[GRASS-SVN] r45306 - grass/trunk/ps/ps.map
svn_grass at osgeo.org
Fri Feb 4 03:48:43 EST 2011
Author: hamish
Date: 2011-02-04 00:48:43 -0800 (Fri, 04 Feb 2011)
New Revision: 45306
grass/trunk/ps/ps.map/main.c
add -b flag to print map box bounds (#153)
Modified: grass/trunk/ps/ps.map/main.c
--- grass/trunk/ps/ps.map/main.c 2011-02-04 08:38:55 UTC (rev 45305)
+++ grass/trunk/ps/ps.map/main.c 2011-02-04 08:48:43 UTC (rev 45306)
@@ -98,7 +98,7 @@
struct Option *input_file;
struct Option *output_file;
struct Option *copies;
- struct Flag *rflag, *pflag, *eflag;
+ struct Flag *rflag, *pflag, *eflag, *bflag;
struct GModule *module;
static char *def_font = "Helvetica";
@@ -132,6 +132,11 @@
eflag->description =
_("Create EPS (Encapsulated PostScript) instead of PostScript file");
+ eflag = G_define_flag();
+ eflag->key = 'b';
+ eflag->description =
+ _("Print map-box's position on the page and exit (inches from top-left of paper)");
input_file = G_define_option();
input_file->key = "input";
input_file->type = TYPE_STRING;
@@ -716,6 +721,12 @@
/* reset map location base on 'paper' on 'location' */
reset_map_location();
+ if (bflag->answer) {
+ fprintf(stdout, "bbox=%.3f,%.3f,%.3f,%.3f\n", PS.map_left,
+ PS.map_top, PS.map_right, PS.map_bot); /* +/- 0.5 ? see ps.map.c brd.* */
+ exit(EXIT_SUCCESS);
/* write the PostScript output file */
ps_mask_file = G_tempfile();
ps_map();
