[GRASS-SVN] r45343 - grass/branches/releasebranch_6_4/locale/po
Wed Feb 9 07:41:15 EST 2011
Author: msieczka
Date: 2011-02-09 04:41:14 -0800 (Wed, 09 Feb 2011)
New Revision: 45343
   grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po
Each msgid, msgstr in 1 line. Drop cruft from the bottom of th file.
Modified: grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po
--- grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po	2011-02-09 12:36:06 UTC (rev 45342)
+++ grass/branches/releasebranch_6_4/locale/po/grasswxpy_pl.po	2011-02-09 12:41:14 UTC (rev 45343)
@@ -15,8 +15,7 @@
 "MIME-Version: 1.0\n"
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
-"Plural-Forms: nplurals=3; plural=(n==1 ? 0 : n%10>=2 && n%10<=4 && (n%100<10 "
-"|| n%100>=20) ? 1 : 2);\n"
+"Plural-Forms: nplurals=3; plural=(n==1 ? 0 : n%10>=2 && n%10<=4 && (n%100<10 || n%100>=20) ? 1 : 2);\n"
 "X-Generator: Lokalize 1.0\n"
 "X-Poedit-Language: Polish\n"
 "X-Poedit-Country: POLAND\n"
@@ -183,12 +182,8 @@
 msgstr "Bieżący mapset to <%s>."
 #: ../gui/wxpython/wxgui.py:556
-msgid ""
-"Current workspace is not empty. Do you want to store current settings to "
-"workspace file?"
-msgstr ""
-"Aktualny plik projektu nie jest pusty. Czy chcesz zapisać aktualne "
-"ustawienia do pliku projektu?"
+msgid "Current workspace is not empty. Do you want to store current settings to workspace file?"
+msgstr "Aktualny plik projektu nie jest pusty. Czy chcesz zapisać aktualne ustawienia do pliku projektu?"
 #: ../gui/wxpython/wxgui.py:559
 msgid "Create new workspace?"
@@ -1040,9 +1035,7 @@
 msgstr "ASCII xyz   (r.in.xyz)"
 #: ../gui/wxpython/menustrings.py:22
-msgid ""
-"Create a raster map from an assemblage of many coordinates using univariate "
-"statistics."
+msgid "Create a raster map from an assemblage of many coordinates using univariate statistics."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:23
@@ -1074,11 +1067,8 @@
 msgstr "ESRI ASCII grid   (r.in.arc)"
 #: ../gui/wxpython/menustrings.py:30
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster "
-"map layer."
-msgstr ""
-"Konwertuje ESRI ARC/INFO ascii rastr (GRID) na (binarną) mapę rastrową."
+msgid "Converts an ESRI ARC/INFO ascii raster file (GRID) into a (binary) raster map layer."
+msgstr "Konwertuje ESRI ARC/INFO ascii rastr (GRID) na (binarną) mapę rastrową."
 #: ../gui/wxpython/menustrings.py:31
 msgid "GRIDATB.FOR import"
@@ -1086,8 +1076,7 @@
 #: ../gui/wxpython/menustrings.py:32
 msgid "Imports GRIDATB.FOR map file (TOPMODEL) into GRASS raster map"
-msgstr ""
-"Importuje plik mapy GRIDATB.FOR (TOPMODEL) do rastrowego formatu GRASS."
+msgstr "Importuje plik mapy GRIDATB.FOR (TOPMODEL) do rastrowego formatu GRASS."
 #: ../gui/wxpython/menustrings.py:33
 #, fuzzy
@@ -1119,12 +1108,8 @@
 msgstr "Terra ASTER HDF   (r.in.aster)"
 #: ../gui/wxpython/menustrings.py:40
-msgid ""
-"Georeference, rectify and import Terra-ASTER imagery and relative DEM's "
-"using gdalwarp."
-msgstr ""
-"Nadaje georeferencje, rektyfikuje i importuje zobrazowania w formacie Terra-"
-"ASTER i związane DEM przy pomocy gdalwarp."
+msgid "Georeference, rectify and import Terra-ASTER imagery and relative DEM's using gdalwarp."
+msgstr "Nadaje georeferencje, rektyfikuje i importuje zobrazowania w formacie Terra-ASTER i związane DEM przy pomocy gdalwarp."
 #: ../gui/wxpython/menustrings.py:41
 msgid "WMS import"
@@ -1168,9 +1153,7 @@
 msgstr "Stary wektorowy format GRASS   (v.convert)"
 #: ../gui/wxpython/menustrings.py:53
-msgid ""
-"Convert all old GRASS < Ver5.7 vector maps in current mapset to current "
-"format"
+msgid "Convert all old GRASS < Ver5.7 vector maps in current mapset to current format"
 msgstr ""
 #: ../gui/wxpython/menustrings.py:54
@@ -1202,24 +1185,16 @@
 msgstr "GPS Garmin   (v.in.garmin)"
 #: ../gui/wxpython/menustrings.py:61
-msgid ""
-"Download waypoints, routes, and tracks from a Garmin GPS receiver into a "
-"vector map."
-msgstr ""
-"Wczytaj punkty nawigacyjne, trasy i ślady z dobiornika GPS Garmin do mapy "
-"wektorowej."
+msgid "Download waypoints, routes, and tracks from a Garmin GPS receiver into a vector map."
+msgstr "Wczytaj punkty nawigacyjne, trasy i ślady z dobiornika GPS Garmin do mapy wektorowej."
 #: ../gui/wxpython/menustrings.py:62
 msgid "GPSBabel GPS import"
 msgstr "GPSBabel GPS   (v.in.gpsbabel)"
 #: ../gui/wxpython/menustrings.py:63
-msgid ""
-"Import waypoints, routes, and tracks from a GPS receiver or GPS download "
-"file into a vector map."
-msgstr ""
-"Wczytuje punkty nawigacyjne, trasy i ślady z pliku dobiornika GPS do mapy "
-"wektorowej."
+msgid "Import waypoints, routes, and tracks from a GPS receiver or GPS download file into a vector map."
+msgstr "Wczytuje punkty nawigacyjne, trasy i ślady z pliku dobiornika GPS do mapy wektorowej."
 #: ../gui/wxpython/menustrings.py:64
 msgid "Geonames import"
@@ -1234,9 +1209,7 @@
 msgstr "GEOnet   (v.in.gns)"
 #: ../gui/wxpython/menustrings.py:67
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
+msgid "Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector points map."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:68
@@ -1257,20 +1230,15 @@
 #: ../gui/wxpython/menustrings.py:72
 msgid "Convert a 3D ASCII raster text file into a (binary) 3D raster map layer"
-msgstr ""
-"Konwertuje tekstowy plik rastrowy 3D ASCII na binarną mapę rastrową 3D."
+msgstr "Konwertuje tekstowy plik rastrowy 3D ASCII na binarną mapę rastrową 3D."
 #: ../gui/wxpython/menustrings.py:73
 msgid "Vis5D import"
 msgstr "Vis5D   (r3.in.v5d)"
 #: ../gui/wxpython/menustrings.py:74
-msgid ""
-"import of 3-dimensional Vis5D files (i.e. the v5d file with 1 variable and 1 "
-"time step)"
-msgstr ""
-"Importuje trójwymiarowe pliki Vis5D (np. plik v5d z 1 zmienną i 1 "
-"znacznikiem czasu)"
+msgid "import of 3-dimensional Vis5D files (i.e. the v5d file with 1 variable and 1 time step)"
+msgstr "Importuje trójwymiarowe pliki Vis5D (np. plik v5d z 1 zmienną i 1 znacznikiem czasu)"
 #: ../gui/wxpython/menustrings.py:75
 msgid "Import database table"
@@ -1309,8 +1277,7 @@
 msgstr "do ASCII x,y,z   (r.out.xyz)"
 #: ../gui/wxpython/menustrings.py:84
-msgid ""
-"Export a raster map to a text file as x,y,z values based on cell centers."
+msgid "Export a raster map to a text file as x,y,z values based on cell centers."
 msgstr "Eksportuje mapę rastrową do pliku tekstowego x,y,z."
 #: ../gui/wxpython/menustrings.py:85
@@ -1366,24 +1333,16 @@
 msgstr "do PPM"
 #: ../gui/wxpython/menustrings.py:98
-msgid ""
-"Converts a GRASS raster map to a PPM image file at the pixel resolution of "
-"the currently defined region."
-msgstr ""
-"Konwertuje 3 warstwy rastrowe GRASS (R,G,B) do pliku obrazu PPM o "
-"rozdzielczości piksela aktualnie zdefiniowanego regionu"
+msgid "Converts a GRASS raster map to a PPM image file at the pixel resolution of the currently defined region."
+msgstr "Konwertuje 3 warstwy rastrowe GRASS (R,G,B) do pliku obrazu PPM o rozdzielczości piksela aktualnie zdefiniowanego regionu"
 #: ../gui/wxpython/menustrings.py:99
 msgid "PPM from RGB export"
 msgstr "do PPM z warstw RGB"
 #: ../gui/wxpython/menustrings.py:100
-msgid ""
-"Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel "
-"resolution of the CURRENTLY DEFINED REGION."
-msgstr ""
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file at the pixel resolution of the CURRENTLY DEFINED REGION."
 #: ../gui/wxpython/menustrings.py:101 ../gui/wxpython/menustrings.py:118
 msgid "POV-Ray export"
@@ -1391,20 +1350,15 @@
 #: ../gui/wxpython/menustrings.py:102
 msgid "Converts a raster map layer into a height-field file for POVRAY."
-msgstr ""
-"Konwertuje warstwę mapy rastrowej do pliku 'height-field' dla formatu POVRAY."
+msgstr "Konwertuje warstwę mapy rastrowej do pliku 'height-field' dla formatu POVRAY."
 #: ../gui/wxpython/menustrings.py:103
 msgid "TIFF export"
 msgstr "do TIFF"
 #: ../gui/wxpython/menustrings.py:104
-msgid ""
-"Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel "
-"resolution of the currently defined region."
-msgstr ""
+msgid "Exports a GRASS raster map to a 8/24bit TIFF image file at the pixel resolution of the currently defined region."
 #: ../gui/wxpython/menustrings.py:105
 msgid "VRML export"
@@ -1437,9 +1391,7 @@
 #: ../gui/wxpython/menustrings.py:113
 msgid "Converts a GRASS binary vector map to a GRASS ASCII vector map."
-msgstr ""
-"Konwertuje binarną mapę wektorową GRASS-a do wektorowej mapy GRASS-a typu "
-"ASCII."
+msgstr "Konwertuje binarną mapę wektorową GRASS-a do wektorowej mapy GRASS-a typu ASCII."
 #: ../gui/wxpython/menustrings.py:114
 msgid "DXF export"
@@ -1454,11 +1406,8 @@
 msgstr "do różnych formatów GPS   (v.out.gpsbabel)"
 #: ../gui/wxpython/menustrings.py:117
-msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GpsBabel."
-msgstr ""
-"Eksportuje mapę wektorową do odbiornika GPS lub pliku obsługiwanego przez "
-"bibliotekę GPSBabel."
+msgid "Exports a vector map to a GPS receiver or file format supported by GpsBabel."
+msgstr "Eksportuje mapę wektorową do odbiornika GPS lub pliku obsługiwanego przez bibliotekę GPSBabel."
 #: ../gui/wxpython/menustrings.py:119
 msgid "Converts to POV-Ray format, GRASS x,y,z -> POV-Ray x,z,y"
@@ -1523,9 +1472,7 @@
 #: ../gui/wxpython/menustrings.py:136
 msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
-msgstr ""
-"Tworzy link rastrowych plików wspieranych przez GDAL do binarnej mapy "
-"rastrowej."
+msgstr "Tworzy link rastrowych plików wspieranych przez GDAL do binarnej mapy rastrowej."
 #: ../gui/wxpython/menustrings.py:137
 #: ../gui/wxpython/gui_modules/gdialogs.py:1101
@@ -1534,8 +1481,7 @@
 #: ../gui/wxpython/menustrings.py:138
 msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
-msgstr ""
-"Tworzy nową warstwę wektorową jako link do warstwy OGR tylko do odczytu."
+msgstr "Tworzy nową warstwę wektorową jako link do warstwy OGR tylko do odczytu."
 #: ../gui/wxpython/menustrings.py:139
 msgid "Manage maps and volumes"
@@ -1546,10 +1492,7 @@
 msgstr "Kopiuj"
 #: ../gui/wxpython/menustrings.py:141
-msgid ""
-"Copies available data files in the user's current mapset search path and "
-"location to the appropriate element directories under the user's current "
-"mapset."
+msgid "Copies available data files in the user's current mapset search path and location to the appropriate element directories under the user's current mapset."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:142
@@ -1557,9 +1500,7 @@
 msgstr "Lista"
 #: ../gui/wxpython/menustrings.py:143 ../gui/wxpython/menustrings.py:145
-msgid ""
-"Lists available GRASS data base files of the user-specified data type to "
-"standard output."
+msgid "Lists available GRASS data base files of the user-specified data type to standard output."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:144
@@ -1628,11 +1569,8 @@
 msgstr "Wektor do bryły rastrowej 3D"
 #: ../gui/wxpython/menustrings.py:162
-msgid ""
-"Converts a binary GRASS vector map (only points) layer into a 3D GRASS "
-"raster map layer."
-msgstr ""
-"Konwertuje binarną mapę wektorową GRASS (punkty) do mapy rastrowej 3D GRASS."
+msgid "Converts a binary GRASS vector map (only points) layer into a 3D GRASS raster map layer."
+msgstr "Konwertuje binarną mapę wektorową GRASS (punkty) do mapy rastrowej 3D GRASS."
 #: ../gui/wxpython/menustrings.py:163
 msgid "2D vector to 3D vector"
@@ -1695,9 +1633,7 @@
 msgstr "Kąty/odległości do współrzędnych   (m.cogo)"
 #: ../gui/wxpython/menustrings.py:180
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
+msgid "A simple utility for converting bearing and distance measurements to coordinates and vice versa."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:181
@@ -1794,9 +1730,7 @@
 #: ../gui/wxpython/menustrings.py:205 ../gui/wxpython/menustrings.py:207
 msgid "Outputs and modifies the user's current GRASS variable settings."
-msgstr ""
-"Wypisuje i modyfikuje bieżące ustawienia użytkownka zmiennych środowiska "
-"GRASS."
+msgstr "Wypisuje i modyfikuje bieżące ustawienia użytkownka zmiennych środowiska GRASS."
 #: ../gui/wxpython/menustrings.py:206
 msgid "Change settings"
@@ -1835,9 +1769,7 @@
 msgstr "Ustaw   (g.proj)"
 #: ../gui/wxpython/menustrings.py:216
-msgid ""
-"Converts co-ordinate system descriptions (i.e. projection information) "
-"between various formats (including GRASS format)."
+msgid "Converts co-ordinate system descriptions (i.e. projection information) between various formats (including GRASS format)."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:217
@@ -1862,8 +1794,7 @@
 #: ../gui/wxpython/menustrings.py:222
 msgid "Tool to maintain GRASS extensions in local GRASS installation."
-msgstr ""
-"Narzędzie do zarządzania rozszerzeniami GRASS w lokalnej instalacji programu."
+msgstr "Narzędzie do zarządzania rozszerzeniami GRASS w lokalnej instalacji programu."
 #: ../gui/wxpython/menustrings.py:223 ../gui/wxpython/menustrings.py:795
 msgid "Preferences"
@@ -1871,9 +1802,7 @@
 #: ../gui/wxpython/menustrings.py:224
 msgid "User GUI preferences (display font, commands, digitizer, etc.)"
-msgstr ""
-"Preferencje użytkownika GUI (czcionka wyświetlania, komendy, digitajzer, "
-"itp.)"
+msgstr "Preferencje użytkownika GUI (czcionka wyświetlania, komendy, digitajzer, itp.)"
 #: ../gui/wxpython/menustrings.py:225
 msgid "&Raster"
@@ -1888,9 +1817,7 @@
 msgstr "Wektoryzacja rastra /wymaga XTerm/ (r.digit)"
 #: ../gui/wxpython/menustrings.py:228
-msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
+msgid "Interactive tool used to draw and save vector features on a graphics monitor using a pointing device (mouse) and save to a raster map."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:229
@@ -1962,10 +1889,7 @@
 msgstr "Próbkowanie z użyciem funkcji sklejalnych   (r.resamp.rst)"
 #: ../gui/wxpython/menustrings.py:246
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
+msgid "Reinterpolates and optionally computes topographic analysis from input raster map to a new raster map (possibly with different resolution) using regularized spline with tension and smoothing."
 msgstr "Próbkuje warstwę mapy rastrowej z użyciem funkcji sklejalnych."
 #: ../gui/wxpython/menustrings.py:247 ../gui/wxpython/menustrings.py:527
@@ -1974,8 +1898,7 @@
 #: ../gui/wxpython/menustrings.py:248
 msgid "Allows creation and/or modification of raster map layer support files."
-msgstr ""
-"Pozwala na tworzenie i/lub modyfikację plików dodatkowych dla map rastrowych."
+msgstr "Pozwala na tworzenie i/lub modyfikację plików dodatkowych dla map rastrowych."
 #: ../gui/wxpython/menustrings.py:249
 msgid "Update map statistics"
@@ -1991,18 +1914,14 @@
 #: ../gui/wxpython/menustrings.py:252
 msgid "Re-projects a raster map from one location to the current location."
-msgstr ""
-"Zmienia odwzorowanie mapy rastrowej kopiując go z innej lokacji do bieżącej "
-"lokacji."
+msgstr "Zmienia odwzorowanie mapy rastrowej kopiując go z innej lokacji do bieżącej lokacji."
 #: ../gui/wxpython/menustrings.py:253
 msgid "Tiling"
 msgstr "Kafelki   (r.tileset)"
 #: ../gui/wxpython/menustrings.py:254
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
+msgid "Produces tilings of the source projection for use in the destination region and projection."
 msgstr "Generowanie zasięgu 'kafli' zadanego domyślnego regionu."
 #: ../gui/wxpython/menustrings.py:255 ../gui/wxpython/menustrings.py:529
@@ -2055,8 +1974,7 @@
 msgstr "Utwórz RGB"
 #: ../gui/wxpython/menustrings.py:267
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
+msgid "Combines red, green and blue raster maps into a single composite raster map."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:648
@@ -2064,9 +1982,7 @@
 msgstr "RGB na HIS   (i.rgb.his)"
 #: ../gui/wxpython/menustrings.py:269
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
+msgid "Generates red, green and blue raster map layers combining hue, intensity and saturation (HIS) values from user-specified input raster map layers."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:270
@@ -2094,12 +2010,8 @@
 msgstr "Buforuj rastry   (r.buffer)"
 #: ../gui/wxpython/menustrings.py:276
-msgid ""
-"Creates a raster map layer showing buffer zones surrounding cells that "
-"contain non-NULL category values."
-msgstr ""
-"Tworzy rastrową warstwę mapy ukazującą strefy buforowe otaczające komórki "
-"rastra które zawierają wartości kategorii inne niż NULL"
+msgid "Creates a raster map layer showing buffer zones surrounding cells that contain non-NULL category values."
+msgstr "Tworzy rastrową warstwę mapy ukazującą strefy buforowe otaczające komórki rastra które zawierają wartości kategorii inne niż NULL"
 #: ../gui/wxpython/menustrings.py:277
 msgid "Closest points"
@@ -2107,8 +2019,7 @@
 #: ../gui/wxpython/menustrings.py:278
 msgid "Locates the closest points between objects in two raster maps."
-msgstr ""
-"Lokalizuje najbliższe punkty pomiędzy obiektami na dwóch mapach rastrowych."
+msgstr "Lokalizuje najbliższe punkty pomiędzy obiektami na dwóch mapach rastrowych."
 #: ../gui/wxpython/menustrings.py:279
 #: ../gui/wxpython/gui_modules/nviz_tools.py:350
@@ -2138,28 +2049,16 @@
 msgstr "Pływające okno   (r.neighbors)"
 #: ../gui/wxpython/menustrings.py:285
-msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
-msgstr ""
-"Czyni wartość kategorii każdej komórki rastra funkcją wartości kategorii "
-"przypisanych do komórek dookoła niej, i zachowuje nową wartość komórki w "
-"wyjściowej wastwie mapy rastrowej."
+msgid "Makes each cell category value a function of the category values assigned to the cells around it, and stores new cell values in an output raster map layer."
+msgstr "Czyni wartość kategorii każdej komórki rastra funkcją wartości kategorii przypisanych do komórek dookoła niej, i zachowuje nową wartość komórki w wyjściowej wastwie mapy rastrowej."
 #: ../gui/wxpython/menustrings.py:286
 msgid "Neighborhood points"
 msgstr "Punkty sąsiedztwa   (v.neighbors)"
 #: ../gui/wxpython/menustrings.py:287
-msgid ""
-"Makes each cell value a function of the attribute values assigned to the "
-"vector points or centroids around it, and stores new cell values in an "
-"output raster map layer."
-msgstr ""
+msgid "Makes each cell value a function of the attribute values assigned to the vector points or centroids around it, and stores new cell values in an output raster map layer."
 #: ../gui/wxpython/menustrings.py:288
 msgid "Overlay rasters"
@@ -2170,37 +2069,24 @@
 msgstr "Produkt poprzecznego łączenia rastrów"
 #: ../gui/wxpython/menustrings.py:290
-msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
-msgstr ""
-"Tworzy produkt przejściowy wartości kategorii ze złożonych warstw map "
-"rastrowych"
+msgid "Creates a cross product of the category values from multiple raster map layers."
+msgstr "Tworzy produkt przejściowy wartości kategorii ze złożonych warstw map rastrowych"
 #: ../gui/wxpython/menustrings.py:291
 msgid "Raster series"
 msgstr "Serie rastrów"
 #: ../gui/wxpython/menustrings.py:292
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
-msgstr ""
-"Czyni wartość komórek wynikowego rastra funkcją wartości przypisanych do "
-"odpowiadających komórek wejściowych warstw rastrowych."
+msgid "Makes each output cell value a function of the values assigned to the corresponding cells in the input raster map layers."
+msgstr "Czyni wartość komórek wynikowego rastra funkcją wartości przypisanych do odpowiadających komórek wejściowych warstw rastrowych."
 #: ../gui/wxpython/menustrings.py:293
 msgid "Patch raster maps"
 msgstr "Uzupełnij komórki bez danych"
 #: ../gui/wxpython/menustrings.py:294
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
-msgstr ""
-"Tworzy złożoną warstwę mapy rastrowej używając znanych kategorii wartości "
-"jednej (lub więcej) warstw(y) do wypełnienia obszarów \"no data\" w innej "
-"warstwie mapy."
+msgid "Creates a composite raster map layer by using known category values from one (or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr "Tworzy złożoną warstwę mapy rastrowej używając znanych kategorii wartości jednej (lub więcej) warstw(y) do wypełnienia obszarów \"no data\" w innej warstwie mapy."
 #: ../gui/wxpython/menustrings.py:295
 msgid "Statistical overlay"
@@ -2228,8 +2114,7 @@
 #: ../gui/wxpython/menustrings.py:301
 #, fuzzy
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
+msgid "Calculates cast shadow areas from sun position and elevation raster map."
 msgstr "Oblicza shape index z mapy rastrowej GRASS"
 #: ../gui/wxpython/menustrings.py:302
@@ -2241,29 +2126,16 @@
 msgstr "Oblicz skumulowany koszt przemieszczenia pomiędzy dwiema lokalizacjami"
 #: ../gui/wxpython/menustrings.py:304
-msgid ""
-"Outputs a raster map layer showing the anisotropic cumulative cost of moving "
-"between different geographic locations on an input elevation raster map "
-"layer whose cell category values represent elevation combined with an input "
-"raster map layer whose cell values represent friction cost."
-msgstr ""
-"Tworzy warstwę mapy rastrowej ukazującą skumulowany koszt przemieszczania "
-"się pomiędzy dwoma lokalizacjami geograficznymi na wejściowej warstwie "
-"rastrowej, której wartości kategorii komórek rastra reprezentują koszt."
+msgid "Outputs a raster map layer showing the anisotropic cumulative cost of moving between different geographic locations on an input elevation raster map layer whose cell category values represent elevation combined with an input raster map layer whose cell values represent friction cost."
+msgstr "Tworzy warstwę mapy rastrowej ukazującą skumulowany koszt przemieszczania się pomiędzy dwoma lokalizacjami geograficznymi na wejściowej warstwie rastrowej, której wartości kategorii komórek rastra reprezentują koszt."
 #: ../gui/wxpython/menustrings.py:305
 msgid "Cost surface"
 msgstr "Powierzchnia kosztu"
 #: ../gui/wxpython/menustrings.py:306
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
-msgstr ""
+msgid "Creates a raster map showing the cumulative cost of moving between different geographic locations on an input raster map whose cell category values represent cost."
 #: ../gui/wxpython/menustrings.py:307
 msgid "Least cost route or flow"
@@ -2288,13 +2160,8 @@
 #: ../gui/wxpython/menustrings.py:312
 #, fuzzy
-msgid ""
-"Generates raster maps of slope, aspect, curvatures and partial derivatives "
-"from a elevation raster map."
-msgstr ""
-"Tworzy rastrowe warstwy spadków, ekspozycji, krzywizn i częściowych "
-"pochodnych z rastrowej mapy rzeczywistych wysokości. Ekspozycja jest "
-"obliczana w kierunku przeciwnym do ruchu wskazówek zegara od wschodu."
+msgid "Generates raster maps of slope, aspect, curvatures and partial derivatives from a elevation raster map."
+msgstr "Tworzy rastrowe warstwy spadków, ekspozycji, krzywizn i częściowych pochodnych z rastrowej mapy rzeczywistych wysokości. Ekspozycja jest obliczana w kierunku przeciwnym do ruchu wskazówek zegara od wschodu."
 #: ../gui/wxpython/menustrings.py:313
 msgid "Terrain parameters"
@@ -2326,8 +2193,7 @@
 #: ../gui/wxpython/menustrings.py:320
 msgid "Generates a raster map layer of distance to features in input layer."
-msgstr ""
-"Tworzy warstwę mapy rastrowej obrazującą odległość do najbliższego obiektu."
+msgstr "Tworzy warstwę mapy rastrowej obrazującą odległość do najbliższego obiektu."
 #: ../gui/wxpython/menustrings.py:321
 msgid "Horizon angle"
@@ -2346,12 +2212,8 @@
 msgstr "Obszary ciągłe"
 #: ../gui/wxpython/menustrings.py:325
-msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
-msgstr ""
-"Zmienia kategorie danych w mapie rastrowej poprzez grupowanie komórek "
-"rastra, które formują fizycznie wydzielone obszary, na kategorie unikalne."
+msgid "Recategorizes data in a raster map by grouping cells that form physically discrete areas into unique categories."
+msgstr "Zmienia kategorie danych w mapie rastrowej poprzez grupowanie komórek rastra, które formują fizycznie wydzielone obszary, na kategorie unikalne."
 #: ../gui/wxpython/menustrings.py:326
 msgid "Grow"
@@ -2359,9 +2221,7 @@
 #: ../gui/wxpython/menustrings.py:327
 msgid "Generates a raster map layer with contiguous areas grown by one cell."
-msgstr ""
-"Generuje warstwę mapy rastrowej z ciągłymi obszarami powiększonymi o jedną "
-"komórkę."
+msgstr "Generuje warstwę mapy rastrowej z ciągłymi obszarami powiększonymi o jedną komórkę."
 #: ../gui/wxpython/menustrings.py:328
 msgid "Thin"
@@ -2370,9 +2230,7 @@
 #: ../gui/wxpython/menustrings.py:329
 #, fuzzy
 msgid "Thins non-zero cells that denote linear features in a raster map."
-msgstr ""
-"Wycienia niezerowe komórki rastra, które tworzą struktury liniowe na mapach "
-"rastrowych"
+msgstr "Wycienia niezerowe komórki rastra, które tworzą struktury liniowe na mapach rastrowych"
 #: ../gui/wxpython/menustrings.py:330
 msgid "Hydrologic modeling"
@@ -2383,12 +2241,8 @@
 msgstr "Wyznacz wysokości cieków"
 #: ../gui/wxpython/menustrings.py:332
-msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
-msgstr ""
-"Na podstawie wektorowego przebiegu cieków, wyznacza z rastrowego modelu "
-"terenu wysokości cieków."
+msgid "Takes vector stream data, transforms it to raster and subtracts depth from the output DEM."
+msgstr "Na podstawie wektorowego przebiegu cieków, wyznacza z rastrowego modelu terenu wysokości cieków."
 #: ../gui/wxpython/menustrings.py:333
 msgid "Fill lake"
@@ -2403,12 +2257,8 @@
 msgstr "Mapa bez obszarów bezodpływowych oraz mapa linii spływu"
 #: ../gui/wxpython/menustrings.py:336
-msgid ""
-"Filters and generates a depressionless elevation map and a flow direction "
-"map from a given elevation layer."
-msgstr ""
-"Filtruje rastrową mapę modelu terenu i generuje mapę powierzchni pozbawionej "
-"depresji oraz mapę linii spływu."
+msgid "Filters and generates a depressionless elevation map and a flow direction map from a given elevation layer."
+msgstr "Filtruje rastrową mapę modelu terenu i generuje mapę powierzchni pozbawionej depresji oraz mapę linii spływu."
 #: ../gui/wxpython/menustrings.py:337
 msgid "Flow accumulation"
@@ -2423,9 +2273,7 @@
 msgstr "Linie spływu"
 #: ../gui/wxpython/menustrings.py:340
-msgid ""
-"Construction of slope curves (flowlines), flowpath lengths, and flowline "
-"densities (upslope areas) from a raster digital elevation model (DEM)"
+msgid "Construction of slope curves (flowlines), flowpath lengths, and flowline densities (upslope areas) from a raster digital elevation model (DEM)"
 msgstr ""
 #: ../gui/wxpython/menustrings.py:341
@@ -2441,9 +2289,7 @@
 msgstr "Modelowanie erozji sedymentów, transportu i depozycji (SIMWE)"
 #: ../gui/wxpython/menustrings.py:344
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)"
+msgid "Sediment transport and erosion/deposition simulation using path sampling method (SIMWE)"
 msgstr ""
 #: ../gui/wxpython/menustrings.py:345
@@ -2486,17 +2332,14 @@
 #: ../gui/wxpython/menustrings.py:354
 msgid "Watershed basin creation program."
-msgstr ""
-"Program do wyznaczania obszaru zlewni na podstawie mapy kierunku spływów."
+msgstr "Program do wyznaczania obszaru zlewni na podstawie mapy kierunku spływów."
 #: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:710
 msgid "Groundwater modeling"
 msgstr "Modelowanie wód gruntowych   (r3.gwflow)"
 #: ../gui/wxpython/menustrings.py:356
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
+msgid "Numerical calculation program for transient, confined and unconfined groundwater flow in two dimensions."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:357
@@ -2508,9 +2351,7 @@
 msgstr "Ustawienia (wymaga XTerm)"
 #: ../gui/wxpython/menustrings.py:359
-msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
+msgid "Interactive tool used to setup the sampling and analysis framework that will be used by the other r.le programs."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:360
@@ -2518,9 +2359,7 @@
 msgstr "Analiza charakterystyk krajobrazu"
 #: ../gui/wxpython/menustrings.py:361
-msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
+msgid "Contains a set of measures for attributes, diversity, texture, juxtaposition, and edge."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:362
@@ -2528,16 +2367,11 @@
 msgstr "Analiza mapy"
 #: ../gui/wxpython/menustrings.py:363
-msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
+msgid "Calculates attribute, patch size, core (interior) size, shape, fractal dimension, and perimeter measures for sets of patches in a landscape."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:365
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
+msgid "Displays the boundary of each r.le patch and shows how the boundary is traced, displays the attribute, size, perimeter and shape indices for each patch and saves the data in an output file."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:366
@@ -2557,8 +2391,7 @@
 msgstr "Wykrywanie krawędzi"
 #: ../gui/wxpython/menustrings.py:370
-msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates edge density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../gui/wxpython/menustrings.py:371
@@ -2574,9 +2407,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:374
-msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
+msgid "Calculates mean patch size index on a raster map, using a 4 neighbour algorithm"
 #: ../gui/wxpython/menustrings.py:375
@@ -2608,8 +2439,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:382
-msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgid "Calculates patch density index on a raster map, using a 4 neighbour algorithm"
 msgstr ""
 #: ../gui/wxpython/menustrings.py:383
@@ -2617,8 +2447,7 @@
 msgstr "Numer kategorii"
 #: ../gui/wxpython/menustrings.py:384
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgid "Calculates patch number index on a raster map, using a 4 neighbour algorithm."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:385
@@ -2666,11 +2495,7 @@
 msgstr "Tempo rozprzestrzeniania się"
 #: ../gui/wxpython/menustrings.py:397
-msgid ""
-"Generates three, or four raster map layers showing 1) the base "
-"(perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the "
-"direction of the maximum ROS, and optionally 4) the maximum potential "
-"spotting distance."
+msgid "Generates three, or four raster map layers showing 1) the base (perpendicular) rate of spread (ROS), 2) the maximum (forward) ROS, 3) the direction of the maximum ROS, and optionally 4) the maximum potential spotting distance."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:398
@@ -2678,9 +2503,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:399
-msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
+msgid "Recursively traces the least cost path backwards to cells from which the cumulative cost was determined."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:400
@@ -2688,10 +2511,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:401
-msgid ""
-"Simulates elliptically anisotropic spread on a graphics window and generates "
-"a raster map of the cumulative time of spread, given raster maps containing "
-"the rates of spread (ROS), the ROS directions and the spread origins."
+msgid "Simulates elliptically anisotropic spread on a graphics window and generates a raster map of the cumulative time of spread, given raster maps containing the rates of spread (ROS), the ROS directions and the spread origins."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:402
@@ -2711,9 +2531,7 @@
 msgstr "Reklasyfikuj według rozmiaru"
 #: ../gui/wxpython/menustrings.py:406
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
+msgid "Reclasses a raster map greater or less than user specified area size (in hectares)."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:583
@@ -2721,12 +2539,8 @@
 msgstr "Reklasyfikuj"
 #: ../gui/wxpython/menustrings.py:408
-msgid ""
-"Creates a new map layer whose category values are based upon a "
-"reclassification of the categories in an existing raster map layer."
-msgstr ""
-"Tworzy nową warstwę mapy, której kategorie są oparte na reklasyfikacji "
-"kategorii z istniejącej warstwy mapy rastrowej."
+msgid "Creates a new map layer whose category values are based upon a reclassification of the categories in an existing raster map layer."
+msgstr "Tworzy nową warstwę mapy, której kategorie są oparte na reklasyfikacji kategorii z istniejącej warstwy mapy rastrowej."
 #: ../gui/wxpython/menustrings.py:409
 msgid "Recode"
@@ -2749,9 +2563,7 @@
 msgstr "Przeskaluj z histogramem"
 #: ../gui/wxpython/menustrings.py:414
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
+msgid "Rescales histogram equalized the range of category values in a raster map layer."
 msgstr "Przeskalowanie zakresu wartości kategorii w warstwie mapy rastrowej."
 #: ../gui/wxpython/menustrings.py:415
@@ -2760,8 +2572,7 @@
 #: ../gui/wxpython/menustrings.py:416
 msgid "Creates a raster map containing concentric rings around a given point."
-msgstr ""
-"Tworzy mapę rastrową zawierającą koncentryczne kręgi wokół zadanych pubktów."
+msgstr "Tworzy mapę rastrową zawierającą koncentryczne kręgi wokół zadanych pubktów."
 #: ../gui/wxpython/menustrings.py:417
 msgid "Generate random cells"
@@ -2780,11 +2591,8 @@
 msgstr "Przypadkowo rozmieszczone komórki i punkty (wektorowe)"
 #: ../gui/wxpython/menustrings.py:421
-msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
-msgstr ""
+msgid "Creates a raster map layer and vector point map containing randomly located points."
 #: ../gui/wxpython/menustrings.py:422
 msgid "Generate surfaces"
@@ -2803,10 +2611,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:426
-msgid ""
-"Generates a raster density map from vector points data using a moving 2D "
-"isotropic Gaussian kernel or optionally generates a vector density map on "
-"vector network with a 1D kernel."
+msgid "Generates a raster density map from vector points data using a moving 2D isotropic Gaussian kernel or optionally generates a vector density map on vector network with a 1D kernel."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:427
@@ -2814,10 +2619,7 @@
 msgstr "Utwórz powierzchnie"
 #: ../gui/wxpython/menustrings.py:428
-msgid ""
-"GRASS module to produce a raster map layer of gaussian deviates whose mean "
-"and standard deviation can be expressed by the user. It uses a gaussian "
-"random number generator."
+msgid "GRASS module to produce a raster map layer of gaussian deviates whose mean and standard deviation can be expressed by the user. It uses a gaussian random number generator."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:429
@@ -2825,9 +2627,7 @@
 msgstr "Płaszczyzna"
 #: ../gui/wxpython/menustrings.py:430
-msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
+msgid "Creates raster plane map given dip (inclination), aspect (azimuth) and one point."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:431
@@ -2835,9 +2635,7 @@
 #: ../gui/wxpython/menustrings.py:432
-msgid ""
-"Produces a raster map of uniform random deviates whose range can be "
-"expressed by the user."
+msgid "Produces a raster map of uniform random deviates whose range can be expressed by the user."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:433
@@ -2897,12 +2695,8 @@
 msgstr "Interpolacja IDW z punktów wektorowych"
 #: ../gui/wxpython/menustrings.py:447
-msgid ""
-"Surface interpolation from vector point data by Inverse Distance Squared "
-"Weighting."
-msgstr ""
-"Interpolacja powierzchni z punktów wektorowych metodą Inverse Distance "
-"Squared Weighting (IDW)."
+msgid "Surface interpolation from vector point data by Inverse Distance Squared Weighting."
+msgstr "Interpolacja powierzchni z punktów wektorowych metodą Inverse Distance Squared Weighting (IDW)."
 #: ../gui/wxpython/menustrings.py:448
 msgid "Raster contours"
@@ -2917,10 +2711,7 @@
 msgstr "Przepróbkowanie z użyciem  RST (regularized spline tension)"
 #: ../gui/wxpython/menustrings.py:451
-msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
+msgid "Spatial approximation and topographic analysis from given point or isoline data in vector format to floating point raster format using regularized spline with tension."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:452
@@ -2928,8 +2719,7 @@
 msgstr "Wypełnij komórki NULL"
 #: ../gui/wxpython/menustrings.py:453
-msgid ""
-"Fills no-data areas in raster maps using v.surf.rst splines interpolation"
+msgid "Fills no-data areas in raster maps using v.surf.rst splines interpolation"
 msgstr ""
 #: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:691
@@ -2949,9 +2739,7 @@
 msgstr "Zarządzaj informacjami o kategoriach"
 #: ../gui/wxpython/menustrings.py:458
-msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
+msgid "Manages category values and labels associated with user-specified raster map layers."
 msgstr "Tworzy/modyfikuje paletę kolorów związaną z warstwą mapy rastrowej."
 #: ../gui/wxpython/menustrings.py:459
@@ -2976,9 +2764,7 @@
 #: ../gui/wxpython/menustrings.py:464
 msgid "Prints terse list of category values found in a raster map layer."
-msgstr ""
-"Wyświetla zwięzłą listę wartości kategorii znajdujących się w warstwie mapy "
-"rastrowej."
+msgstr "Wyświetla zwięzłą listę wartości kategorii znajdujących się w warstwie mapy rastrowej."
 #: ../gui/wxpython/menustrings.py:465
 msgid "Sum category values"
@@ -3001,9 +2787,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:470
-msgid ""
-"Calculates the volume of data \"clumps\", and (optionally) produces a GRASS "
-"vector points map containing the calculated centroids of these clumps."
+msgid "Calculates the volume of data \"clumps\", and (optionally) produces a GRASS vector points map containing the calculated centroids of these clumps."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:471
@@ -3019,8 +2803,7 @@
 msgstr "Statystyki mapy rastrowej"
 #: ../gui/wxpython/menustrings.py:474
-msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
+msgid "Calculates univariate statistics from the non-null cells of a raster map."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:475
@@ -3029,32 +2812,23 @@
 #: ../gui/wxpython/menustrings.py:476
 msgid "Outputs the raster map layer values lying on user-defined line(s)."
-msgstr ""
-"Tworzy plik wartości mapy rastrowej leżących na linii/liniach zdefiniowanych "
-"przez użytkownika."
+msgstr "Tworzy plik wartości mapy rastrowej leżących na linii/liniach zdefiniowanych przez użytkownika."
 #: ../gui/wxpython/menustrings.py:477
 msgid "Sample transects (bearing/distance)"
 msgstr "Próbkuj wartości wzdłuż przecięć"
 #: ../gui/wxpython/menustrings.py:478
-msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
-msgstr ""
+msgid "Outputs raster map layer values lying along user defined transect line(s)."
 #: ../gui/wxpython/menustrings.py:479
 msgid "Covariance/correlation"
 msgstr "Kowariancja/korelacja"
 #: ../gui/wxpython/menustrings.py:480
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map layer"
-"(s)."
-msgstr ""
-"Tworzy matrycę kowariancji/korelacji dla określonej przez użytkownika "
-"warstwy/warstw mapy rastrowej."
+msgid "Outputs a covariance/correlation matrix for user-specified raster map layer(s)."
+msgstr "Tworzy matrycę kowariancji/korelacji dla określonej przez użytkownika warstwy/warstw mapy rastrowej."
 #: ../gui/wxpython/menustrings.py:481
 msgid "Linear regression"
@@ -3069,9 +2843,7 @@
 msgstr "Sumuj wartości kategorii"
 #: ../gui/wxpython/menustrings.py:484
-msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
+msgid "Tabulates the mutual occurrence (coincidence) of categories for two raster map layers."
 #: ../gui/wxpython/menustrings.py:485
@@ -3104,9 +2876,7 @@
 msgstr "Edytuj mapę wektorową /nie interaktywnie/   (v.edit)"
 #: ../gui/wxpython/menustrings.py:492
-msgid ""
-"Edits a vector map, allows adding, deleting and modifying selected vector "
-"features."
+msgid "Edits a vector map, allows adding, deleting and modifying selected vector features."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:493
@@ -3123,8 +2893,7 @@
 #: ../gui/wxpython/menustrings.py:496
 msgid "Rebuilds topology on all vector maps in the current mapset."
-msgstr ""
-"Przebudowuje topologię dla wszystkich map wektorowych w bieżącym mapsecie."
+msgstr "Przebudowuje topologię dla wszystkich map wektorowych w bieżącym mapsecie."
 #: ../gui/wxpython/menustrings.py:497
 msgid "Clean vector map"
@@ -3195,9 +2964,7 @@
 msgstr "Granice regionu"
 #: ../gui/wxpython/menustrings.py:514
-msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
+msgid "Dissolves boundaries between adjacent areas sharing a common category number or attribute."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:515
@@ -3230,20 +2997,15 @@
 #: ../gui/wxpython/menustrings.py:522
 msgid "Creates paint labels for a vector map from attached attributes."
-msgstr ""
-"Tworzy etykiety dla mapt wektorowej na podstawie dołączonej tabeli atrybutów."
+msgstr "Tworzy etykiety dla mapt wektorowej na podstawie dołączonej tabeli atrybutów."
 #: ../gui/wxpython/menustrings.py:523
 msgid "Reposition vector map"
 msgstr "Transformuj mapę wektorową   (v.transform)"
 #: ../gui/wxpython/menustrings.py:524
-msgid ""
-"Performs an affine transformation (shift, scale and rotate, or GPCs) on "
-"vector map."
-msgstr ""
-"Wykonuje transformację afiniczną (przesuń, skaluj i obróć, lub GPC) mapy "
-"wektorowej."
+msgid "Performs an affine transformation (shift, scale and rotate, or GPCs) on vector map."
+msgstr "Wykonuje transformację afiniczną (przesuń, skaluj i obróć, lub GPC) mapy wektorowej."
 #: ../gui/wxpython/menustrings.py:525
 msgid "Reproject vector map"
@@ -3251,17 +3013,14 @@
 #: ../gui/wxpython/menustrings.py:526
 msgid "Re-projects a vector map from one location to the current location."
-msgstr ""
-"lokacji."
 #: ../gui/wxpython/menustrings.py:528
 msgid "Updates vector map metadata."
 msgstr "Aktualizuje metadane mapy wektorowej."
 #: ../gui/wxpython/menustrings.py:531
-msgid ""
-"Set color rules for features in a vector using a numeric attribute column."
+msgid "Set color rules for features in a vector using a numeric attribute column."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:533
@@ -3273,9 +3032,7 @@
 msgstr "Zapytanie według atrybutów   (v.extract)"
 #: ../gui/wxpython/menustrings.py:535
-msgid ""
-"Selects vector objects from an existing vector map and creates a new map "
-"containing only the selected objects."
+msgid "Selects vector objects from an existing vector map and creates a new map containing only the selected objects."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:536
@@ -3291,8 +3048,7 @@
 msgstr "Wybierz względem innej mapy wektorowej   (v.select)"
 #: ../gui/wxpython/menustrings.py:539
-msgid ""
-"Selects features from vector map (A) by features from other vector map (B)."
+msgid "Selects features from vector map (A) by features from other vector map (B)."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:540
@@ -3300,8 +3056,7 @@
 msgstr "Buforuj wektory   (v.buffer)"
 #: ../gui/wxpython/menustrings.py:541
-msgid ""
-"Creates a buffer around features of given type (areas must contain centroid)."
+msgid "Creates a buffer around features of given type (areas must contain centroid)."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:542
@@ -3321,9 +3076,7 @@
 msgstr "Wykryj obszary wewnętrzne   (v.lidar.growing)"
 #: ../gui/wxpython/menustrings.py:546
-msgid ""
-"Building contour determination and Region Growing algorithm for determining "
-"the building inside"
+msgid "Building contour determination and Region Growing algorithm for determining the building inside"
 msgstr ""
 #: ../gui/wxpython/menustrings.py:547
@@ -3331,9 +3084,7 @@
 msgstr "Popraw i przeklasyfikuj obiekty   (v.lidar.correction)"
 #: ../gui/wxpython/menustrings.py:548
-msgid ""
-"Correction of the v.lidar.growing output. It is the last of the three "
-"algorithms for LIDAR filtering."
+msgid "Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:549
@@ -3361,9 +3112,7 @@
 msgstr "Utwórz punkty/segmenty   (v.lrs.segment)"
 #: ../gui/wxpython/menustrings.py:555
-msgid ""
-"Creates points/segments from input lines, linear reference system and "
-"positions read from stdin or a file."
+msgid "Creates points/segments from input lines, linear reference system and positions read from stdin or a file."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:556
@@ -3371,9 +3120,7 @@
 msgstr "Znajdź ID linii i odchyłkę"
 #: ../gui/wxpython/menustrings.py:557
-msgid ""
-"Finds line id and real km+offset for given points in vector map using linear "
-"reference system."
+msgid "Finds line id and real km+offset for given points in vector map using linear reference system."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:558
@@ -3381,9 +3128,7 @@
 msgstr "Najbliższe obiekty   (v.distance)"
 #: ../gui/wxpython/menustrings.py:559
-msgid ""
-"Finds the nearest element in vector map 'to' for elements in vector map "
-"'from'."
+msgid "Finds the nearest element in vector map 'to' for elements in vector map 'from'."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:560
@@ -3460,8 +3205,7 @@
 #: ../gui/wxpython/menustrings.py:579
 msgid "Create a new vector map layer by combining other vector map layers."
-msgstr ""
-"Tworzy nową warstwę wektorową przez połączenie innych warstw wektorowych."
+msgstr "Tworzy nową warstwę wektorową przez połączenie innych warstw wektorowych."
 #: ../gui/wxpython/menustrings.py:580
 msgid "Change attributes"
@@ -3476,9 +3220,7 @@
 msgstr ""
 #: ../gui/wxpython/menustrings.py:584
-msgid ""
-"Changes vector category values for an existing vector map according to "
-"results of SQL queries or a value in attribute table column."
+msgid "Changes vector category values for an existing vector map according to results of SQL queries or a value in attribute table column."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:585
@@ -3506,9 +3248,7 @@
 msgstr "Triangulacja Delonego   (v.delaunay)"
 #: ../gui/wxpython/menustrings.py:591
-msgid ""
-"Creates a Delaunay triangulation from an input vector map containing points "
-"or centroids."
+msgid "Creates a Delaunay triangulation from an input vector map containing points or centroids."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:592
@@ -3516,9 +3256,7 @@
 msgstr "Diagram Woronoja/poligony Thiessena   (v.voronoi)"
 #: ../gui/wxpython/menustrings.py:593
-msgid ""
-"Creates a Voronoi diagram from an input vector map containing points or "
-"centroids."
+msgid "Creates a Voronoi diagram from an input vector map containing points or centroids."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:594
@@ -3538,8 +3276,7 @@
 msgstr "z bazy danych   (v.in.db)"
 #: ../gui/wxpython/menustrings.py:598
-msgid ""
-"Creates new vector (points) map from database table containing coordinates."
+msgid "Creates new vector (points) map from database table containing coordinates."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:599
@@ -3587,9 +3324,7 @@
 msgstr "Modyfikuj atrybuty obszarów z rastra   (v.rast.stats)"
 #: ../gui/wxpython/menustrings.py:610
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygons "
-"and uploads statistics to new attribute columns."
+msgid "Calculates univariate statistics from a raster map based on vector polygons and uploads statistics to new attribute columns."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:611
@@ -3630,9 +3365,7 @@
 #: ../gui/wxpython/menustrings.py:620
 msgid "Outputs basic information about a user-specified vector map."
-msgstr ""
 #: ../gui/wxpython/menustrings.py:621
 msgid "Classify attribute data"
@@ -3663,9 +3396,7 @@
 msgstr "Aktualizuj statystyki atrybutów mapy punktowej   (v.univar)"
 #: ../gui/wxpython/menustrings.py:628
-msgid ""
-"Calculates univariate statistics for attribute. Variance and standard "
-"deviation is calculated only for points if specified."
+msgid "Calculates univariate statistics for attribute. Variance and standard deviation is calculated only for points if specified."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:629
@@ -3673,9 +3404,7 @@
 msgstr "Aktualizuj statystyki kolumn atrybutów   (v.db.univar)"
 #: ../gui/wxpython/menustrings.py:630
-msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
+msgid "Calculates univariate statistics on selected table column for a GRASS vector map."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:631
@@ -3743,15 +3472,11 @@
 msgstr "HIS na RGB   (i.his.rgb)"
 #: ../gui/wxpython/menustrings.py:647
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
+msgid "Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to RGB (Red-Green-Blue) color space."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:649
-msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
+msgid "Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-Intensity-Saturation) color space."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:650
@@ -3759,12 +3484,8 @@
 msgstr "Rektyfikacja obrazu lub rastra   (i.rectify)"
 #: ../gui/wxpython/menustrings.py:651
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
-msgstr ""
-"Rektyfikuje obraz poprzez obliczenie transformacji współrzędnych dla każdego "
-"piksela obrazu (oparte na punktach kontrolnych)."
+msgid "Rectifies an image by computing a coordinate transformation for each pixel in the image based on the control points."
+msgstr "Rektyfikuje obraz poprzez obliczenie transformacji współrzędnych dla każdego piksela obrazu (oparte na punktach kontrolnych)."
 #: ../gui/wxpython/menustrings.py:652
 msgid "Ortho photo rectification (requires Xterm)"
@@ -3779,11 +3500,8 @@
 msgstr "Transformacja Brovey'a   (i.fusion.brovey)"
 #: ../gui/wxpython/menustrings.py:655
-msgid ""
-"Brovey transform to merge multispectral and high-res panchromatic channels"
-msgstr ""
-"Transformacja Brovey'a do integracji multispektralnych i wysokiej "
-"rozdzielczości kanałów panchromatycznych."
+msgid "Brovey transform to merge multispectral and high-res panchromatic channels"
+msgstr "Transformacja Brovey'a do integracji multispektralnych i wysokiej rozdzielczości kanałów panchromatycznych."
 #: ../gui/wxpython/menustrings.py:656
 msgid "Classify image"
@@ -3794,9 +3512,7 @@
 msgstr "Analiza skupień dla klasifikacji nienadzorowanej   (i.cluster)"
 #: ../gui/wxpython/menustrings.py:658
-msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
+msgid "Generates spectral signatures for land cover types in an image using a clustering algorithm."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:659
@@ -3812,21 +3528,15 @@
 msgstr "Klasyfikacja SMAP (Sequential maximum a posterior)"
 #: ../gui/wxpython/menustrings.py:662
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
-msgstr ""
-"Przeprowadza klasyfikację kontekstową obrazu przy użyciu (SMAP) -sequential "
-"maxmum a posteriori."
+msgid "Performs contextual image classification using sequential maximum a posteriori (SMAP) estimation."
+msgstr "Przeprowadza klasyfikację kontekstową obrazu przy użyciu (SMAP) -sequential maxmum a posteriori."
 #: ../gui/wxpython/menustrings.py:663
 msgid "Interactive input for supervised classification (requires Xterm)"
 msgstr "Interaktywny input dla klasifikacji nadzorowanej (wymaga Xterm)"
 #: ../gui/wxpython/menustrings.py:664
-msgid ""
-"Generates spectral signatures for an image by allowing the user to outline "
-"regions of interest."
+msgid "Generates spectral signatures for an image by allowing the user to outline regions of interest."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:665
@@ -3879,8 +3589,7 @@
 msgstr "Pasma spektralne   (i.spectral)"
 #: ../gui/wxpython/menustrings.py:677
-msgid ""
-"Displays spectral response at user specified locations in group or images."
+msgid "Displays spectral response at user specified locations in group or images."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:678
@@ -3948,12 +3657,8 @@
 msgstr "Analiza Kappa   (r.kappa)"
 #: ../gui/wxpython/menustrings.py:695
-msgid ""
-"Calculate error matrix and kappa parameter for accuracy assessment of "
-"classification result."
-msgstr ""
-"Oblicza matrycę błędów i parametru kappa dla oszacowania dokładności wyników "
-"klasyfikacji."
+msgid "Calculate error matrix and kappa parameter for accuracy assessment of classification result."
+msgstr "Oblicza matrycę błędów i parametru kappa dla oszacowania dokładności wyników klasyfikacji."
 #: ../gui/wxpython/menustrings.py:696
 msgid "OIF for LandSat TM"
@@ -4008,17 +3713,11 @@
 msgstr "Przekrój   (r3.cross.rast)"
 #: ../gui/wxpython/menustrings.py:709
-msgid ""
-"Creates cross section 2D raster map from 3d raster map based on 2D elevation "
-"map"
-msgstr ""
-"Tworzy mapę rastrową przekroju (2D) mapy rastrowej 3D i mapy rastrowej "
-"wysokości (2D)"
+msgid "Creates cross section 2D raster map from 3d raster map based on 2D elevation map"
+msgstr "Tworzy mapę rastrową przekroju (2D) mapy rastrowej 3D i mapy rastrowej wysokości (2D)"
 #: ../gui/wxpython/menustrings.py:711
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions"
+msgid "Numerical calculation program for transient, confined groundwater flow in three dimensions"
 msgstr ""
 #: ../gui/wxpython/menustrings.py:712
@@ -4026,9 +3725,7 @@
 msgstr "Raster 3D z punktów   (v.vol.rst)"
 #: ../gui/wxpython/menustrings.py:713
-msgid ""
-"Interpolates point data to a G3D grid volume using regularized spline with "
-"tension (RST) algorithm."
+msgid "Interpolates point data to a G3D grid volume using regularized spline with tension (RST) algorithm."
 msgstr "Interpoluje dane punktowe do G3D za pomocą algorytmu RST."
 #: ../gui/wxpython/menustrings.py:714
@@ -4041,9 +3738,7 @@
 #: ../gui/wxpython/menustrings.py:716
 msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr ""
-"Wyświetla podstawowe informacje dla określonej przez użytkownika warstwy "
-"mapy rastrowej 3D."
+msgstr "Wyświetla podstawowe informacje dla określonej przez użytkownika warstwy mapy rastrowej 3D."
 #: ../gui/wxpython/menustrings.py:717
 msgid "Voxel statistics"
@@ -4058,9 +3753,7 @@
 msgstr "Statystyki   (r3.univar)"
 #: ../gui/wxpython/menustrings.py:720
-msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
+msgid "Calculates univariate statistics from the non-null 3d cells of a raster3d map."
 msgstr ""
 #: ../gui/wxpython/menustrings.py:721
@@ -4145,9 +3838,7 @@
 #: ../gui/wxpython/menustrings.py:741
 msgid "Test database driver, database must exist and set by db.connect."
-msgstr ""
-"Testuje sterownik bazy danych, baza danych musi istnieć i być ustawiona przy "
-"pomocy db.connect"
+msgstr "Testuje sterownik bazy danych, baza danych musi istnieć i być ustawiona przy pomocy db.connect"
 #: ../gui/wxpython/menustrings.py:742
 #: ../gui/wxpython/gui_modules/sqlbuilder.py:193
@@ -4187,12 +3878,8 @@
 msgstr "Nowa tabela   (v.db.addtable)"
 #: ../gui/wxpython/menustrings.py:751
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr ""
-"Tworzy i dodaje nową tabelę atrybutów do zadanej warstwy istniejącej mapy "
-"wektorowej."
+msgid "Creates and connects a new attribute table to a given layer of an existing vector map."
+msgstr "Tworzy i dodaje nową tabelę atrybutów do zadanej warstwy istniejącej mapy wektorowej."
 #: ../gui/wxpython/menustrings.py:752
 msgid "Remove table"
@@ -4215,20 +3902,15 @@
 msgstr "Dodaj kolumny   (v.db.addcol)"
 #: ../gui/wxpython/menustrings.py:757
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
-msgstr ""
-"Dodaje jedną lub więcej kolumn do tabeli atrybutów połączonej z zadaną mapą "
-"wektorową."
+msgid "Adds one or more columns to the attribute table connected to a given vector map."
+msgstr "Dodaje jedną lub więcej kolumn do tabeli atrybutów połączonej z zadaną mapą wektorową."
 #: ../gui/wxpython/menustrings.py:758
 msgid "Drop column"
 msgstr "Usuń kolumnę   (v.db.dropcol)"
 #: ../gui/wxpython/menustrings.py:759
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
+msgid "Drops a column from the attribute table connected to a given vector map."
 msgstr "Usuwa kolumnę z tabeli atrybutów połączonej z zadaną mapą wektorową."
 #: ../gui/wxpython/menustrings.py:760 ../gui/wxpython/gui_modules/dbm.py:932
@@ -4236,21 +3918,16 @@
 msgstr "Zmień nazwę kolumny   (v.db.renamecol)"
 #: ../gui/wxpython/menustrings.py:761
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr ""
-"Zmienia nazwę kolumny w tabeli atrybutów połączonej z zadaną mapą wektorową."
+msgid "Renames a column in the attribute table connected to a given vector map."
+msgstr "Zmienia nazwę kolumny w tabeli atrybutów połączonej z zadaną mapą wektorową."
 #: ../gui/wxpython/menustrings.py:762
 msgid "Change values"
 msgstr "Aktualizuj dane   (v.db.update)"
 #: ../gui/wxpython/menustrings.py:763
-msgid ""
-"Allows to update a column in the attribute table connected to a vector map."
-msgstr ""
-"Umożliwia aktualizację kolumny w tabeli atrybutów połączonej z mapą "
-"wektorową."
+msgid "Allows to update a column in the attribute table connected to a vector map."
+msgstr "Umożliwia aktualizację kolumny w tabeli atrybutów połączonej z mapą wektorową."
 #: ../gui/wxpython/menustrings.py:764
 msgid "Reconnect vectors to database"
@@ -4498,9 +4175,7 @@
 #: ../gui/wxpython/gui_modules/colorrules.py:701
 #, fuzzy
-msgid ""
-"Color table already exists. Check out 'replace existing color table' to "
-"overwrite it."
+msgid "Color table already exists. Check out 'replace existing color table' to overwrite it."
 msgstr "Plik regionu <%s> już istnieje.Chcesz go nadpisać?"
 #: ../gui/wxpython/gui_modules/histogram.py:175
@@ -4733,8 +4408,7 @@
 #, python-format
 msgid ""
 "No attribute table linked to vector map <%(vector)s> found. %(msg)s\n"
-"You can disable this message from digitization settings. Or you can create "
-"and link attribute table to the vector map using Attribute Table Manager."
+"You can disable this message from digitization settings. Or you can create and link attribute table to the vector map using Attribute Table Manager."
 msgstr ""
 #: ../gui/wxpython/gui_modules/dbm_dialogs.py:94
@@ -4976,14 +4650,12 @@
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1310
 msgid ""
-"Insufficient points defined and active (checked) for selected rectification "
-"method.\n"
+"Insufficient points defined and active (checked) for selected rectification method.\n"
 "3+ points needed for 1st order,\n"
 "6+ points for 2nd order, and\n"
 "10+ points for 3rd order."
 msgstr ""
-"Niedostateczna  ilość punktów zdefiniowanych i aktywnych do wybranej metody "
-"georektyfikacji.\n"
+"Niedostateczna  ilość punktów zdefiniowanych i aktywnych do wybranej metody georektyfikacji.\n"
 "3+ punkty potrzeba do georektyfikacji 1. rzędu,\n"
 "6+ punktów potrzeba do georektyfikacji 2. rzędu,\n"
 "10+ punktów potrzeba do georektyfikacji 3. rzędu"
@@ -5005,11 +4677,8 @@
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1447
 #, python-format
-msgid ""
-"Vector map <%s> already exists. Change extension name and georectify again."
-msgstr ""
-"Mapa wektorowa <%s> już istnieje. Zmień nazwę rozszerzenia i spróbuj jeszcze "
-"raz."
+msgid "Vector map <%s> already exists. Change extension name and georectify again."
+msgstr "Mapa wektorowa <%s> już istnieje. Zmień nazwę rozszerzenia i spróbuj jeszcze raz."
 #: ../gui/wxpython/gui_modules/gcpmanager.py:1481
 msgid "GCP Manager settings"
@@ -5130,11 +4799,8 @@
 #: ../gui/wxpython/gui_modules/profile.py:1038
 #: ../gui/wxpython/gui_modules/profile.py:1390
 #: ../gui/wxpython/gui_modules/preferences.py:975
-msgid ""
-"Apply and save changes to user settings file (default for next sessions)"
-msgstr ""
-"Zatwierdź zmiany bieżącej sesji do pliku ustawień użytkownika (domyślne dla "
-"następnej sesji)"
+msgid "Apply and save changes to user settings file (default for next sessions)"
+msgstr "Zatwierdź zmiany bieżącej sesji do pliku ustawień użytkownika (domyślne dla następnej sesji)"
 #: ../gui/wxpython/gui_modules/gcpmanager.py:2372
 #: ../gui/wxpython/gui_modules/ogc_services.py:77
@@ -5325,10 +4991,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:178
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:184
-msgid ""
-"Show/hide computational region extent (set with g.region). Display region "
-"drawn as a blue box inside the computational region, computational region "
-"inside a display region as a red box)."
+msgid "Show/hide computational region extent (set with g.region). Display region drawn as a blue box inside the computational region, computational region inside a display region as a red box)."
 msgstr ""
 #: ../gui/wxpython/gui_modules/mapdisp.py:186
@@ -5339,9 +5002,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:190
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:196
-msgid ""
-"Constrain display resolution to computational region settings. Default value "
-"for new map displays can be set up in 'User GUI settings' dialog."
+msgid "Constrain display resolution to computational region settings. Default value for new map displays can be set up in 'User GUI settings' dialog."
 msgstr ""
 #: ../gui/wxpython/gui_modules/mapdisp.py:218
@@ -5353,9 +5014,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:222
 #: ../gui/wxpython/gui_modules/gcpmapdisp.py:228
-msgid ""
-"Reproject coordinates displayed in the statusbar. Projection can be defined "
-"in GUI preferences dialog (tab 'Display')"
+msgid "Reproject coordinates displayed in the statusbar. Projection can be defined in GUI preferences dialog (tab 'Display')"
 msgstr ""
 #: ../gui/wxpython/gui_modules/mapdisp.py:317
@@ -5403,9 +5062,7 @@
 "\n"
 "Details: %s"
 msgstr ""
-"Nie można przełączyć w tryb wyświetlania 3D. Rozszerzenie Python dla Nviz "
-"nie zostało znalezione lub załadowane poprawnie. Nastąpi przełączenie do "
-"trybu 2D.\n"
+"Nie można przełączyć w tryb wyświetlania 3D. Rozszerzenie Python dla Nviz nie zostało znalezione lub załadowane poprawnie. Nastąpi przełączenie do trybu 2D.\n"
 "\n"
 "Szczegóły: %s"
@@ -5465,9 +5122,7 @@
 #: ../gui/wxpython/gui_modules/mapdisp.py:1603
 #, python-format
-msgid ""
-"Click and drag with left mouse button to measure.%sDouble click with left "
-"button to clear."
+msgid "Click and drag with left mouse button to measure.%sDouble click with left button to clear."
 msgstr ""
 #: ../gui/wxpython/gui_modules/mapdisp.py:1610
@@ -5738,9 +5393,7 @@
 msgstr "Nie można utworzyć lokacji"
 #: ../gui/wxpython/gui_modules/location_wizard.py:228
-msgid ""
-"Title of the location is limited only to one line and 256 characters. The "
-"rest of the text will be ignored."
+msgid "Title of the location is limited only to one line and 256 characters. The rest of the text will be ignored."
 msgstr ""
 #: ../gui/wxpython/gui_modules/location_wizard.py:235
@@ -5989,12 +5642,8 @@
 #: ../gui/wxpython/gui_modules/location_wizard.py:1984
 #, python-format
-msgid ""
-"Location <%(loc)s> will be created in GIS data directory <%(dir)s>.You will "
-"need to change the default GIS data directory in the GRASS startup screen."
-msgstr ""
-"Lokacja <%(loc)s> zostanie utworzona w kartotece z danymi <%(dir)s>. Dostęp "
-"do niej będzie możliwy w trakcie uruchamiania programu. "
+msgid "Location <%(loc)s> will be created in GIS data directory <%(dir)s>.You will need to change the default GIS data directory in the GRASS startup screen."
+msgstr "Lokacja <%(loc)s> zostanie utworzona w kartotece z danymi <%(dir)s>. Dostęp do niej będzie możliwy w trakcie uruchamiania programu. "
 #: ../gui/wxpython/gui_modules/location_wizard.py:1989
 msgid "New GIS data directory"
@@ -6993,8 +6642,7 @@
 #: ../gui/wxpython/gui_modules/vdigit.py:114
 msgid ""
-"Unable to initialize display driver of vector digitizer. See 'Command "
-"output' for details.\n"
+"Unable to initialize display driver of vector digitizer. See 'Command output' for details.\n"
 "\n"
 "Details: "
 msgstr ""
@@ -7005,8 +6653,7 @@
 msgid ""
 "Unable to open vector map <%s> for editing.\n"
 "\n"
-"Data are probably corrupted, try to run v.build to rebuild the topology "
-"(Vector->Develop vector map->Create/rebuild topology)."
+"Data are probably corrupted, try to run v.build to rebuild the topology (Vector->Develop vector map->Create/rebuild topology)."
 msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:684
@@ -7077,8 +6724,7 @@
 msgstr "Wybierz obiekty znajdujące się wewnątrz obszaru zaznaczenia"
 #: ../gui/wxpython/gui_modules/vdigit.py:1320
-msgid ""
-"By default are selected all features overlapping selection bounding box "
+msgid "By default are selected all features overlapping selection bounding box "
 msgstr "Domyślnie są wybrane wszystkie obiekty nachodzące na prostokąt wyboru"
 #: ../gui/wxpython/gui_modules/vdigit.py:1323
@@ -7208,9 +6854,7 @@
 msgstr "Parametry"
 #: ../gui/wxpython/gui_modules/vdigit.py:1606
-msgid ""
-"Note: These settings are stored  in the workspace not in the vector "
-"digitizer preferences."
+msgid "Note: These settings are stored  in the workspace not in the vector digitizer preferences."
 msgstr ""
 #: ../gui/wxpython/gui_modules/vdigit.py:1636
@@ -7462,9 +7106,7 @@
 #: ../gui/wxpython/gui_modules/dbm_base.py:40
 #: ../gui/wxpython/gui_modules/dbm.py:298
 msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
-msgstr ""
-"Nie można odszyfrować wartości. Ustaw kodowanie w preferencjach GUI "
-"(\"Atrybuty\")."
+msgstr "Nie można odszyfrować wartości. Ustaw kodowanie w preferencjach GUI (\"Atrybuty\")."
 #: ../gui/wxpython/gui_modules/gmodeler.py:90
 msgid "model"
@@ -7543,12 +7185,8 @@
 #: ../gui/wxpython/gui_modules/gmodeler.py:776
 #: ../gui/wxpython/gui_modules/gmodeler.py:889
 #, fuzzy
-msgid ""
-"Current model is not empty. Do you want to store current settings to model "
-"file?"
-msgstr ""
-"Aktualny plik projektu nie jest pusty. Czy chcesz zapisać aktualne "
-"ustawienia do pliku projektu?"
+msgid "Current model is not empty. Do you want to store current settings to model file?"
+msgstr "Aktualny plik projektu nie jest pusty. Czy chcesz zapisać aktualne ustawienia do pliku projektu?"
 #: ../gui/wxpython/gui_modules/gmodeler.py:779
 #: ../gui/wxpython/gui_modules/gmodeler.py:892
@@ -7631,8 +7269,7 @@
 msgstr "Zapisz plik"
 #: ../gui/wxpython/gui_modules/gmodeler.py:1186
-msgid ""
-"Module r.mapcalc cannot be used in the model. Use r.mapcalculator instead."
+msgid "Module r.mapcalc cannot be used in the model. Use r.mapcalculator instead."
 msgstr ""
 #: ../gui/wxpython/gui_modules/gmodeler.py:1244
@@ -7648,9 +7285,7 @@
 "\n"
 #: ../gui/wxpython/gui_modules/gmodeler.py:1247
-msgid ""
-"This program is free software under the GNU General Public License(>=v2). "
-"Read the file COPYING that comes with GRASS for details."
+msgid "This program is free software under the GNU General Public License(>=v2). Read the file COPYING that comes with GRASS for details."
 msgstr ""
 #: ../gui/wxpython/gui_modules/gmodeler.py:1377
@@ -7658,9 +7293,7 @@
 msgid ""
 "Reading model file <%s> failed.\n"
 "Invalid file, unable to parse XML document."
-msgstr ""
-"Odczyt pliku projektu <%s> nie powiódł się. Plik uszkodzony, nie można "
-"przeanalizować dokumentu XML."
+msgstr "Odczyt pliku projektu <%s> nie powiódł się. Plik uszkodzony, nie można przeanalizować dokumentu XML."
 #: ../gui/wxpython/gui_modules/gmodeler.py:1383
 msgid "Please wait, loading model..."
@@ -7869,8 +7502,7 @@
 #: ../gui/wxpython/gui_modules/gmodeler.py:3730
 #, fuzzy, python-format
 msgid "Variable <%s> already exists in the model. Adding variable failed."
-msgstr ""
-"Nie można utworzyć nowej tabeli. Tabela <%s> już istnieje w bazie danych."
+msgstr "Nie można utworzyć nowej tabeli. Tabela <%s> już istnieje w bazie danych."
 #: ../gui/wxpython/gui_modules/gmodeler.py:3759
 #, fuzzy
@@ -7927,12 +7559,8 @@
 #: ../gui/wxpython/gui_modules/gmodeler.py:4107
 #: ../gui/wxpython/gui_modules/dbm.py:1181
 #, python-format
-msgid ""
-"Selected data records (%d) will permanently deleted from table. Do you want "
-"to delete them?"
-msgstr ""
-"Wybrane rekordy (%d) zostaną całkowicie usunięte z tabeli. Chcesz je "
-"wykasować?"
+msgid "Selected data records (%d) will permanently deleted from table. Do you want to delete them?"
+msgstr "Wybrane rekordy (%d) zostaną całkowicie usunięte z tabeli. Chcesz je wykasować?"
 #: ../gui/wxpython/gui_modules/gmodeler.py:4110
 #: ../gui/wxpython/gui_modules/dbm.py:1184
@@ -8106,9 +7734,7 @@
 #: ../gui/wxpython/gui_modules/goutput.py:479
 #, python-format
-msgid ""
-"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
-"layer instead."
+msgid "Command '%s' not yet implemented in the WxGUI. Try adding it as a command layer instead."
 msgstr ""
 #: ../gui/wxpython/gui_modules/goutput.py:583
@@ -8117,10 +7743,8 @@
 #: ../gui/wxpython/gui_modules/goutput.py:698
 #, fuzzy
-msgid ""
-"Please note that the data are left in inconsistent state and may be corrupted"
-msgstr ""
-"Zauważ, że dane są pozostawione w niespójnym stanie i  mogą zostać uszkodzone"
+msgid "Please note that the data are left in inconsistent state and may be corrupted"
+msgstr "Zauważ, że dane są pozostawione w niespójnym stanie i  mogą zostać uszkodzone"
 #: ../gui/wxpython/gui_modules/goutput.py:701
 msgid "Command aborted"
@@ -8132,8 +7756,7 @@
 #: ../gui/wxpython/gui_modules/goutput.py:1051
 msgid "Unable to encode text. Please set encoding in GUI preferences."
-msgstr ""
-"Nie można zakodować tekstu. Proszę ustawić kodowanie w preferencjach GUI."
+msgstr "Nie można zakodować tekstu. Proszę ustawić kodowanie w preferencjach GUI."
 #: ../gui/wxpython/gui_modules/wxnviz.py:227
 #: ../gui/wxpython/gui_modules/wxnviz.py:238
@@ -8163,14 +7786,8 @@
 msgstr "Powód: %s"
 #: ../gui/wxpython/gui_modules/toolbars.py:190
-msgid ""
-"Note that the wxGUI's 3D view mode is currently disabled on MS Windows "
-"(hopefully this will be fixed soon). Please keep an eye out for updated "
-"versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
-msgstr ""
-"Widok 3D wxGUI jest obecnie wyłączony w systemie Windows (miejmy nadzieję, "
-"że niedługo uda nam się go naprawić). Śledź aktualizacje GRASS-a. Do tego "
-"czasu można używać \"NVIZ\" z menu Plik."
+msgid "Note that the wxGUI's 3D view mode is currently disabled on MS Windows (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS. In the meantime you can use \"NVIZ\" from the File menu."
+msgstr "Widok 3D wxGUI jest obecnie wyłączony w systemie Windows (miejmy nadzieję, że niedługo uda nam się go naprawić). Śledź aktualizacje GRASS-a. Do tego czasu można używać \"NVIZ\" z menu Plik."
 #: ../gui/wxpython/gui_modules/toolbars.py:197
 #: ../gui/wxpython/gui_modules/toolbars.py:1316
@@ -8182,14 +7799,8 @@
 msgstr "Narzędzia digitalizacji nie jest dostępne"
 #: ../gui/wxpython/gui_modules/toolbars.py:206
-msgid ""
-"Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
-"will be fixed soon). Please keep an eye out for updated versions of GRASS. "
-"In the meantime you can use \"v.digit\" from the Develop Vector menu."
-msgstr ""
-"Digitizer wxGUI jest obecnie wyłączony (miejmy nadzieję, że niedługo uda nam "
-"się go naprawić). Śledź aktualizacje GRASS-a. Do tego czasu można używać \"v."
-"digit\" z menu Wektor > Tworzenie mapy wektorowej."
+msgid "Note that the wxGUI's vector digitizer is currently disabled (hopefully this will be fixed soon). Please keep an eye out for updated versions of GRASS. In the meantime you can use \"v.digit\" from the Develop Vector menu."
+msgstr "Digitizer wxGUI jest obecnie wyłączony (miejmy nadzieję, że niedługo uda nam się go naprawić). Śledź aktualizacje GRASS-a. Do tego czasu można używać \"v.digit\" z menu Wektor > Tworzenie mapy wektorowej."
 #: ../gui/wxpython/gui_modules/toolbars.py:417
 msgid "Set map canvas for "
@@ -8281,12 +7892,8 @@
 msgstr "Proszę czekać, otwieram mapę wektorową <%s> do edycji..."
 #: ../gui/wxpython/gui_modules/toolbars.py:1304
-msgid ""
-"output' for details."
-msgstr ""
-"Nie można uruchomić sterownika wyświetlania dla digitizera. Szczegóły w "
-"zakładce 'Wynik polecenia'."
+msgid "Unable to initialize display driver of vector digitizer. See 'Command output' for details."
+msgstr "Nie można uruchomić sterownika wyświetlania dla digitizera. Szczegóły w zakładce 'Wynik polecenia'."
 #: ../gui/wxpython/gui_modules/toolbars.py:1355
 #, python-format
@@ -8324,16 +7931,12 @@
 #: ../gui/wxpython/gui_modules/render.py:430
 msgid "GISBASE not set. You must be in GRASS GIS to run this program."
-msgstr ""
-"GISBASE nie jest ustawiona. Musisz być w GRASS GIS, aby uruchomić ten "
-"program."
+msgstr "GISBASE nie jest ustawiona. Musisz być w GRASS GIS, aby uruchomić ten program."
 #: ../gui/wxpython/gui_modules/render.py:470
 #, python-format
 msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
-msgstr ""
-"Błąd: Nie można otworzyć '%(file)s'. Powód: %(ret)s. wxGUI zostało "
-"zamknięte.\n"
+msgstr "Błąd: Nie można otworzyć '%(file)s'. Powód: %(ret)s. wxGUI zostało zamknięte.\n"
 #: ../gui/wxpython/gui_modules/render.py:642
 #, python-format
@@ -8346,9 +7949,7 @@
 msgstr "Nie można powiększyć do mapy wektorowej <%s>."
 #: ../gui/wxpython/gui_modules/render.py:646
-msgid ""
-"Unable to get current geographic extent. Force quiting wxGUI. Please run "
-"manually g.region to fix the problem."
+msgid "Unable to get current geographic extent. Force quiting wxGUI. Please run manually g.region to fix the problem."
 msgstr ""
 #: ../gui/wxpython/gui_modules/render.py:929
@@ -8377,12 +7978,8 @@
 #: ../gui/wxpython/gui_modules/dbm.py:154
 #, python-format
-msgid ""
-"Attribute table <%s> not found. For creating the table switch to 'Manage "
-"layers' tab."
-msgstr ""
-"Nie znaleziono tabeli atrybutów <%s>. Aby utworzyć tabelę, przejdź do "
-"zakładki 'Zarządzanie warstwami'."
+msgid "Attribute table <%s> not found. For creating the table switch to 'Manage layers' tab."
+msgstr "Nie znaleziono tabeli atrybutów <%s>. Aby utworzyć tabelę, przejdź do zakładki 'Zarządzanie warstwami'."
 #: ../gui/wxpython/gui_modules/dbm.py:165
 #, python-format
@@ -8414,14 +8011,11 @@
 #: ../gui/wxpython/gui_modules/dbm.py:307
 #, python-format
 msgid ""
-"Error loading attribute data. Record number: %(rec)d. Unable to convert "
-"value '%(val)s' in key column (%(key)s) to integer.\n"
+"Error loading attribute data. Record number: %(rec)d. Unable to convert value '%(val)s' in key column (%(key)s) to integer.\n"
 "\n"
 "Details: %(detail)s"
 msgstr ""
-"Błąd podczas wczytywania danych atrybutowych. Numer wiersza: %(rec)d. Nie "
-"można przekonwertować wartości '%(val)s' w kolumnie klucza (%(key)s) na "
-"integer.\n"
+"Błąd podczas wczytywania danych atrybutowych. Numer wiersza: %(rec)d. Nie można przekonwertować wartości '%(val)s' w kolumnie klucza (%(key)s) na integer.\n"
 "\n"
 "Szczegóły: %(detail)s"
@@ -8481,9 +8075,7 @@
 #: ../gui/wxpython/gui_modules/dbm.py:590
 #, python-format
-msgid ""
-"Database connection for vector map <%s> is not defined in DB file. You can "
-"define new connection in 'Manage layers' tab."
+msgid "Database connection for vector map <%s> is not defined in DB file. You can define new connection in 'Manage layers' tab."
 msgstr ""
 #: ../gui/wxpython/gui_modules/dbm.py:594
@@ -8627,12 +8219,8 @@
 #: ../gui/wxpython/gui_modules/dbm.py:1227
 #, python-format
-msgid ""
-"All data records (%d) will permanently deleted from table. Do you want to "
-"delete them?"
-msgstr ""
-"Wszystkie rekordy (%d) zostaną całkowicie usunięte z tabeli. Chcesz je "
-"wykasować?"
+msgid "All data records (%d) will permanently deleted from table. Do you want to delete them?"
+msgstr "Wszystkie rekordy (%d) zostaną całkowicie usunięte z tabeli. Chcesz je wykasować?"
 #: ../gui/wxpython/gui_modules/dbm.py:1373
 #, python-format
@@ -8668,21 +8256,13 @@
 #: ../gui/wxpython/gui_modules/dbm.py:1612
 #, python-format
-msgid ""
-"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
-"exists in the table <%(table)s>."
-msgstr ""
-"Nie można zmienić nazwy kolumny <%(column)s> na <%(columnTo)s>. Kolumna już "
-"istnieje w tabeli <%(table)s>."
+msgid "Unable to rename column <%(column)s> to <%(columnTo)s>. Column already exists in the table <%(table)s>."
+msgstr "Nie można zmienić nazwy kolumny <%(column)s> na <%(columnTo)s>. Kolumna już istnieje w tabeli <%(table)s>."
 #: ../gui/wxpython/gui_modules/dbm.py:1629
 #, python-format
-msgid ""
-"Unable to rename column. Column <%(column)s> doesn't exist in the table <"
-"%(table)s>."
-msgstr ""
-"Nie można zmienić nazwy kolumny. Kolumna <%(column)s> nie istnieje w tabeli <"
-"%(table)s>."
+msgid "Unable to rename column. Column <%(column)s> doesn't exist in the table <%(table)s>."
+msgstr "Nie można zmienić nazwy kolumny. Kolumna <%(column)s> nie istnieje w tabeli <%(table)s>."
 #: ../gui/wxpython/gui_modules/dbm.py:1657
 msgid "Drop selected column"
@@ -8694,12 +8274,8 @@
 #: ../gui/wxpython/gui_modules/dbm.py:1675
 #, python-format
-msgid ""
-"Selected column '%s' will PERMANENTLY removed from table. Do you want to "
-"drop the column?"
-msgstr ""
-"Wybrane kolumny '%s' zostaną całkowicie usunięte z tabeli. Chcesz je "
-"wykasować?"
+msgid "Selected column '%s' will PERMANENTLY removed from table. Do you want to drop the column?"
+msgstr "Wybrane kolumny '%s' zostaną całkowicie usunięte z tabeli. Chcesz je wykasować?"
 #: ../gui/wxpython/gui_modules/dbm.py:1678
 #: ../gui/wxpython/gui_modules/dbm.py:1715
@@ -8773,12 +8349,8 @@
 msgstr "Klucz"
 #: ../gui/wxpython/gui_modules/dbm.py:2359
-msgid ""
-"Unknown default DB connection. Please define DB connection using db.connect "
-"module."
-msgstr ""
-"Nieznane domyślne połączenie DB. Proszę określić połączenie DB przy użyciu "
-"modułu db.connect."
+msgid "Unknown default DB connection. Please define DB connection using db.connect module."
+msgstr "Nieznane domyślne połączenie DB. Proszę określić połączenie DB przy użyciu modułu db.connect."
 #: ../gui/wxpython/gui_modules/dbm.py:2380
 msgid "Add layer"
@@ -8852,24 +8424,17 @@
 #: ../gui/wxpython/gui_modules/dbm.py:2857
 msgid "Unable to create new table. Table name or key column name is missing."
-msgstr ""
-"Nie można utworzyć nowej tabeli. Brakuje nazwy tabeli lub nazwy kolumny "
-"przechowującej klucz."
+msgstr "Nie można utworzyć nowej tabeli. Brakuje nazwy tabeli lub nazwy kolumny przechowującej klucz."
 #: ../gui/wxpython/gui_modules/dbm.py:2864
 #, python-format
 msgid "Unable to create new table. Table <%s> already exists in the database."
-msgstr ""
 #: ../gui/wxpython/gui_modules/dbm.py:2902
 #, python-format
-msgid ""
-"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
-"exists."
-msgstr ""
-"Nie można dodać nowej warstwy do mapy wektorowej <%(vector)s>. Warstwa "
-"%(layer)d już istnieje."
+msgid "Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already exists."
+msgstr "Nie można dodać nowej warstwy do mapy wektorowej <%(vector)s>. Warstwa %(layer)d już istnieje."
 #: ../gui/wxpython/gui_modules/gdialogs.py:108
 msgid "Select GRASS location and mapset"
@@ -8908,11 +8473,8 @@
 #: ../gui/wxpython/gui_modules/gdialogs.py:272
 #, python-format
-msgid ""
-"Vector map <%s> already exists in the current mapset. Do you want to "
-"overwrite it?"
-msgstr ""
-"Mapa wektorowa <%s> już istnieje w bieżącym mapsecie. Chcesz ją nadpisać?"
+msgid "Vector map <%s> already exists in the current mapset. Do you want to overwrite it?"
+msgstr "Mapa wektorowa <%s> już istnieje w bieżącym mapsecie. Chcesz ją nadpisać?"
 #: ../gui/wxpython/gui_modules/gdialogs.py:275
 msgid "Overwrite?"
@@ -9079,11 +8641,7 @@
 msgstr "Szablon:"
 #: ../gui/wxpython/gui_modules/profile.py:34
-msgid ""
-"This module requires the NumPy module, which could not be imported. It "
-"probably is not installed (it's not part of the standard Python "
-"distribution). See the Numeric Python site (http://numpy.scipy.org) for "
-"information on downloading source or binaries."
+msgid "This module requires the NumPy module, which could not be imported. It probably is not installed (it's not part of the standard Python distribution). See the Numeric Python site (http://numpy.scipy.org) for information on downloading source or binaries."
 msgstr ""
 #: ../gui/wxpython/gui_modules/profile.py:56
@@ -9348,8 +8906,7 @@
 #: ../gui/wxpython/gui_modules/layertree.py:374
 msgid "Set computational region from selected map(s) (ignore NULLs)"
-msgstr ""
-"Ustaw zasięg bieżącej mapy jako region obliczeniowy (ignoruj wartość NULL)"
+msgstr "Ustaw zasięg bieżącej mapy jako region obliczeniowy (ignoruj wartość NULL)"
 #: ../gui/wxpython/gui_modules/layertree.py:470
 msgid "Unable to create profile of raster map."
@@ -9505,9 +9062,7 @@
 msgstr "Zamknij okno po zakończeniu"
 #: ../gui/wxpython/gui_modules/menuform.py:819
-msgid ""
-"Close dialog when command is successfully finished. Change this settings in "
-"Preferences dialog ('Command' tab)."
+msgid "Close dialog when command is successfully finished. Change this settings in Preferences dialog ('Command' tab)."
 msgstr ""
 #: ../gui/wxpython/gui_modules/menuform.py:987
@@ -9854,9 +9409,7 @@
 msgstr "Zapisz układ okien jako domyślny"
 #: ../gui/wxpython/gui_modules/preferences.py:1148
-msgid ""
-"Save current position and size of Layer Manager window and opened Map "
-"Display window(s) and use as default for next sessions."
+msgid "Save current position and size of Layer Manager window and opened Map Display window(s) and use as default for next sessions."
 msgstr "Zapisuje bieżącą pozycję i rozmiar okien."
 #: ../gui/wxpython/gui_modules/preferences.py:1161
@@ -9985,9 +9538,7 @@
 msgstr "Plik EPSG:"
 #: ../gui/wxpython/gui_modules/preferences.py:1719
-msgid ""
-"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
-"directly."
+msgid "Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string directly."
 msgstr ""
 #: ../gui/wxpython/gui_modules/preferences.py:1727
@@ -10032,11 +9583,8 @@
 msgstr "Motyw ikon:"
 #: ../gui/wxpython/gui_modules/preferences.py:1888
-msgid ""
-"Note: For changing the icon theme, you must save the settings and restart "
-"this GUI."
-msgstr ""
-"Uwaga: Po zmianie motywu ikon musisz zapisać ustawienia i zrestartować GUI."
+msgid "Note: For changing the icon theme, you must save the settings and restart this GUI."
+msgstr "Uwaga: Po zmianie motywu ikon musisz zapisać ustawienia i zrestartować GUI."
 #: ../gui/wxpython/gui_modules/preferences.py:1917
 #, python-format
@@ -10211,9 +9759,7 @@
 "Mapset <PERMANENT> is required for valid GRASS location.\n"
 "\n"
 "This mapset cannot be renamed."
-msgstr ""
-"Mapset <PERMANENT> jest potrzebny do utworzenia prawidłowej lokacji GRASS."
-"\\n \\n Nazwy tego mapsetu to nie można zmienić."
+msgstr "Mapset <PERMANENT> jest potrzebny do utworzenia prawidłowej lokacji GRASS.\\n \\n Nazwy tego mapsetu to nie można zmienić."
 #: ../gui/wxpython/gis_set.py:445 ../gui/wxpython/gis_set.py:480
 #, python-format
@@ -10290,8 +9836,7 @@
 #: ../gui/wxpython/gis_set.py:521
 #, python-format
 msgid ""
-"Do you want to continue with deleting mapset <%(mapset)s> from location <"
-"%(location)s>?\n"
+"Do you want to continue with deleting mapset <%(mapset)s> from location <%(location)s>?\n"
 "\n"
 "ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
 msgstr ""
@@ -10352,676 +9897,5 @@
 msgstr "Uruchamianie GRASS GIS po raz pierwszy"
 #: ../gui/wxpython/gis_set.py:837
-msgid ""
-"GRASS needs a directory in which to store its data. Create one now if you "
-"have not already done so. A popular choice is \"grassdata\", located in your "
-"home directory."
-msgstr ""
-"GRASS potrzebuje katalogu, do przechowywania danych. Załóż go teraz, jeśli "
-"nie zostało to zrobione. Zwykle jest to \"grassdata\", znajdujący się w "
-"katalogu domowym."
-#, fuzzy
-#~ msgid "Shortest path using timetables"
-#~ msgstr "Najkrótsza trasa"
-#, fuzzy
-#~ msgid "Shortest path for all pairs"
-#, fuzzy
-#~ msgid "Vertex connectivity"
-#~ msgstr "Połączenie wektora z bazą danych"
-#, fuzzy
-#~ msgid "Components"
-#~ msgstr "wykładnik"
-#~ msgid "Location wizard"
-#~ msgstr "Kreator lokacji"
-#~ msgid "Choose input file"
-#~ msgstr "Wybierz plik wejściowy"
-#~ msgid "Import GDAL supported raster file into a binary raster map layer."
-#~ msgstr ""
-#~ "Importuje pliki rastrowe obsługiwane przez GDAL do binarnej mapy "
-#~ "rastrowej."
-#~ msgid "Bulk import of raster data"
-#~ msgstr "Import masowy"
-#~ msgid "Converts multiple GDAL supported layers to GRASS raster maps."
-#~ msgstr ""
-#~ "Konwertuje wybrane warstwy GDAL do mapy rastrowej GRASS-a przy użyciu r."
-#~ "in.gdal."
-#, fuzzy
-#~ msgid "Link GDAL supported raster file to a binary raster map layer."
-#~ msgstr ""
-#~ "rastrowej."
-#~ msgid "Bulk link of raster data"
-#~ msgstr "Linkowanie masowe"
-#~ msgid ""
-#~ "Link multiple GDAL supported raster maps as pseudo GRASS raster map "
-#~ "layers."
-#~ msgstr ""
-#~ "Tworzy link rastrowych plików wspieranych przez GDAL do binarnej mapy "
-#~ "rastrowej."
-#~ msgid "Bulk import of vector data"
-#~ msgid "Converts selected OGR layers to GRASS vector maps using v.in.ogr"
-#~ msgstr ""
-#~ "Konwertuje wybrane warstwy OGR do mapy rastrowej GRASS-a przy użyciu r.in."
-#~ "ogr."
-#, fuzzy
-#~ msgid "Creates a new vector as a read-only link to OGR layer."
-#~ msgstr ""
-#~ "Tworzy nową warstwę wektorową jako link do warstwy OGR tylko do odczytu."
-#~ msgid "Bulk link of vector data"
-#~ msgid ""
-#~ "Creates multiple new pseduo-vector maps as a read-only links using OGR."
-#~ msgstr ""
-#~ msgid "Bulk import of DXF"
-#~ msgstr "Masowy import DXF"
-#~ msgid "Converts multiple DXF layers to GRASS vector maps."
-#~ msgstr "Konwertuje wiele warstw DXF do map wektorowych GRASS-a."
-#~ msgid "Georectify raster and vector maps"
-#~ msgstr "Georektyfikacja map rastrowych i wektorowych"
-#, fuzzy
-#~ msgid "Generates stream channels."
-#~ msgstr "Wyznacz wysokości cieków"
-#, fuzzy
-#~ msgid "Creates watershed basins."
-#~ msgstr "Dział wodny zlewni"
-#~ msgid "Reclassify interactively"
-#~ msgstr "Reklasyfikuj interaktywnie"
-#~ msgid "Reclassify using rules file"
-#~ msgstr "Reklasyfikuj przy użyciu pliku reguł"
-#~ msgid "Recode using rules file"
-#~ msgstr "Przekoduj przy użyciu pliku reguł"
-#~ msgid "Allows projection conversion of vector maps."
-#~ msgstr "Umożliwia zmianę odwzorowania map wektorowych."
-#~ msgid "Set colors interactively by entering color rules"
-#~ msgstr "Ustaw kolory interaktywnie wprowadzając reguły kolorów"
-#~ msgid "Reclassify objects interactively"
-#~ msgstr "Reklasufikuj obiekty interaktywnie"
-#~ msgid "Reclassify objects using rules file"
-#~ msgid "Set/unset access to mapsets in current location"
-#~ msgstr "Ustaw dostępy do mapsetów w bieżącej lokacji"
-#~ msgid "GRASS GIS Map Display: 1"
-#~ msgstr "Okno Mapy GRASS GIS: 1"
-#~ msgid "Select image/map to display for ground control point (GCP) creation"
-#~ msgstr "Wybierz zobrazowanie/mapę do wyświetlenia w oknie wskazywania GCP"
-#~ msgid "Select display image/map:"
-#~ msgstr "Wybierz zobrazowanie/mapę:"
-#~ msgid "You must select a valid image/map in order to continue"
-#~ msgstr "Musisz wskazać właściwe zobrazowanie/mapę aby kontynuować"
-#~ msgid "Define/manage ground control points"
-#~ msgstr "Edytuj terenowe punkty kontrolne (GCP)"
-#~ msgid "Ground Control Points"
-#~ msgstr "Terenowe Punkty Kontrolne (GCP)"
-#~ msgid "POINTS file <%s> saved"
-#~ msgstr "Zbiór POINTAS<%s> został zapisany"
-#~ msgid "POINTS file saved"
-#~ msgstr "Zbiór POINTAS został zapisany"
-#~ msgid "Georectifier settings"
-#~ msgstr "Ustawienia georektyfikacji"
-#~ msgid "use| X coord"
-#~ msgstr "użyj współrzędnych | X "
-#~ msgid "Y coord"
-#~ msgstr "Y "
-#~ msgid "E coord"
-#~ msgstr "E "
-#~ msgid "N coord"
-#~ msgstr "N "
-#~ msgid "Ground Control Point"
-#~ msgstr "Terenowy Punkt Kontrolny GCP"
-#~ msgid "X:"
-#~ msgstr "X:"
-#~ msgid "Y:"
-#~ msgstr "Y:"
-#~ msgid "E:"
-#~ msgstr "E:"
-#~ msgid "N:"
-#~ msgstr "N:"
-#~ msgid "Georectifier settings saved to file '%s'."
-#~ msgstr "Ustawienia georektyfikacji zapisano w pliku '%s'."
-#~ msgid "Enter rules"
-#~ msgstr "Wprowadź reguły"
-#~ msgid "Create new color table using color rules"
-#~ msgstr "Utwórz nową tabelę kolorów używając regół kolorów"
-#~ msgid "Raster map:"
-#~ msgstr "Mapa rastrowa:"
-#~ msgid "Enter color rules"
-#~ msgstr "Wprowadź reguły kolorów"
-#~ msgid "Reclassify raster map using rules"
-#~ msgstr "Reklasyfikuj mapę rastrową używając regół kolorów"
-#~ msgid "Raster map to reclassify:"
-#~ msgstr "Mapa rastrowa do ponownej klasyfikacji:"
-#~ msgid "Reclassified raster map:"
-#~ msgstr "Reklasyfikowana mapa rastrowa:"
-#~ msgid "Enter reclassification rules"
-#~ msgstr "Wprowadź reguły reklasyfikacji"
-#~ msgid "Recode raster map using rules"
-#~ msgstr "Przekoduj mapę rastrową używając regół kolorów"
-#~ msgid "Raster map to recode:"
-#~ msgstr "Mapa rastrowa do przekodowania:"
-#~ msgid "Recoded raster map:"
-#~ msgstr "Przekodowana mapa rastrowa:"
-#~ msgid "Enter recoding rules"
-#~ msgstr "Wprowadź reguły przekodowania"
-#~ msgid "Reclassify vector map using SQL rules"
-#~ msgstr "Reklasyfikuj mapę wektorową przy użyciu zapytań SQL"
-#~ msgid "Vector map to reclassify:"
-#~ msgstr "Mapa wektorowa do reklasyfikacji:"
-#~ msgid "Reclassified vector map:"
-#~ msgstr "Reklasyfikowana mapa wektorowa"
-#~ msgid "overwrite existing file"
-#~ msgstr "nadpisz istniejący plik"
-#~ msgid "Map layers for each display"
-#~ msgstr "Lista warstw"
-#~ msgid "Unable to read workspace file"
-#~ msgstr "Nie można odczytać pliku projektu"
-#~ msgid "Unable to open workspace file <%s> for writing."
-#~ msgstr "Nie można otworzyć pliku projektu <%s> do zapisu."
-#~ msgid "GRASS GIS Raster Map Calculator (3D raster)"
-#~ msgstr "Kalkulator Map (rastrowych 3D) GRASS GIS"
-#~ msgid "GPL.TXT file missing"
-#~ msgstr "Brak pliku GPL.TXT"
-#~ msgid "AUTHORS file missing"
-#~ msgstr "Brak pliku AUTHORS"
-#~ msgid "Add 3D raster map"
-#~ msgstr "Dodaj mapę rastrową 3D"
-#~ msgid "Redraw GCP markers in map displays"
-#~ msgstr "Przerysuj znaczniki GCP w oknie mapy"
-#~ msgid "Save workspace to open file"
-#~ msgstr "Zapisuje projekt w bieżącym pliku"
-#~ msgid "Close loaded workspace"
-#~ msgstr "Zamyka bieżący projekt"
-#~ msgid "MAT-File (v.4) import"
-#~ msgstr "MAT-File (v.4)   (r.in.mat)"
-#~ msgid "MAT-File (v.4) export"
-#~ msgstr "do MAT-File (v.4)"
-#~ msgid "E&xit"
-#~ msgstr "&Koniec"
-#~ msgid "Config"
-#~ msgstr "Ustawienia"
-#~ msgid "Generates a raster map layer showing watershed subbasins."
-#~ msgstr "Generuje warstwę mapy rastrowej pokazującą działy wodne zlewni."
-#~ msgid "Display shortest route (requires XTerm)"
-#~ msgstr "Ustawienia (wymaga XTerm)"
-#~ msgid "Uses a GRASS vector points map to produce a convex hull vector map."
-#~ msgstr ""
-#~ "Na podstawie mapy punktowej GRASS-a tworzy warstwę wektorową z otoczką "
-#~ "wypukłą."
-#~ msgid "GRASS GIS GUI help"
-#~ msgstr "O interfejsie użytkownika"
-#~ msgid "Set ground control points (GCPs)"
-#~ msgstr "Umieść punkty kontrolne (GCP)"
-#~ msgid "Quit wxGUI. GRASS is not running."
-#~ msgstr "Zamknij wxGUI. GRASS nie jest uruchomiony."
-#~ msgid "wxGUI closed."
-#~ msgstr "wxGUI zamknięte."
-#~ msgid "Error in command execution %s"
-#~ msgstr "Wykonanie polecenia %s nie powiodło się"
-#~ msgid "Preferences error"
-#~ msgstr "Błąd ustawień"
-#~ msgid "Attribute table manager error"
-#~ msgstr "Błąd menadżera tabeli atrybutów"
-#~ msgid "Nviz error"
-#~ msgstr "Błąd Nviz"
-#~ msgid "Map calculator"
-#~ msgstr "Kalkulator map"
-#~ msgid "3D View Tools"
-#~ msgstr "Narzędzia widoku 3D"
-#~ msgid "Default"
-#~ msgstr "Domyślny"
-#~ msgid "Restore default settings"
-#~ msgstr "Przywróć ustawienia domyślne"
-#~ msgid "Nviz toolbar"
-#~ msgstr "Pasek narzędzi Nviz"
-#~ msgid "Unable to read EPGS file: '%s'"
-#~ msgstr "Nie można przeczytać pliku z kodamu EPSG: %s"
-#~ msgid "Resolution cannot be 0"
-#~ msgstr "Rozdzielczość nie może być 0"
-#~ msgid "Extents set incorrectly"
-#~ msgstr "Niepoprawnie ustawione zakresy"
-#~ msgid "DXF file:"
-#~ msgstr "Plik DXF:"
-#~ msgid "Input DXF file"
-#~ msgstr "Plik DXF do wczytania"
-#~ msgid "Input directory"
-#~ msgstr "Katalog wejściowy"
-#~ msgid "Choose DXF file:"
-#~ msgstr "Wybierz plik DXF:"
-#~ msgid "Choose directory:"
-#~ msgstr "Wybierz ścieżkę:"
-#~ msgid "Select file extension:"
-#~ msgstr "Wybierz rozszerzenie pliku:"
-#~ msgid ""
-#~ "Unable to start vector digitizer.\n"
-#~ "The VDigit python extension was not found or loaded properly.\n"
-#~ "Switching back to 2D display mode.\n"
-#~ "\n"
-#~ "Details: %s"
-#~ msgstr ""
-#~ "Nie można uruchomić digitalizacji wektorów. Rozszerzenie Pythona VDigit "
-#~ "nie zostało znalezione lub załadowane poprawnie. Nastąpi przełączenie do "
-#~ "trybu 2D.\n"
-#~ "\n"
-#~ "Szczegóły: %s"
-#~ msgid ""
-#~ "Unable to switch to 3D display mode.\n"
-#~ "The GLCanvas class has not been included with this build of wxPython!\n"
-#~ "\n"
-#~ "Details: %s"
-#~ msgstr ""
-#~ "Nie można przełączyć w tryb wyświetlania 3D. Klasa GLCanvas nie jest "
-#~ "dostępna w tej wersji wxPython! Nastąpi przełączenie do trybu 2D.\n"
-#~ "\n"
-#~ "Szczegóły: %s"
-#~ msgid "GRASS %s Map Calculator"
-#~ msgstr "GRASS %s Kalkulator Map"
-#~ msgid "Create & manage ground control points"
-#~ msgid "Height"
-#~ msgstr "Wysokość"
-#~ msgid "Twist"
-#~ msgstr "Skręcenie"
-#~ msgid "Z-exag"
-#~ msgstr "Przewyższenie"
-#~ msgid "(step):"
-#~ msgstr "(krok):"
-#~ msgid "Import raster map"
-#~ msgstr "Import map rastrowych"
-#~ msgid "Multiple raster data import using GDAL"
-#~ msgstr "Import wielu danych rastrowych (GDAL)"
-#~ msgid "Link to GDAL"
-#~ msgstr "Link do GDAL"
-#~ msgid "Multiple link to GDAL"
-#~ msgid "Import vector map"
-#~ msgstr "Import mapy wektorowej"
-#~ msgid "Import vector data using OGR"
-#~ msgstr "Import mapy wektorowej (OGR)"
-#~ msgid "Multiple vector data import using OGR"
-#~ msgstr "Import wielu warstw wektorowych (OGR)"
-#~ msgid "Link to OGR"
-#~ msgstr "Link do OGR"
-#~ msgid "Multiple link to OGR"
-#~ msgid "Multiple DXF layers import"
-#~ msgstr "Import wielu warstw DXF"
-#~ msgid "Import grid 3D volume"
-#~ msgstr "Import grid 3D volume"
-#~ msgid "Multiple export formats using GDAL"
-#~ msgstr "Do różnych formatów GDAL"
-#~ msgid "Export grid 3D volume"
-#~ msgstr "Do grid3D volume"
-#~ msgid "Map calculator for volumetric map algebra"
-#~ msgstr "Kalkulator do algebry map rastrowych 3D"
-#~ msgid ""
-#~ "Current name: %s\n"
-#~ "Enter new name:"
-#~ msgstr ""
-#~ "Bieżąca nazwa: %s\n"
-#~ "Wprowadź nową nazwę:"
-#~ msgid "Unable to rename mapset"
-#~ msgstr "Nie można zmienić nazwy mapsetu"
-#~ msgid "Unable to rename location"
-#~ msgstr "Nie można zmienić nazwy lokacji"
-#~ msgid "Import GDAL layers"
-#~ msgstr "Import warstw GDAL"
-#~ msgid "Link GDAL layers"
-#~ msgid "Import OGR layers"
-#~ msgstr "Import warstw OGR"
-#~ msgid "Link OGR layers"
-#~ msgid "Command %s could not be run"
-#~ msgstr "Polecenie '%s' nie zostało jeszcze zaimplementowana."
-#~ msgid "Command '%s' not yet implemented."
-#~ msgid "&Close"
-#~ msgstr "Zamknij"
-#~ msgid "&Stop"
-#~ msgstr "górę"
-#~ msgid " (those in bold typeface are required)"
-#~ msgstr "(pogrubione są wymagane)"
-#~ msgid "Click here to show database connection information"
-#~ msgstr "Aby zobaczyć informację o połączeniu z bazą danych, kliknij tutaj"
-#~ msgid "Click here to hide database connection information"
-#~ msgstr "Aby ukryć informację o połączeniu z bazą danych, kliknij tutaj"
-#~ msgid "Encoding"
-#~ msgstr "Kodowanie"
-#~ msgid "Note: Requires GUI restart."
-#~ msgstr "Uwaga: Wymagany restart GUI."
-#~ msgid "Group"
-#~ msgstr "Grupa"
-#~ msgid "Create custom PROJ.4 parameters string for coordinate system"
-#~ msgstr "Utwórz własne parametry PROJ.4 odwzorowania kartograficznego"
-#~ msgid "Select ellipsoid"
-#~ msgstr "Wybierz elipsoidę"
-#~ msgid "Set zone for UTM projection:"
-#~ msgstr "Wybierz strefę projekcji UTM:"
-#~ msgid "Zone:"
-#~ msgstr "Strefa:"
-#~ msgid "Hemisphere for zone:"
-#~ msgstr "Półkula:"
-#~ msgid "Transformation parameters:"
-#~ msgstr "Parametry transformacji:"
-#~ msgid "Browse EPSG Codes"
-#~ msgstr "Wyświetl kody EPSG"
-#~ msgid "Output vector map name"
-#~ msgstr "Nazwa wektorowej mapy wyjściowej"
-#~ msgid "Add overlay"
-#~ msgstr "Dodaj warstwy"
-#~ msgid "Add graphic overlays to map"
-#~ msgstr "Dodaj warstwy graficzne do mapy"
-#~ msgid "GRASS GIS Layer Manager (Experimental Prototype)"
-#~ msgstr "Menadżer warstw GRASS GIS (Prototyp)"
-#~ msgid "Save current settings?"
-#~ msgstr "Zapisać bieżące ustawienia?"
-#~ msgid "New workspace"
-#~ msgstr "Nowy projekt"
-#~ msgid "Create new workspace file (erase current workspace settings first)"
-#~ msgstr ""
-#~ "Utwórz nowy plik projektu (najpierw wymaż bieżące ustawienia pliku "
-#~ "projektu)"
-#~ msgid "Open existing workspace"
-#~ msgstr "Otwórz projekt"
-#~ msgid "Load map layers from GRC file to layer tree (not fully implemented)"
-#~ msgstr ""
-#~ "Załaduj warstwy mapy z pliku GRC do listy warstw (nie w pełni "
-#~ "zaimplementowane)"
-#~ msgid "Save workspace as"
-#~ msgstr "Zapisz projekt jako"
-#~ msgid "Save current workspace as file"
-#~ msgstr "Zapisz bieżący projekt jako plik"
-#~ msgid "Close current workspace"
-#~ msgstr "Zamknij bieżący plik projektu"
-#~ msgid "Close current workspace file"
-#~ msgid ""
-#~ "Computes direct (beam), diffuse and reflected solar irradiation raster "
-#~ "maps for given day, latitude, surface and atmospheric conditions. Solar "
-#~ "parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-#~ "irradiance, daylight length) are saved in the map history file. "
-#~ "Alternatively, a local time can be specified to compute solar incidence "
-#~ "angle and/or irradiance raster maps. The shadowing effect of the "
-#~ "topography is optionally incorporated."
-#~ msgstr ""
-#~ "Oblicza mapy rastrowe bezpośredniego, rozproszonego i odbitego "
-#~ "napromienienia słonecznego dla danego dnia, szerokości geogr., "
-#~ "powierzchni i warunków atmosferycznych.Parametry słoneczne (np. czas "
-#~ "wschodu i zachodu, deklinacja, napromieniowanie pozaziemskie, długość "
-#~ "dnia) są zapisane w pliku historii mapy. Alternatywnie do obliczenia kąta "
-#~ "padania promieni słonecznych i/lub napromieniowania może być użyty czas "
-#~ "lokalny. Opcjonalnie włączony jest efekt cieniowania topografii."
-#~ msgid "Reclassify raster categories interactively by entering reclass rules"
-#~ msgstr "Reklasyfikuj kategorie rastra interaktywnie według zadanych reguł"
-#~ msgid ""
-#~ "Recode raster categories interactively by entering recode rules (create "
-#~ "new raster map)"
-#~ msgstr ""
-#~ "Przekoduj kategorie rastra interaktywnie według zadanych reguł (tworzy "
-#~ "nową mapę rastrową)"
-#~ msgid "Generalization"
-#~ msgstr "Generalizacja"
-#~ msgid "Reclassify vector objects interactively by entering SQL rules"
-#~ msgstr ""
-#~ "Reklasufikuj obiekty wektorowe interaktywnie przy użyciu zapytania SQL"
-#~ msgid ""
-#~ "Hue-intensity-saturation (his) to red-green-blue (rgb) raster map color "
-#~ "transformation function."
-#~ msgstr ""
-#~ "Funkcja transformacji kolorów mapy hue-intensity-saturation(his) do red."
-#~ "green-blue(rgb) "
-#~ msgid ""
-#~ "Red-green-blue (rgb) to hue-intensity-saturation (his) raster map color "
-#~ "transformation function"
-#~ msgstr ""
-#~ "Funkcja transformacji kolorów mapy red.green-blue(rgb) do hue-intensity-"
-#~ "saturation(his) "
-#~ msgid "Ortho Photo rectification"
-#~ msgstr "Rektyfikacja orto foto"
-#~ msgid "All"
-#~ msgstr "Wszystko"
-#~ msgid "Make null cells opaque"
-#~ msgstr "Ustaw komórki NULL jako nieprzezroczyste"
-#~ msgid "Albedo"
-#~ msgstr "Albedo"
-#~ msgid "Witdh:"
-#~ msgstr "Szerokość:"
-#~ msgid "About wxPython GRASS GUI"
-#~ msgstr "O wxPython GRASS GUI"
-#~ msgid "Error in command execution '%s'"
-#~ msgstr "Wykonanie polecenia '%s' nie powiodło się"
-#~ msgid "Use for all loaded surfaces"
-#~ msgstr "Zastosuj dla wszystkich powierzchni"
-#~ msgid "It assumes a cartesian coordinate system"
-#~ msgstr "Przelicza kąty i odległości do współrzędnych i odwrotnie."
-#~ msgid "Emissivity"
-#~ msgstr "Emisja"
-#~ msgid "Cancel the command settings and ignore changes"
-#~ msgstr "Zamknij okno bez zapisywania zmian"
-#~ msgid "No database record available."
-#~ msgstr "Import tabeli baz danych"
-#~ msgid "Vector digitizer interface:"
-#~ msgstr "Ustawienia digitizera zapisano w pliku <%s>."
-#~ msgid "Query selected vector map in editable mode"
-#~ msgstr "Zapytania do map wektorowych (tryb edycji) "
-#~ msgid "Albedo from Modis, Aster, Landsat, AVHRR."
-#~ msgstr "Albedo z danych Modis, Aster, Landsat, AVHRR."
-#~ msgid "Vegetation Indices"
-#~ msgstr "Indeksy wegetacji"
-#~ msgid "14 types of vegetation Indices."
-#~ msgstr "14 typów indeksów wegetacji"
-#~ msgid "Emissivity from NDVI."
-#~ msgstr "Emisja z NDVI."
-#~ msgid "GRASS GIS Map Calculator"
-#~ msgstr "Kalkulator Map GRASS GIS"
-#~ msgid "GRASS GIS Map Calculator (3D raster)"
-#~ msgid "Projection for current location"
-#~ msgstr "Układ współrzędnych bieżącej lokacji"
-#~ msgid "Raster calculator"
-#~ msgstr "Kalkulator rastrów"
-#~ msgid "logical AND (ignores NULLs"
-#~ msgstr "logiczne AND (ignoruje wartości null"
-#~ msgid "logical OR (ignores NULLs"
-#~ msgstr "logiczne OR (ignoruje wartości null"
-#~ msgid "Create/edit projection information for current location"
-#~ msgstr ""
-#~ "Utwórz/edytuj informacje o układzie współrzędnych dla bieżącej lokacji"
+msgid "GRASS needs a directory in which to store its data. Create one now if you have not already done so. A popular choice is \"grassdata\", located in your home directory."
+msgstr "GRASS potrzebuje katalogu, do przechowywania danych. Załóż go teraz, jeśli nie zostało to zrobione. Zwykle jest to \"grassdata\", znajdujący się w katalogu domowym."
