[GRASS-SVN] r45014 - grass/branches/releasebranch_6_4/gui/wxpython/docs
Thu Jan 13 10:37:01 EST 2011
Author: martinl
Date: 2011-01-13 07:37:01 -0800 (Thu, 13 Jan 2011)
New Revision: 45014
   grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
   grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.GCP_Manager.html
   grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Modeler.html
   grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Nviz.html
   grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.html
add missing </dd>
Modified: grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html
--- grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html	2011-01-13 15:30:25 UTC (rev 45013)
+++ grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Attribute_Table_Manager.html	2011-01-13 15:37:01 UTC (rev 45014)
@@ -22,7 +22,7 @@
 <p>
 Other wxGUI components:<br>
-<em
+<em>
   <a href="wxGUI.Vector_Digitizer.html">Vector Digitizer</a><br>
   <a href="wxGUI.Nviz.html">3D Viewer</a><br>
   <a href="wxGUI.Modeler.html">Graphical Modeler</a><br>
Modified: grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.GCP_Manager.html
--- grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.GCP_Manager.html	2011-01-13 15:30:25 UTC (rev 45013)
+++ grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.GCP_Manager.html	2011-01-13 15:37:01 UTC (rev 45014)
@@ -297,7 +297,7 @@
 <p>
-<em
+<em>
   <a href="wxGUI.Attribute_Table_Manager.html">Attribute Table Manager</a><br>
Modified: grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Modeler.html
--- grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Modeler.html	2011-01-13 15:30:25 UTC (rev 45013)
+++ grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Modeler.html	2011-01-13 15:37:01 UTC (rev 45014)
@@ -29,7 +29,7 @@
 <p>
-<em
+<em>
Modified: grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Nviz.html
--- grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Nviz.html	2011-01-13 15:30:25 UTC (rev 45013)
+++ grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.Nviz.html	2011-01-13 15:37:01 UTC (rev 45014)
@@ -300,7 +300,7 @@
 <p>
-<em
+<em>
Modified: grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.html
--- grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.html	2011-01-13 15:30:25 UTC (rev 45013)
+++ grass/branches/releasebranch_6_4/gui/wxpython/docs/wxGUI.html	2011-01-13 15:37:01 UTC (rev 45014)
@@ -35,7 +35,7 @@
 defined by the <tt>-wxpython</tt> switch:
 <div class="code"><pre>
-    grass65 -wxpython
+    grass64 -wxpython
 </pre></div>
 <p>
@@ -113,27 +113,28 @@
   <dt><img src="icons/grass2/layer-open.png">&nbsp;
     <em>Load / import map layers into workspace</em></dt>
-  <dd>Loads or imports selected raster or vector maps into current layer tree.</dd>
+  <dd>Loads or imports selected raster or vector maps into current layer tree.
+    <dl>
+      <dt><img src="icons/grass2/create.png">&nbsp;
+	<em>Create new workspace file</em></dt>
+      <dd>Removes all layers in the layer tree and creates a new, empty tree
+	where new layers can be added.</dd>
+      <dt><img src="icons/grass2/layer-open.png">&nbsp;
+	<em>Load map layers into workspace</em></dt>
+      <dd>Loads selected raster or vector maps into current layer tree.</dd>
+      <dt><img src="icons/grass2/layer-import.png">&nbsp;
+	<em>Import raster data</em></dt>
+      <dd>Import selected raster data into GRASS and load them into current layer tree.</dd>
+	<em>Import vector data</em></dt>
+      <dd>Import selected vector data into GRASS and load them into current layer tree.</dd>
+    </dl>
+  </dd>
-  <dl>
-    <dt><img src="icons/grass2/create.png">&nbsp;
-      <em>Create new workspace file</em></dt>
-    <dd>Removes all layers in the layer tree and creates a new, empty tree
-      where new layers can be added.</dd>
-    <dt><img src="icons/grass2/layer-open.png">&nbsp;
-      <em>Load map layers into workspace</em></dt>
-    <dd>Loads selected raster or vector maps into current layer tree.</dd>
-    <dt><img src="icons/grass2/layer-import.png">&nbsp;
-      <em>Import raster data</em></dt>
-    <dd>Import selected raster data into GRASS and load them into current layer tree.</dd>
-      <em>Import vector data</em></dt>
-    <dd>Import selected vector data into GRASS and load them into current layer tree.</dd>
-  </dl>
   <dt><img src="icons/grass2/open.png">&nbsp;
     <em>Open existing workspace file</em></dt>
   <dd>Opens an previously saved workspace file, containing a set of display
@@ -151,7 +152,7 @@
   <dt><img src="icons/grass2/layer-raster-more.png">&nbsp;
     <em>Add various raster map layers (RGB, HIS, shaded relief...)</em></dt>
-  <dd>Opens a dropdown menu that allows user to select to:<br>
+  <dd>Opens a dropdown menu that allows user to select to:
     <dl>
       <dt><img src="icons/grass2/layer-raster3d-add.png">&nbsp;
@@ -187,14 +188,15 @@
       <dd>Adds map of raster cells with numbers representing the cell values,
 	see <em><a href="d.rast.num.html">d.rast.num</a></em>.</dd>
     </dl>
-    <dt><img src="icons/grass2/layer-vector-add.png">&nbsp;
-      <em>Add vector map layer</em></dt>
+    </dd>
+  <dt><img src="icons/grass2/layer-vector-add.png">&nbsp;
+    <em>Add vector map layer</em></dt>
   <dd>Adds a vector map layer, see <em><a href="d.vect.html">d.vect</a></em>.</dd>
   <dt><img src="icons/grass2/layer-vector-more.png">&nbsp;
     <em>Add various vector map layers (thematic, chart...)</em></dt>
     <dl>
       <dt><img src="icons/grass2/layer-vector-thematic-add.png">&nbsp;
@@ -219,14 +221,15 @@
 	on attribute column),
 	see <em><a href="d.vect.chart.html">d.vect.chart</a></em>.</dd>
     </dl>
-    <dt><img src="icons/grass2/layer-group-add.png">&nbsp;
+  </dd>
+  <dt><img src="icons/grass2/layer-group-add.png">&nbsp;
       <em>Add group</em></dt>
   <dd>Adds an empty group. Layers can then be added to the group.</dd>
   <dt><img src="icons/grass2/layer-more.png">&nbsp;
     <em>Add grid or vector labels overlay</em></dt>
     <dl>
       <dt><img src="icons/grass2/layer-grid-add.png">&nbsp;
@@ -268,9 +271,10 @@
 </pre></div>
       </dd>
     </dl>
+  </dd>
-    <dt><img src="icons/grass2/layer-remove.png">&nbsp;
-      <em>Delete selected layer</em></dt>
+  <dt><img src="icons/grass2/layer-remove.png">&nbsp;
+    <em>Delete selected layer</em></dt>
   <dd>Removes selected map layer or map layer group from layer tree.</dd>
   <dt><img src="icons/grass2/table.png">&nbsp;
@@ -391,19 +395,21 @@
   <dt><img src="icons/grass2/info.png">&nbsp;
     <em>Query raster/vector maps</em></dt>
-  <dd>Opens a dropdown menu that allows user to select to:</dd>
-  <dl>
-    <dt><em>Display mode</em></dt>
-    <dd>Query selected raster, RGB raster (all three map channels will be
-      queried), or vector map(s) using the mouse. Map(s) must be selected
-      before query.  Vector charts and thematic vector maps cannot be
-      queried. The results of the query will be displayed in the console window,
-      see <em><a href="r.what.html">r.what</a>, <a href="v.what.html">v.what</a></em>.</dd>
-    <dt><em>Edit mode</em></dt>
-    <dd>Query selected vector map in edit mode. The results of the query
-      will be displayed in a form that permits editing of the queried vector
-      attributes.</dd>
-  </dl>
+    <dl>
+      <dt><em>Display mode</em></dt>
+      <dd>Query selected raster, RGB raster (all three map channels will be
+	queried), or vector map(s) using the mouse. Map(s) must be selected
+	before query.  Vector charts and thematic vector maps cannot be
+	queried. The results of the query will be displayed in the console window,
+	see <em><a href="r.what.html">r.what</a>, <a href="v.what.html">v.what</a></em>.</dd>
+      <dt><em>Edit mode</em></dt>
+      <dd>Query selected vector map in edit mode. The results of the query
+	will be displayed in a form that permits editing of the queried vector
+	attributes.</dd>
+    </dl>
+  </dd>
   <dt><img src="icons/grass2/pan.png">&nbsp;
     <em>Pan</em></dt>
   <dd>Interactive selection of a new center of view in the active
@@ -453,7 +459,7 @@
   <dt><img src="icons/grass2/zoom-more.png">&nbsp;
     <em>Zoom options</em></dt>
-  <dd>Opens a dropdown menu that allows user to:<br>
+  <dd>Opens a dropdown menu that allows user to:
     <ul>
       <li>Zoom to match the extents of a selected map</li>
       <li>Zoom to match the computational region (set with <em>g.region</em>)</li>
@@ -464,57 +470,60 @@
         see <em><a href="g.region.html">g.region</a></em>.</li>
       <li>Save display geometry (current extents) to a named region file</li>
     </ul>
+  </dd>
+  <dt><img src="icons/grass2/layer-raster-analyze.png">&nbsp;
+      <em>Analyze menu</em></dt>
+  <dd>Opens a dropdown menu with:
+    <dl>
+      <dt><img src="icons/grass2/measure-length.png">&nbsp;
+	<em>Distance measurement tool</em></dt>
+      <dd>Interactive measurement of lengths defined with the mouse. The
+	length of each segment and the cumulative length of all segments
+	measuered is displayed in the command output window frame. Lengths are
+	measured in the current measurement unit,
+	see <em><a href="d.measure.html">d.measure</a></em>.</dd>
+      <dt><img src="icons/grass2/layer-raster-profile.png">&nbsp;
+	<em>Profile tool</em></dt>
+      <dd>Interactively create profile of a raster map. Profile transect is
+	drawn with the mouse in map display. The profile may be of the
+	displayed map or a different map. Up to three maps can be profiled
+	simultaneously,
+	see <em><a href="gm_profile.html">Profile Tool help page</a></em>.</dd>
+      <dt><img src="icons/grass2/layer-raster-histogram.png">&nbsp;
+	<em>Histogram tool</em></dt>
+      <dd>Displays histogram of selected raster map or image in new window,
+	see <em><a href="d.histogram.html">d.histogram</a></em>.</dd>
+    </dl>
+  </dd>
-    <dt><img src="icons/grass2/layer-raster-analyze.png">&nbsp;
-      <em>Analyze menu</em></dt>
-  <dd>Opens a dropdown menu with:</dd>
-  <dl>
-    <dt><img src="icons/grass2/measure-length.png">&nbsp;
-      <em>Distance measurement tool</em></dt>
-    <dd>Interactive measurement of lengths defined with the mouse. The
-      length of each segment and the cumulative length of all segments
-      measuered is displayed in the command output window frame. Lengths are
-      measured in the current measurement unit,
-      see <em><a href="d.measure.html">d.measure</a></em>.</dd>
-    <dt><img src="icons/grass2/layer-raster-profile.png">&nbsp;
-      <em>Profile tool</em></dt>
-    <dd>Interactively create profile of a raster map. Profile transect is
-      drawn with the mouse in map display. The profile may be of the
-      displayed map or a different map. Up to three maps can be profiled
-      simultaneously,
-      see <em><a href="gm_profile.html">Profile Tool help page</a></em>.</dd>
-    <dt><img src="icons/grass2/layer-raster-histogram.png">&nbsp;
-      <em>Histogram tool</em></dt>
-    <dd>Displays histogram of selected raster map or image in new window,
-      see <em><a href="d.histogram.html">d.histogram</a></em>.</dd>
-  </dl>
   <dt><img src="icons/grass2/overlay-add.png">&nbsp;
     <em>Add overlay</em></dt>
-  <dd>opens a dropdown menu that allows user to:</dd>
-  <dl>
-    <dt><img src="icons/grass2/scalebar-add.png">&nbsp;
-      <em>Add scalebar and north arrow</em></dt>
-    <dd>Adds layer to display a combined scalebar and north arrow. Options
-      include scalebar placement (using screen coordinates or a mouse),
-      scalebar format, and scalebar colors,
-      see <em><a href="d.barscale.html">d.barscale</a></em>.</dd>
-    <dt><img src="icons/grass2/legend-add.png">&nbsp;
-      <em>Add raster map legend</em></dt>
-    <dd>Adds layer to display with legend of selected raster map,
-      see <em><a href="d.legend.html">d.legend</a></em>.</dd>
-    <dt><img src="icons/grass2/text-add.png">&nbsp;
-      <em>Add text layer</em></dt>
-    <dd>Adds layer to display a line of text using default GRASS font
-      (selected with <em><a href="d.font.html">d.font</a></em>).  Options
-      include: text placement (screen coordinates); and text size, bolding,
-      and color, see <em><a href="d.text.html">d.text</a></em>.</dd>
-  </dl>
+  <dd>opens a dropdown menu that allows user to:
+    <dl>
+      <dt><img src="icons/grass2/scalebar-add.png">&nbsp;
+	<em>Add scalebar and north arrow</em></dt>
+      <dd>Adds layer to display a combined scalebar and north arrow. Options
+	include scalebar placement (using screen coordinates or a mouse),
+	scalebar format, and scalebar colors,
+	see <em><a href="d.barscale.html">d.barscale</a></em>.</dd>
+      <dt><img src="icons/grass2/legend-add.png">&nbsp;
+	<em>Add raster map legend</em></dt>
+      <dd>Adds layer to display with legend of selected raster map,
+	see <em><a href="d.legend.html">d.legend</a></em>.</dd>
+      <dt><img src="icons/grass2/text-add.png">&nbsp;
+	<em>Add text layer</em></dt>
+      <dd>Adds layer to display a line of text using default GRASS font
+	(selected with <em><a href="d.font.html">d.font</a></em>).  Options
+	include: text placement (screen coordinates); and text size, bolding,
+	and color, see <em><a href="d.text.html">d.text</a></em>.</dd>
+    </dl>
+  </dd>
   <dt><img src="icons/grass2/map-export.png">&nbsp;
     <em>Save display to graphic file</em></dt>
   <dd>Save the visible image in map display to different raster graphic formats.</dd>
@@ -524,27 +533,28 @@
   <dd>Prints map on system native printer or PostScript device;
     saves visible map display (including PostScript text and labels) to PDF
     or EPS file.</dd>
   <dt><em>Map display mode</em></dt>
-  <dd>Opens a dropdown menu for selecting different display mode</dd>
-  <dl>
-    <dt><em>2D view mode</em></dt>
-    <dd>Normal GIS display. All active layers are composited and displayed
-      in 2D mode.</dd>
-    <dt><em>3D view mode</em></dt>
-    <dd>Experimental replacement for NVIZ. Displays all active layers in
-      3D perspective using OpenGL. A new control panel opens to manage the
-      3D view. 3D view can be zoomed, panned, rotated, and tilted. The
-      vertical exaggeration of rasters and 3D vectors can be set. Various
-      color and lighten settings are possible. Not yet functional for
-      Windows platforms</dd>
-    <dt><em>Digitize mode</em></dt>
-    <dd>Puts display into vector digitizing mode and opens a new digitizing
-      toolbar. The user can digitize a new map or edit an existing
-      map. Not yet functional for Windows platforms</dd>
-  </dl>
+  <dd>Opens a dropdown menu for selecting different display mode
+    <dl>
+      <dt><em>2D view mode</em></dt>
+      <dd>Normal GIS display. All active layers are composited and displayed
+	in 2D mode.</dd>
+      <dt><em>3D view mode</em></dt>
+      <dd>Experimental replacement for NVIZ. Displays all active layers in
+	3D perspective using OpenGL. A new control panel opens to manage the
+	3D view. 3D view can be zoomed, panned, rotated, and tilted. The
+	vertical exaggeration of rasters and 3D vectors can be set. Various
+	color and lighten settings are possible. Not yet functional for
+	Windows platforms</dd>
+      <dt><em>Digitize mode</em></dt>
+      <dd>Puts display into vector digitizing mode and opens a new digitizing
+	toolbar. The user can digitize a new map or edit an existing
+	map. Not yet functional for Windows platforms</dd>
+    </dl>
+  </dd>
 </dl>
 <h2>SEE ALSO</h2>
