.run_command('g.remove', vect = v_mainchannel)
+            grass.run_command('g.remove', rast = r_accumulation)
+            grass.run_command('g.remove', rast = r_drainage)
+            grass.run_command('g.remove', rast = r_aspect)
+            grass.run_command('g.remove', rast = r_strahler)
+            grass.run_command('g.remove', rast = r_shreve)
+            grass.run_command('g.remove', rast = r_horton)
+            grass.run_command('g.remove', rast = r_hack)
+            grass.run_command('g.remove', rast = r_distance)
+            grass.run_command('g.remove', rast = r_hillslope_distance)
+            grass.run_command('g.remove', rast = r_slope)
-    parametri_bacino = {}
-    parametri_bacino["mean_slope"] = float(mean_slope)
-    parametri_bacino["mean_elev"] = float(mean_elev)
-    parametri_bacino["basin_average_aspect"] = float(basin_average_aspect)
-    parametri_bacino["basin_east"] = float(basin_east)
-    parametri_bacino["basin_north"] = float(basin_north)
-    parametri_bacino["basin_resolution"] = float(basin_resolution)
-    parametri_bacino["nw"] = nw
-    parametri_bacino["se"] = se
-    parametri_bacino["area_basin"] = float(area_basin)
-    parametri_bacino["perimeter_basin"] = float(perimeter_basin)
-    parametri_bacino["L_orienting_vect"] = float(L_orienting_vect)
-    parametri_bacino["prevalent_orientation"] = float(prevalent_orientation)
-    parametri_bacino["C_comp"] = float(C_comp)
-    parametri_bacino["R_c"] = float(R_c)
-    parametri_bacino["mainchannel"] = float(mainchannel)
-    parametri_bacino["D_topo"] = float(D_topo)
-    parametri_bacino["mainchannel_slope" ] = float(mainchannel_slope)
-    parametri_bacino["R_al"] = float(R_al)
-    parametri_bacino["S_f"] = float(S_f)
-    parametri_bacino["H1"] = float(H1)
-    parametri_bacino["H2"] = float(H2)
-    parametri_bacino["HM"] = float(HM)
-    parametri_bacino["t_c"] = float(t_c)
-    parametri_bacino["mean_hillslope_length"] = float(mean_hillslope_length)
-    parametri_bacino["magnitudo"] = float(magnitudo)
-    parametri_bacino["Max_order"] = float(Max_order)
-    parametri_bacino["Num_streams"] = float(Num_streams)
-    parametri_bacino["Len_streams"] = float(Len_streams)
-    parametri_bacino["Stream_freq"] = float(Stream_freq)
-    parametri_bacino["Bif_ratio"] = float(Bif_ratio)
-    parametri_bacino["Len_ratio"] = float(Len_ratio)
-    parametri_bacino["Area_ratio"] = float(Area_ratio)
-    parametri_bacino["Slope_ratio"] = float(Slope_ratio)
-    parametri_bacino["drainage_density"] = float(drainage_density)
-    parametri_bacino["FSF"] = float(FSF)
-    grass.message( "\n" )
-    grass.message( "##################################" )
-    grass.message( "Morphometric parameters of basin :" )
-    grass.message( "##################################\n" )
-    grass.message( "Easting Centroid of basin : %s " % basin_east )
-    grass.message( "Northing Centroid of Basin : %s " % basin_north )
-    grass.message( "Rectangle containing basin N-W : %s , %s " % nw )
-    grass.message( "Rectangle containing basin S-E : %s , %s " % se )
-    grass.message( "Area of basin [km^2] : %s " % area_basin )
-    grass.message( "Perimeter of basin [km] : %s " % perimeter_basin )
-    grass.message( "Max Elevation [m s.l.m.] : %s " % H1 )
-    grass.message( "Min Elevation [m s.l.m.]: %s " % H2 )
-    grass.message( "Elevation Difference [m]: %s " % HM )
-    grass.message( "Mean Elevation [m s.l.m.]: %s " % mean_elev )
-    grass.message( "Mean Slope : %s " % mean_slope )
-    grass.message( "Length of Directing Vector [km] : %s " % L_orienting_vect )
-    grass.message( "Prevalent Orientation [degree from north, counterclockwise] : %s " % prevalent_orientation )
-    grass.message( "Compactness Coefficient : %s " % C_comp )
-    grass.message( "Circularity Ratio : %s " % R_c )
-    grass.message( "Topological Diameter : %s " % D_topo )
-    grass.message( "Elongation Ratio : %s " % R_al )
-    grass.message( "Shape Factor : %s " % S_f )
-    grass.message( "Concentration Time (Giandotti, 1934) [hr] : %s " % t_c )
-    grass.message( "Length of Mainchannel [km] : %s " % mainchannel )
-    grass.message( "Mean slope of mainchannel [percent] : %f " % mainchannel_slope )
-    grass.message( "Mean hillslope length [m] : %s " % mean_hillslope_length )
-    grass.message( "Magnitudo : %s " % magnitudo )
-    grass.message( "Max order (Strahler) : %s " % Max_order )
-    grass.message( "Number of streams : %s " % Num_streams )
-    grass.message( "Total Stream Length [km] : %s " % Len_streams )
-    grass.message( "First order stream frequency : %s " % FSF )
-    grass.message( "Drainage Density [km/km^2] : %s " % drainage_density )
-    grass.message( "Bifurcation Ratio (Horton) : %s " % Bif_ratio )
-    grass.message( "Length Ratio (Horton) : %s " % Len_ratio )
-    grass.message( "Area ratio (Horton) : %s " % Area_ratio )
-    grass.message( "Slope ratio (Horton): %s " % Slope_ratio )
-    grass.message( "Done!")
+        parametri_bacino = {}
+        parametri_bacino["mean_slope"] = float(mean_slope)
+        parametri_bacino["mean_elev"] = float(mean_elev)
+        parametri_bacino["basin_average_aspect"] = float(basin_average_aspect)
+        parametri_bacino["basin_east"] = float(basin_east)
+        parametri_bacino["basin_north"] = float(basin_north)
+        parametri_bacino["basin_resolution"] = float(basin_resolution)
+        parametri_bacino["nw"] = nw
+        parametri_bacino["se"] = se
+        parametri_bacino["area_basin"] = float(area_basin)
+        parametri_bacino["perimeter_basin"] = float(perimeter_basin)
+        parametri_bacino["L_orienting_vect"] = float(L_orienting_vect)
+        parametri_bacino["prevalent_orientation"] = float(prevalent_orientation)
+        parametri_bacino["C_comp"] = float(C_comp)
+        parametri_bacino["R_c"] = float(R_c)
+        parametri_bacino["mainchannel"] = float(mainchannel)
+        parametri_bacino["D_topo"] = float(D_topo)
+        parametri_bacino["mainchannel_slope" ] = float(mainchannel_slope)
+        parametri_bacino["R_al"] = float(R_al)
+        parametri_bacino["S_f"] = float(S_f)
+        parametri_bacino["H1"] = float(H1)
+        parametri_bacino["H2"] = float(H2)
+        parametri_bacino["HM"] = float(HM)
+        parametri_bacino["t_c"] = float(t_c)
+        parametri_bacino["mean_hillslope_length"] = float(mean_hillslope_length)
+        parametri_bacino["magnitudo"] = float(magnitudo)
+        parametri_bacino["Max_order"] = float(Max_order)
+        parametri_bacino["Num_streams"] = float(Num_streams)
+        parametri_bacino["Len_streams"] = float(Len_streams)
+        parametri_bacino["Stream_freq"] = float(Stream_freq)
+        parametri_bacino["Bif_ratio"] = float(Bif_ratio)
+        parametri_bacino["Len_ratio"] = float(Len_ratio)
+        parametri_bacino["Area_ratio"] = float(Area_ratio)
+        parametri_bacino["Slope_ratio"] = float(Slope_ratio)
+        parametri_bacino["drainage_density"] = float(drainage_density)
+        parametri_bacino["FSF"] = float(FSF)
+        grass.message( "\n" )
+        grass.message( "##################################" )
+        grass.message( "Morphometric parameters of basin :" )
+        grass.message( "##################################\n" )
+        grass.message( "Easting Centroid of basin : %s " % basin_east )
+        grass.message( "Northing Centroid of Basin : %s " % basin_north )
+        grass.message( "Rectangle containing basin N-W : %s , %s " % nw )
+        grass.message( "Rectangle containing basin S-E : %s , %s " % se )
+        grass.message( "Area of basin [km^2] : %s " % area_basin )
+        grass.message( "Perimeter of basin [km] : %s " % perimeter_basin )
+        grass.message( "Max Elevation [m s.l.m.] : %s " % H1 )
+        grass.message( "Min Elevation [m s.l.m.]: %s " % H2 )
+        grass.message( "Elevation Difference [m]: %s " % HM )
+        grass.message( "Mean Elevation [m s.l.m.]: %s " % mean_elev )
+        grass.message( "Mean Slope : %s " % mean_slope )
+        grass.message( "Length of Directing Vector [km] : %s " % L_orienting_vect )
+        grass.message( "Prevalent Orientation [degree from north, counterclockwise] : %s " % prevalent_orientation )
+        grass.message( "Compactness Coefficient : %s " % C_comp )
+        grass.message( "Circularity Ratio : %s " % R_c )
+        grass.message( "Topological Diameter : %s " % D_topo )
+        grass.message( "Elongation Ratio : %s " % R_al )
+        grass.message( "Shape Factor : %s " % S_f )
+        grass.message( "Concentration Time (Giandotti, 1934) [hr] : %s " % t_c )
+        grass.message( "Length of Mainchannel [km] : %s " % mainchannel )
+        grass.message( "Mean slope of mainchannel [percent] : %f " % mainchannel_slope )
+        grass.message( "Mean hillslope length [m] : %s " % mean_hillslope_length )
+        grass.message( "Magnitudo : %s " % magnitudo )
+        grass.message( "Max order (Strahler) : %s " % Max_order )
+        grass.message( "Number of streams : %s " % Num_streams )
+        grass.message( "Total Stream Length [km] : %s " % Len_streams )
+        grass.message( "First order stream frequency : %s " % FSF )
+        grass.message( "Drainage Density [km/km^2] : %s " % drainage_density )
+        grass.message( "Bifurcation Ratio (Horton) : %s " % Bif_ratio )
+        grass.message( "Length Ratio (Horton) : %s " % Len_ratio )
+        grass.message( "Area ratio (Horton) : %s " % Area_ratio )
+        grass.message( "Slope ratio (Horton): %s " % Slope_ratio )
+        grass.message( "Done!")
+    except:
+	    grass.message( "ERROR" )
+	    grass.message( "Outlet coordinates must belong to the river network!" )
+	    grass.message( "Please run r.stream.extract and choose coordinates matching with the extracted stream map" )
+    # Set region to original
+    grass.read_command('g.region', flags = 'p', region = 'original')
 if __name__ == "__main__":
     options, flags = grass.parser()
