[GRASS-SVN] r44934 - grass/branches/develbranch_6/vector/v.transform
    svn_grass at osgeo.org
    Mon Jan 10 08:55:05 EST 2011
Author: martinl
Date: 2011-01-10 05:55:05 -0800 (Mon, 10 Jan 2011)
New Revision: 44934
   grass/branches/develbranch_6/vector/v.transform/main.c
v.transform: more guisection, fix gisprompt for 'columns'
Modified: grass/branches/develbranch_6/vector/v.transform/main.c
--- grass/branches/develbranch_6/vector/v.transform/main.c	2011-01-10 13:54:05 UTC (rev 44933)
+++ grass/branches/develbranch_6/vector/v.transform/main.c	2011-01-10 13:55:05 UTC (rev 44934)
@@ -82,12 +82,19 @@
     tozero_flag = G_define_flag();
     tozero_flag->key = 't';
     tozero_flag->description = _("Shift all z values to bottom=0");
+    tozero_flag->guisection = _("Custom");
+    swap_flag = G_define_flag();
+    swap_flag->key = 'w';
+    swap_flag->description =
+	_("Swap coordinates x, y and then apply other parameters");
+    swap_flag->guisection = _("Custom");
     print_mat_flag = G_define_flag();
     print_mat_flag->key = 'm';
     print_mat_flag->description =
 	_("Print the transformation matrix to stdout");
     /* remove in GRASS7 */
     shift_flag = G_define_flag();
     shift_flag->key = 's';
@@ -95,14 +102,11 @@
 	_("Instead of points use transformation parameters "
 	  "(xshift, yshift, zshift, xscale, yscale, zscale, zrot)");
     shift_flag->guisection = _("Custom");
+    vold = G_define_standard_option(G_OPT_V_INPUT);
-    swap_flag = G_define_flag();
-    swap_flag->key = 'w';
-    swap_flag->description =
-	_("Swap coordinates x, y and then apply other parameters");
+    field = G_define_standard_option(G_OPT_V_FIELD);
-    vold = G_define_standard_option(G_OPT_V_INPUT);
     vnew = G_define_standard_option(G_OPT_V_OUTPUT);
     pointsfile = G_define_standard_option(G_OPT_F_INPUT);
@@ -113,7 +117,8 @@
 				"(xshift, yshift, zshift, xscale, yscale, zscale, zrot) are used instead");
     pointsfile->gisprompt = "old_file,file,points";
+    pointsfile->guisection = _("Points");
     xshift = G_define_option();
     xshift->key = "xshift";
     xshift->type = TYPE_DOUBLE;
@@ -181,18 +186,19 @@
     table = G_define_standard_option(G_OPT_TABLE);
     table->description =
 	_("Name of table containing transformation parameters");
-    table->guisection = _("Custom");
+    table->guisection = _("Attributes");
-    columns = G_define_standard_option(G_OPT_COLUMNS);
+    columns = G_define_option();
+    columns->key = "columns";
+    columns->type = TYPE_STRING;
+    columns->required = NO;
+    columns->multiple = NO;
     columns->label =
 	_("Name of attribute column(s) used as transformation parameters");
     columns->description =
 	_("Format: parameter:column, e.g. xshift:xs,yshift:ys,zrot:zr");
-    columns->guisection = _("Custom");
+    columns->guisection = _("Attributes");
-    field = G_define_standard_option(G_OPT_V_FIELD);
-    field->guisection = _("Custom");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
