[GRASS-SVN] r45096 - grass/trunk/gui/wxpython/gui_modules
Thu Jan 20 08:10:51 EST 2011
Author: martinl
Date: 2011-01-20 05:10:51 -0800 (Thu, 20 Jan 2011)
New Revision: 45096
   grass/trunk/gui/wxpython/gui_modules/render.py
wxGUI: cosmetics in render module, track error and warnings
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2011-01-20 12:34:27 UTC (rev 45095)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2011-01-20 13:10:51 UTC (rev 45096)
@@ -1,7 +1,7 @@
 @package render
-Rendering map layers and overlays into map composition image
+Rendering map layers and overlays into map composition image.
 Classes:
  - Layer
@@ -9,13 +9,13 @@
  - Overlay
  - Map
-(C) 2006-2010 by the GRASS Development Team
+(C) 2006-2011 by the GRASS Development Team
 This program is free software under the GNU General Public
 License (>=v2). Read the file COPYING that comes with GRASS
 for details.
 @author Michael Barton
- at author Jachym Cepicky,
+ at author Jachym Cepicky
 @author Martin Landa <landa.martin gmail.com>
@@ -59,8 +59,8 @@
     For map layer use MapLayer class.
     For overlays use Overlay class.
-    def __init__(self, type, cmd, name=None,
-                 active=True, hidden=False, opacity=1.0):
+    def __init__(self, type, cmd, name = None,
+                 active = True, hidden = False, opacity = 1.0):
         @todo pass cmd as tuple instead of list
@@ -90,7 +90,7 @@
         Debug.msg (3, "Layer.__init__(): type=%s, cmd='%s', name=%s, " \
                        "active=%d, opacity=%d, hidden=%d" % \
-                       (self.type, self.GetCmd(string=True), self.name, self.active,
+                       (self.type, self.GetCmd(string = True), self.name, self.active,
                         self.opacity, self.hidden))
         # generated file for each layer
@@ -103,7 +103,7 @@
     def __del__(self):
         Debug.msg (3, "Layer.__del__(): layer=%s, cmd='%s'" %
-                   (self.name, self.GetCmd(string=True)))
+                   (self.name, self.GetCmd(string = True)))
     def Render(self):
         """!Render layer to image
@@ -162,8 +162,11 @@
                                            getErrorMsg = True,
                                            quiet = True,
                                            **self.cmd[1])
+            if len(msg):
+                sys.stderr.write(_("Running") + " '" + utils.GetCmdString(self.cmd) + "'")
+                sys.stderr.write(msg)
             if ret != 0:
-                print >> sys.stderr, msg
                 # clean up after problem
                 try:
                     os.remove(self.mapfile)
@@ -196,7 +199,7 @@
         return self.mapfile
-    def GetCmd(self, string=False):
+    def GetCmd(self, string = False):
         """!Get GRASS command as list of string.
         @param string get command as string if True otherwise as list
@@ -225,7 +228,7 @@
             return 'cell'
         return self.type
-    def GetOpacity(self, float=False):
+    def GetOpacity(self, float = False):
         Get layer opacity level
@@ -276,11 +279,11 @@
         """!Set layer name"""
         self.name = name
-    def SetActive(self, enable=True):
+    def SetActive(self, enable = True):
         """!Active or deactive layer"""
         self.active = bool(enable)
-    def SetHidden(self, enable=False):
+    def SetHidden(self, enable = False):
         """!Hide or show map layer in Layer Manager"""
         self.hidden = bool(enable)
@@ -301,14 +304,14 @@
                 self.cmd.append(utils.CmdToTuple(c))
         else:
             self.cmd  = utils.CmdToTuple(cmd)
-        Debug.msg(3, "Layer.SetCmd(): cmd='%s'" % self.GetCmd(string=True))
+        Debug.msg(3, "Layer.SetCmd(): cmd='%s'" % self.GetCmd(string = True))
         # for re-rendering
         self.force_render = True
 class MapLayer(Layer):
         """!Represents map layer in the map canvas
         @param type layer type ('raster', 'vector', 'command', etc.)
@@ -338,7 +341,7 @@
 class Overlay(Layer):
     def __init__(self, id, type, cmd,
-                 active=True, hidden=True, opacity=1.0):
+                 active = True, hidden = True, opacity = 1.0):
         """!Represents overlay displayed in map canvas
         @param id overlay id (for PseudoDC)
@@ -377,7 +380,7 @@
         self.gisrc = gisrc
         # generated file for g.pnmcomp output for rendering the map
-        self.mapfile = tempfile.mkstemp(suffix='.ppm')[1]
+        self.mapfile = tempfile.mkstemp(suffix = '.ppm')[1]
         # setting some initial env. variables
         self._initGisEnv() # g.gisenv
@@ -657,7 +660,7 @@
         """!Get current display region settings"""
         return self.region
-    def SetRegion(self, windres=False):
+    def SetRegion(self, windres = False):
         """!Render string for GRASS_REGION env. variable, so that the
         images will be rendered from desired zoom level.
@@ -724,8 +727,8 @@
         except:
             return None
-    def GetListOfLayers(self, l_type=None, l_mapset=None, l_name=None,
-                        l_active=None, l_hidden=None):
+    def GetListOfLayers(self, l_type = None, l_mapset = None, l_name = None,
+                        l_active = None, l_hidden = None):
         """!Returns list of layers of selected properties or list of
         all layers.
@@ -811,7 +814,7 @@
             if mapWindow:
                 # update progress bar
                 ### wx.SafeYield(mapWindow)
-                event = wxUpdateProgressBar(value=ilayer)
+                event = wxUpdateProgressBar(value = ilayer)
                 wx.PostEvent(mapWindow, event)
             # add image to compositing list
@@ -823,7 +826,7 @@
             Debug.msg (3, "Map.Render() type=%s, layer=%s " % (layer.type, layer.name))
             ilayer += 1
-    def Render(self, force=False, mapWindow=None, windres=False):
+    def Render(self, force = False, mapWindow = None, windres = False):
         """!Creates final image composite
         This function can conditionaly use high-level tools, which
@@ -836,7 +839,7 @@
         @return name of file with rendered image or None
         maps = []
-        masks =[]
+        masks = []
         opacities = []
         # use external gisrc if defined
@@ -851,7 +854,7 @@
 	os.environ["GRASS_PNG_AUTO_WRITE"] = "TRUE"
 	os.environ["GRASS_COMPRESSION"] = "0"
 	os.environ["GRASS_TRUECOLOR"] = "TRUE"
-        driver = UserSettings.Get(group='display', key='driver', subkey='type')
+        driver = UserSettings.Get(group = 'display', key = 'driver', subkey = 'type')
         if driver == 'cairo':
             os.environ["GRASS_RENDER_IMMEDIATE"] = "cairo"
         elif driver == 'png':
@@ -880,8 +883,8 @@
             mapoutstr = self.mapfile.replace('\\', '/')
         # compose command
-        bgcolor = ':'.join(map(str, UserSettings.Get(group='display', key='bgcolor',
-                                                     subkey='color')))
+        bgcolor = ':'.join(map(str, UserSettings.Get(group = 'display', key = 'bgcolor',
+                                                     subkey = 'color')))
         complist = ["g.pnmcomp",
                     "in=%s" % ",".join(maps),
@@ -924,9 +927,9 @@
         return self.mapfile
-    def AddLayer(self, type, command, name=None,
-                 l_active=True, l_hidden=False, l_opacity=1.0, l_render=False,
-                 pos=-1):
+    def AddLayer(self, type, command, name = None,
+                 l_active = True, l_hidden = False, l_opacity = 1.0, l_render = False,
+                 pos = -1):
         """!Adds generic map layer to list of layers
         @param type layer type ('raster', 'vector', etc.)
@@ -944,8 +947,8 @@
         # l_opacity must be <0;1>
         if l_opacity < 0: l_opacity = 0
         elif l_opacity > 1: l_opacity = 1
-        layer = MapLayer(type=type, name=name, cmd=command,
-                         active=l_active, hidden=l_hidden, opacity=l_opacity)
+        layer = MapLayer(type = type, name = name, cmd = command,
+                         active = l_active, hidden = l_hidden, opacity = l_opacity)
         # add maplayer to the list of layers
         if pos > -1:
@@ -960,7 +963,7 @@
         return layer
-    def DeleteLayer(self, layer, overlay=False):
+    def DeleteLayer(self, layer, overlay = False):
         """!Removes layer from list of layers
         @param layer layer instance in layer tree
@@ -1005,7 +1008,7 @@
         Debug.msg (4, "Map.ReoderLayers(): layers=%s" % \
                    (layerNameList))
-    def ChangeLayer(self, layer, render=False, **kargs):
+    def ChangeLayer(self, layer, render = False, **kargs):
         """!Change map layer properties
         @param layer map layer instance
@@ -1078,7 +1081,7 @@
                    (layer.name, name))
         layer.name =  name
-    def RemoveLayer(self, name=None, id=None):
+    def RemoveLayer(self, name = None, id = None):
         """!Removes layer from layer list
         Layer is defined by name at mapset or id.
@@ -1105,7 +1108,7 @@
         return None
-    def GetLayerIndex(self, layer, overlay=False):
+    def GetLayerIndex(self, layer, overlay = False):
         """!Get index of layer in layer list.
         @param layer layer instace in layer tree
@@ -1125,7 +1128,7 @@
         return -1
     def AddOverlay(self, id, type, command,
-                   l_active=True, l_hidden=True, l_opacity=1.0, l_render=False):
+                   l_active = True, l_hidden = True, l_opacity = 1.0, l_render = False):
         """!Adds overlay (grid, barscale, legend, etc.) to list of
         overlays
@@ -1140,8 +1143,8 @@
         @retutn None on failure
         Debug.msg (2, "Map.AddOverlay(): cmd=%s, render=%d" % (command, l_render))
-        overlay = Overlay(id=id, type=type, cmd=command,
+        overlay = Overlay(id = id, type = type, cmd = command,
         self.overlays.append(overlay)
@@ -1152,7 +1155,7 @@
         return self.overlays[-1]
-    def ChangeOverlay(self, id, render=False, **kargs):
+    def ChangeOverlay(self, id, render = False, **kargs):
         """!Change overlay properities
         Add new overlay if overlay with 'id' doesn't exist.
@@ -1166,7 +1169,7 @@
         @return new layer on success
-        overlay = self.GetOverlay(id, list=False)
+        overlay = self.GetOverlay(id, list = False)
         if  overlay is None:
             overlay = Overlay(id, type = None, cmd = None)
@@ -1191,7 +1194,7 @@
         return overlay
-    def GetOverlay(self, id, list=False):
+    def GetOverlay(self, id, list = False):
         """!Return overlay(s) with 'id'
@@ -1222,7 +1225,7 @@
         @return removed overlay on success or None
-        return self.DeleteLayer(overlay, overlay=True)
+        return self.DeleteLayer(overlay, overlay = True)
     def Clean(self):
         """!Clean layer stack - go trough all layers and remove them
@@ -1270,25 +1273,25 @@
     Usage: display=Render()
     import gettext
-    gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
+    gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
     print "Initializing..."
-    grass.run_command("g.region", flags="d")
+    grass.run_command("g.region", flags = "d")
     map = Map()
     map.width = 640
     map.height = 480
-    map.AddLayer(type="raster",
-                 name="elevation.dem",
+    map.AddLayer(type = "raster",
+                 name = "elevation.dem",
                  command = ["d.rast", "elevation.dem at PERMANENT", "catlist=1000-1500", "-i"],
-                 l_opacity=.7)
+                 l_opacity = .7)
-    map.AddLayer(type="vector",
-                 name="streams",
+    map.AddLayer(type = "vector",
+                 name = "streams",
                  command = ["d.vect", "streams at PERMANENT", "color=red", "width=3", "type=line"])
-    image = map.Render(force=True)
+    image = map.Render(force = True)
     if image:
         os.system("display %s" % image)
