[GRASS-SVN] r45322 - grass/trunk/ps/ps.map
Mon Feb 7 02:19:53 EST 2011
Author: hamish
Date: 2011-02-06 23:19:53 -0800 (Sun, 06 Feb 2011)
New Revision: 45322
   grass/trunk/ps/ps.map/colortable.h
   grass/trunk/ps/ps.map/ps_clrtbl.c
   grass/trunk/ps/ps.map/ps_fclrtbl.c
   grass/trunk/ps/ps.map/r_colortable.c
RGB color for colortables; bugfix for number of columns hangover (merge from devbr6 r45314-8
Modified: grass/trunk/ps/ps.map/colortable.h
--- grass/trunk/ps/ps.map/colortable.h	2011-02-07 07:13:32 UTC (rev 45321)
+++ grass/trunk/ps/ps.map/colortable.h	2011-02-07 07:19:53 UTC (rev 45322)
@@ -4,6 +4,7 @@
 #include <stdio.h>
+#include "clr.h"
 struct colortable
@@ -14,7 +15,7 @@
     char *name;
     const char *mapset;
     int fontsize;
-    int color;
+    PSCOLOR color;
     int cols;
     int nodata;
     int tickbar;
Modified: grass/trunk/ps/ps.map/ps_clrtbl.c
--- grass/trunk/ps/ps.map/ps_clrtbl.c	2011-02-07 07:13:32 UTC (rev 45321)
+++ grass/trunk/ps/ps.map/ps_clrtbl.c	2011-02-07 07:19:53 UTC (rev 45322)
@@ -5,13 +5,17 @@
 #include <grass/raster.h>
 #include <grass/glocale.h>
 #include "ps_info.h"
 #include "colortable.h"
+#include "local_proto.h"
-#define NSTEPS 5		/* number of steps to divide color box when showing color for
-				   category data range */
+#define NSTEPS 5		/* number of steps to divide color box when
+				    showing color for category data range */
+#define FONTFIT_FACT 4.0	/* how agressive to be with shrinking the font size
+				    to get it to fit in the column (normal range: 2-4) */
+#define PRETEXT_MULT 2.0	/* space between box and text (this*fontsize) */
 int PS_colortable(void)
     char *label;
@@ -80,8 +84,8 @@
     r = l + 72.0 * ct.width;
     col_width = ct.width / (double)ct.cols;
-    G_debug(3, "clrtbl: adjusted ct.x=[%.3f]  ct.y=[%.3f]  ct.width=[%.3f]",
-	    ct.x, ct.y, ct.width);
+    G_debug(3, "clrtbl: adjusted ct.x=[%.3f] ct.y=[%.3f] ct.width=[%.3f] "
+	    "col_width=[%.3f]", ct.x, ct.y, ct.width, col_width);
     /* read cats into PostScript array "a" */
     fprintf(PS.fp, "/a [\n");
@@ -107,7 +111,8 @@
     if (ct.cols == 1)
 	tl = 72.0 * col_width - 2.0 * fontsize;
     else
-	tl = 72.0 * col_width - 4.0 * fontsize;
+	tl = 72.0 * col_width - FONTFIT_FACT * fontsize;
+    G_debug(5, "clrtbl: fontsize=%.1f  adjusted tl=%.1f", fontsize, tl);
     fprintf(PS.fp, "/s %.1f def\n", fontsize);
     fprintf(PS.fp, "mw %.1f gt {/s s %.1f mul mw div def } if\n", tl, tl);
     fprintf(PS.fp, "(%s) FN s SF\n", ct.font);
@@ -128,7 +133,7 @@
     k = 0;
     for (i = 0; i <= num_cats;) {
 	if (!i && !ct.nodata)
-	    i++;		/* step over 'no data' */
+	    i++;  /* step over 'no data' */
 	/* test for bottom of page */
 	y -= dy;
@@ -191,10 +196,14 @@
 		if (center_cols)
 		    fprintf(PS.fp, "mvx ");
 		fprintf(PS.fp, "%.1f ", y + fontsize);
-		fprintf(PS.fp, "B F BW stroke\n");
+/* no border	fprintf(PS.fp, "B CF stroke\n"); */
+/* grey border	fprintf(PS.fp, "B F .247 .247 .247 C 1 W stroke\n"); */
+		fprintf(PS.fp, "B F ");
+		set_ps_color(&ct.color);
+		fprintf(PS.fp, "1 W stroke\n");
 	    else
-		/* split the rectangle into NSTEPS horisontal strips and
+		/* split the rectangle into NSTEPS horizontal strips and
 		   draw each with the corresponding value's color */
 		for (jj = 0; jj < NSTEPS; jj++) {
@@ -228,15 +237,17 @@
 		fprintf(PS.fp, "B BW stroke\n");
-	    }			/* done drawing the box */
+	    }	/* done drawing the box */
 	    /* do the text */
-	    fprintf(PS.fp, "a %d get %.1f ", k++, x1 + 2.0 * fontsize);
+	    fprintf(PS.fp, "a %d get %.1f ", k++, x1 + PRETEXT_MULT * fontsize);
 	    if (center_cols)
 	    fprintf(PS.fp, "%.1f MS\n", y);
 	    i++;
-	    if (i >= num_cats)
+	    if (i > num_cats)
 		j = ct.cols + 1;
Modified: grass/trunk/ps/ps.map/ps_fclrtbl.c
--- grass/trunk/ps/ps.map/ps_fclrtbl.c	2011-02-07 07:13:32 UTC (rev 45321)
+++ grass/trunk/ps/ps.map/ps_fclrtbl.c	2011-02-07 07:19:53 UTC (rev 45322)
@@ -153,7 +153,7 @@
     /* Frame around */
     fprintf(PS.fp, "NP\n");
-    set_rgb_color(ct.color);
     fprintf(PS.fp, "%.8f W\n", lwidth);
     fprintf(PS.fp, "%f %f %f %f B\n", x1,
 	    t - (ncols - 1) * cwidth - (cwidth + lwidth) / 2, x2,
Modified: grass/trunk/ps/ps.map/r_colortable.c
--- grass/trunk/ps/ps.map/r_colortable.c	2011-02-07 07:13:32 UTC (rev 45321)
+++ grass/trunk/ps/ps.map/r_colortable.c	2011-02-07 07:19:53 UTC (rev 45322)
@@ -6,8 +6,10 @@
 #include <stdlib.h>
 #include <string.h>
+#include <grass/glocale.h>
+#include "clr.h"
 #define KEY(x) (strcmp(key,x)==0)
@@ -33,14 +35,16 @@
     char buf[1024];
     char *key, *data;
     char name[GNAME_MAX], mapset[GMAPSET_MAX];
-    int color, fontsize, cols, nodata, tickbar, discrete;
+    int fontsize, cols, nodata, tickbar, discrete;
     double w, h, x, y;
     int range_override;
     double min, max, tmpD;
+    int r, g, b, ret;
+    PSCOLOR color;
     fontsize = 0;
-    color = BLACK;
+    set_color(&color, 0, 0, 0);
     cols = 1;
     h = w = x = y = 0.0;
     ct.nodata = TRUE;
@@ -55,7 +59,7 @@
 	if (KEY("where")) {
 	    if (sscanf(data, "%lf %lf", &x, &y) != 2) {
 		x = y = 0.0;
-		error(key, data, "illegal where request");
+		error(key, data, _("illegal where request"));
 	    else
 		continue;
@@ -63,7 +67,7 @@
 	if (KEY("width")) {
 	    if (sscanf(data, "%lf", &w) != 1 || w <= 0) {
-		error(key, data, "illegal width request");
+		error(key, data, _("illegal width request"));
 	    else
 		continue;
@@ -71,7 +75,7 @@
 	if (KEY("height")) {
 	    if (sscanf(data, "%lf", &h) != 1 || h <= 0) {
-		error(key, data, "illegal height request");
+		error(key, data, _("illegal height request"));
 	    else
 		continue;
@@ -88,7 +92,7 @@
 	if (KEY("range")) {
 	    if (sscanf(data, "%lf %lf", &min, &max) != 2) {
 		range_override = FALSE;
-		error(key, data, "illegal range request");
+		error(key, data, _("illegal range request"));
 	    else {
 		range_override = TRUE;
@@ -104,7 +108,7 @@
 	if (KEY("cols")) {
 	    if (sscanf(data, "%d", &cols) != 1) {
 		cols = 1;
-		error(key, data, "illegal columns request");
+		error(key, data, _("illegal columns request"));
 	    else
 		continue;
@@ -118,11 +122,15 @@
 	if (KEY("color")) {
-	    color = get_color_number(data);
-	    if (color < 0) {
-		color = BLACK;
-		error(key, data, "illegal color request");
+	    ret = G_str_to_color(data, &r, &g, &b);
+	    if (ret == 1)
+		set_color(&color, r, g, b);
+	    else if (ret == 2)	/* i.e. "none" */
+		/* unset_color(&color); */
+		error(key, data, _("Unsupported color request (colortable)"));
+	    else
+		error(key, data, _("illegal color request (colortable)"));
 	    continue;
@@ -148,7 +156,7 @@
 	    continue;
-	error(key, data, "illegal colortabe sub-request");
+	error(key, data, _("illegal colortabe sub-request"));
     ct.x = x;
@@ -159,7 +167,7 @@
     /* Check for Raster */
     if (!ct.name) {
 	if (!PS.cell_name) {
-	    error(key, data, "No raster selected for colortable !");
+	    error(key, data, _("No raster selected for colortable!"));
 	else {
 	    ct.name = PS.cell_name;
