[GRASS-SVN] r45346 - grass/branches/develbranch_6/vector/v.overlay
Wed Feb 9 09:43:06 EST 2011
Author: neteler
Date: 2011-02-09 06:43:06 -0800 (Wed, 09 Feb 2011)
New Revision: 45346
   grass/branches/develbranch_6/vector/v.overlay/main.c
patch from Martin Landa to catch wrong atype parameter (user error)
Modified: grass/branches/develbranch_6/vector/v.overlay/main.c
--- grass/branches/develbranch_6/vector/v.overlay/main.c	2011-02-09 14:42:51 UTC (rev 45345)
+++ grass/branches/develbranch_6/vector/v.overlay/main.c	2011-02-09 14:43:06 UTC (rev 45346)
@@ -194,7 +194,7 @@
     /* Copy lines to output */
     for (input = 0; input < 2; input++) {
-	int ncats, index;
+	int ncats, index, nlines_out;
 	G_message(_("Copying vector objects from vector map <%s>..."),
 		  in_opt[input]->answer);
@@ -210,6 +210,7 @@
 	nlines = Vect_get_num_lines(&(In[input]));
+	nlines_out = 0;
 	for (line = 1; line <= nlines; line++) {
 	    int ltype;
@@ -227,8 +228,15 @@
 	    Vect_write_line(&Out, ltype, Points, Cats);
+	    nlines_out++;
+	if (nlines_out == 0) {
+	    Vect_delete(out_opt->answer);
+	    G_fatal_error(_("No %s features found in vector map <%s>. Verify '%s' parameter."),
+		      type_opt[input]->answer, Vect_get_full_name(&(In[input])),
+		      type_opt[input]->key);
 	/* Allocate attributes */
 	attr[input].n = 0;
 	/* this may be more than necessary */
