[GRASS-SVN] r44912 - grass/trunk/gui/wxpython/gui_modules
Sun Jan 9 09:35:52 EST 2011
Author: martinl
Date: 2011-01-09 06:35:52 -0800 (Sun, 09 Jan 2011)
New Revision: 44912
   grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
   grass/trunk/gui/wxpython/gui_modules/wxvdigit.py
   grass/trunk/gui/wxpython/gui_modules/wxvdriver.py
wxGUI/vdigit pythonization: merge/snap/query/split/connect implemented
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2011-01-09 12:14:15 UTC (rev 44911)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2011-01-09 14:35:52 UTC (rev 44912)
@@ -1704,11 +1704,11 @@
                     self.copyCatsIds = digitClass.GetDisplay().GetSelected()
         elif digitToolbar.GetAction() == "queryLine":
-            selected = digitClass.SelectLinesByQuery(pos1, pos2)
+            selected = digitClass.SelectLinesByQuery(bbox = (pos1, pos2))
             nselected = len(selected)
             if nselected > 0:
                 digitClass.GetDisplay().SetSelected(selected)
         else:
             # -> moveLine || deleteLine, etc. (select by point/box)
             if digitToolbar.GetAction() == 'moveLine' and \
@@ -1741,7 +1741,7 @@
             # check for duplicates
-            if UserSettings.Get(group = 'vdigit', key = 'checkForDupl', subkey = 'enabled') is True:
+            if UserSettings.Get(group = 'vdigit', key = 'checkForDupl', subkey = 'enabled'):
                 dupl = digitClass.GetDisplay().GetDuplicates()
                 self.UpdateMap(render = False)
Modified: grass/trunk/gui/wxpython/gui_modules/wxvdigit.py
--- grass/trunk/gui/wxpython/gui_modules/wxvdigit.py	2011-01-09 12:14:15 UTC (rev 44911)
+++ grass/trunk/gui/wxpython/gui_modules/wxvdigit.py	2011-01-09 14:35:52 UTC (rev 44912)
@@ -31,6 +31,10 @@
 class VDigitError:
     def __init__(self, parent):
+        """!Class for managing error messages for vector digitizer
+        @param parent parent window for dialogs
         self.parent  = parent
         self.caption = _('Digitization Error')
@@ -136,7 +140,7 @@
         # layer / max category
         self.cats = dict()
         # settings
         self.settings = {
             'breakLines'  : False,
@@ -189,6 +193,24 @@
             return None
         return pointer(bgMapInfo)
+    def _getSnapMode(self):
+        """!Get snapping mode
+        - snap to vertex
+        - snap to nodes
+        - no snapping
+        @return snap mode
+        threshold = self._display.GetThreshold()
+        if threshold > 0.0:
+            if UserSettings.Get(group = 'vdigit', key = 'snapToVertex', subkey = 'enabled'):
+                return SNAPVERTEX
+            else:
+                return SNAP
+        else:
+            return NO_SNAP
     def _breakLineAtIntersection(self):
         pass
@@ -248,7 +270,7 @@
     def _applyChangeset(self):
         pass
-    def _removeActionFromChangeset(self):
+    def _removeActionFromChangeset(self, changeset, line, add):
         """!Remove action from changeset
         @param changeset changeset id
@@ -268,15 +290,6 @@
         return len(alist)
-    def _listToIList(self, plist):
-        """!Generate from list struct_ilist
-        ilist = Vect_new_list()
-        for val in plist:
-            Vect_list_append(ilist, val)
-        return ilist
     def AddFeature(self, ftype, points):
         """!Add new feature
@@ -316,7 +329,7 @@
         self.toolbar.EnableUndo()
         return self._addFeature(vtype, points, layer, cat,
-                                bgmap, self._display.GetSnapMode(), self._display.GetThreshold())
+                                bgmap, self._getSnapMode(), self._display.GetThreshold())
     def DeleteSelectedLines(self):
         """!Delete selected features
@@ -349,9 +362,9 @@
         # register changeset
         changeset = self._addActionsBefore()
-        ilist = self._listToIList(self._display.selected['ids'])
-        nlines = Vedit_delete_lines(self.poMapInfo, ilist)
-        Vect_destroy_list(ilist)
+        poList = self._display.GetSelectedIList()
+        nlines = Vedit_delete_lines(self.poMapInfo, poList)
+        Vect_destroy_list(poList)
         self._display.selected['ids'] = list()
         if nlines > 0 and deleteRec:
@@ -417,7 +430,7 @@
             return -1
         thresh = self._display.GetThreshold()
-        snap   = self._display.GetSnapMode()
+        snap   = self._getSnapMode()
         bgmap = str(UserSettings.Get(group='vdigit', key="bgmap",
                                      subkey='value', internal=True))
@@ -436,7 +449,7 @@
-        poList = self._listToIList(self._display.selected['ids'])
         nlines = Vedit_move_lines(self.poMapInfo, poBgMapInfo, nbgmaps,
                                   poList,
                                   move[0], move[1], 0,
@@ -446,7 +459,7 @@
         if nlines > 0:
             self._addActionsAfter(changeset, nlines)
         else:
-            changesets.remove(changeset)
+            del self.changesets[changeset]
         if nlines > 0 and self.settings['breakLines']:
             for i in range(1, nlines):
@@ -497,19 +510,19 @@
         # move only first found vertex in bbox
         moved = Vedit_move_vertex(self.poMapInfo, poBgMapInfo, nbgmaps,
                                   poList, self.poPoints,
                                   self._display.GetThreshold(type = 'selectThresh'),
                                   self._display.GetThreshold(),
                                   move[0], move[1], 0.0,
-                                  1, self._display.GetSnapMode())
+                                  1, self._getSnapMode())
         if moved > 0:
         else:
         if moved > 0 and self.settings['breakLines']:
             self._breakLineAtIntersection(Vect_get_num_lines(self.poMapInfo),
@@ -569,7 +582,7 @@
         if not self._checkMap():
             return -1
         Vect_reset_line(self.poPoints)
         Vect_append_point(self.poPoints, point[0], point[1], 0.0)
@@ -579,17 +592,14 @@
         ret = Vedit_split_lines(self.poMapInfo, poList,
                                 self.poPoints, thresh, poList)
         if ret > 0:
+            self.toolbar.EnableUndo()
         else:
-            self.changesets.remove(changeset);
-        Vect_destroy_list(poList)
-        if ret > 0:
-            self.toolbar.EnableUndo()
         return ret
     def EditLine(self, line, coords):
@@ -613,14 +623,12 @@
             self.DeleteSelectedLines()
             return 0
-        thresh = self._display.GetThreshold()
         ret = self.digit.RewriteLine(lineid, listCoords,
-                                         bgmap, snap, thresh)
+                                     self._display.GetThreshold())
         if ret > 0:
@@ -641,7 +649,7 @@
         ret = Vedit_flip_lines(self.poMapInfo, poList)
@@ -649,7 +657,7 @@
         else:
         return ret
@@ -659,11 +667,23 @@
         @return number of modified lines
         @return -1 on error
-        ret = self.digit.MergeLines()
+        if not self._checkMap():
+            return -1
+        nlines = Vect_get_num_lines(self.poMapInfo)
+        changeset = self._addActionsBefore()
+        ret = Vedit_merge_lines(self.poMapInfo, poList)
         if ret > 0:
+            self._addActionsAfter(changeset, nlines)
+        else:
         return ret
     def BreakLine(self):
@@ -672,11 +692,24 @@
         @return -1 on error
-        ret = self.digit.BreakLines()
+            return -1
+        ret = Vect_break_lines_list(self.poMapInfo, poList, None,
+                                    GV_LINES, None)
         if ret > 0:
+        else:
         return ret
     def SnapLine(self):
@@ -685,14 +718,24 @@
         @return on success
         @return -1 on error
-        snap, thresh = self.__getSnapThreshold()
-        ret = self.digit.SnapLines(thresh)
+            return -1
-        if ret == 0:
+        Vect_snap_lines_list(self.poMapInfo, poList,
+                             self._display.GetThreshold(), None)
+        if nlines < Vect_get_num_lines(self.poMapInfo):
-        return ret
+        else:
     def ConnectLine(self):
         """!Connect selected lines/boundaries
@@ -700,12 +743,25 @@
         @return 0 lines not connected
         @return -1 on error
-        ret = self.digit.ConnectLines(thresh)
+            return -1
+        # register changeset
+        ret = Vedit_connect_lines(self.poMapInfo, poList,
         if ret > 0:
+        else:
         return ret
     def CopyLine(self, ids=[]):
@@ -748,31 +804,73 @@
         return ret
-    def SelectLinesByQuery(self, pos1, pos2):
+    def _selectLinesByQueryThresh(self):
+        """!Generic method used for SelectLinesByQuery() -- to get
+        threshold value"""
+        thresh = 0.0
+        if UserSettings.Get(group = 'vdigit', key = 'query', subkey = 'selection') == 0:
+            thresh = UserSettings.Get(group = 'vdigit', key = 'queryLength', subkey = 'thresh')
+            if UserSettings.Get(group = 'vdigit', key = "queryLength", subkey = 'than-selection') == 0:
+                thresh = -1 * thresh
+        else:
+            thresh = UserSettings.Get(group = 'vdigit', key = 'queryDangle', subkey = 'thresh')
+            if UserSettings.Get(group = 'vdigit', key = "queryDangle", subkey = 'than-selection') == 0:
+        return thresh
+    def SelectLinesByQuery(self, bbox):
         """!Select features by query
-        @param pos1, pos2 bounding box definition
+        @todo layer / 3D
+        @param bbox bounding box definition
-        thresh = self.SelectLinesByQueryThresh()
+            return -1
-        w, n = pos1
-        e, s = pos2
-        query = wxvdigit.QUERY_UNKNOWN
-        if UserSettings.Get(group='vdigit', key='query', subkey='selection') == 0:
-            query = wxvdigit.QUERY_LENGTH
+        thresh = self._selectLinesByQueryThresh()
+        query = QUERY_UNKNOWN
+            query = QUERY_LENGTH
         else:
-            query = wxvdigit.QUERY_DANGLE
-        type = wxvdigit.GV_POINTS | wxvdigit.GV_LINES # TODO: 3D
+            query = QUERY_DANGLE
-        ids = self.digit.SelectLinesByQuery(w, n, 0.0, e, s, 1000.0,
-                                            UserSettings.Get(group='vdigit', key='query', subkey='box'),
-                                            query, type, thresh)
-        Debug.msg(4, "VDigit.SelectLinesByQuery(): %s" % \
-                      ",".join(["%d" % v for v in ids]))
+        ftype = GV_POINTS | GV_LINES # TODO: 3D
+        layer = 1 # TODO
+        ids = list()
+        poList = Vect_new_list()
+        coList = poList.contents
+        if UserSettings.Get(group = 'vdigit', key = 'query', subkey = 'box'):
+            Vect_reset_line(self.poPoints)
+            x1, y1 = bbox[0]
+            x2, y2 = bbox[1]
+            z1 = z2 = 0.0
+            Vect_append_point(self.poPoints, x1, y1, z1)
+            Vect_append_point(self.poPoints, x2, y1, z2)
+            Vect_append_point(self.poPoints, x2, y2, z1)
+            Vect_append_point(self.poPoints, x1, y2, z2)
+            Vect_select_lines_by_polygon(self.poMapInfo, self.poPoints, 0, None,
+                                         ftype, poList)
+            if coList.n_values == 0:
+                return ids
+        Vedit_select_by_query(self.poMapInfo,
+                              ftype, layer, thresh, query,
+                              poList)
+        for i in range(coList.n_values):
+            ids.append(int(coList.value[i]))
+        Debug.msg(3, "IVDigit.SelectLinesByQuery(): lines=%d", coList.n_values)
         return ids
     def GetLineCats(self, line=-1):
@@ -1091,9 +1189,8 @@
             self._breakLineAtIntersection(newline, self.poPoints, changeset)
         # close background map if opened
-        if bgMapInfo:
-            Vect_close(byref(bgMapInfo))
-        del bgMapInfo
+        if poBgMapInfo:
+            Vect_close(poBgMapInfo)
         if type & GV_BOUNDARY and \
                 not self.settings['catBoundary'] and \
@@ -1157,7 +1254,7 @@
         if len(selected['ids']) != 1:
             return 0
-        poList  = self._listToIList(selected['ids'])
         Vect_append_point(self.poPoints, coords[0], coords[1], 0.0)
@@ -1172,23 +1269,19 @@
         else:
             ret = Vedit_remove_vertex(self.poMapInfo, poList,
                                       self.poPoints, thresh)
         if ret > 0:
         else:
         if not add and ret > 0 and self.settings['breakLines']:
                                           None, changeset)
         return nlines + 1 # feature is write at the end of the file
-    def SelectLinesByQuery(self):
-        pass
     def GetLineLength(self):
         pass
Modified: grass/trunk/gui/wxpython/gui_modules/wxvdriver.py
--- grass/trunk/gui/wxpython/gui_modules/wxvdriver.py	2011-01-09 12:14:15 UTC (rev 44911)
+++ grass/trunk/gui/wxpython/gui_modules/wxvdriver.py	2011-01-09 14:35:52 UTC (rev 44912)
@@ -584,6 +584,24 @@
         return (px.value, py.value, pz.value)
+    def _listToIList(self, plist):
+        """!Generate from list struct_ilist
+        ilist = Vect_new_list()
+        for val in plist:
+            Vect_list_append(ilist, val)
+        return ilist
+    def GetSelectedIList(self):
+        """!Get list of selected objects as struct_ilist
+        Returned IList must be freed by Vect_destroy_list().
+        @return struct_ilist
+        return self._listToIList(self.selected['ids'])
     def GetSelected(self, grassId = True):
         """!Get ids of selected objects
@@ -632,7 +650,7 @@
         else:
             field = -1
             self.selected['ids'] = ids
     def GetSelectedVertex(self, pos):
         """Get PseudoDC vertex id of selected line
@@ -834,24 +852,6 @@
         self.region = self.mapObj.GetCurrentRegion()
-    def GetSnapMode(self):
-        """!Get snapping mode
-        - snap to vertex
-        - snap to nodes
-        - no snapping
-        @return snap mode
-        threshold = self.GetThreshold()
-        if threshold > 0.0:
-            if UserSettings.Get(group = 'vdigit', key = 'snapToVertex', subkey = 'enabled'):
-                return SNAPVERTEX
-            else:
-                return SNAP
-        else:
-            return NO_SNAP
     def GetThreshold(self, type = 'snapping', value = None, units = None):
         """!Return threshold value in map units
