[GRASS-SVN] r45070 - grass/trunk/general/g.findfile
Mon Jan 17 13:06:25 EST 2011
Author: martinl
Date: 2011-01-17 10:06:24 -0800 (Mon, 17 Jan 2011)
New Revision: 45070
   grass/trunk/general/g.findfile/g.findfile.html
clean up g.findfile manual page
Modified: grass/trunk/general/g.findfile/g.findfile.html
--- grass/trunk/general/g.findfile/g.findfile.html	2011-01-17 17:50:32 UTC (rev 45069)
+++ grass/trunk/general/g.findfile/g.findfile.html	2011-01-17 18:06:24 UTC (rev 45070)
@@ -1,77 +1,49 @@
-<H2>DESCRIPTION</H2>
+<h2>DESCRIPTION</h2>
-<EM>g.findfile</EM> is designed for Bourne shell scripts that need to search
-for mapset <em>elements</em>, including: raster, vector maps, region
-definitions and <em><a HREF="i.group.html">imagery</a></em> groups.
+<em>g.findfile</em> is designed for Bourne shell or Python scripts
+that need to search for mapset <em>elements</em>, including: raster,
+vector maps, region definitions
+and <em><a href="i.group.html">imagery</a></em> groups.
 <p>
-The list of <em>element</em> names to search for is not fixed; any
-subdirectory of the mapset directory is a valid <em>element</em> name.
+The list of <b>element</b> names to search for is not fixed; any
+subdirectory of the mapset directory is a valid <b>element</b> name.
 <p>
-However, the user can find the list of standard GRASS <em>element</em> names in
-the file $GISBASE/etc/element_list. This is the file which
-g.remove/g.rename/g.copy use to determine which files need to be
-deleted/renamed/copied for a given entity type.
+However, the user can find the list of standard GRASS <b>element</b>
+names in the file <tt>$GISBASE/etc/element_list</tt>. This is the file
+which <em><a href="g.remove.html">g.remove</a></em>, <em><a href="g.rename.html">g.rename</a></em>
+and <em><a href="g.copy.html">g.copy</a></em> use to determine which files
+need to be deleted/renamed/copied for a given entity type.
-<!-- unused
-<H2>OPTIONS</H2>
+<h2>NOTES</h2>
-<H3>Parameters:</H3>
+<em>g.findfile</em> writes four lines to standard output:
-<DL>
-<DT><B>element=</B><EM>name</EM>
-<DD>The data base element (i.e., directory within a GRASS
-mapset) to be searched.
-<DT><B>mapset=</B><EM>name</EM>
-<DD>The mapset in which to search for the specified file
-<EM>name</EM>.  If not specified, all mapsets in the user's
-GRASS search path are searched.  Otherwise, the specified
-mapset is searched.  As a convenience, if specified as a
-single dot (.) only the current mapset is searched.
-<DT><B>file=</B><EM>name</EM>
-<DD>The name of a GRASS data file (of the stated
-<EM>element</EM> type) for which to search.
-</DL>
-<H2>OUTPUT</H2>
-<EM>g.findfile</EM> writes four lines to standard output:
 <div class="code"><pre>
-name='<EM>file_name</EM>'
-mapset='<EM>mapset_name</EM>'
-file='<EM>unix_filename</EM>'
-fullname='<EM>grass_fullname</EM>'
+name='<em>file_name</em>'
+mapset='<em>mapset_name</em>'
+file='<em>unix_filename</em>'
+fullname='<em>grass_fullname</em>'
 </pre></div>
-The output is <EM>/bin/sh</EM> commands to set the variable
-<EM>name</EM> to the GRASS data base file name,
-<EM>mapset</EM> to the mapset in which the file resides,
-and <EM>file</EM> to the full UNIX path name for the named
-file.  These variables may be set in the <EM>/bin/sh</EM>
+The output is <em>Bash</em> commands to set the variable
+<em>name</em> to the GRASS data base file name,
+<em>mapset</em> to the mapset in which the file resides,
+and <em>file</em> to the full UNIX path name for the named
+file. These variables may be set in the <em>Bash</em>
 as follows:
 eval `g.findfile element=name mapset=name file=name`
 </pre></div>
-<P>
+<p>
 For example (raster map):
-eval `g.findfile element=cell file=mymap`
+eval `g.findfile element=cell file=elevation`
 </pre></div>
-<H2>NOTES</H2>
+If the specified file does not exist, the variables will be set as
+follows:
-If the specified file does not exist, the variables will be set as follows:
 name=
 mapset=
@@ -79,30 +51,40 @@
 file=
 </pre></div>
 The following is a way to test for this case:
-<div class="code">
-<PRE>
+<div class="code"><pre>
 if [ ! "$file" ]
 then
 	exit
 fi
-</PRE>
-</DIV>
+</pre></div>
 Note that region files are searched as <em>element=windows</em>.
-<H2>SEE ALSO</H2>
+<h2>PYTHON</h2>
-<EM><A HREF="g.ask.html">g.ask</A></EM><br>
-<EM><A HREF="g.filename.html">g.filename</A></EM><br>
-<EM><A HREF="g.gisenv.html">g.gisenv</A></EM><br>
-<EM><A HREF="g.mapsets.html">g.mapsets</A></EM><br>
-<EM><A HREF="parser.html">parser</A></EM>
+See <em><a href="http://grass.osgeo.org/programming7/pythonlib.html">Python
+Scripting Library</a></em> for more info.
-<H2>AUTHOR</H2>
+import grass.script as grass
+grass.find_file('elevation', element = 'cell')
+</pre></div>
+<h2>SEE ALSO</h2>
+<em>
+  <a href="g.filename.html">g.filename</a>,
+  <a href="g.gisenv.html">g.gisenv</a>,
+  <a href="g.mapsets.html">g.mapsets</a>,
+  <a href="g.parser.html">g.parser</a>
+</em>
+<h2>AUTHOR</h2>
 Michael Shapiro,
 U.S.Army Construction Engineering Research Laboratory
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
