[GRASS-SVN] r45472 - grass/trunk/lib/python
Sun Feb 27 06:31:46 EST 2011
Author: martinl
Date: 2011-02-27 03:31:46 -0800 (Sun, 27 Feb 2011)
New Revision: 45472
   grass/trunk/lib/python/array.py
   grass/trunk/lib/python/pythonlib.dox
pythonlib: document array.py
Modified: grass/trunk/lib/python/array.py
--- grass/trunk/lib/python/array.py	2011-02-27 11:09:51 UTC (rev 45471)
+++ grass/trunk/lib/python/array.py	2011-02-27 11:31:46 UTC (rev 45472)
@@ -1,6 +1,6 @@
 """!@package grass.script.array
- at brief GRASS Python scripting module
+ at brief GRASS Python scripting module (rasters with numpy)
 Functions to use GRASS rasters with NumPy.
@@ -11,7 +11,7 @@
 @endcode
-(C) 2010 by Glynn Clements and the GRASS Development Team
+(C) 2010-2011 by Glynn Clements and the GRASS Development Team
 This program is free software under the GNU General Public
 License (>=v2). Read the file COPYING that comes with GRASS
 for details.
@@ -26,46 +26,59 @@
 # i18N
 import gettext
-gettext.install('grasslibs', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
+gettext.install('grasslibs', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
 class array(numpy.memmap):
     def __new__(cls, dtype = numpy.double):
+        """!Define new numpy array
+        @param cls
+        @param dtype data type (default: numpy.double)
 	reg = grass.region()
 	r = reg['rows']
 	c = reg['cols']
 	shape = (r, c)
 	filename = grass.tempfile()
 	self = numpy.memmap.__new__(
 	    cls,
 	    filename = filename,
 	    dtype = dtype,
 	    mode = 'w+',
 	    shape = shape)
 	self.filename = filename
 	return self
     def _close(self):
 	numpy.memmap._close(self)
 	if isinstance(self, array):
 	    grass.try_remove(self.filename)
     def read(self, mapname, null = None):
+        """!Read raster map into array
+        @param mapname name of raster map to be read
+        @param null null value
+        @return 0 on success
+        @return non-zero code on failure
 	kind = self.dtype.kind
 	size = self.dtype.itemsize
 	if kind == 'f':
 	    flags = 'f'
 	elif kind in 'biu':
 	    flags = 'i'
 	else:
-	    raise ValueError(_('invalid kind <%s>') % kind)
+	    raise ValueError(_('Invalid kind <%s>') % kind)
 	if size not in [1,2,4,8]:
-	    raise ValueError(_('invalid size <%d>') % size)
+	    raise ValueError(_('Invalid size <%d>') % size)
 	return grass.run_command(
 	    'r.out.bin',
 	    flags = flags,
@@ -75,28 +88,37 @@
 	    null = null,
 	    quiet = True)
+    def write(self, mapname, title = None, null = None, overwrite = None):
+        """!Write array into raster map
-    def write(self, mapname, title = None, null = None, overwrite = None):
+        @param mapname name for raster map
+        @param title title for raster map
+        @param overwrite True for overwritting existing raster maps
 	if kind == 'f':
 	    if size == 4:
 		flags = 'f'
 	    elif size == 8:
 		flags = 'd'
 	    else:
-		raise ValueError(_('invalid FP size <%d>') % size)
+		raise ValueError(_('Invalid FP size <%d>') % size)
 	    size = None
 	elif kind in 'biu':
 	    if size not in [1,2,4]:
-		raise ValueError(_('invalid integer size <%d>') % size)
+		raise ValueError(_('Invalid integer size <%d>') % size)
 	    flags = None
 	else:
 	    'r.in.bin',
 	    flags = flags,
@@ -113,3 +135,4 @@
 	    west  = reg['w'],
 	    rows  = reg['rows'],
 	    cols  = reg['cols'])
Modified: grass/trunk/lib/python/pythonlib.dox
--- grass/trunk/lib/python/pythonlib.dox	2011-02-27 11:09:51 UTC (rev 45471)
+++ grass/trunk/lib/python/pythonlib.dox	2011-02-27 11:31:46 UTC (rev 45472)
@@ -16,6 +16,7 @@
 - raster.py
 - vector.py
 - setup.py
+- array.py
 <b>Table of content</b>
@@ -26,17 +27,20 @@
  - \subpage pythonRaster
  - \subpage pythonVector
  - \subpage pythonSetup
+ - \subpage pythonArray
 \section pythonScripting GRASS scripting tasks for Python provided by "grass.script"
-Usage:
+Statement
 \code
 import grass.script as grass
 \endcode
-or just import selected module, e.g.
+imports core.py, db.py, raster.py and vector.py modules.
+To import only selected module
 \code
 from grass.script import core as grass
 \endcode
@@ -235,8 +239,20 @@
 \section pythonSetup Setup
+\code
+from grass.script import setup as gsetup
+\endcode
  - python::setup::init()
+\section pythonArray Array
+\code
+from grass.script import array as garray
+\endcode
+ - python::array::array
 \section pythonAuthors Authors
  Glynn Clements
