[GRASS-SVN] r44997 - in grass/trunk/imagery: i.aster.toar i.biomass i.eb.eta i.eb.h_SEBAL01 i.eb.soilheatflux i.sunhours
Wed Jan 12 18:04:05 EST 2011
Author: ychemin
Date: 2011-01-12 15:04:05 -0800 (Wed, 12 Jan 2011)
New Revision: 44997
   grass/trunk/imagery/i.aster.toar/main.c
   grass/trunk/imagery/i.biomass/main.c
   grass/trunk/imagery/i.eb.eta/main.c
   grass/trunk/imagery/i.eb.h_SEBAL01/main.c
   grass/trunk/imagery/i.eb.soilheatflux/main.c
   grass/trunk/imagery/i.sunhours/main.c
more explicit parameter names
Modified: grass/trunk/imagery/i.aster.toar/main.c
--- grass/trunk/imagery/i.aster.toar/main.c	2011-01-12 22:49:43 UTC (rev 44996)
+++ grass/trunk/imagery/i.aster.toar/main.c	2011-01-12 23:04:05 UTC (rev 44997)
@@ -108,7 +108,7 @@
     input->description = _("Names of ASTER DN layers (15 layers)");
     input1 = G_define_option();
-    input1->key = "doy";
+    input1->key = "dayofyear";
     input1->type = TYPE_DOUBLE;
     input1->required = YES;
     input1->gisprompt = "value";
Modified: grass/trunk/imagery/i.biomass/main.c
--- grass/trunk/imagery/i.biomass/main.c	2011-01-12 22:49:43 UTC (rev 44996)
+++ grass/trunk/imagery/i.biomass/main.c	2011-01-12 23:04:05 UTC (rev 44997)
@@ -60,25 +60,25 @@
     input1->description = _("Name of fPAR raster map");
     input2 = G_define_standard_option(G_OPT_R_INPUT);
-    input2->key = "luf";
+    input2->key = "lightuseefficiency";
     input2->description =
 	_("Name of light use efficiency raster map (UZB:cotton=1.9)");
     input3 = G_define_standard_option(G_OPT_R_INPUT);
-    input3->key = "lat";
+    input3->key = "latitude";
     input3->description = _("Name of degree latitude raster map [dd.ddd]");
     input4 = G_define_standard_option(G_OPT_R_INPUT);
-    input4->key = "doy";
+    input4->key = "dayofyear";
     input4->description = _("Name of Day of Year raster map [1-366]");
     input5 = G_define_standard_option(G_OPT_R_INPUT);
-    input5->key = "tsw";
+    input5->key = "transmissivitysingleway";
     input5->description =
 	_("Name of single-way transmissivity raster map [0.0-1.0]");
     input6 = G_define_standard_option(G_OPT_R_INPUT);
-    input6->key = "wa";
+    input6->key = "wateravailability";
     input6->description =
 	_("Value of water availability raster map [0.0-1.0]");
Modified: grass/trunk/imagery/i.eb.eta/main.c
--- grass/trunk/imagery/i.eb.eta/main.c	2011-01-12 22:49:43 UTC (rev 44996)
+++ grass/trunk/imagery/i.eb.eta/main.c	2011-01-12 23:04:05 UTC (rev 44997)
@@ -49,24 +49,23 @@
     /* Define the different options */
     input1 = G_define_standard_option(G_OPT_R_INPUT);
-    input1->key = "rnetday";
+    input1->key = "netradiationdiurnal";
     input1->description = _("Name of the diurnal Net Radiation map [W/m2]");
     input1->answer = "rnetday";
-    input2->key = "evapfr";
+    input2->key = "evaporativefraction";
     input2->description = _("Name of the evaporative fraction map [-]");
     input2->answer = "evapfr";
-    input3->key = "tempk";
+    input3->key = "temperature";
     input3->description = _("Name of the surface skin temperature [K]");
     input3->answer = "tempk";
     output1 = G_define_standard_option(G_OPT_R_OUTPUT);
     output1->description =
 	_("Name of the output actual evapotranspiration layer [mm/d]");
-    output1->answer = "eta";
     if (G_parser(argc, argv))
         exit(EXIT_FAILURE);
Modified: grass/trunk/imagery/i.eb.h_SEBAL01/main.c
--- grass/trunk/imagery/i.eb.h_SEBAL01/main.c	2011-01-12 22:49:43 UTC (rev 44996)
+++ grass/trunk/imagery/i.eb.h_SEBAL01/main.c	2011-01-12 23:04:05 UTC (rev 44997)
@@ -89,65 +89,65 @@
     /* Define different options */
     input_Rn = G_define_standard_option(G_OPT_R_INPUT);
-    input_Rn->key = "rnet";
+    input_Rn->key = "netradiation";
     input_Rn->description =
 	_("Name of instantaneous Net Radiation raster map [W/m2]");
     input_g0 = G_define_standard_option(G_OPT_R_INPUT);
-    input_g0->key = "g0";
+    input_g0->key = "soilheatflux";
     input_g0->description =
 	_("Name of instantaneous soil heat flux raster map [W/m2]");
     input_z0m = G_define_standard_option(G_OPT_R_INPUT);
-    input_z0m->key = "z0m";
+    input_z0m->key = "aerodynresistance";
     input_z0m->description =
 	_("Name of aerodynamic resistance to heat momentum raster map [s/m]");
     input_t0dem = G_define_standard_option(G_OPT_R_INPUT);
-    input_t0dem->key = "t0dem";
+    input_t0dem->key = "temperaturemeansealevel";
     input_t0dem->description =
 	_("Name of altitude corrected surface temperature raster map [K]");
     input_ustar = G_define_option();
-    input_ustar->key = "ustar";
+    input_ustar->key = "frictionvelocitystar";
     input_ustar->type = TYPE_DOUBLE;
     input_ustar->required = YES;
     input_ustar->gisprompt = "old,value";
     input_ustar->answer = "0.32407";
-    input_ustar->description = _("Value of the friction velocity [m/s]");
+    input_ustar->description = _("Value of the height independent friction velocity (u*) [m/s]");
     input_ustar->guisection = _("Parameters");
     input_ea = G_define_option();
-    input_ea->key = "ea";
+    input_ea->key = "vapourpressureactual";
     input_ea->type = TYPE_DOUBLE;
     input_ea->required = YES;
     input_ea->answer = "1.511";
-    input_ea->description = _("Value of the actual vapour pressure [KPa]");
+    input_ea->description = _("Value of the actual vapour pressure (e_act) [KPa]");
     input_ea->guisection = _("Parameters");
     input_row_wet = G_define_option();
-    input_row_wet->key = "row_wet";
+    input_row_wet->key = "row_wet_pixel";
     input_row_wet->type = TYPE_DOUBLE;
     input_row_wet->required = NO;
     input_row_wet->description = _("Row value of the wet pixel");
     input_row_wet->guisection = _("Parameters");
     input_col_wet = G_define_option();
-    input_col_wet->key = "col_wet";
+    input_col_wet->key = "column_wet_pixel";
     input_col_wet->type = TYPE_DOUBLE;
     input_col_wet->required = NO;
     input_col_wet->description = _("Column value of the wet pixel");
     input_col_wet->guisection = _("Parameters");
     input_row_dry = G_define_option();
-    input_row_dry->key = "row_dry";
+    input_row_dry->key = "row_dry_pixel";
     input_row_dry->type = TYPE_DOUBLE;
     input_row_dry->required = NO;
     input_row_dry->description = _("Row value of the dry pixel");
     input_row_dry->guisection = _("Parameters");
     input_col_dry = G_define_option();
-    input_col_dry->key = "col_dry";
+    input_col_dry->key = "column_dry_pixel";
     input_col_dry->type = TYPE_DOUBLE;
     input_col_dry->required = NO;
     input_col_dry->description = _("Column value of the dry pixel");
Modified: grass/trunk/imagery/i.eb.soilheatflux/main.c
--- grass/trunk/imagery/i.eb.soilheatflux/main.c	2011-01-12 22:49:43 UTC (rev 44996)
+++ grass/trunk/imagery/i.eb.soilheatflux/main.c	2011-01-12 23:04:05 UTC (rev 44997)
@@ -1,7 +1,7 @@
- * MODULE:       i.eb.g0
+ * MODULE:       i.eb.soilheatflux
  * AUTHOR(S):    Yann Chemin - yann.chemin at gmail.com
  * PURPOSE:      Calculates an approximation of soil heat flux
  *               as seen in Bastiaanssen (1995) using time of
@@ -63,16 +63,16 @@
     input2->description = _("Name of NDVI raster map [-1.0;+1.0]");
 	_("Name of Surface temperature raster map [degree Kelvin]");
-    input4->key = "rnet";
+    input4->key = "netradiation";
     input4->description = _("Name of Net Radiation raster map [W/m2]");
-    input5->key = "time";
+    input5->key = "localutctime";
 	_("Name of time of satellite overpass raster map [local UTC]");
@@ -179,4 +179,3 @@
     exit(EXIT_SUCCESS);
Modified: grass/trunk/imagery/i.sunhours/main.c
--- grass/trunk/imagery/i.sunhours/main.c	2011-01-12 22:49:43 UTC (rev 44996)
+++ grass/trunk/imagery/i.sunhours/main.c	2011-01-12 23:04:05 UTC (rev 44997)
@@ -50,11 +50,11 @@
-    input1->key = _("doy");
+    input1->key = _("dayofyear");
     input1->description = _("Name of the day of year input map");
-    input2->key = _("lat");
+    input2->key = _("latitude");
     input2->description = _("Name of the latitude input map");
