[GRASS-SVN] r45035 - in grass/branches/develbranch_6/gui/wxpython: . gui_modules
Fri Jan 14 15:47:26 EST 2011
Author: martinl
Date: 2011-01-14 12:47:26 -0800 (Fri, 14 Jan 2011)
New Revision: 45035
   grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
   grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: layer tree popup menu - export data
(merge r45034 from trunk)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py	2011-01-14 20:41:52 UTC (rev 45034)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py	2011-01-14 20:47:26 UTC (rev 45035)
@@ -236,7 +236,8 @@
             return
         ltype = self.GetPyData(self.layer_selected)[0]['type']
+        mapLayer = self.GetPyData(self.layer_selected)[0]['maplayer']
         Debug.msg (4, "LayerTree.OnContextMenu: layertype=%s" % \
                        ltype)
@@ -257,15 +258,16 @@
             self.popupID14 = wx.NewId()
             self.popupID15 = wx.NewId()
             self.popupID16 = wx.NewId()
+            self.popupID17 = wx.NewId()
         self.popupMenu = wx.Menu()
         numSelected = len(self.GetSelections())
         # general item
         self.popupMenu.Append(self.popupID1, text=_("Remove"))
         self.Bind(wx.EVT_MENU, self.lmgr.OnDeleteLayer, id=self.popupID1)
         if ltype != "command": # rename
             self.popupMenu.Append(self.popupID2, text=_("Rename"))
             self.Bind(wx.EVT_MENU, self.OnRenameLayer, id=self.popupID2)
@@ -290,23 +292,31 @@
                 self.Bind(wx.EVT_MENU, self.mapdisplay.OnZoomToMap, id=self.popupID9)
                 self.popupMenu.Append(self.popupID10, text=_("Set computational region from selected map(s)"))
                 self.Bind(wx.EVT_MENU, self.OnSetCompRegFromMap, id=self.popupID10)
             if numSelected > 1:
                 self.popupMenu.Enable(self.popupID8, False)
                 self.popupMenu.Enable(self.popupID3, False)
         # specific items
         try:
             mltype = self.GetPyData(self.layer_selected)[0]['type']
         except:
             mltype = None
         # vector layers (specific items)
         if mltype and mltype == "vector":
             self.popupMenu.AppendSeparator()
-            self.popupMenu.Append(self.popupID4, text=_("Show attribute data"))
-            self.Bind (wx.EVT_MENU, self.lmgr.OnShowAttributeTable, id=self.popupID4)
+            self.popupMenu.Append(self.popupID17, text = _("Export"))
+            self.Bind(wx.EVT_MENU, lambda x: self.lmgr.OnMenuCmd(cmd = ['v.out.ogr',
+        'input=%s' % mapLayer.GetName()]),
+                      id = self.popupID17)
+            self.popupMenu.AppendSeparator()
+            self.popupMenu.Append(self.popupID4, text = _("Show attribute data"))
+            self.Bind(wx.EVT_MENU, self.lmgr.OnShowAttributeTable, id = self.popupID4)
             self.popupMenu.Append(self.popupID5, text=_("Start editing"))
             self.popupMenu.Append(self.popupID6, text=_("Stop editing"))
             self.popupMenu.Enable(self.popupID6, False)
@@ -359,11 +369,13 @@
             self.popupMenu.Append(self.popupID7, _("Metadata"))
             self.Bind (wx.EVT_MENU, self.OnMetadata, id=self.popupID7)
             if numSelected > 1:
-                self.popupMenu.Enable(self.popupID4, False)
-                self.popupMenu.Enable(self.popupID5, False)
-                self.popupMenu.Enable(self.popupID6, False)
-                self.popupMenu.Enable(self.popupID7, False)
+                self.popupMenu.Enable(self.popupID4,  False)
+                self.popupMenu.Enable(self.popupID5,  False)
+                self.popupMenu.Enable(self.popupID6,  False)
+                self.popupMenu.Enable(self.popupID7,  False)
                 self.popupMenu.Enable(self.popupID14, False)
+                self.popupMenu.Enable(self.popupID16, False)
+                self.popupMenu.Enable(self.popupID17, False)
         # raster layers (specific items)
@@ -373,7 +385,14 @@
             self.Bind(wx.EVT_MENU, self.mapdisplay.OnZoomToRaster, id=self.popupID12)
             self.popupMenu.Append(self.popupID13, text=_("Set computational region from selected map(s) (ignore NULLs)"))
             self.Bind(wx.EVT_MENU, self.OnSetCompRegFromRaster, id=self.popupID13)
+            self.Bind(wx.EVT_MENU, lambda x: self.lmgr.OnMenuCmd(cmd = ['r.out.gdal',
             self.popupMenu.Append(self.popupID15, _("Set color table"))
             self.Bind (wx.EVT_MENU, self.OnColorTable, id=self.popupID15)
             self.popupMenu.Append(self.popupID4, _("Histogram"))
@@ -391,6 +410,9 @@
                 self.popupMenu.Enable(self.popupID11, False)
         ## self.PopupMenu(self.popupMenu, pos)
         self.PopupMenu(self.popupMenu)
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py	2011-01-14 20:41:52 UTC (rev 45034)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py	2011-01-14 20:47:26 UTC (rev 45035)
@@ -417,13 +417,13 @@
         return cmdlist
-    def RunMenuCmd(self, event, cmd = ''):
+    def RunMenuCmd(self, event = None, cmd = []):
         """!Run command selected from menu"""
         if event:
             cmd = self.GetMenuCmd(event)
         self.goutput.RunCmd(cmd, switchPage = False)
-    def OnMenuCmd(self, event, cmd = ''):
+    def OnMenuCmd(self, event = None, cmd = []):
         """!Parse command selected from menu"""
         if event:
