[GRASS-SVN] r45335 - grass/trunk/raster/r.out.vtk
Mon Feb 7 18:15:02 EST 2011
Author: huhabla
Date: 2011-02-07 15:15:02 -0800 (Mon, 07 Feb 2011)
New Revision: 45335
   grass/trunk/raster/r.out.vtk/main.c
   grass/trunk/raster/r.out.vtk/parameters.c
Make the input maps obligatory to allow the export of rgb or vector maps
without the specification of an input map.
Modified: grass/trunk/raster/r.out.vtk/main.c
--- grass/trunk/raster/r.out.vtk/main.c	2011-02-07 22:30:09 UTC (rev 45334)
+++ grass/trunk/raster/r.out.vtk/main.c	2011-02-07 23:15:02 UTC (rev 45335)
@@ -67,6 +67,12 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
+   if (param.input->answers == NULL && param.rgbmaps->answers == NULL &&
+        param.vectmaps->answers == NULL) {
+        G_fatal_error(_("No input maps specified. You need to specify at least one input map or three vector maps or three rgb maps."));
     /*open the output */
     if (param.output->answer) {
 	fp = fopen(param.output->answer, "w");
Modified: grass/trunk/raster/r.out.vtk/parameters.c
--- grass/trunk/raster/r.out.vtk/parameters.c	2011-02-07 22:30:09 UTC (rev 45334)
+++ grass/trunk/raster/r.out.vtk/parameters.c	2011-02-07 23:15:02 UTC (rev 45335)
@@ -29,6 +29,9 @@
 void set_params()
     param.input = G_define_standard_option(G_OPT_R_INPUTS);
+    param.input->required = NO;
+    param.input->description =
+        _("Raster map(s) to be converted to VTK-ASCII data format");
     param.output = G_define_option();
     param.output->key = "output";
