[GRASS-SVN] r45308 - grass/trunk/ps/ps.map
Fri Feb 4 04:04:48 EST 2011
Author: hamish
Date: 2011-02-04 01:04:48 -0800 (Fri, 04 Feb 2011)
New Revision: 45308
   grass/trunk/ps/ps.map/main.c
don't start file if just printing bounds
Modified: grass/trunk/ps/ps.map/main.c
--- grass/trunk/ps/ps.map/main.c	2011-02-04 09:00:14 UTC (rev 45307)
+++ grass/trunk/ps/ps.map/main.c	2011-02-04 09:04:48 UTC (rev 45308)
@@ -257,17 +257,19 @@
 	copies_set = 1;
-    if (output_file->answer) {
-	if ((PS.fp = fopen(output_file->answer, "w")) == NULL)
-	    G_fatal_error("%s - %s: %s", G_program_name(),
-			  output_file->answer, strerror(errno));
+    if(!bflag->answer) {
+	if (output_file->answer) {
+	    if ((PS.fp = fopen(output_file->answer, "w")) == NULL)
+		G_fatal_error("%s - %s: %s", G_program_name(),
+			      output_file->answer, strerror(errno));
+	else {
+	    G_message(_("\nERROR: Required parameter <%s> not set:\n    (%s).\n"),
+		      output_file->key, output_file->description);
+	    G_usage();
+	    exit(EXIT_FAILURE);
-    else {
-	G_message(_("\nERROR: Required parameter <%s> not set:\n    (%s).\n"),
-		  output_file->key, output_file->description);
-	G_usage();
-	exit(EXIT_FAILURE);
     /* get current mapset */
     PS.cell_mapset = G_mapset();
